Am currently working on a project that requires me to read the Analog Inputs A0, A1, A2 and A3 at a 20kHz update/refresh speed. There is a current transformer connected to two of the inputs A0 and A2 and there will be a potentiometer and another sensor input on A1 and A3. The project isnt exactly noise free but we are doing what we can to suppress noise as much as possible. Also the analog input pins can be shifted to other analog input pins if necessary.
When I try with just one input (A0), it works fine and I get fairly consistent values (Using the ADC library I have set the Conversion Speed to MED_SPEED and Sampling Speed to LOW_SPEED, any faster and the input values vary quite a bit and are not as stable as in this setting. Averaging is set to 4 and Resolution is 10bits). I am using the analogRead(A0) command in an interrupt that triggers at 20kHz to update the variable with the analog input value. The project uses 2 high speed timer interrupts using the IntervalTimer library as well as two Flex timers using the Teensy_PWM library.
I have a potentiometer connected to A1 and when I try reading a second analog input (A1) after reading the first analog input the value of A0 that is read varies quite a lot and is not as steady as before. The only change done is the reading of another Analog Input.
I spoke to a mentor of mine and he mentions for fast analog reading he takes 3 or 5 readings of an analog pin and discards the first reading as it may contain noise from when the analog input pin is switched for reading the ADC value and averages out the remaining 2 or 4 readings and this gives stable results with the microcontrollers he uses (non IMXRT/Teensy microcontrollers)
If someone could help me with the ADC library or write me sample code that I can use to read multiple analog values in a way mentioned above or if there is a better way to get stable readings at the speed required, your help and any code written would be very helpful and much appreciated. I do not have much experience with DMA or with using the ADC library or analog registers other than changing the Conversion Speed, Sampling Speed, Resolution and averaging.
Thanks.
Thanks.
