I connected an unpowered USB 3.0 Hub to a Teensy 4.1 host and then connected a Keyboard (that I missed had RGB). This ended up damaging the host port (i'm assuming the voltage regular and/or the current switch) and I'm not getting power from either the 5V or either data lines from the host.
The board is still programmable, so I'm wondering if there is any chance of a work around to get it host USB some other way. I'm guessing no since the MCU won't be interacting with it, but figured I'd ask since it has serial ports.
I have ordered another Teensy 4.1 in the meantime.
To avoid this in the future, can I power the device with a separate 5V line? (not on the Teensy)
Ironically the reason I didn't power the hub is because I heard 5V can damage the teensy.
