Teensy 4.1 and Arducam
Hello, I am using a Teensy 4.1 to take pictures and save to an SD card. I am using the Arducam 5MP Plus OV5642 Mini Module Camera Shield SPI Camera Module:
https://www.arducam.com/product/arducam-5mp-plus-spi-cam-arduino-ov5642/
The library I am using is the Arducam Arduino library: https://github.com/ArduCAM/Arduino/
In order to test the camera, I followed the instructions here: https://www.youtube.com/watch?v=hybQpjwJ4aA
As prescribed, after uploading the library to the Arduino libraries folder, I ran the "ArduCAM_Mini_5MP_OV5642_Plus_Functions" sketch with the Arduino IDE v1.8.19, and opened the "ArduCAM_Host_V2" tool (in to view the image coming from the camera. I tested this with the Arduino UNO R3 connected to my PC by USB and it worked, so I know the camera works. The Host tool is supposed to show this, and an image shows up in the other window after I press the 'Capture' button:
The code for ArduCAM_Mini_5MP_OV5642_Plus_Functions is in this GitHub link:
https://github.com/ArduCAM/Arduino/...ns/ArduCAM_Mini_5MP_OV5642_Plus_Functions.ino
With the Teensy, I wire it as follows in the image below. I connect to the Teensy by USB.
Then I tried the same sketch with the Teensy 4.1. I used the Arduino IDE again, using the following settings:
I compile and upload the sketch, and on the terminal I get this message (very long so it is in an attachment) if this is the first time opening Arduino IDE:
View attachment Teensy first message.txt
This is the message if I compile and upload the sketch again:
C:\Users\User\Documents\Arduino\libraries\ArduCAM\examples\mini\ArduCAM_Mini_5MP_OV5642_Plus_Functions\ArduCAM_Mini_5MP_OV5642_Plus_Functions.ino: In function 'void loop()':
C:\Users\User\Documents\Arduino\libraries\ArduCAM\examples\mini\ArduCAM_Mini_5MP_OV5642_Plus_Functions\ArduCAM_Mini_5MP_OV5642_Plus_Functions.ino:763:19: warning: unused variable 'temp_last' [-Wunused-variable]
  763 |     uint8_t temp, temp_last;
teensy_size: Memory Usage on Teensy 4.1:
teensy_size:   FLASH: code:27736, data:12532, headers:8880   free for files:8077316
teensy_size:    RAM1: variables:9120, code:24704, padding:8064   free for local variables:482400
teensy_size:    RAM2: variables:12416  free for malloc/new:511872
Teensy should be selected from "teensy ports" rather
than "Serial ports" in Arduino's Tools > Port menu
Then opening the ArduCAM_Host_V2 tool, I get the following message:
What do I need to change to get this to work? Thank you.
Can you please show your code.
You are supplying the Arduacam with 5V.
The inputs to the T4.1 are NOT 5V tolerant.
This is the GitHub link to the example sketch from the ArduCam library: https://github.com/ArduCAM/Arduino/...ns/ArduCAM_Mini_5MP_OV5642_Plus_Functions.ino
Here is the sketch code if you prefer. Please keep in mind that this is just the example code, and to run it requires the library that the example is inside.
// ArduCAM Mini demo (C)2017 Lee
// Web: http://www.ArduCAM.com
// This program is a demo of how to use most of the functions
// of the library with ArduCAM Mini camera, and can run on any Arduino platform.
// This demo was made for ArduCAM_Mini_5MP_Plus.
// It needs to be used in combination with PC software.
// It can test OV5642 functions.
// This program requires the ArduCAM V4.0.0 (or later) library and ArduCAM_Mini_5MP_Plus
// and use Arduino IDE 1.6.8 compiler or above
#include <ArduCAM.h>
#include "memorysaver.h"
//This demo can only work on OV5642_MINI_5MP_Plus  platform.
//#if !(defined OV5642_MINI_5MP_PLUS)
//  #error Please select the hardware platform and camera module in the ../libraries/ArduCAM/memorysaver.h file
//#endif
#define BMPIMAGEOFFSET 66
const char bmp_header[BMPIMAGEOFFSET] PROGMEM =
  0x42, 0x4D, 0x36, 0x58, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0x28, 0x00,
  0x00, 0x00, 0x40, 0x01, 0x00, 0x00, 0xF0, 0x00, 0x00, 0x00, 0x01, 0x00, 0x10, 0x00, 0x03, 0x00,
  0x00, 0x00, 0x00, 0x58, 0x02, 0x00, 0xC4, 0x0E, 0x00, 0x00, 0xC4, 0x0E, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF8, 0x00, 0x00, 0xE0, 0x07, 0x00, 0x00, 0x1F, 0x00,
  0x00, 0x00
// set pin 7 as the slave select for the digital pot:
const int CS = 7;
bool is_header = false;
int mode = 0;
uint8_t start_capture = 0;
 ArduCAM myCAM( OV5642, CS );
uint8_t read_fifo_burst(ArduCAM myCAM);
uint8_t vid, pid;
uint8_t temp;
#if defined(__SAM3X8E__)
  Wire1.begin();
#else
  Wire.begin();
  Serial.begin(921600);
Serial.println(F("ACK CMD ArduCAM Start! END"));
// set the CS as an output:
pinMode(CS, OUTPUT);
digitalWrite(CS, HIGH);
// initialize SPI:
SPI.begin();
 //Reset the CPLD
myCAM.write_reg(0x07, 0x80);
myCAM.write_reg(0x07, 0x00);
while(1){
  //Check if the ArduCAM SPI bus is OK
  myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
  temp = myCAM.read_reg(ARDUCHIP_TEST1);
  if (temp != 0x55){
    Serial.println(F("ACK CMD SPI interface Error! END"));
    delay(1000);continue;
  }else{
    Serial.println(F("ACK CMD SPI interface OK. END"));break;
  while(1){
    //Check if the camera module type is OV5642
    myCAM.wrSensorReg16_8(0xff, 0x01);
    myCAM.rdSensorReg16_8(OV5642_CHIPID_HIGH, &vid);
    myCAM.rdSensorReg16_8(OV5642_CHIPID_LOW, &pid);
    if((vid != 0x56) || (pid != 0x42)){
      Serial.println(F("ACK CMD Can't find OV5642 module! END"));
    else{
      Serial.println(F("ACK CMD OV5642 detected. END"));break;
//Change to JPEG capture mode and initialize the OV5642 module
myCAM.set_format(JPEG);
myCAM.InitCAM();
  myCAM.write_reg(ARDUCHIP_TIM, VSYNC_LEVEL_MASK);   //VSYNC is active HIGH
  myCAM.OV5642_set_JPEG_size(OV5642_320x240);
myCAM.clear_fifo_flag();
myCAM.write_reg(ARDUCHIP_FRAMES,0x00);
uint8_t temp = 0xff, temp_last = 0;
if (Serial.available())
  temp = Serial.read();
  switch (temp)
    case 0:
      myCAM.OV5642_set_JPEG_size(OV5642_320x240);delay(1000);
      Serial.println(F("ACK CMD switch to OV5642_320x240 END"));
    temp = 0xff;
    case 1:
      myCAM.OV5642_set_JPEG_size(OV5642_640x480);delay(1000);
      Serial.println(F("ACK CMD switch to OV5642_640x480 END"));
    temp = 0xff;
    case 2:
      myCAM.OV5642_set_JPEG_size(OV5642_1024x768);delay(1000);
      Serial.println(F("ACK CMD switch to OV5642_1024x768 END"));
    temp = 0xff;
    case 3:
    temp = 0xff;
      myCAM.OV5642_set_JPEG_size(OV5642_1280x960);delay(1000);
      Serial.println(F("ACK CMD switch to OV5642_1280x960 END"));
    case 4:
    temp = 0xff;
      myCAM.OV5642_set_JPEG_size(OV5642_1600x1200);delay(1000);
      Serial.println(F("ACK CMD switch to OV5642_1600x1200 END"));
    case 5:
    temp = 0xff;
      myCAM.OV5642_set_JPEG_size(OV5642_2048x1536);delay(1000);
      Serial.println(F("ACK CMD switch to OV5642_2048x1536 END"));
    case 6:
    temp = 0xff;
      myCAM.OV5642_set_JPEG_size(OV5642_2592x1944);delay(1000);
      Serial.println(F("ACK CMD switch to OV5642_2592x1944 END"));
    case 0x10:
    mode = 1;
    temp = 0xff;
    start_capture = 1;
    Serial.println(F("ACK CMD CAM start single shoot. END"));
    case 0x11:
    temp = 0xff;
    myCAM.InitCAM();
    #if !(defined (OV2640_MINI_2MP))
    myCAM.set_bit(ARDUCHIP_TIM, VSYNC_LEVEL_MASK);
    case 0x20:
    mode = 2;
    temp = 0xff;
    start_capture = 2;
    Serial.println(F("ACK CMD CAM start video streaming. END"));
    case 0x30:
    mode = 3;
    temp = 0xff;
    start_capture = 3;
    case 0x31:
    temp = 0xff;
    myCAM.set_format(BMP);
    myCAM.InitCAM();
    myCAM.clear_bit(ARDUCHIP_TIM, VSYNC_LEVEL_MASK);
    myCAM.wrSensorReg16_8(0x3818, 0x81);
    myCAM.wrSensorReg16_8(0x3621, 0xA7);
    case 0x40:
    myCAM.OV5642_set_Light_Mode(Advanced_AWB);temp = 0xff;
     Serial.println(F("ACK CMD Set to Advanced_AWB END"));break;
    case 0x41:
    myCAM.OV5642_set_Light_Mode(Simple_AWB);temp = 0xff;
     Serial.println(F("ACK CMD Set to Simple_AWB END"));break;
     case 0x42:
    myCAM.OV5642_set_Light_Mode(Manual_day);temp = 0xff;
     Serial.println(F("ACK CMD Set to Manual_day END"));break;
     case 0x43:
    myCAM.OV5642_set_Light_Mode(Manual_A);temp = 0xff;
     Serial.println(F("ACK CMD Set to Manual_A END"));break;
     case 0x44:
    myCAM.OV5642_set_Light_Mode(Manual_cwf);temp = 0xff;
     Serial.println(F("ACK CMD Set to Manual_cwf END"));break;
     case 0x45:
    myCAM.OV5642_set_Light_Mode(Manual_cloudy);temp = 0xff;
     Serial.println(F("ACK CMD Set to Manual_cloudy END"));break;
      case 0x50:
    myCAM.OV5642_set_Color_Saturation(Saturation4);temp = 0xff;
     Serial.println(F("ACK CMD Set to Saturation+4 END"));break;
   case 0x51:
      myCAM.OV5642_set_Color_Saturation(Saturation3);temp = 0xff;
     Serial.println(F("ACK CMD Set to Saturation+3 END"));break;
   case 0x52:
    myCAM.OV5642_set_Color_Saturation(Saturation2);temp = 0xff;
   Serial.println(F("ACK CMD Set to Saturation+2 END"));break;
  case 0x53:
    myCAM.OV5642_set_Color_Saturation(Saturation1);temp = 0xff;
   Serial.println(F("ACK CMD Set to Saturation+1 END"));break;
   case 0x54:
    myCAM.OV5642_set_Color_Saturation(Saturation0);temp = 0xff;
   Serial.println(F("ACK CMD Set to Saturation+0 END"));break;
   case 0x55:
    myCAM.OV5642_set_Color_Saturation(Saturation_1);temp = 0xff;
   Serial.println(F("ACK CMD Set to Saturation-1 END"));break;
   case 0x56:
    myCAM.OV5642_set_Color_Saturation(Saturation_2);temp = 0xff;
   Serial.println(F("ACK CMD Set to Saturation-2"));break;
    case 0x57:
    myCAM.OV5642_set_Color_Saturation(Saturation_3);temp = 0xff;
   Serial.println(F("ACK CMD Set to Saturation-3 END"));break;
   case 0x58:
  myCAM.OV5642_set_Light_Mode(Saturation_4);temp = 0xff;
   Serial.println(F("ACK CMD Set to Saturation-4 END"));break;
   case 0x60:
  myCAM.OV5642_set_Brightness(Brightness4);temp = 0xff;
   Serial.println(F("ACK CMD Set to Brightness+4 END"));break;
  case 0x61:
  myCAM.OV5642_set_Brightness(Brightness3);temp = 0xff;
   Serial.println(F("ACK CMD Set to Brightness+3 END"));break;
  case 0x62:
  myCAM.OV5642_set_Brightness(Brightness2);temp = 0xff;
   Serial.println(F("ACK CMD Set to Brightness+2 END"));break;
   case 0x63:
  myCAM.OV5642_set_Brightness(Brightness1);temp = 0xff;
   Serial.println(F("ACK CMD Set to Brightness+1 END"));break;
   case 0x64:
  myCAM.OV5642_set_Brightness(Brightness0);temp = 0xff;
   Serial.println(F("ACK CMD Set to Brightness+0 END"));break;
    case 0x65:
  myCAM.OV5642_set_Brightness(Brightness_1);temp = 0xff;
   Serial.println(F("ACK CMD Set to Brightness-1 END"));break;
     case 0x66:
  myCAM.OV5642_set_Brightness(Brightness_2);temp = 0xff;
   Serial.println(F("ACK CMD Set to Brightness-2 END"));break;
    case 0x67:
  myCAM.OV5642_set_Brightness(Brightness_3);temp = 0xff;
   Serial.println(F("ACK CMD Set to Brightness-3 END"));break;
    case 0x68:
  myCAM.OV5642_set_Brightness(Brightness_4);temp = 0xff;
   Serial.println(F("ACK CMD Set to Brightness-4 END"));break;
case 0x70:
  myCAM.OV5642_set_Contrast(Contrast4);temp = 0xff;
   Serial.println(F("ACK CMD Set to Contrast+4 END"));break;
  case 0x71:
  myCAM.OV5642_set_Contrast(Contrast3);temp = 0xff;
   Serial.println(F("ACK CMD Set to Contrast+3 END"));break;
  case 0x72:
  myCAM.OV5642_set_Contrast(Contrast2);temp = 0xff;
   Serial.println(F("ACK CMD Set to Contrast+2 END"));break;
   case 0x73:
  myCAM.OV5642_set_Contrast(Contrast1);temp = 0xff;
   Serial.println(F("ACK CMD Set to Contrast+1 END"));break;
   case 0x74:
  myCAM.OV5642_set_Contrast(Contrast0);temp = 0xff;
   Serial.println(F("ACK CMD Set to Contrast+0 END"));break;
    case 0x75:
  myCAM.OV5642_set_Contrast(Contrast_1);temp = 0xff;
   Serial.println(F("ACK CMD Set to Contrast-1 END"));break;
     case 0x76:
  myCAM.OV5642_set_Contrast(Contrast_2);temp = 0xff;
   Serial.println(F("ACK CMD Set to Contrast-2 END"));break;
    case 0x77:
  myCAM.OV5642_set_Contrast(Contrast_3);temp = 0xff;
   Serial.println(F("ACK CMD Set to Contrast-3 END"));break;
    case 0x78:
  myCAM.OV5642_set_Contrast(Contrast_4);temp = 0xff;
   Serial.println(F("ACK CMD Set to Contrast-4 END"));break;
   case 0x80:
    myCAM.OV5642_set_hue(degree_180);temp = 0xff;
     Serial.println(F("ACK CMD Set to -180 degree END"));break;
   case 0x81:
   myCAM.OV5642_set_hue(degree_150);temp = 0xff;
     Serial.println(F("ACK CMD Set to -150 degree END"));break;
   case 0x82:
   myCAM.OV5642_set_hue(degree_120);temp = 0xff;
     Serial.println(F("ACK CMD Set to -120 degree END"));break;
   case 0x83:
   myCAM.OV5642_set_hue(degree_90);temp = 0xff;
     Serial.println(F("ACK CMD Set to -90 degree END"));break;
    case 0x84:
   myCAM.OV5642_set_hue(degree_60);temp = 0xff;
     Serial.println(F("ACK CMD Set to -60 degree END"));break;
    case 0x85:
   myCAM.OV5642_set_hue(degree_30);temp = 0xff;
     Serial.println(F("ACK CMD Set to -30 degree END"));break;
     case 0x86:
   myCAM.OV5642_set_hue(degree_0);temp = 0xff;
     Serial.println(F("ACK CMD Set to 0 degree END"));break;
   case 0x87:
   myCAM.OV5642_set_hue(degree30);temp = 0xff;
     Serial.println(F("ACK CMD Set to 30 degree END"));break;
   case 0x88:
   myCAM.OV5642_set_hue(degree60);temp = 0xff;
     Serial.println(F("ACK CMD Set to 60 degree END"));break;
    case 0x89:
   myCAM.OV5642_set_hue(degree90);temp = 0xff;
     Serial.println(F("ACK CMD Set to 90 degree END"));break;
     case 0x8a:
   myCAM.OV5642_set_hue(degree120);temp = 0xff;
     Serial.println(F("ACK CMD Set to 120 degree END"));break ;
   case 0x8b:
   myCAM.OV5642_set_hue(degree150);temp = 0xff;
     Serial.println(F("ACK CMD Set to 150 degree END"));break ;
   case 0x90:
   myCAM.OV5642_set_Special_effects(Normal);temp = 0xff;
     Serial.println(F("ACK CMD Set to Normal END"));break ;
      case 0x91:
   myCAM.OV5642_set_Special_effects(BW);temp = 0xff;
     Serial.println(F("ACK CMD Set to BW END"));break ;
    case 0x92:
   myCAM.OV5642_set_Special_effects(Bluish);temp = 0xff;
     Serial.println(F("ACK CMD Set to Bluish END"));break ;
      case 0x93:
   myCAM.OV5642_set_Special_effects(Sepia);temp = 0xff;
     Serial.println(F("ACK CMD Set to Sepia END"));break ;
    case 0x94:
   myCAM.OV5642_set_Special_effects(Reddish);temp = 0xff;
     Serial.println(F("ACK CMD Set to Reddish END"));break ;
   case 0x95:
   myCAM.OV5642_set_Special_effects(Greenish);temp = 0xff;
     Serial.println(F("ACK CMD Set to Greenish END"));break ;
   case 0x96:
   myCAM.OV5642_set_Special_effects(Negative);temp = 0xff;
     Serial.println(F("ACK CMD Set to Negative END"));break ;
   case 0xA0:
   myCAM.OV5642_set_Exposure_level(Exposure_17_EV);temp = 0xff;
     Serial.println(F("ACK CMD Set to -1.7EV"));break ;
     case 0xA1:
   myCAM.OV5642_set_Exposure_level(Exposure_13_EV);temp = 0xff;
     Serial.println(F("ACK CMD Set to -1.3EV END"));break ;
      case 0xA2:
   myCAM.OV5642_set_Exposure_level(Exposure_10_EV);temp = 0xff;
     Serial.println(F("ACK CMD Set to -1.0EV END"));break ;
    case 0xA3:
   myCAM.OV5642_set_Exposure_level(Exposure_07_EV);temp = 0xff;
     Serial.println(F("ACK CMD Set to -0.7EV END"));break ;
     case 0xA4:
   myCAM.OV5642_set_Exposure_level(Exposure_03_EV);temp = 0xff;
     Serial.println(F("ACK CMD Set to -0.3EV END"));break ;
   case 0xA5:
   myCAM.OV5642_set_Exposure_level(Exposure_default);temp = 0xff;
     Serial.println(F("ACK CMD Set to -Exposure_default END"));break ;
    case 0xA6:
   myCAM.OV5642_set_Exposure_level(Exposure07_EV);temp = 0xff;
     Serial.println(F("ACK CMD Set to 0.7EV END"));break ;
   case 0xA7:
   myCAM.OV5642_set_Exposure_level(Exposure10_EV);temp = 0xff;
     Serial.println(F("ACK CMD Set to 1.0EV END"));break ;
    case 0xA8:
   myCAM.OV5642_set_Exposure_level(Exposure13_EV);temp = 0xff;
     Serial.println(F("ACK CMD Set to 1.3EV END"));break ;
    case 0xA9:
   myCAM.OV5642_set_Exposure_level(Exposure17_EV);temp = 0xff;
     Serial.println(F("ACK CMD Set to 1.7EV END"));break ;
   case 0xB0:
   myCAM.OV5642_set_Sharpness(Auto_Sharpness_default);temp = 0xff;
     Serial.println(F("ACK CMD Set to Auto Sharpness default END"));break ;
    case 0xB1:
   myCAM.OV5642_set_Sharpness(Auto_Sharpness1);temp = 0xff;
     Serial.println(F("ACK CMD Set to Auto Sharpness +1 END"));break ;
    case 0xB2:
   myCAM.OV5642_set_Sharpness(Auto_Sharpness2);temp = 0xff;
     Serial.println(F("ACK CMD Set to Auto Sharpness +2 END"));break ;
      case 0xB3:
   myCAM.OV5642_set_Sharpness(Manual_Sharpnessoff);temp = 0xff;
     Serial.println(F("ACK CMD Set to Auto Manual Sharpness off END"));break ;
     case 0xB4:
     myCAM.OV5642_set_Sharpness(Manual_Sharpness1);temp = 0xff;
     Serial.println(F("ACK CMD Set to Auto Manual Sharpness +1 END"));break ;
     case 0xB5:
     myCAM.OV5642_set_Sharpness(Manual_Sharpness2);temp = 0xff;
     Serial.println(F("ACK CMD Set to Auto Manual Sharpness +2 END"));break ;
     case 0xB6:
     myCAM.OV5642_set_Sharpness(Manual_Sharpness3);temp = 0xff;
     Serial.println(F("ACK CMD Set to Auto Manual Sharpness +3 END"));break ;
     case 0xB7:
     myCAM.OV5642_set_Sharpness(Manual_Sharpness4);temp = 0xff;
     Serial.println(F("ACK CMD Set to Auto Manual Sharpness +4 END"));break ;
    case 0xB8:
     myCAM.OV5642_set_Sharpness(Manual_Sharpness5);temp = 0xff;
     Serial.println(F("ACK CMD Set to Auto Manual Sharpness +5 END"));break ;
    case 0xC0:
     myCAM.OV5642_set_Mirror_Flip(MIRROR);temp = 0xff;
     Serial.println(F("ACK CMD Set to MIRROR END"));break ;
    case 0xC1:
     myCAM.OV5642_set_Mirror_Flip(FLIP);temp = 0xff;
     Serial.println(F("ACK CMD Set to FLIP END"));break ;
    case 0xC2:
     myCAM.OV5642_set_Mirror_Flip(MIRROR_FLIP);temp = 0xff;
     Serial.println(F("ACK CMD Set to MIRROR&FLIP END"));break ;
    case 0xC3:
     myCAM.OV5642_set_Mirror_Flip(Normal);temp = 0xff;
     case 0xD0:
     myCAM.OV5642_set_Compress_quality(high_quality);temp = 0xff;
     Serial.println(F("ACK CMD Set to high quality END"));break ;
      case 0xD1:
     myCAM.OV5642_set_Compress_quality(default_quality);temp = 0xff;
     Serial.println(F("ACK CMD Set to default quality END"));break ;
      case 0xD2:
     myCAM.OV5642_set_Compress_quality(low_quality);temp = 0xff;
     Serial.println(F("ACK CMD Set to low quality END"));break ;
      case 0xE0:
     myCAM.OV5642_Test_Pattern(Color_bar);temp = 0xff;
     Serial.println(F("ACK CMD Set to Color bar END"));break ;
      case 0xE1:
     myCAM.OV5642_Test_Pattern(Color_square);temp = 0xff;
     Serial.println(F("ACK CMD Set to Color square END"));break ;
      case 0xE2:
     myCAM.OV5642_Test_Pattern(BW_square);temp = 0xff;
     Serial.println(F("ACK CMD Set to BW square END"));break ;
     case 0xE3:
     myCAM.OV5642_Test_Pattern(DLI);temp = 0xff;
     Serial.println(F("ACK CMD Set to DLI END"));break ;
      default:
if (mode == 1)
  if (start_capture == 1)
    myCAM.flush_fifo();
    //Start capture
    myCAM.start_capture();
    start_capture = 0;
  if (myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK))
    Serial.println(F("ACK CMD CAM Capture Done. END"));delay(50);
    read_fifo_burst(myCAM);
    //Clear the capture done flag
else if (mode == 2)
  while (1)
    if (temp == 0x21)
      start_capture = 0;
      mode = 0;
      Serial.println(F("ACK CMD CAM stop video streaming. END"));
    switch(temp){
       case 0x40:
    case 0x41:
     case 0x42:
     case 0x43:
     case 0x44:
     case 0x45:
      case 0x50:
   case 0x51:
   case 0x52:
  case 0x53:
   case 0x54:
   case 0x55:
   case 0x56:
   Serial.println(F("ACK CMD Set to Saturation-2 END"));break;
    case 0x57:
   case 0x58:
   case 0x60:
  case 0x61:
  case 0x62:
   case 0x63:
   case 0x64:
    case 0x65:
     case 0x66:
    case 0x67:
    case 0x68:
case 0x70:
  case 0x71:
  case 0x72:
   case 0x73:
   case 0x74:
    case 0x75:
     case 0x76:
    case 0x77:
    case 0x78:
   case 0x80:
   case 0x81:
   case 0x82:
   case 0x83:
    case 0x84:
    case 0x85:
     case 0x86:
   case 0x87:
   case 0x88:
    case 0x89:
     case 0x8a:
   case 0x8b:
  case 0x90:
      case 0x91:
    case 0x92:
      case 0x93:
    case 0x94:
   case 0x95:
   case 0x96:
   case 0xA0:
     Serial.println(F("ACK CMD Set to -1.7EV END"));break ;
     case 0xA1:
      case 0xA2:
    case 0xA3:
     case 0xA4:
   case 0xA5:
    case 0xA6:
   case 0xA7:
    case 0xA8:
    case 0xA9:
   case 0xB0:
    case 0xB1:
    case 0xB2:
      case 0xB3:
     case 0xB4:
     case 0xB5:
     case 0xB6:
     case 0xB7:
    case 0xB8:
    case 0xC0:
    case 0xC1:
    case 0xC2:
    case 0xC3:
     case 0xD0:
      case 0xD1:
      case 0xD2:
      case 0xE0:
      case 0xE1:
      case 0xE2:
     case 0xE3:
    if (start_capture == 2)
      myCAM.flush_fifo();
      //Start capture
      start_capture = 0;
      uint32_t length = 0;
      length = myCAM.read_fifo_length();
      if ((length >= MAX_FIFO_SIZE) | (length == 0))
        start_capture = 2;
        continue;
      myCAM.CS_LOW();
      myCAM.set_fifo_burst();//Set fifo burst mode
      temp =  SPI.transfer(0x00);
      length --;
      while ( length-- )
        temp_last = temp;
        if (is_header == true)
          Serial.write(temp);
        else if ((temp == 0xD8) & (temp_last == 0xFF))
          is_header = true;
          Serial.println(F("ACK IMG END"));
          Serial.write(temp_last);
          Serial.write(temp);
        if ( (temp == 0xD9) && (temp_last == 0xFF) ) //If find the end ,break while,
        delayMicroseconds(4);
      myCAM.CS_HIGH();
      start_capture = 2;
      is_header = false;
else if (mode == 3)
  if (start_capture == 3)
    //Flush the FIFO
    myCAM.flush_fifo();
    //Start capture
    start_capture = 0;
    if (length >= MAX_FIFO_SIZE )
      Serial.println(F("ACK CMD Over size. END"));
      return;
    if (length == 0 ) //0 kb
      Serial.println(F("ACK CMD Size is 0. END"));
      return;
    myCAM.CS_LOW();
    Serial.write(0xFF);
    Serial.write(0xAA);
    for (temp = 0; temp < BMPIMAGEOFFSET; temp++)
      Serial.write(pgm_read_byte(&bmp_header[temp]));
    //SPI.transfer(0x00);
    char VH, VL;
    int i = 0, j = 0;
    for (i = 0; i < 240; i++)
      for (j = 0; j < 320; j++)
        VH = SPI.transfer(0x00);;
        VL = SPI.transfer(0x00);;
        Serial.write(VL);
        delayMicroseconds(12);
        Serial.write(VH);
    Serial.write(0xBB);
    Serial.write(0xCC);
    myCAM.CS_HIGH();
  uint8_t temp = 0, temp_last = 0;
  Serial.println(length, DEC);
  if (length >= MAX_FIFO_SIZE) //512 kb
    return 0;
    return 0;
  myCAM.CS_LOW();
  length --;
  while ( length-- )
    temp_last = temp;
      Serial.write(temp);
      is_header = true;
      Serial.write(temp);
    delayMicroseconds(15);
  myCAM.CS_HIGH();
  is_header = false;
  return 1;
Its been a while since I played with Arducam but I remember I had it working with a T4.0. With that said I did have to modify the library a bit to get it working by adding a delaymicroseconds on CBI and SBI. If you want to give it a try this is the version that I had working (seems like an eternity ago). Let us know if it works;
https://github.com/mjs513/ArduCAM_t4
EDIT: link to original post: https://forum.pjrc.com/threads/54711-Teensy-4-0-First-Beta-Test?p=212356&viewfull=1#post212356
Hello, thank you very much for writing this library. First I changed memorysaver.h to be configured to the 5MP OV5642 Plus Module, and the power voltage to 3.3V. In "ArduCAM_Mini_2MP_Plus_functions" I also commented out the
#if !(defined OV2640_MINI_2MP_PLUS)
Then I tried the library without changing the wiring, but ran into the same issue of "SPI Interface Error." I then changed to an SPI bus that was previously unused (i.e. not fried by 5V), and it seems that I made progress, with a different error message.
Now I run into the issue where I get a message saying "Can't find OV5642 module!"
It seems that the vid and pid values are not read correctly by the Teensy (refer to line 94) and it doesn't recognize them. How would I fix this?
Modified code here:
// This demo was made for ArduCAM_Mini_2MP_Plus.
// It can test OV2640 functions
// This program requires the ArduCAM V4.0.0 (or later) library and ArduCAM_Mini_2MP_Plus
//This demo can only work on OV2640_MINI_2MP_PLUS platform.
//#if !(defined OV2640_MINI_2MP_PLUS)
//#endif
  0x00, 0x00
// set pin 10 as the slave select for the digital pot:
const int CS = 10;
int mode = 0;
#if defined (OV2640_MINI_2MP_PLUS)
  ArduCAM myCAM( OV2640, CS );
#else
uint8_t vid, pid;
uint8_t temp;
  Wire1.begin();
#else
  Wire.begin();
// initialize SPI:
SPI.begin();
SPI.beginTransaction(SPISettings(8000000, MSBFIRST, SPI_MODE0));
  //Reset the CPLD
while(1){
  if (temp != 0x55){
  }else{
  while(1){
    //Check if the camera module type is OV2640
    myCAM.wrSensorReg8_8(0xff, 0x01);
    myCAM.rdSensorReg8_8(OV2640_CHIPID_HIGH, &vid);
    myCAM.rdSensorReg8_8(OV2640_CHIPID_LOW, &pid);
    if ((vid != 0x26 ) && (( pid != 0x41 ) || ( pid != 0x42 ))){
      Serial.println(F("ACK CMD Can't find OV2640 module! END"));
    else{
      Serial.println(F("ACK CMD OV2640 detected. END"));break;
#else
  while(1){
    else{
myCAM.InitCAM();
  myCAM.OV2640_set_JPEG_size(OV2640_320x240);
#else
#if !(defined (OV2640_MINI_2MP_PLUS))
  switch (temp)
    case 0:
      myCAM.OV2640_set_JPEG_size(OV2640_160x120);delay(1000);
      Serial.println(F("ACK CMD switch to OV2640_160x120 END"));
     temp = 0xff;
    case 1:
      myCAM.OV2640_set_JPEG_size(OV2640_176x144);delay(1000);
      Serial.println(F("ACK CMD switch to OV2640_176x144 END"));
    temp = 0xff;
    case 2:
      myCAM.OV2640_set_JPEG_size(OV2640_320x240);delay(1000);
      Serial.println(F("ACK CMD switch to OV2640_320x240 END"));
    temp = 0xff;
    case 3:
    myCAM.OV2640_set_JPEG_size(OV2640_352x288);delay(1000);
    Serial.println(F("ACK CMD switch to OV2640_352x288 END"));
   temp = 0xff;
    case 4:
      myCAM.OV2640_set_JPEG_size(OV2640_640x480);delay(1000);
      Serial.println(F("ACK CMD switch to OV2640_640x480 END"));
    temp = 0xff;
    case 5:
    myCAM.OV2640_set_JPEG_size(OV2640_800x600);delay(1000);
    Serial.println(F("ACK CMD switch to OV2640_800x600 END"));
    temp = 0xff;
    case 6:
     myCAM.OV2640_set_JPEG_size(OV2640_1024x768);delay(1000);
     Serial.println(F("ACK CMD switch to OV2640_1024x768 END"));
    temp = 0xff;
    case 7:
    myCAM.OV2640_set_JPEG_size(OV2640_1280x1024);delay(1000);
    Serial.println(F("ACK CMD switch to OV2640_1280x1024 END"));
    temp = 0xff;
    case 8:
    myCAM.OV2640_set_JPEG_size(OV2640_1600x1200);delay(1000);
    Serial.println(F("ACK CMD switch to OV2640_1600x1200 END"));
     temp = 0xff;
    case 0x10:
    mode = 1;
    temp = 0xff;
    start_capture = 1;
    case 0x11:
    temp = 0xff;
    myCAM.InitCAM();
    case 0x20:
    mode = 2;
    temp = 0xff;
    start_capture = 2;
    case 0x30:
    mode = 3;
    temp = 0xff;
    start_capture = 3;
    case 0x31:
    temp = 0xff;
    myCAM.InitCAM();
    case 0x40:
    myCAM.OV2640_set_Light_Mode(Auto);temp = 0xff;
    Serial.println(F("ACK CMD Set to Auto END"));break;
     case 0x41:
    myCAM.OV2640_set_Light_Mode(Sunny);temp = 0xff;
    Serial.println(F("ACK CMD Set to Sunny END"));break;
     case 0x42:
    myCAM.OV2640_set_Light_Mode(Cloudy);temp = 0xff;
    Serial.println(F("ACK CMD Set to Cloudy END"));break;
     case 0x43:
    myCAM.OV2640_set_Light_Mode(Office);temp = 0xff;
    Serial.println(F("ACK CMD Set to Office END"));break;
   case 0x44:
    myCAM.OV2640_set_Light_Mode(Home);   temp = 0xff;
   Serial.println(F("ACK CMD Set to Home END"));break;
   case 0x50:
    myCAM.OV2640_set_Color_Saturation(Saturation2); temp = 0xff;
   case 0x51:
     myCAM.OV2640_set_Color_Saturation(Saturation1); temp = 0xff;
   case 0x52:
    myCAM.OV2640_set_Color_Saturation(Saturation0); temp = 0xff;
    case 0x53:
    myCAM. OV2640_set_Color_Saturation(Saturation_1); temp = 0xff;
    case 0x54:
     myCAM.OV2640_set_Color_Saturation(Saturation_2); temp = 0xff;
   case 0x60:
    myCAM.OV2640_set_Brightness(Brightness2); temp = 0xff;
   case 0x61:
     myCAM.OV2640_set_Brightness(Brightness1); temp = 0xff;
   case 0x62:
    myCAM.OV2640_set_Brightness(Brightness0); temp = 0xff;
    case 0x63:
    myCAM. OV2640_set_Brightness(Brightness_1); temp = 0xff;
    case 0x64:
     myCAM.OV2640_set_Brightness(Brightness_2); temp = 0xff;
    case 0x70:
      myCAM.OV2640_set_Contrast(Contrast2);temp = 0xff;
    case 0x71:
      myCAM.OV2640_set_Contrast(Contrast1);temp = 0xff;
     case 0x72:
      myCAM.OV2640_set_Contrast(Contrast0);temp = 0xff;
    case 0x73:
      myCAM.OV2640_set_Contrast(Contrast_1);temp = 0xff;
   case 0x74:
      myCAM.OV2640_set_Contrast(Contrast_2);temp = 0xff;
   case 0x80:
    myCAM.OV2640_set_Special_effects(Antique);temp = 0xff;
    Serial.println(F("ACK CMD Set to Antique END"));break;
   case 0x81:
    myCAM.OV2640_set_Special_effects(Bluish);temp = 0xff;
    Serial.println(F("ACK CMD Set to Bluish END"));break;
   case 0x82:
    myCAM.OV2640_set_Special_effects(Greenish);temp = 0xff;
    Serial.println(F("ACK CMD Set to Greenish END"));break;
   case 0x83:
    myCAM.OV2640_set_Special_effects(Reddish);temp = 0xff;
    Serial.println(F("ACK CMD Set to Reddish END"));break;
   case 0x84:
    myCAM.OV2640_set_Special_effects(BW);temp = 0xff;
    Serial.println(F("ACK CMD Set to BW END"));break;
  case 0x85:
    myCAM.OV2640_set_Special_effects(Negative);temp = 0xff;
    Serial.println(F("ACK CMD Set to Negative END"));break;
  case 0x86:
    myCAM.OV2640_set_Special_effects(BWnegative);temp = 0xff;
    Serial.println(F("ACK CMD Set to BWnegative END"));break;
   case 0x87:
    myCAM.OV2640_set_Special_effects(Normal);temp = 0xff;
    Serial.println(F("ACK CMD Set to Normal END"));break;
if (mode == 1)
    myCAM.flush_fifo();
    //Start capture
    start_capture = 0;
else if (mode == 2)
  while (1)
    if (temp == 0x21)
      start_capture = 0;
      mode = 0;
    switch (temp)
       case 0x40:
     case 0x41:
     case 0x42:
     case 0x43:
   case 0x44:
   case 0x50:
   case 0x51:
   case 0x52:
    case 0x53:
    case 0x54:
   case 0x60:
   case 0x61:
   case 0x62:
    case 0x63:
    case 0x64:
    case 0x70:
    case 0x71:
     case 0x72:
    case 0x73:
   case 0x74:
   case 0x80:
   case 0x81:
   case 0x82:
   case 0x83:
   case 0x84:
  case 0x85:
  case 0x86:
   case 0x87:
      myCAM.flush_fifo();
      //Start capture
      start_capture = 0;
        start_capture = 2;
        continue;
      myCAM.CS_LOW();
      length --;
      while ( length-- )
        temp_last = temp;
          Serial.write(temp);
          is_header = true;
          Serial.write(temp);
      myCAM.CS_HIGH();
      start_capture = 2;
      is_header = false;
else if (mode == 3)
    //Flush the FIFO
    myCAM.flush_fifo();
    //Start capture
    start_capture = 0;
      return;
      return;
    myCAM.CS_LOW();
    Serial.write(0xFF);
    Serial.write(0xAA);
    char VH, VL;
    int i = 0, j = 0;
        Serial.write(VL);
        Serial.write(VH);
    Serial.write(0xBB);
    Serial.write(0xCC);
    myCAM.CS_HIGH();
    return 0;
    return 0;
  myCAM.CS_LOW();
  length --;
  while ( length-- )
    temp_last = temp;
      Serial.write(temp);
      is_header = true;
      Serial.write(temp);
  myCAM.CS_HIGH();
  is_header = false;
  return 1;
Will see if I can help since I don't think I have that particular camera. Looking at the example it looks like it not getting a different value than expected for the 5642.
Its expecting vid and pid equal to the defined the defined values. Looking again I see in the sketch that the selected wire bus is defined by:
  Wire1.begin();
#else
  Wire.begin();
so for the Teensy 4.1 its using Wire not Wire1 where you show that you have the camera connected to. Suggest that you change those lines to just
  Wire1.begin();
Yes this is what I meant.
Hmmm, I tried the edited code, but I still run into the same problem of "Can't find OV5642 module!" I did both Wire.begin() and Wire1.begin(), and changed the Serial baud rate between 115200 and 921600.
Ok looks like you are going to have to edit ArduCAM.cpp - made me look a bit deeper. At about line 115 in the file you will see this:
	#define Wire Wire1
The library defaults to Wire for anything other than the SAM3X8E boards.  Replace those three lines with just
#define Wire Wire1
and see if that works.
When I get some more time I will try and make it generic so you can put any Wire port in.
I just pushed an update to the library (not tested yet) that allows you to select Wire and SPI ports. The constructor has been changed to:
ArduCAM(byte model ,int CS, TwoWire *i2c = &Wire, SPIClass *spi = &SPI);
Default values are Wire and SPI ports so any of the following will be valid:
ArduCAM myCAM( OV5642, CS, Wire, SPI );
ArduCAM myCAM( OV5642, CS, &Wire1, &SPI );
In your case would be now using
Will be testing today as well
EDIT: ran your configuration but using a OV2640 and worked with the updated library.
Thank you for putting the effort into updating and testing the library. Unfortunately, it still doesn't work. Any message relating to the SPI interface and detecting the OV5642 do not show up, so for some reason it seems to keep skipping the block of code checking whether SPI is good to go.
while(1){
  if (temp != 0x55){
  }else{
For reference for newcomers to this thread, this is what should show up when the camera works (with an Arduino):
//#endif
  0x00, 0x00
// set pin 10 as the peripheral select for the digital pot:
const int CS = 10;
int mode = 0;
  ArduCAM myCAM( OV2640, CS, &Wire1 );
#else
  ArduCAM myCAM( OV2640, CS, &Wire1, &SPI );
#else
  ArduCAM myCAM( OV5642, CS, &Wire1);
#else
  ArduCAM myCAM( OV5642, CS, &Wire, &SPI );  //or just ArduCAM myCAM( OV5642, CS);
uint8_t vid, pid;
uint8_t temp;
#else
//Reset the CPLD
while(1){
  if (temp != 0x55){
  }else{
  while(1){
    else{
#else
  while(1){
    else{
myCAM.InitCAM();
#else
  switch (temp)
    case 0:
     temp = 0xff;
    case 1:
    temp = 0xff;
    case 2:
    temp = 0xff;
    case 3:
   temp = 0xff;
    case 4:
    temp = 0xff;
    case 5:
    temp = 0xff;
    case 6:
    temp = 0xff;
    case 7:
    temp = 0xff;
    case 8:
     temp = 0xff;
    case 0x10:
    mode = 1;
    temp = 0xff;
    start_capture = 1;
    case 0x11:
    temp = 0xff;
    myCAM.InitCAM();
    case 0x20:
    mode = 2;
    temp = 0xff;
    start_capture = 2;
    case 0x30:
    mode = 3;
    temp = 0xff;
    start_capture = 3;
    case 0x31:
    temp = 0xff;
    myCAM.InitCAM();
    case 0x40:
     case 0x41:
     case 0x42:
     case 0x43:
   case 0x44:
   case 0x50:
   case 0x51:
   case 0x52:
    case 0x53:
    case 0x54:
   case 0x60:
   case 0x61:
   case 0x62:
    case 0x63:
    case 0x64:
    case 0x70:
    case 0x71:
     case 0x72:
    case 0x73:
   case 0x74:
   case 0x80:
   case 0x81:
   case 0x82:
   case 0x83:
   case 0x84:
  case 0x85:
  case 0x86:
   case 0x87:
if (mode == 1)
    myCAM.flush_fifo();
    //Start capture
    start_capture = 0;
else if (mode == 2)
  while (1)
    if (temp == 0x21)
      start_capture = 0;
      mode = 0;
    switch (temp)
       case 0x40:
     case 0x41:
     case 0x42:
     case 0x43:
   case 0x44:
   case 0x50:
   case 0x51:
   case 0x52:
    case 0x53:
    case 0x54:
   case 0x60:
   case 0x61:
   case 0x62:
    case 0x63:
    case 0x64:
    case 0x70:
    case 0x71:
     case 0x72:
    case 0x73:
   case 0x74:
   case 0x80:
   case 0x81:
   case 0x82:
   case 0x83:
   case 0x84:
  case 0x85:
  case 0x86:
   case 0x87:
      myCAM.flush_fifo();
      //Start capture
      start_capture = 0;
        start_capture = 2;
        continue;
      myCAM.CS_LOW();
      length --;
      while ( length-- )
        temp_last = temp;
          Serial.write(temp);
          is_header = true;
          Serial.write(temp);
      myCAM.CS_HIGH();
      start_capture = 2;
      is_header = false;
else if (mode == 3)
    //Flush the FIFO
    myCAM.flush_fifo();
    //Start capture
    start_capture = 0;
      return;
      return;
    myCAM.CS_LOW();
    Serial.write(0xFF);
    Serial.write(0xAA);
    char VH, VL;
    int i = 0, j = 0;
        Serial.write(VL);
        Serial.write(VH);
    Serial.write(0xBB);
    Serial.write(0xCC);
    myCAM.CS_HIGH();
    return 0;
    return 0;
  myCAM.CS_LOW();
  length --;
  while ( length-- )
    temp_last = temp;
      Serial.write(temp);
      is_header = true;
      Serial.write(temp);
  myCAM.CS_HIGH();
  is_header = false;
  return 1;
#else
#else
#else
  [COLOR="#FF0000"]ArduCAM myCAM( OV5642, CS, &Wire, &SPI );  //or just ArduCAM myCAM( OV5642, CS);[/COLOR]
Note line in red. Your camera is connected to Wire1 from your last schematic so you need to change it to read:
If it still doesn't work you need to check your wiring.
Hm even though I change that to Wire1, and checked to make sure that I2C1 is being used, I still get the same result of no image. I also repeated this with a fresh Teensy 4.0, wired like so, and still run into the same problem. I also did this with I2C0 of the 4.0 (because that bus isn't fried like the I2C0 bus on my 4.1) and modified code to be Wire, and still get the same issue.
Also I'm curious as to whether I should de-comment what I have in red. I did try it, it didn't change anything. What does it do, and what difference does it make?
#ifndef _MEMORYSAVER_
#define _MEMORYSAVER_
//Only when using raspberry,enable it
//#define RASPBERRY_PI
//There are two steps you need to modify in this file before normal compilation
//Only ArduCAM Shield series platform need to select camera module, ArduCAM-Mini series platform doesn't
//Step 1: select the hardware platform, only one at a time
//#define OV2640_MINI_2MP
//#define OV3640_MINI_3MP
//#define OV5642_MINI_5MP
//#define OV5642_MINI_5MP_BIT_ROTATION_FIXED
//#define OV2640_MINI_2MP_PLUS
#define OV5642_MINI_5MP_PLUS
//#define OV5640_MINI_5MP_PLUS
//#define ARDUCAM_SHIELD_REVC
//#define ARDUCAM_SHIELD_V2
//Step 2: Select one of the camera module, only one at a time
#if (defined(ARDUCAM_SHIELD_REVC) || defined(ARDUCAM_SHIELD_V2))
	//#define OV7660_CAM
	//#define OV7725_CAM
	//#define OV7670_CAM
	//#define OV7675_CAM
  //#define OV2640_CAM
	//#define OV3640_CAM
[COLOR="#FF0000"]	//#define OV5642_CAM[/COLOR]
	//#define OV5640_CAM
	//#define MT9D111A_CAM
	//#define MT9D111B_CAM
	//#define MT9M112_CAM
	//#define MT9V111_CAM
	//#define MT9M001_CAM
	//#define MT9V034_CAM
	//#define MT9M034_CAM
	//#define MT9T112_CAM
	//#define MT9D112_CAM
#endif	//_MEMORYSAVER_
Simple answer is yes - if you dont have that uncommented it won't know what camera you are using. But just in case I ordered one and should be here today.
Interesting, because with the Arduino UNO R3 I left it commented, as the instructions indicated and it worked. And it made no difference with the Teensy.
Teensy runs alot faster than an R3 thats why the mods to SBI and CBI. Something else must be going on. As I said I have a OV5642 on order and should arrive tonight. So I can play tomorrow or when I get it.
EDIT: Besides checking I2C you can check your SPI wiring. Make sure you CS pin is set correctly in the sketch
const int CS = 10;
And yes you are right that change was for the shiled not the camera.
@the-photographer
I got my OV5642 and hooked it up to a Teensy 4.0. And it worked:
I am using the following sketch downloaded specifically tailored to the OV5642 that I go from the Github Arducam.
  0x00, 0x00
const int CS = 10;
int mode = 0;
uint8_t vid, pid;
uint8_t temp;
 //Reset the CPLD
while(1){
  if (temp != 0x55){
  }else{
  while(1){
    else{
myCAM.InitCAM();
  switch (temp)
    case 0:
    temp = 0xff;
    case 1:
    temp = 0xff;
    case 2:
    temp = 0xff;
    case 3:
    temp = 0xff;
    case 4:
    temp = 0xff;
    case 5:
    temp = 0xff;
    case 6:
    temp = 0xff;
    case 0x10:
    mode = 1;
    temp = 0xff;
    start_capture = 1;
    case 0x11:
    temp = 0xff;
    myCAM.InitCAM();
    case 0x20:
    mode = 2;
    temp = 0xff;
    start_capture = 2;
    case 0x30:
    mode = 3;
    temp = 0xff;
    start_capture = 3;
    case 0x31:
    temp = 0xff;
    myCAM.InitCAM();
    case 0x40:
    case 0x41:
     case 0x42:
     case 0x43:
     case 0x44:
     case 0x45:
      case 0x50:
   case 0x51:
   case 0x52:
  case 0x53:
   case 0x54:
   case 0x55:
   case 0x56:
    case 0x57:
   case 0x58:
   case 0x60:
  case 0x61:
  case 0x62:
   case 0x63:
   case 0x64:
    case 0x65:
     case 0x66:
    case 0x67:
    case 0x68:
case 0x70:
  case 0x71:
  case 0x72:
   case 0x73:
   case 0x74:
    case 0x75:
     case 0x76:
    case 0x77:
    case 0x78:
   case 0x80:
   case 0x81:
   case 0x82:
   case 0x83:
    case 0x84:
    case 0x85:
     case 0x86:
   case 0x87:
   case 0x88:
    case 0x89:
     case 0x8a:
   case 0x8b:
   case 0x90:
      case 0x91:
    case 0x92:
      case 0x93:
    case 0x94:
   case 0x95:
   case 0x96:
   case 0xA0:
     case 0xA1:
      case 0xA2:
    case 0xA3:
     case 0xA4:
   case 0xA5:
    case 0xA6:
   case 0xA7:
    case 0xA8:
    case 0xA9:
   case 0xB0:
    case 0xB1:
    case 0xB2:
      case 0xB3:
     case 0xB4:
     case 0xB5:
     case 0xB6:
     case 0xB7:
    case 0xB8:
    case 0xC0:
    case 0xC1:
    case 0xC2:
    case 0xC3:
     case 0xD0:
      case 0xD1:
      case 0xD2:
      case 0xE0:
      case 0xE1:
      case 0xE2:
     case 0xE3:
      default:
if (mode == 1)
    myCAM.flush_fifo();
    //Start capture
    start_capture = 0;
else if (mode == 2)
  while (1)
    if (temp == 0x21)
      start_capture = 0;
      mode = 0;
    switch(temp){
       case 0x40:
    case 0x41:
     case 0x42:
     case 0x43:
     case 0x44:
     case 0x45:
      case 0x50:
   case 0x51:
   case 0x52:
  case 0x53:
   case 0x54:
   case 0x55:
   case 0x56:
    case 0x57:
   case 0x58:
   case 0x60:
  case 0x61:
  case 0x62:
   case 0x63:
   case 0x64:
    case 0x65:
     case 0x66:
    case 0x67:
    case 0x68:
case 0x70:
  case 0x71:
  case 0x72:
   case 0x73:
   case 0x74:
    case 0x75:
     case 0x76:
    case 0x77:
    case 0x78:
   case 0x80:
   case 0x81:
   case 0x82:
   case 0x83:
    case 0x84:
    case 0x85:
     case 0x86:
   case 0x87:
   case 0x88:
    case 0x89:
     case 0x8a:
   case 0x8b:
  case 0x90:
      case 0x91:
    case 0x92:
      case 0x93:
    case 0x94:
   case 0x95:
   case 0x96:
   case 0xA0:
     case 0xA1:
      case 0xA2:
    case 0xA3:
     case 0xA4:
   case 0xA5:
    case 0xA6:
   case 0xA7:
    case 0xA8:
    case 0xA9:
   case 0xB0:
    case 0xB1:
    case 0xB2:
      case 0xB3:
     case 0xB4:
     case 0xB5:
     case 0xB6:
     case 0xB7:
    case 0xB8:
    case 0xC0:
    case 0xC1:
    case 0xC2:
    case 0xC3:
     case 0xD0:
      case 0xD1:
      case 0xD2:
      case 0xE0:
      case 0xE1:
      case 0xE2:
     case 0xE3:
      myCAM.flush_fifo();
      //Start capture
      start_capture = 0;
        start_capture = 2;
        continue;
      myCAM.CS_LOW();
      length --;
      while ( length-- )
        temp_last = temp;
          Serial.write(temp);
          is_header = true;
          Serial.write(temp);
      myCAM.CS_HIGH();
      start_capture = 2;
      is_header = false;
else if (mode == 3)
    //Flush the FIFO
    myCAM.flush_fifo();
    //Start capture
    start_capture = 0;
      return;
      return;
    myCAM.CS_LOW();
    Serial.write(0xFF);
    Serial.write(0xAA);
    char VH, VL;
    int i = 0, j = 0;
        Serial.write(VL);
        Serial.write(VH);
    Serial.write(0xBB);
    Serial.write(0xCC);
    myCAM.CS_HIGH();
    return 0;
    return 0;
  myCAM.CS_LOW();
  length --;
  while ( length-- )
    temp_last = temp;
      Serial.write(temp);
      is_header = true;
      Serial.write(temp);
  myCAM.CS_HIGH();
  is_header = false;
  return 1;
Thank you for checking with an OV5642. Again, I get no image and no SPI interface message nor message regarding finding the OV5642. With all this learned, the problem seems to be something wrong with my equipment. I will uninstall then reinstall everything related to Arduino and see if it helps.
I did find that at times I would not see the camera but a simple cycling of the power would resolve that issue. Also did found that we have have to add the spi.endtransaction after completion of the capture fixes issue I was seeing. Will post new sketch soon
Updated sketch
  0x00, 0x00
const int CS = 10;
int mode = 0;
uint8_t vid, pid;
uint8_t temp;
 //Reset the CPLD
while(1){
  if (temp != 0x55){
  }else{
  while(1){
    else{
myCAM.InitCAM();
  switch (temp)
    case 0:
    temp = 0xff;
    case 1:
    temp = 0xff;
    case 2:
    temp = 0xff;
    case 3:
    temp = 0xff;
    case 4:
    temp = 0xff;
    case 5:
    temp = 0xff;
    case 6:
    temp = 0xff;
    case 0x10:
    mode = 1;
    temp = 0xff;
    start_capture = 1;
    case 0x11:
    temp = 0xff;
    myCAM.InitCAM();
    case 0x20:
    mode = 2;
    temp = 0xff;
    start_capture = 2;
    case 0x30:
    mode = 3;
    temp = 0xff;
    start_capture = 3;
    case 0x31:
    temp = 0xff;
    myCAM.InitCAM();
    case 0x40:
    case 0x41:
     case 0x42:
     case 0x43:
     case 0x44:
     case 0x45:
      case 0x50:
   case 0x51:
   case 0x52:
  case 0x53:
   case 0x54:
   case 0x55:
   case 0x56:
    case 0x57:
   case 0x58:
   case 0x60:
  case 0x61:
  case 0x62:
   case 0x63:
   case 0x64:
    case 0x65:
     case 0x66:
    case 0x67:
    case 0x68:
case 0x70:
  case 0x71:
  case 0x72:
   case 0x73:
   case 0x74:
    case 0x75:
     case 0x76:
    case 0x77:
    case 0x78:
   case 0x80:
   case 0x81:
   case 0x82:
   case 0x83:
    case 0x84:
    case 0x85:
     case 0x86:
   case 0x87:
   case 0x88:
    case 0x89:
     case 0x8a:
   case 0x8b:
   case 0x90:
      case 0x91:
    case 0x92:
      case 0x93:
    case 0x94:
   case 0x95:
   case 0x96:
   case 0xA0:
     case 0xA1:
      case 0xA2:
    case 0xA3:
     case 0xA4:
   case 0xA5:
    case 0xA6:
   case 0xA7:
    case 0xA8:
    case 0xA9:
   case 0xB0:
    case 0xB1:
    case 0xB2:
      case 0xB3:
     case 0xB4:
     case 0xB5:
     case 0xB6:
     case 0xB7:
    case 0xB8:
    case 0xC0:
    case 0xC1:
    case 0xC2:
    case 0xC3:
     case 0xD0:
      case 0xD1:
      case 0xD2:
      case 0xE0:
      case 0xE1:
      case 0xE2:
     case 0xE3:
      default:
if (mode == 1)
    myCAM.flush_fifo();
    //Start capture
    start_capture = 0;
else if (mode == 2)
  while (1)
    if (temp == 0x21)
      start_capture = 0;
      mode = 0;
    switch(temp){
       case 0x40:
    case 0x41:
     case 0x42:
     case 0x43:
     case 0x44:
     case 0x45:
      case 0x50:
   case 0x51:
   case 0x52:
  case 0x53:
   case 0x54:
   case 0x55:
   case 0x56:
    case 0x57:
   case 0x58:
   case 0x60:
  case 0x61:
  case 0x62:
   case 0x63:
   case 0x64:
    case 0x65:
     case 0x66:
    case 0x67:
    case 0x68:
case 0x70:
  case 0x71:
  case 0x72:
   case 0x73:
   case 0x74:
    case 0x75:
     case 0x76:
    case 0x77:
    case 0x78:
   case 0x80:
   case 0x81:
   case 0x82:
   case 0x83:
    case 0x84:
    case 0x85:
     case 0x86:
   case 0x87:
   case 0x88:
    case 0x89:
     case 0x8a:
   case 0x8b:
  case 0x90:
      case 0x91:
    case 0x92:
      case 0x93:
    case 0x94:
   case 0x95:
   case 0x96:
   case 0xA0:
     case 0xA1:
      case 0xA2:
    case 0xA3:
     case 0xA4:
   case 0xA5:
    case 0xA6:
   case 0xA7:
    case 0xA8:
    case 0xA9:
   case 0xB0:
    case 0xB1:
    case 0xB2:
      case 0xB3:
     case 0xB4:
     case 0xB5:
     case 0xB6:
     case 0xB7:
    case 0xB8:
    case 0xC0:
    case 0xC1:
    case 0xC2:
    case 0xC3:
     case 0xD0:
      case 0xD1:
      case 0xD2:
      case 0xE0:
      case 0xE1:
      case 0xE2:
     case 0xE3:
      myCAM.flush_fifo();
      //Start capture
      start_capture = 0;
        start_capture = 2;
        continue;
      myCAM.CS_LOW();
      length --;
      while ( length-- )
        temp_last = temp;
          Serial.write(temp);
          is_header = true;
          Serial.write(temp);
      myCAM.CS_HIGH();
      SPI.endTransaction();
      start_capture = 2;
      is_header = false;
else if (mode == 3)
    //Flush the FIFO
    myCAM.flush_fifo();
    //Start capture
    start_capture = 0;
      return;
      return;
    myCAM.CS_LOW();
    Serial.write(0xFF);
    Serial.write(0xAA);
    char VH, VL;
    int i = 0, j = 0;
        Serial.write(VL);
        Serial.write(VH);
    Serial.write(0xBB);
    Serial.write(0xCC);
    myCAM.CS_HIGH();
    return 0;
    return 0;
  myCAM.CS_LOW();
  length --;
  while ( length-- )
    temp_last = temp;
      Serial.write(temp);
      is_header = true;
      Serial.write(temp);
  myCAM.CS_HIGH();
  is_header = false;
  return 1;
@mjs513
So before I uninstalled Arduino, and before I saw this updated code, I tried something new and added a part where during setup(), the analog output will set pin 1 to LOW for 4 seconds, then to HIGH for 4 seconds, then back to LOW. I noticed only 0 V when measuring the output from that pin. However, when I run the pin test as a standalone, like below, I can see that from startup, the pin was 0V from startup until 4 seconds in, then 3.3V for 4 seconds, then went back to 0V. This indicates that my Teensy seems to be getting stuck on the include statements or the initialization of the myCam object. This also happens with your updated code from today.
  pinMode(PIND1, OUTPUT);
  delay(4000);
  digitalWrite(PIND1, HIGH);
  delay(4000);
  digitalWrite(PIND1, LOW);
For reference this is the main code with the pin test.
  0x00, 0x00
const int CS = 10;
int mode = 0;
  delay(4000);
  delay(4000);
uint8_t vid, pid;
uint8_t temp;
 //Reset the CPLD
while(1){
  if (temp != 0x55){
  }else{
  while(1){
    else{
myCAM.InitCAM();
  switch (temp)
    case 0:
    temp = 0xff;
    case 1:
    temp = 0xff;
    case 2:
    temp = 0xff;
    case 3:
    temp = 0xff;
    case 4:
    temp = 0xff;
    case 5:
    temp = 0xff;
    case 6:
    temp = 0xff;
    case 0x10:
    mode = 1;
    temp = 0xff;
    start_capture = 1;
    case 0x11:
    temp = 0xff;
    myCAM.InitCAM();
    case 0x20:
    mode = 2;
    temp = 0xff;
    start_capture = 2;
    case 0x30:
    mode = 3;
    temp = 0xff;
    start_capture = 3;
    case 0x31:
    temp = 0xff;
    myCAM.InitCAM();
    case 0x40:
    case 0x41:
     case 0x42:
     case 0x43:
     case 0x44:
     case 0x45:
      case 0x50:
   case 0x51:
   case 0x52:
  case 0x53:
   case 0x54:
   case 0x55:
   case 0x56:
    case 0x57:
   case 0x58:
   case 0x60:
  case 0x61:
  case 0x62:
   case 0x63:
   case 0x64:
    case 0x65:
     case 0x66:
    case 0x67:
    case 0x68:
case 0x70:
  case 0x71:
  case 0x72:
   case 0x73:
   case 0x74:
    case 0x75:
     case 0x76:
    case 0x77:
    case 0x78:
   case 0x80:
   case 0x81:
   case 0x82:
   case 0x83:
    case 0x84:
    case 0x85:
     case 0x86:
   case 0x87:
   case 0x88:
    case 0x89:
     case 0x8a:
   case 0x8b:
   case 0x90:
      case 0x91:
    case 0x92:
      case 0x93:
    case 0x94:
   case 0x95:
   case 0x96:
   case 0xA0:
     case 0xA1:
      case 0xA2:
    case 0xA3:
     case 0xA4:
   case 0xA5:
    case 0xA6:
   case 0xA7:
    case 0xA8:
    case 0xA9:
   case 0xB0:
    case 0xB1:
    case 0xB2:
      case 0xB3:
     case 0xB4:
     case 0xB5:
     case 0xB6:
     case 0xB7:
    case 0xB8:
    case 0xC0:
    case 0xC1:
    case 0xC2:
    case 0xC3:
     case 0xD0:
      case 0xD1:
      case 0xD2:
      case 0xE0:
      case 0xE1:
      case 0xE2:
     case 0xE3:
      default:
if (mode == 1)
    myCAM.flush_fifo();
    //Start capture
    start_capture = 0;
else if (mode == 2)
  while (1)
    if (temp == 0x21)
      start_capture = 0;
      mode = 0;
    switch(temp){
       case 0x40:
    case 0x41:
     case 0x42:
     case 0x43:
     case 0x44:
     case 0x45:
      case 0x50:
   case 0x51:
   case 0x52:
  case 0x53:
   case 0x54:
   case 0x55:
   case 0x56:
    case 0x57:
   case 0x58:
   case 0x60:
  case 0x61:
  case 0x62:
   case 0x63:
   case 0x64:
    case 0x65:
     case 0x66:
    case 0x67:
    case 0x68:
case 0x70:
  case 0x71:
  case 0x72:
   case 0x73:
   case 0x74:
    case 0x75:
     case 0x76:
    case 0x77:
    case 0x78:
   case 0x80:
   case 0x81:
   case 0x82:
   case 0x83:
    case 0x84:
    case 0x85:
     case 0x86:
   case 0x87:
   case 0x88:
    case 0x89:
     case 0x8a:
   case 0x8b:
  case 0x90:
      case 0x91:
    case 0x92:
      case 0x93:
    case 0x94:
   case 0x95:
   case 0x96:
   case 0xA0:
     case 0xA1:
      case 0xA2:
    case 0xA3:
     case 0xA4:
   case 0xA5:
    case 0xA6:
   case 0xA7:
    case 0xA8:
    case 0xA9:
   case 0xB0:
    case 0xB1:
    case 0xB2:
      case 0xB3:
     case 0xB4:
     case 0xB5:
     case 0xB6:
     case 0xB7:
    case 0xB8:
    case 0xC0:
    case 0xC1:
    case 0xC2:
    case 0xC3:
     case 0xD0:
      case 0xD1:
      case 0xD2:
      case 0xE0:
      case 0xE1:
      case 0xE2:
     case 0xE3:
      myCAM.flush_fifo();
      //Start capture
      start_capture = 0;
        start_capture = 2;
        continue;
      myCAM.CS_LOW();
      length --;
      while ( length-- )
        temp_last = temp;
          Serial.write(temp);
          is_header = true;
          Serial.write(temp);
      myCAM.CS_HIGH();
      start_capture = 2;
      is_header = false;
else if (mode == 3)
    //Flush the FIFO
    myCAM.flush_fifo();
    //Start capture
    start_capture = 0;
      return;
      return;
    myCAM.CS_LOW();
    Serial.write(0xFF);
    Serial.write(0xAA);
    char VH, VL;
    int i = 0, j = 0;
        Serial.write(VL);
        Serial.write(VH);
    Serial.write(0xBB);
    Serial.write(0xCC);
    myCAM.CS_HIGH();
    return 0;
    return 0;
  myCAM.CS_LOW();
  length --;
  while ( length-- )
    temp_last = temp;
      Serial.write(temp);
      is_header = true;
      Serial.write(temp);
  myCAM.CS_HIGH();
  is_header = false;
  return 1;
I will still uninstall then reinstall arduino and Teensy software and see if it fixes anything
EDIT: I uninstalled then reinstalled Arduino and Teensy on my computer, and the problem where it seems to be not executing the setup() function at all persists.
As for my procedure for installing it is:
1) Download Arduino 1.8.19 installer
2) Run installer, install to C:\Program Files(x86)
3) Run Teensyduino installer, in installer, I selected install to C:\Program Files\Arduino
4) Download libraries to Arduino folder in C:\User\USER\Documents\Arduino\libraries
5) Save example code to Documents\Arduino
So now I added a Serial print statement to the ArduCAM.cpp file and it seems it's getting stuck on the first I2C and SPI transmissions. "Before any transmission on any protocol (128)" appears on my Serial Monitor, but no print statement afterwards.
  ArduCAM.cpp - Arduino library support for CMOS Image Sensor
  Copyright (C)2011-2015 ArduCAM.com. All right reserved
  Basic functionality of this library are based on the demo-code provided by
  ArduCAM.com. You can find the latest version of the libraryspi at
  ArduCAM.com. You can find the latest version of the library at
  Now supported controllers:
    - OV7670
    - MT9D111
    - OV7675
    - OV2640
    - OV3640
    - OV5642
    - OV7660
    - OV7725
    - MT9M112
    - MT9V111
    - OV5640
    - MT9M001
    - MT9T112
    - MT9D112
  We will add support for many other sensors in next release.
  Supported MCU platform
    - Theoretically support all Arduino families
      - Arduino UNO R3      (Tested)
      - Arduino MEGA2560 R3   (Tested)
      - Arduino Leonardo R3   (Tested)
      - Arduino Nano      (Tested)
      - Arduino DUE       (Tested)
      - Arduino Yun       (Tested)
      - Raspberry Pi      (Tested)
      - ESP8266-12        (Tested)
  If you make any modifications or improvements to the code, I would appreciate
  that you share the code with me so that I might include it in the next release.
  I can be contacted through http://www.ArduCAM.com
  This library is free software; you can redistribute it and/or
  modify it under the terms of the GNU Lesser General Public
  License as published by the Free Software Foundation; either
  version 2.1 of the License, or (at your option) any later version.
  This library is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
  Lesser General Public License for more details.
  You should have received a copy of the GNU Lesser General Public
  License along with this library; if not, write to the Free Software
  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
  Revision History:
  2012/09/20  V1.0.0  by Lee  first release
  2012/10/23  V1.0.1  by Lee  Resolved some timing issue for the Read/Write Register
  2012/11/29  V1.1.0  by Lee  Add support for MT9D111 sensor
  2012/12/13  V1.2.0  by Lee  Add support for OV7675 sensor
  2012/12/28  V1.3.0  by Lee  Add support for OV2640,OV3640,OV5642 sensors
  2013/02/26  V2.0.0  by Lee  New Rev.B shield hardware, add support for FIFO control
                              and support Mega1280/2560 boards
  2013/05/28  V2.1.0  by Lee  Add support all drawing functions derived from UTFT library
  2013/08/24  V3.0.0  by Lee  Support ArudCAM shield Rev.C hardware, features SPI interface and low power mode.
                Support almost all series of Arduino boards including DUE.
  2014/02/06  V3.0.1  by Lee  Minor change to the library, fixed some bugs, add self test code to the sketches for easy debugging.
  2014/03/09  V3.1.0  by Lee  Add the more impressive example sketches.
                Optimise the OV5642 settings, improve image quality.
                Add live preview before JPEG capture.
                Add play back photos one by one after BMP capture.
  2014/05/01  V3.1.1  by Lee  Minor changes to add support Arduino IDE for linux distributions.
  2014/09/30  V3.2.0  by Lee  Improvement on OV5642 camera dirver.
  2014/10/06  V3.3.0  by Lee  Add OV7660,OV7725 camera support.
  2015/02/27  V3.4.0  by Lee  Add the support for Arduino Yun board, update the latest UTFT library for ArduCAM.
  2015/06/09  V3.4.1  by Lee  Minor changes and add some comments
  2015/06/19  V3.4.2  by Lee  Add support for MT9M112 camera.
  2015/06/20  V3.4.3  by Lee  Add support for MT9V111 camera.
  2015/06/22  V3.4.4  by Lee  Add support for OV5640 camera.
  2015/06/22  V3.4.5  by Lee  Add support for MT9M001 camera.
  2015/08/05  V3.4.6  by Lee  Add support for MT9T112 camera.
  2015/08/08  V3.4.7  by Lee  Add support for MT9D112 camera.
  2015/09/20  V3.4.8  by Lee  Add support for ESP8266 processor.
  2016/02/03  V3.4.9  by Lee  Add support for Arduino ZERO board.
  2016/06/07  V3.5.0  by Lee  Add support for OV5642_CAM_BIT_ROTATION_FIXED.
  2016/06/14  V3.5.1  by Lee  Add support for ArduCAM-Mini-5MP-Plus OV5640_CAM.
  2016/09/29  V3.5.2  by Lee  Optimize the OV5642 register settings
	2016/10/05	V4.0.0	by Lee	Add support for second generation hardware platforms like ArduCAM shield V2, ArduCAM-Mini-5MP-Plus(OV5642/OV5640).
  2016/10/28  V4.0.1  by Lee	Add support for Raspberry Pi
  2017/04/27  V4.1.0  by Lee	Add support for OV2640/OV5640/OV5642 functions.
  2017/07/07  V4.1.0  by Lee	Add support for ArduCAM_ESP32 paltform
  2017/07/25  V4.1.1  by Lee	Add support for MT9V034
#if defined ( RASPBERRY_PI )
	#include <string.h>
	#include <time.h>
	#include <stdio.h>
	#include <stdlib.h>
	#include <stdint.h>
	#include <unistd.h>
	#include <wiringPiI2C.h>
	#include <wiringPi.h>
	#include "ArduCAM.h"
	#include "arducam_arch_raspberrypi.h"
#else
	#include "Arduino.h"
	#include "HardwareSerial.h"
	//#if defined(__SAM3X8E__)
	//#define Wire Wire1
	//#endif
ArduCAM::ArduCAM()
  sensor_model = OV7670;
  sensor_addr = 0x42;
ArduCAM::ArduCAM(byte model ,int CS, TwoWire *i2c, SPIClass *spi)
	[COLOR="#FF0000"]Serial.println("Before any transmission on any protocol (128)");
    i2c_ = i2c;
    i2c_->begin();
    Serial.println("After I2C, before SPI");
    spi_ = spi;
    spi_->begin();
	Serial.println("Before SPI transaction line (133)");
    spi_->beginTransaction(SPISettings(8000000, MSBFIRST, SPI_MODE0));
[/COLOR]
	#if defined (RASPBERRY_PI)
		if(CS>=0)
			B_CS = CS;
	#else
		#if (defined(ESP8266)||defined(ESP32)||defined(TEENSYDUINO))
		  B_CS = CS;
		#else
		  P_CS  = portOutputRegister(digitalPinToPort(CS));
		  B_CS  = digitalPinToBitMask(CS);
  // pinMode(CS, OUTPUT);
 #else
      sbi(P_CS, B_CS);
	sensor_model = model;
	switch (sensor_model)
		case OV7660:
		case OV7670:
		case OV7675:
		case OV7725:
				sensor_addr = 0x21;
		#else
		  	sensor_addr = 0x42;
		case MT9D111_A: //Standard MT9D111 module
      sensor_addr = 0xba;
    case MT9D111_B: //Flex MT9D111 AF module
      sensor_addr = 0x90;
    case MT9M112:
    		sensor_addr = 0x5d;
    	#else
      	sensor_addr = 0x90;
    case MT9M001:
      sensor_addr = 0xba;
    case MT9V034:
      sensor_addr = 0x90;
    case MT9M034:
      sensor_addr = 0x20;// 7 bits
    case OV3640:
    case OV5640:
    case OV5642:
    case MT9T112:
    case MT9D112:
    		sensor_addr = 0x3c;
    	#else
      	sensor_addr = 0x78;
    case OV2640:
    case OV9650:
    case OV9655:
    		sensor_addr = 0x30;
    	#else
      	sensor_addr = 0x60;
		default:
		 		sensor_addr = 0x21;
		 	#else
		 		sensor_addr = 0x42;
		// initialize i2c:
	if (!arducam_i2c_init(sensor_addr)) {
		printf("ERROR: I2C init failed\n");
void ArduCAM::InitCAM()
    case OV7660:
#if defined OV7660_CAM
        wrSensorReg8_8(0x12, 0x80);
        wrSensorRegs8_8(OV7660_QVGA);
    case OV7725:
#if defined OV7725_CAM
       byte reg_val;
        wrSensorRegs8_8(OV7725_QVGA);
        rdSensorReg8_8(0x15, &reg_val);
        wrSensorReg8_8(0x15, (reg_val | 0x02));
    case OV7670:
#if defined OV7670_CAM
        wrSensorRegs8_8(OV7670_QVGA);
    case OV7675:
#if defined OV7675_CAM
        wrSensorRegs8_8(OV7675_QVGA);
    case MT9D111_A:
#if defined MT9D111A_CAM
        wrSensorRegs8_16(MT9D111_QVGA_30fps);
        wrSensorReg8_16(0x97, 0x0020);
        wrSensorReg8_16(0xf0, 0x00);
        wrSensorReg8_16(0x21, 0x8403); //Mirror Column
        wrSensorReg8_16(0xC6, 0xA103);//SEQ_CMD
        wrSensorReg8_16(0xC8, 0x0005); //SEQ_CMD
    case MT9D111_B:
   #if defined MT9D111B_CAM
    case OV5642:
#if ( defined(OV5642_CAM) || defined(OV5642_MINI_5MP) || defined(OV5642_MINI_5MP_BIT_ROTATION_FIXED) || defined(OV5642_MINI_5MP_PLUS) )
        wrSensorReg16_8(0x3008, 0x80);
       if (m_fmt == RAW){
       	//Init and set 640x480;
         wrSensorRegs16_8(OV5642_1280x960_RAW);
		     wrSensorRegs16_8(OV5642_640x480_RAW);
      }else{
      	wrSensorRegs16_8(OV5642_QVGA_Preview);
			  arducam_delay_ms(100);
				#else
        if (m_fmt == JPEG)
					#else
          wrSensorRegs16_8(OV5642_JPEG_Capture_QSXGA);
          wrSensorRegs16_8(ov5642_320x240);
				#else
          wrSensorReg16_8(0x3818, 0xa8);
          wrSensorReg16_8(0x3621, 0x10);
          wrSensorReg16_8(0x3801, 0xb0);
          #if (defined(OV5642_MINI_5MP_PLUS) || (defined ARDUCAM_SHIELD_V2))
          wrSensorReg16_8(0x4407, 0x04);
          #else
          wrSensorReg16_8(0x4407, 0x0C);
	 wrSensorReg16_8(0x5888, 0x00);
        	byte reg_val;
          wrSensorReg16_8(0x4740, 0x21);
          wrSensorReg16_8(0x501e, 0x2a);
          wrSensorReg16_8(0x5002, 0xf8);
          wrSensorReg16_8(0x501f, 0x01);
          wrSensorReg16_8(0x4300, 0x61);
          rdSensorReg16_8(0x3818, &reg_val);
          wrSensorReg16_8(0x3818, (reg_val | 0x60) & 0xff);
          rdSensorReg16_8(0x3621, &reg_val);
          wrSensorReg16_8(0x3621, reg_val & 0xdf);
    case OV5640:
#if ( defined(OV5640_CAM) || defined(OV5640_MINI_5MP_PLUS) )
        if (m_fmt == JPEG)
          wrSensorReg16_8(0x3103, 0x11);
          wrSensorReg16_8(0x3008, 0x82);
          wrSensorRegs16_8(OV5640YUV_Sensor_Dvp_Init);
          wrSensorRegs16_8(OV5640_JPEG_QSXGA);
          wrSensorRegs16_8(OV5640_QSXGA2QVGA);
          #if (defined(OV5640_MINI_5MP_PLUS) || (defined ARDUCAM_SHIELD_V2))
          #else
          wrSensorRegs16_8(OV5640_RGB_QVGA);
    case OV3640:
#if defined OV3640_CAM
    wrSensorRegs16_8(OV3640_QVGA);
    case OV2640:
#if (defined(OV2640_CAM) || defined(OV2640_MINI_2MP) || defined(OV2640_MINI_2MP_PLUS))
        if (m_fmt == JPEG)
          wrSensorRegs8_8(OV2640_JPEG_INIT);
          wrSensorRegs8_8(OV2640_YUV422);
          wrSensorRegs8_8(OV2640_JPEG);
          wrSensorReg8_8(0x15, 0x00);
          wrSensorRegs8_8(OV2640_320x240_JPEG);
          //wrSensorReg8_8(0xff, 0x00);
          //wrSensorReg8_8(0x44, 0x32);
          wrSensorRegs8_8(OV2640_QVGA);
    case OV9655:
    case MT9M112:
#if defined MT9M112_CAM
        wrSensorRegs8_16(MT9M112_QVGA);
          case MT9M034:
#if defined MT9M034_CAM
        wrSensorRegs16_16(MT9M034_RAW);
    case MT9V111:
#if defined MT9V111_CAM
        //Reset sensor core
        wrSensorReg8_16(0x01, 0x04);
        wrSensorReg8_16(0x0D, 0x01);
        wrSensorReg8_16(0x0D, 0x00);
        //Reset IFP
        wrSensorReg8_16(0x01, 0x01);
        wrSensorReg8_16(0x07, 0x01);
        wrSensorReg8_16(0x07, 0x00);
        wrSensorRegs8_16(MT9V111_QVGA);
        //delay(1000);
    case MT9M001:
#if defined MT9M001_CAM
        wrSensorRegs8_16(MT9M001_QVGA_30fps);
    case MT9T112:
#if defined MT9T112_CAM
        wrSensorReg16_16(0x001a , 0x0219 );
        wrSensorReg16_16(0x001a , 0x0018 );
        //reset camera
        wrSensorReg16_16(0x0014 , 0x2425 );
        wrSensorReg16_16(0x0014 , 0x2145 );
        wrSensorReg16_16(0x0010 , 0x0110 );
        wrSensorReg16_16(0x0012 , 0x00f0 );
        wrSensorReg16_16(0x002a , 0x7f77 );
        wrSensorReg16_16(0x0014 , 0x2545 );
        wrSensorReg16_16(0x0014 , 0x2547 );
        wrSensorReg16_16(0x0014 , 0x3447 );
        wrSensorReg16_16(0x0014 , 0x3047 );
        delay(10);
        wrSensorReg16_16(0x0014 , 0x3046 );
        wrSensorReg16_16(0x0022 , 0x01f4 );
        wrSensorReg16_16(0x001e , 0x0707 );
        wrSensorReg16_16(0x3b84 , 0x01f4 );
        wrSensorReg16_16(0x002e , 0x0500 );
        wrSensorReg16_16(0x0018 , 0x402b );
        wrSensorReg16_16(0x3b82 , 0x0004 );
        wrSensorReg16_16(0x0018 , 0x402f );
        wrSensorReg16_16(0x0018 , 0x402e );
        delay(50);
        wrSensorReg16_16(0x0614 , 0x0001 );
        delay(1);
        delay(1);
        delay(1);
        delay(1);
        delay(1);
        delay(1);
        delay(10);
        //init pll
        wrSensorReg16_16(0x098e , 0x6800 );
        wrSensorReg16_16(0x0990 , 0x0140 );
        wrSensorReg16_16(0x098e , 0x6802 );
        wrSensorReg16_16(0x0990 , 0x00f0 );
        wrSensorReg16_16(0x098e , 0x68a0 );
        wrSensorReg16_16(0x0990 , 0x082d );
        wrSensorReg16_16(0x098e , 0x4802 );
        wrSensorReg16_16(0x0990 , 0x0000 );
        wrSensorReg16_16(0x098e , 0x4804 );
        wrSensorReg16_16(0x098e , 0x4806 );
        wrSensorReg16_16(0x0990 , 0x060d );
        wrSensorReg16_16(0x098e , 0x4808 );
        wrSensorReg16_16(0x0990 , 0x080d );
        wrSensorReg16_16(0x098e , 0x480c );
        wrSensorReg16_16(0x0990 , 0x046c );
        wrSensorReg16_16(0x098e , 0x480f );
        wrSensorReg16_16(0x0990 , 0x00cc );
        wrSensorReg16_16(0x098e , 0x4811 );
        wrSensorReg16_16(0x0990 , 0x0381 );
        wrSensorReg16_16(0x098e , 0x4813 );
        wrSensorReg16_16(0x0990 , 0x024f );
        wrSensorReg16_16(0x098e , 0x481d );
        wrSensorReg16_16(0x0990 , 0x0436 );
        wrSensorReg16_16(0x098e , 0x481f );
        wrSensorReg16_16(0x0990 , 0x05d0 );
        wrSensorReg16_16(0x098e , 0x4825 );
        wrSensorReg16_16(0x0990 , 0x1153 );
        wrSensorReg16_16(0x098e , 0x6ca0 );
        wrSensorReg16_16(0x098e , 0x484a );
        wrSensorReg16_16(0x0990 , 0x0004 );
        wrSensorReg16_16(0x098e , 0x484c );
        wrSensorReg16_16(0x098e , 0x484e );
        wrSensorReg16_16(0x0990 , 0x060b );
        wrSensorReg16_16(0x098e , 0x4850 );
        wrSensorReg16_16(0x0990 , 0x080b );
        wrSensorReg16_16(0x098e , 0x4857 );
        wrSensorReg16_16(0x0990 , 0x008c );
        wrSensorReg16_16(0x098e , 0x4859 );
        wrSensorReg16_16(0x0990 , 0x01f1 );
        wrSensorReg16_16(0x098e , 0x485b );
        wrSensorReg16_16(0x0990 , 0x00ff );
        wrSensorReg16_16(0x098e , 0x4865 );
        wrSensorReg16_16(0x0990 , 0x0668 );
        wrSensorReg16_16(0x098e , 0x4867 );
        wrSensorReg16_16(0x0990 , 0x0af0 );
        wrSensorReg16_16(0x098e , 0x486d );
        wrSensorReg16_16(0x098e , 0xa005 );
        wrSensorReg16_16(0x0990 , 0x0001 );
        wrSensorReg16_16(0x098e , 0x6c11 );
        wrSensorReg16_16(0x0990 , 0x0003 );
        wrSensorReg16_16(0x098e , 0x6811 );
        wrSensorReg16_16(0x098e , 0xc8a5 );
        wrSensorReg16_16(0x0990 , 0x0025 );
        wrSensorReg16_16(0x098e , 0xc8a6 );
        wrSensorReg16_16(0x0990 , 0x0028 );
        wrSensorReg16_16(0x098e , 0xc8a7 );
        wrSensorReg16_16(0x0990 , 0x002c );
        wrSensorReg16_16(0x098e , 0xc8a8 );
        wrSensorReg16_16(0x0990 , 0x002f );
        wrSensorReg16_16(0x098e , 0xc844 );
        wrSensorReg16_16(0x0990 , 0x00ba );
        wrSensorReg16_16(0x098e , 0xc92f );
        wrSensorReg16_16(0x098e , 0xc845 );
        wrSensorReg16_16(0x0990 , 0x009b );
        wrSensorReg16_16(0x098e , 0xc92d );
        wrSensorReg16_16(0x098e , 0xc88c );
        wrSensorReg16_16(0x0990 , 0x0082 );
        wrSensorReg16_16(0x098e , 0xc930 );
        wrSensorReg16_16(0x098e , 0xc88d );
        wrSensorReg16_16(0x0990 , 0x006d );
        wrSensorReg16_16(0x098e , 0xc92e );
        wrSensorReg16_16(0x098e , 0xa002 );
        wrSensorReg16_16(0x0990 , 0x0010 );
        wrSensorReg16_16(0x098e , 0xa009 );
        wrSensorReg16_16(0x0990 , 0x0002 );
        wrSensorReg16_16(0x098e , 0xa00a );
        wrSensorReg16_16(0x098e , 0xa00c );
        wrSensorReg16_16(0x0990 , 0x000a );
        wrSensorReg16_16(0x098e , 0x4846 );
        wrSensorReg16_16(0x0990 , 0x0014 );
        wrSensorReg16_16(0x098e , 0x488e );
        wrSensorReg16_16(0x0990 , 0x0085 );
        wrSensorReg16_16(0x0990 , 0x006e );
        wrSensorReg16_16(0x0990 , 0x006c );
        wrSensorReg16_16(0x0990 , 0x001b );
        wrSensorReg16_16(0x0990 , 0x001e );
        wrSensorReg16_16(0x0990 , 0x0020 );
        wrSensorReg16_16(0x0990 , 0x0023 );
        //init setting
        wrSensorReg16_16(0x0018 , 0x002a );
        wrSensorReg16_16(0x3084 , 0x2409 );
        wrSensorReg16_16(0x3092 , 0x0a49 );
        wrSensorReg16_16(0x3094 , 0x4949 );
        wrSensorReg16_16(0x3096 , 0x4950 );
        wrSensorReg16_16(0x0990 , 0x0a2e );
        wrSensorReg16_16(0x098e , 0x6c90 );
        wrSensorReg16_16(0x0990 , 0x0cb4 );
        wrSensorReg16_16(0x098e , 0x6807 );
        wrSensorReg16_16(0x098e , 0xe88e );
        wrSensorReg16_16(0x316c , 0x350f );
        wrSensorReg16_16(0x001e , 0x0777 );
        wrSensorReg16_16(0x098e , 0x8400 );
        wrSensorReg16_16(0x0990 , 0x0006 );
        //Serial.println("MT9T112 init done");
    case MT9D112:
#if defined MT9D112_CAM
        wrSensorReg16_16(0x301a , 0x0acc );
        wrSensorReg16_16(0x3202 , 0x0008 );
        delay(100 );
        wrSensorReg16_16(0x341e , 0x8f09 );
        wrSensorReg16_16(0x341c , 0x020c );
        delay(100 );
        wrSensorRegs16_16(MT9D112_default_setting);
        wrSensorReg16_16(0x338c , 0xa103 );
        wrSensorReg16_16(0x3390 , 0x0006 );
        delay(100 );
        wrSensorReg16_16(0x3390 , 0x0005 );
        delay(100 );
        wrSensorRegs16_16(MT9D112_soc_init);
        delay(200);
        wrSensorReg16_16(0x332E, 0x0020); //RGB565
    default:
void ArduCAM::flush_fifo(void)
	write_reg(ARDUCHIP_FIFO, FIFO_CLEAR_MASK);
void ArduCAM::start_capture(void)
	write_reg(ARDUCHIP_FIFO, FIFO_START_MASK);
void ArduCAM::clear_fifo_flag(void )
uint32_t ArduCAM::read_fifo_length(void)
	uint32_t len1,len2,len3,length=0;
	len1 = read_reg(FIFO_SIZE1);
  len2 = read_reg(FIFO_SIZE2);
  len3 = read_reg(FIFO_SIZE3) & 0x7f;
  length = ((len3 << 16) | (len2 << 8) | len1) & 0x07fffff;
	return length;
uint8_t ArduCAM::transfer(uint8_t data)
  uint8_t temp;
  temp = arducam_spi_transfer(data);
  return temp;
void ArduCAM::transfers(uint8_t *buf, uint32_t size)
	arducam_spi_transfers(buf, size);
void ArduCAM::set_fifo_burst()
	transfer(BURST_FIFO_READ);
	#else
    spi_->transfer(BURST_FIFO_READ);
void ArduCAM::CS_HIGH(void)
	 sbi(P_CS, B_CS);
void ArduCAM::CS_LOW(void)
	 cbi(P_CS, B_CS);
uint8_t ArduCAM::read_fifo(void)
	uint8_t data;
	data = bus_read(SINGLE_FIFO_READ);
	return data;
uint8_t ArduCAM::read_reg(uint8_t addr)
	uint8_t data;
		data = bus_read(addr);
	#else
		data = bus_read(addr & 0x7F);
	return data;
void ArduCAM::write_reg(uint8_t addr, uint8_t data)
		bus_write(addr , data);
	#else
	 bus_write(addr | 0x80, data);
//Set corresponding bit
void ArduCAM::set_bit(uint8_t addr, uint8_t bit)
	uint8_t temp;
	temp = read_reg(addr);
	write_reg(addr, temp | bit);
//Clear corresponding bit
void ArduCAM::clear_bit(uint8_t addr, uint8_t bit)
	uint8_t temp;
	write_reg(addr, temp & (~bit));
//Get corresponding bit status
uint8_t ArduCAM::get_bit(uint8_t addr, uint8_t bit)
  uint8_t temp;
  temp = temp & bit;
  return temp;
//Set ArduCAM working mode
//MCU2LCD_MODE: MCU writes the LCD screen GRAM
//CAM2LCD_MODE: Camera takes control of the LCD screen
//LCD2MCU_MODE: MCU read the LCD screen GRAM
void ArduCAM::set_mode(uint8_t mode)
  switch (mode)
    case MCU2LCD_MODE:
      write_reg(ARDUCHIP_MODE, MCU2LCD_MODE);
    case CAM2LCD_MODE:
      write_reg(ARDUCHIP_MODE, CAM2LCD_MODE);
    case LCD2MCU_MODE:
      write_reg(ARDUCHIP_MODE, LCD2MCU_MODE);
    default:
uint8_t ArduCAM::bus_write(int address,int value)
	cbi(P_CS, B_CS);
		arducam_spi_write(address | 0x80, value);
	#else
		spi_->transfer(address);
		spi_->transfer(value);
	sbi(P_CS, B_CS);
	return 1;
uint8_t ArduCAM:: bus_read(int address)
	uint8_t value;
	cbi(P_CS, B_CS);
		value = arducam_spi_read(address & 0x7F);
		sbi(P_CS, B_CS);
		return value;
	#else
		#if (defined(ESP8266) || defined(__arm__) ||defined(TEENSYDUINO))
		#if defined(OV5642_MINI_5MP)
		  value = spi_->transfer(0x00);
		  // correction for bit rotation from readback
		  value = (byte)(value >> 1) | (value << 7);
		  // take the SS pin high to de-select the chip:
		  sbi(P_CS, B_CS);
		  return value;
		#else
		  sbi(P_CS, B_CS);
		  return value;
		#else
		  sbi(P_CS, B_CS);
		  return value;
void ArduCAM:: OV3640_set_JPEG_size(uint8_t size)
#if (defined (OV3640_CAM)||defined (OV3640_MINI_2MP))
	switch(size)
		case OV3640_176x144:
			wrSensorRegs8_8(OV3640_176x144_JPEG);
		case OV3640_320x240:
			wrSensorRegs16_8(OV3640_320x240_JPEG);
		case OV3640_352x288:
	  	wrSensorRegs16_8(OV3640_352x288_JPEG);
		case OV3640_640x480:
			wrSensorRegs16_8(OV3640_640x480_JPEG);
		case OV3640_800x600:
			wrSensorRegs16_8(OV3640_800x600_JPEG);
		case OV3640_1024x768:
			wrSensorRegs16_8(OV3640_1024x768_JPEG);
		case OV3640_1280x960:
			wrSensorRegs16_8(OV3640_1280x960_JPEG);
		case OV3640_1600x1200:
			wrSensorRegs16_8(OV3640_1600x1200_JPEG);
		case OV3640_2048x1536:
			wrSensorRegs16_8(OV3640_2048x1536_JPEG);
		default:
void ArduCAM::OV2640_set_JPEG_size(uint8_t size)
 #if (defined (OV2640_CAM)||defined (OV2640_MINI_2MP)||defined (OV2640_MINI_2MP_PLUS))
	switch(size)
		case OV2640_160x120:
			wrSensorRegs8_8(OV2640_160x120_JPEG);
		case OV2640_176x144:
			wrSensorRegs8_8(OV2640_176x144_JPEG);
		case OV2640_320x240:
		case OV2640_352x288:
	  	wrSensorRegs8_8(OV2640_352x288_JPEG);
		case OV2640_640x480:
			wrSensorRegs8_8(OV2640_640x480_JPEG);
		case OV2640_800x600:
			wrSensorRegs8_8(OV2640_800x600_JPEG);
		case OV2640_1024x768:
			wrSensorRegs8_8(OV2640_1024x768_JPEG);
		case OV2640_1280x1024:
			wrSensorRegs8_8(OV2640_1280x1024_JPEG);
		case OV2640_1600x1200:
			wrSensorRegs8_8(OV2640_1600x1200_JPEG);
		default:
void ArduCAM::OV5642_set_RAW_size(uint8_t size)
		#if defined(OV5642_CAM) || defined(OV5642_CAM_BIT_ROTATION_FIXED)|| defined(OV5642_MINI_5MP) || defined (OV5642_MINI_5MP_PLUS)
			switch (size)
				case OV5642_640x480:
				case OV5642_1280x960:
				case OV5642_1920x1080:
					wrSensorRegs16_8(ov5642_RAW);
	        wrSensorRegs16_8(OV5642_1920x1080_RAW);
	      case OV5642_2592x1944:
void ArduCAM::OV5642_set_JPEG_size(uint8_t size)
  uint8_t reg_val;
  switch (size)
    case OV5642_320x240:
      wrSensorRegs16_8(ov5642_640x480);
    case OV5642_1024x768:
      wrSensorRegs16_8(ov5642_1024x768);
      wrSensorRegs16_8(ov5642_1280x960);
    case OV5642_1600x1200:
      wrSensorRegs16_8(ov5642_1600x1200);
    case OV5642_2048x1536:
      wrSensorRegs16_8(ov5642_2048x1536);
      wrSensorRegs16_8(ov5642_2592x1944);
    default:
void ArduCAM::OV5640_set_JPEG_size(uint8_t size)
#if (defined (OV5640_CAM)||defined (OV5640_MINI_5MP_PLUS))
  switch (size)
    case OV5640_320x240:
    case OV5640_352x288:
      wrSensorRegs16_8(OV5640_QSXGA2CIF);
    case OV5640_640x480:
      wrSensorRegs16_8(OV5640_QSXGA2VGA);
    case OV5640_800x480:
      wrSensorRegs16_8(OV5640_QSXGA2WVGA);
    case OV5640_1024x768:
      wrSensorRegs16_8(OV5640_QSXGA2XGA);
    case OV5640_1280x960:
      wrSensorRegs16_8(OV5640_QSXGA2SXGA);
    case OV5640_1600x1200:
      wrSensorRegs16_8(OV5640_QSXGA2UXGA);
    case OV5640_2048x1536:
      wrSensorRegs16_8(OV5640_QSXGA2QXGA);
    case OV5640_2592x1944:
    default:
      //320x240
void ArduCAM::set_format(byte fmt)
  if (fmt == BMP)
    m_fmt = BMP;
  else if(fmt == RAW)
    m_fmt = RAW;
    m_fmt = JPEG;
	void ArduCAM::OV2640_set_Light_Mode(uint8_t Light_Mode)
		 switch(Light_Mode)
			  case Auto:
				wrSensorReg8_8(0xc7, 0x00); //AWB on
			  case Sunny:
				wrSensorReg8_8(0xc7, 0x40); //AWB off
			  wrSensorReg8_8(0xcc, 0x5e);
				wrSensorReg8_8(0xcd, 0x41);
				wrSensorReg8_8(0xce, 0x54);
			  case Cloudy:
				wrSensorReg8_8(0xcc, 0x65);
				wrSensorReg8_8(0xce, 0x4f);
			  case Office:
			  wrSensorReg8_8(0xcc, 0x52);
			  wrSensorReg8_8(0xce, 0x66);
			  case Home:
			  wrSensorReg8_8(0xcc, 0x42);
			  wrSensorReg8_8(0xcd, 0x3f);
			  wrSensorReg8_8(0xce, 0x71);
			  default :
	void ArduCAM:: OV3640_set_Light_Mode(uint8_t Light_Mode)
	 #if (defined (OV3640_CAM)||defined (OV3640_MINI_3MP))
			 switch(Light_Mode)
			  case Auto:
				wrSensorReg16_8(0x332b, 0x00);//AWB auto, bit[3]:0,auto
			  case Sunny:
				wrSensorReg16_8(0x332b, 0x08); //AWB off
				wrSensorReg16_8(0x33a7, 0x5e);
				wrSensorReg16_8(0x33a8, 0x40);
				wrSensorReg16_8(0x33a9, 0x46);
			  case Cloudy:
				wrSensorReg16_8(0x33a7, 0x68);
				wrSensorReg16_8(0x33a9, 0x4e);
			  case Office:
				wrSensorReg16_8(0x33a7, 0x52);
				wrSensorReg16_8(0x33a9, 0x58);
			  case Home:
				wrSensorReg16_8(0x33a7, 0x44);
				wrSensorReg16_8(0x33a9, 0x70);
	void ArduCAM::OV5642_set_Light_Mode(uint8_t Light_Mode)
		 switch(Light_Mode)
			  case Advanced_AWB:
				wrSensorReg16_8(0x3406 ,0x0 );
				wrSensorReg16_8(0x5192 ,0x04);
				wrSensorReg16_8(0x5191 ,0xf8);
				wrSensorReg16_8(0x518d ,0x26);
				wrSensorReg16_8(0x518f ,0x42);
				wrSensorReg16_8(0x518e ,0x2b);
				wrSensorReg16_8(0x5190 ,0x42);
				wrSensorReg16_8(0x518b ,0xd0);
				wrSensorReg16_8(0x518c ,0xbd);
				wrSensorReg16_8(0x5187 ,0x18);
				wrSensorReg16_8(0x5188 ,0x18);
				wrSensorReg16_8(0x5189 ,0x56);
				wrSensorReg16_8(0x518a ,0x5c);
				wrSensorReg16_8(0x5186 ,0x1c);
				wrSensorReg16_8(0x5181 ,0x50);
				wrSensorReg16_8(0x5184 ,0x20);
				wrSensorReg16_8(0x5182 ,0x11);
				wrSensorReg16_8(0x5183 ,0x0 );
			  case Simple_AWB:
				wrSensorReg16_8(0x3406 ,0x00);
				wrSensorReg16_8(0x5183 ,0x80);
				wrSensorReg16_8(0x5191 ,0xff);
				wrSensorReg16_8(0x5192 ,0x00);
			  case Manual_day:
				wrSensorReg16_8(0x3406 ,0x1 );
				wrSensorReg16_8(0x3400 ,0x7 );
				wrSensorReg16_8(0x3401 ,0x32);
				wrSensorReg16_8(0x3402 ,0x4 );
				wrSensorReg16_8(0x3403 ,0x0 );
				wrSensorReg16_8(0x3404 ,0x5 );
				wrSensorReg16_8(0x3405 ,0x36);
			  case Manual_A:
				wrSensorReg16_8(0x3400 ,0x4 );
				wrSensorReg16_8(0x3401 ,0x88);
				wrSensorReg16_8(0x3404 ,0x8 );
				wrSensorReg16_8(0x3405 ,0xb6);
			  case Manual_cwf:
				wrSensorReg16_8(0x3400 ,0x6 );
				wrSensorReg16_8(0x3401 ,0x13);
				wrSensorReg16_8(0x3404 ,0x7 );
				wrSensorReg16_8(0x3405 ,0xe2);
			  case Manual_cloudy:
				wrSensorReg16_8(0x3405 ,0x0);
			  default :
	void ArduCAM::OV5640_set_Light_Mode(uint8_t Light_Mode)
		switch(Light_Mode)
			case Auto:
				wrSensorReg16_8(0x3212, 0x03); // start group 3
				wrSensorReg16_8(0x3406, 0x00);
				wrSensorReg16_8(0x3400, 0x04);
				wrSensorReg16_8(0x3401, 0x00);
				wrSensorReg16_8(0x3402, 0x04);
				wrSensorReg16_8(0x3403, 0x00);
				wrSensorReg16_8(0x3404, 0x04);
				wrSensorReg16_8(0x3405, 0x00);
				wrSensorReg16_8(0x3212, 0x13); // end group 3
				wrSensorReg16_8(0x3212, 0xa3); // lanuch group 3
			case Sunny:
				wrSensorReg16_8(0x3406, 0x01);
				wrSensorReg16_8(0x3400, 0x06);
				wrSensorReg16_8(0x3401, 0x1c);
				wrSensorReg16_8(0x3405, 0xf3);
			  case Office:
				wrSensorReg16_8(0x3400, 0x05);
				wrSensorReg16_8(0x3401, 0x48);
				wrSensorReg16_8(0x3404, 0x07);
				wrSensorReg16_8(0x3405, 0xcf);
				wrSensorReg16_8(0x3405, 0xd3);
			  case Cloudy:
			  case Home:
				wrSensorReg16_8(0x3401, 0x10);
				wrSensorReg16_8(0x3404, 0x08);
				wrSensorReg16_8(0x3405, 0x40);
			  default :
	void ArduCAM::OV2640_set_Color_Saturation(uint8_t Color_Saturation)
		switch(Color_Saturation)
			case Saturation2:
				wrSensorReg8_8(0x7c, 0x00);
				wrSensorReg8_8(0x7d, 0x02);
				wrSensorReg8_8(0x7c, 0x03);
				wrSensorReg8_8(0x7d, 0x68);
			case Saturation1:
				wrSensorReg8_8(0x7d, 0x58);
			case Saturation0:
				wrSensorReg8_8(0x7d, 0x48);
			case Saturation_1:
				wrSensorReg8_8(0x7d, 0x38);
			case Saturation_2:
				wrSensorReg8_8(0x7d, 0x28);
	void ArduCAM::OV3640_set_Color_Saturation(uint8_t Color_Saturation)
			case Saturation2:
				wrSensorReg16_8(0x3302, 0xef);//bit[7]:1, enable SDE
				wrSensorReg16_8(0x3355, 0x02); //enable color saturation
				wrSensorReg16_8(0x3358, 0x70);
				wrSensorReg16_8(0x3359, 0x70);
			case Saturation1:
				wrSensorReg16_8(0x3358, 0x50);
				wrSensorReg16_8(0x3359, 0x50);
			case Saturation0:
				wrSensorReg16_8(0x3358, 0x40);
				wrSensorReg16_8(0x3359, 0x40);
			case Saturation_1:
				wrSensorReg16_8(0x3358, 0x30);
				wrSensorReg16_8(0x3359, 0x30);
			case Saturation_2:
				wrSensorReg16_8(0x3358, 0x20);
				wrSensorReg16_8(0x3359, 0x20);
	void ArduCAM::OV5640_set_Color_Saturation(uint8_t Color_Saturation)
			case Saturation3:
				wrSensorReg16_8(0x5381, 0x1c);
				wrSensorReg16_8(0x5382, 0x5a);
				wrSensorReg16_8(0x5383, 0x06);
				wrSensorReg16_8(0x5384, 0x2b);
				wrSensorReg16_8(0x5385, 0xab);
				wrSensorReg16_8(0x5386, 0xd6);
				wrSensorReg16_8(0x5387, 0xda);
				wrSensorReg16_8(0x5388, 0xd6);
				wrSensorReg16_8(0x5389, 0x04);
				wrSensorReg16_8(0x538b, 0x98);
				wrSensorReg16_8(0x538a, 0x01);
				wrSensorReg16_8(0x3212, 0xa3); // launch group 3
			case Saturation2:
				wrSensorReg16_8(0x5384, 0x24);
				wrSensorReg16_8(0x5385, 0x8f);
				wrSensorReg16_8(0x5386, 0xb3);
				wrSensorReg16_8(0x5387, 0xb6);
				wrSensorReg16_8(0x5388, 0xb3);
				wrSensorReg16_8(0x5389, 0x03);
			case Saturation1:
				wrSensorReg16_8(0x5384, 0x1f);
				wrSensorReg16_8(0x5385, 0x7a);
				wrSensorReg16_8(0x5386, 0x9a);
				wrSensorReg16_8(0x5387, 0x9c);
				wrSensorReg16_8(0x5388, 0x9a);
				wrSensorReg16_8(0x5389, 0x02);
			case Saturation0:
				wrSensorReg16_8(0x5384, 0x1a);
				wrSensorReg16_8(0x5385, 0x66);
				wrSensorReg16_8(0x5386, 0x80);
				wrSensorReg16_8(0x5387, 0x82);
				wrSensorReg16_8(0x5388, 0x80);
			case Saturation_1:
				wrSensorReg16_8(0x5384, 0x15);
				wrSensorReg16_8(0x5385, 0x52);
				wrSensorReg16_8(0x5386, 0x66);
				wrSensorReg16_8(0x5387, 0x68);
				wrSensorReg16_8(0x5388, 0x66);
				case Saturation_2:
				wrSensorReg16_8(0x5384, 0x10);
				wrSensorReg16_8(0x5385, 0x3d);
				wrSensorReg16_8(0x5386, 0x4d);
				wrSensorReg16_8(0x5387, 0x4e);
				wrSensorReg16_8(0x5388, 0x4d);
				wrSensorReg16_8(0x5389, 0x01);
				case Saturation_3:
				wrSensorReg16_8(0x5384, 0x0c);
				wrSensorReg16_8(0x5385, 0x30);
				wrSensorReg16_8(0x5386, 0x3d);
				wrSensorReg16_8(0x5387, 0x3e);
				wrSensorReg16_8(0x5388, 0x3d);
	void ArduCAM::OV5642_set_Color_Saturation(uint8_t Color_Saturation)
			case Saturation4:
				wrSensorReg16_8(0x5001 ,0xff);
				wrSensorReg16_8(0x5583 ,0x80);
				wrSensorReg16_8(0x5584 ,0x80);
				wrSensorReg16_8(0x5580 ,0x02);
			case Saturation3:
				wrSensorReg16_8(0x5583 ,0x70);
				wrSensorReg16_8(0x5584 ,0x70);
			case Saturation2:
				wrSensorReg16_8(0x5583 ,0x60);
				wrSensorReg16_8(0x5584 ,0x60);
			case Saturation1:
				wrSensorReg16_8(0x5583 ,0x50);
				wrSensorReg16_8(0x5584 ,0x50);
			case Saturation0:
				wrSensorReg16_8(0x5583 ,0x40);
				wrSensorReg16_8(0x5584 ,0x40);
			case Saturation_1:
				wrSensorReg16_8(0x5583 ,0x30);
				wrSensorReg16_8(0x5584 ,0x30);
				case Saturation_2:
				wrSensorReg16_8(0x5583 ,0x20);
				wrSensorReg16_8(0x5584 ,0x20);
				case Saturation_3:
				wrSensorReg16_8(0x5583 ,0x10);
				wrSensorReg16_8(0x5584 ,0x10);
				case Saturation_4:
				wrSensorReg16_8(0x5583 ,0x00);
				wrSensorReg16_8(0x5584 ,0x00);
	void ArduCAM::OV2640_set_Brightness(uint8_t Brightness)
		switch(Brightness)
			case Brightness2:
				wrSensorReg8_8(0x7d, 0x04);
				wrSensorReg8_8(0x7c, 0x09);
				wrSensorReg8_8(0x7d, 0x40);
				wrSensorReg8_8(0x7d, 0x00);
			case Brightness1:
				wrSensorReg8_8(0x7d, 0x30);
			case Brightness0:
				wrSensorReg8_8(0x7d, 0x20);
			case Brightness_1:
				wrSensorReg8_8(0x7d, 0x10);
			case Brightness_2:
	void ArduCAM::OV3640_set_Brightness(uint8_t Brightness)
			switch(Brightness)
				 case Brightness3:
						wrSensorReg16_8(0x3355, 0x04); //bit[2] enable
						wrSensorReg16_8(0x3354, 0x01); //bit[3] sign of brightness
						wrSensorReg16_8(0x335e, 0x30);
				 case Brightness2:
					wrSensorReg16_8(0x335e, 0x20);
				case Brightness1:
					wrSensorReg16_8(0x335e, 0x10);
		   case Brightness0:
				wrSensorReg16_8(0x335e, 0x00);
			 case Brightness_1:
					wrSensorReg16_8(0x3354, 0x09);
			 case Brightness_2:
				case Brightness_3:
	void ArduCAM::OV5642_set_Brightness(uint8_t Brightness)
		switch(Brightness)
			case Brightness4:
				wrSensorReg16_8(0x5589 ,0x40);
				wrSensorReg16_8(0x5580 ,0x04);
				wrSensorReg16_8(0x558a ,0x00);
			case Brightness3:
				wrSensorReg16_8(0x5589 ,0x30);
			case Brightness2:
				wrSensorReg16_8(0x5589 ,0x20);
			case Brightness1:
				wrSensorReg16_8(0x5589 ,0x10);
			case Brightness0:
				wrSensorReg16_8(0x5589 ,0x00);
			case Brightness_1:
				wrSensorReg16_8(0x558a ,0x08);
			case Brightness_2:
			case Brightness_3:
			case Brightness_4:
	void ArduCAM::OV5640_set_Brightness(uint8_t Brightness)
			switch(Brightness)
					case Brightness4:
						wrSensorReg16_8(0x5587, 0x40);
						wrSensorReg16_8(0x5588, 0x01);
				 case Brightness3:
						wrSensorReg16_8(0x5587, 0x30);
				 case Brightness2:
					wrSensorReg16_8(0x5587, 0x20);
				case Brightness1:
					wrSensorReg16_8(0x5587, 0x10);
		   case Brightness0:
				wrSensorReg16_8(0x5587, 0x00);
			 case Brightness_1:
					wrSensorReg16_8(0x5588, 0x09);
			 case Brightness_2:
				case Brightness_3:
			case Brightness_4:
	void ArduCAM::OV2640_set_Contrast(uint8_t Contrast)
		switch(Contrast)
			case Contrast2:
				wrSensorReg8_8(0x7c, 0x07);
				wrSensorReg8_8(0x7d, 0x0c);
				wrSensorReg8_8(0x7d, 0x06);
			case Contrast1:
				wrSensorReg8_8(0x7d, 0x24);
				wrSensorReg8_8(0x7d, 0x16);
			case Contrast0:
			case Contrast_1:
				wrSensorReg8_8(0x7d, 0x2a);
			case Contrast_2:
				wrSensorReg8_8(0x7d, 0x18);
				wrSensorReg8_8(0x7d, 0x34);
	void ArduCAM::OV3640_set_Contrast(uint8_t Contrast)
		switch(Contrast)
			case Contrast3:
				wrSensorReg16_8(0x3355, 0x04); //bit[2] enable contrast/brightness
				wrSensorReg16_8(0x3354, 0x01); //bit[2] Yoffset sign
				wrSensorReg16_8(0x335c, 0x2c);
				wrSensorReg16_8(0x335d, 0x2c);
			case Contrast2:
				wrSensorReg16_8(0x335c, 0x28);
				wrSensorReg16_8(0x335d, 0x28);
			case Contrast1:
				wrSensorReg16_8(0x335c, 0x24);
				wrSensorReg16_8(0x335d, 0x24);
			case Contrast0:
				wrSensorReg16_8(0x335c, 0x20);
				wrSensorReg16_8(0x335d, 0x20);
			case Contrast_1:
				wrSensorReg16_8(0x335c, 0x1c);
				wrSensorReg16_8(0x335d, 0x1c);
			case Contrast_2:
				wrSensorReg16_8(0x335c, 0x18);
				wrSensorReg16_8(0x335d, 0x18);
			case Contrast_3:
				wrSensorReg16_8(0x335c, 0x14);
				wrSensorReg16_8(0x335d, 0x14);
	void ArduCAM::OV5642_set_Contrast(uint8_t Contrast)
		switch(Contrast)
			case Contrast4:
				wrSensorReg16_8(0x5587 ,0x30);
				wrSensorReg16_8(0x5588 ,0x30);
			case Contrast3:
				wrSensorReg16_8(0x5587 ,0x2c);
				wrSensorReg16_8(0x5588 ,0x2c);
			case Contrast2:
				wrSensorReg16_8(0x5587 ,0x28);
				wrSensorReg16_8(0x5588 ,0x28);
			case Contrast1:
				wrSensorReg16_8(0x5587 ,0x24);
				wrSensorReg16_8(0x5588 ,0x24);
			case Contrast0:
				wrSensorReg16_8(0x5587 ,0x20);
				wrSensorReg16_8(0x5588 ,0x20);
			case Contrast_1:
				wrSensorReg16_8(0x5587 ,0x1C);
				wrSensorReg16_8(0x5588 ,0x1C);
				wrSensorReg16_8(0x558a ,0x1C);
			case Contrast_2:
				wrSensorReg16_8(0x5587 ,0x18);
				wrSensorReg16_8(0x5588 ,0x18);
			case Contrast_3:
				wrSensorReg16_8(0x5587 ,0x14);
				wrSensorReg16_8(0x5588 ,0x14);
			case Contrast_4:
				wrSensorReg16_8(0x5587 ,0x10);
				wrSensorReg16_8(0x5588 ,0x10);
	void ArduCAM::OV5640_set_Contrast(uint8_t Contrast)
			switch(Contrast)
			case Contrast3:
				wrSensorReg16_8(0x5586, 0x2c);
				wrSensorReg16_8(0x5585, 0x1c);
			case Contrast2:
				wrSensorReg16_8(0x5586, 0x28);
				wrSensorReg16_8(0x5585, 0x18);
			case Contrast1:
				wrSensorReg16_8(0x5586, 0x24);
				wrSensorReg16_8(0x5585, 0x10);
			case Contrast0:
				wrSensorReg16_8(0x5586, 0x20);
				wrSensorReg16_8(0x5585, 0x00);
			case Contrast_1:
				wrSensorReg16_8(0x5586, 0x1c);
			case Contrast_2:
				wrSensorReg16_8(0x5586, 0x18);
			case Contrast_3:
				wrSensorReg16_8(0x5586, 0x14);
				wrSensorReg16_8(0x5585, 0x14);
	void ArduCAM::OV5642_set_hue(uint8_t degree)
		switch(degree)
			case degree_180:
				wrSensorReg16_8(0x5580 ,0x01);
				wrSensorReg16_8(0x5581 ,0x80);
				wrSensorReg16_8(0x5582 ,0x00);
				wrSensorReg16_8(0x558a ,0x32);
			case degree_150:
				wrSensorReg16_8(0x5581 ,0x6f);
				wrSensorReg16_8(0x5582 ,0x40);
			case degree_120:
				wrSensorReg16_8(0x5581 ,0x40);
				wrSensorReg16_8(0x5582 ,0x6f);
			case degree_90:
				wrSensorReg16_8(0x5581 ,0x00);
				wrSensorReg16_8(0x5582 ,0x80);
				wrSensorReg16_8(0x558a ,0x02);
			case degree_60:
			case degree_30:
			case degree_0:
				wrSensorReg16_8(0x558a ,0x01);
			case degree30:
			case degree60:
			case degree90:
				wrSensorReg16_8(0x558a ,0x31);
			case degree120:
			case degree150:
	void ArduCAM::OV2640_set_Special_effects(uint8_t Special_effect)
		switch(Special_effect)
			case Antique:
				wrSensorReg8_8(0x7c, 0x05);
				wrSensorReg8_8(0x7d, 0xa6);
			case Bluish:
				wrSensorReg8_8(0x7d, 0xa0);
			case Greenish:
			case Reddish:
				wrSensorReg8_8(0x7d, 0xc0);
			case BW:
				wrSensorReg8_8(0x7d, 0x80);
			case Negative:
			case BWnegative:
			case Normal:
	void ArduCAM::OV3640_set_Special_effects(uint8_t Special_effect)
			case Antique:
				wrSensorReg16_8(0x3355, 0x18);
				wrSensorReg16_8(0x335a, 0x40);
				wrSensorReg16_8(0x335b, 0xa6);
			case Bluish:
				wrSensorReg16_8(0x335a, 0xa0);
				wrSensorReg16_8(0x335b, 0x40);
			case Greenish:
				wrSensorReg16_8(0x335a, 0x60);
				wrSensorReg16_8(0x335b, 0x60);
			case Reddish:
				wrSensorReg16_8(0x335a, 0x80);
				wrSensorReg16_8(0x335b, 0xc0);
			case Yellowish:
				wrSensorReg16_8(0x335a, 0x30);
				wrSensorReg16_8(0x335b, 0x90);
			case BW:
				wrSensorReg16_8(0x3355, 0x18);//bit[4]fix u enable, bit[3]fix v enable
				wrSensorReg16_8(0x335b, 0x80);
			case Negative:
				wrSensorReg16_8(0x3355, 0x40);//bit[6] negative
			case BWnegative:
			case Normal:
				wrSensorReg16_8(0x3355, 0x00);
	void ArduCAM::OV5642_set_Special_effects(uint8_t Special_effect)
			case Bluish:
				wrSensorReg16_8(0x5580 ,0x18);
				wrSensorReg16_8(0x5585 ,0xa0);
				wrSensorReg16_8(0x5586 ,0x40);
			case Greenish:
				wrSensorReg16_8(0x5585 ,0x60);
				wrSensorReg16_8(0x5586 ,0x60);
			case Reddish:
				wrSensorReg16_8(0x5585 ,0x80);
				wrSensorReg16_8(0x5586 ,0xc0);
			case BW:
				wrSensorReg16_8(0x5586 ,0x80);
			case Negative:
				wrSensorReg16_8(0x5580 ,0x40);
				case Sepia:
				wrSensorReg16_8(0x5585 ,0x40);
				wrSensorReg16_8(0x5586 ,0xa0);
			case Normal:
				wrSensorReg16_8(0x5001 ,0x7f);
				wrSensorReg16_8(0x5580 ,0x00);
	void ArduCAM::OV5640_set_Special_effects(uint8_t Special_effect)
			case Normal:
				wrSensorReg16_8(0x5580, 0x06);
				wrSensorReg16_8(0x5583, 0x40); // sat U
				wrSensorReg16_8(0x5584, 0x10); // sat V
				wrSensorReg16_8(0x5003, 0x08);
			case Blueish:
				wrSensorReg16_8(0x5580, 0x1e);
				wrSensorReg16_8(0x5583, 0xa0);
				wrSensorReg16_8(0x5584, 0x40);
			case Reddish:
				wrSensorReg16_8(0x5583, 0x80);
				wrSensorReg16_8(0x5584, 0xc0);
			case BW:
				wrSensorReg16_8(0x5584, 0x80);
			case Sepia:
				wrSensorReg16_8(0x5584, 0xa0);
				case Negative:
				wrSensorReg16_8(0x5580, 0x40);
			case Greenish:
				wrSensorReg16_8(0x5583, 0x60);
				wrSensorReg16_8(0x5584, 0x60);
		case Overexposure:
				wrSensorReg16_8(0x5583, 0xf0);
				wrSensorReg16_8(0x5584, 0xf0);
		case Solarize:
				wrSensorReg16_8(0x5003, 0x09);
	void ArduCAM::OV3640_set_Exposure_level(uint8_t level)
		switch(level)
			case Exposure_17_EV:
			wrSensorReg16_8(0x3018, 0x10);
				wrSensorReg16_8(0x3019, 0x08);
				wrSensorReg16_8(0x301a, 0x21);
			case Exposure_13_EV:
				wrSensorReg16_8(0x3018, 0x18);
				wrSensorReg16_8(0x3019, 0x10);
				wrSensorReg16_8(0x301a, 0x31);
			case Exposure_10_EV:
				wrSensorReg16_8(0x3018, 0x20);
				wrSensorReg16_8(0x3019, 0x18);
				wrSensorReg16_8(0x301a, 0x41);
			case Exposure_07_EV:
				wrSensorReg16_8(0x3018, 0x28);
				wrSensorReg16_8(0x3019, 0x20);
				wrSensorReg16_8(0x301a, 0x51);
			case Exposure_03_EV:
				wrSensorReg16_8(0x3018, 0x30);
				wrSensorReg16_8(0x3019, 0x28);
				wrSensorReg16_8(0x301a, 0x61);
			case Exposure_default:
				wrSensorReg16_8(0x3018, 0x38);
			wrSensorReg16_8(0x3019, 0x30);
			case Exposure03_EV:
				wrSensorReg16_8(0x3018, 0x40);
				wrSensorReg16_8(0x3019, 0x38);
				wrSensorReg16_8(0x301a, 0x71);
			case Exposure07_EV:
				wrSensorReg16_8(0x3018, 0x48);
				wrSensorReg16_8(0x3019, 0x40);
				wrSensorReg16_8(0x301a, 0x81);
			case Exposure10_EV:
				wrSensorReg16_8(0x3018, 0x50);
				wrSensorReg16_8(0x3019, 0x48);
				wrSensorReg16_8(0x301a, 0x91);
			case Exposure13_EV:
				wrSensorReg16_8(0x3018, 0x58);
				wrSensorReg16_8(0x3019, 0x50);
			case Exposure17_EV:
				wrSensorReg16_8(0x3018, 0x60);
				wrSensorReg16_8(0x3019, 0x58);
				wrSensorReg16_8(0x301a, 0xa1);
	void ArduCAM::OV5642_set_Exposure_level(uint8_t level)
		switch(level)
			  wrSensorReg16_8(0x3a0f ,0x10);
				wrSensorReg16_8(0x3a10 ,0x08);
				wrSensorReg16_8(0x3a1b ,0x10);
				wrSensorReg16_8(0x3a1e ,0x08);
				wrSensorReg16_8(0x3a11 ,0x20);
				wrSensorReg16_8(0x3a1f ,0x10);
				wrSensorReg16_8(0x3a0f ,0x18);
				wrSensorReg16_8(0x3a10 ,0x10);
				wrSensorReg16_8(0x3a1b ,0x18);
				wrSensorReg16_8(0x3a1e ,0x10);
				wrSensorReg16_8(0x3a11 ,0x30);
				wrSensorReg16_8(0x3a0f ,0x20);
				wrSensorReg16_8(0x3a10 ,0x18);
				wrSensorReg16_8(0x3a11 ,0x41);
				wrSensorReg16_8(0x3a1b ,0x20);
				wrSensorReg16_8(0x3a1e ,0x18);
				wrSensorReg16_8(0x3a0f ,0x28);
				wrSensorReg16_8(0x3a10 ,0x20);
				wrSensorReg16_8(0x3a11 ,0x51);
				wrSensorReg16_8(0x3a1b ,0x28);
				wrSensorReg16_8(0x3a1e ,0x20);
				wrSensorReg16_8(0x3a0f ,0x30);
				wrSensorReg16_8(0x3a10 ,0x28);
				wrSensorReg16_8(0x3a11 ,0x61);
				wrSensorReg16_8(0x3a1b ,0x30);
				wrSensorReg16_8(0x3a1e ,0x28);
				wrSensorReg16_8(0x3a0f ,0x38);
				wrSensorReg16_8(0x3a10 ,0x30);
				wrSensorReg16_8(0x3a1b ,0x38);
				wrSensorReg16_8(0x3a1e ,0x30);
			case Exposure03_EV:
				wrSensorReg16_8(0x3a0f ,0x40);
				wrSensorReg16_8(0x3a10 ,0x38);
				wrSensorReg16_8(0x3a11 ,0x71);
				wrSensorReg16_8(0x3a1b ,0x40);
				wrSensorReg16_8(0x3a1e ,0x38);
			case Exposure07_EV:
				wrSensorReg16_8(0x3a0f ,0x48);
				wrSensorReg16_8(0x3a10 ,0x40);
				wrSensorReg16_8(0x3a11 ,0x80);
				wrSensorReg16_8(0x3a1b ,0x48);
				wrSensorReg16_8(0x3a1e ,0x40);
				wrSensorReg16_8(0x3a1f ,0x20);
			case Exposure10_EV:
				wrSensorReg16_8(0x3a0f ,0x50);
				wrSensorReg16_8(0x3a10 ,0x48);
				wrSensorReg16_8(0x3a11 ,0x90);
				wrSensorReg16_8(0x3a1b ,0x50);
				wrSensorReg16_8(0x3a1e ,0x48);
			case Exposure13_EV:
				wrSensorReg16_8(0x3a0f ,0x58);
				wrSensorReg16_8(0x3a10 ,0x50);
				wrSensorReg16_8(0x3a11 ,0x91);
				wrSensorReg16_8(0x3a1b ,0x58);
				wrSensorReg16_8(0x3a1e ,0x50);
			case Exposure17_EV:
				wrSensorReg16_8(0x3a0f ,0x60);
				wrSensorReg16_8(0x3a10 ,0x58);
				wrSensorReg16_8(0x3a11 ,0xa0);
				wrSensorReg16_8(0x3a1b ,0x60);
				wrSensorReg16_8(0x3a1e ,0x58);
	void ArduCAM::OV3640_set_Sharpness(uint8_t Sharpness)
		switch(Sharpness)
			case Sharpness1:
				wrSensorReg16_8(0x332d, 0x41);
			case Sharpness2:
				wrSensorReg16_8(0x332d, 0x42);
			case Sharpness3:
				wrSensorReg16_8(0x332d, 0x43);
			case Sharpness4:
				wrSensorReg16_8(0x332d, 0x44);
			case Sharpness5:
				wrSensorReg16_8(0x332d, 0x45);
			case Sharpness6:
				wrSensorReg16_8(0x332d, 0x46);
			case Sharpness7:
				wrSensorReg16_8(0x332d, 0x47);
			case Sharpness8:
				wrSensorReg16_8(0x332d, 0x48);
			case Sharpness_auto:
				wrSensorReg16_8(0x332d, 0x60);
				wrSensorReg16_8(0x332f, 0x03);
	void ArduCAM::OV3640_set_Mirror_Flip(uint8_t Mirror_Flip)
			switch(Mirror_Flip)
			case MIRROR:
				wrSensorReg16_8(0x307c, 0x12);//mirror
				wrSensorReg16_8(0x3090, 0xc8);
				wrSensorReg16_8(0x3023, 0x0a);
			case FLIP:
				wrSensorReg16_8(0x307c, 0x11);//flip
				wrSensorReg16_8(0x3023, 0x09);
				wrSensorReg16_8(0x3090, 0xc0);
			case MIRROR_FLIP:
			 wrSensorReg16_8(0x307c, 0x13);//flip/mirror
			case Normal:
				wrSensorReg16_8(0x307c, 0x10);//no mirror/flip
	void ArduCAM::OV5642_set_Sharpness(uint8_t Sharpness)
		switch(Sharpness)
			case Auto_Sharpness_default:
			wrSensorReg16_8(0x530A ,0x00);
				wrSensorReg16_8(0x530c ,0x0 );
				wrSensorReg16_8(0x530d ,0xc );
				wrSensorReg16_8(0x5312 ,0x40);
			case Auto_Sharpness1:
				wrSensorReg16_8(0x530c ,0x4 );
				wrSensorReg16_8(0x530d ,0x18);
				wrSensorReg16_8(0x5312 ,0x20);
			case Auto_Sharpness2:
				wrSensorReg16_8(0x530c ,0x8 );
				wrSensorReg16_8(0x530d ,0x30);
				wrSensorReg16_8(0x5312 ,0x10);
			case Manual_Sharpnessoff:
				wrSensorReg16_8(0x530A ,0x08);
				wrSensorReg16_8(0x531e ,0x00);
				wrSensorReg16_8(0x531f ,0x00);
			case Manual_Sharpness1:
				wrSensorReg16_8(0x531e ,0x04);
				wrSensorReg16_8(0x531f ,0x04);
			case Manual_Sharpness2:
				wrSensorReg16_8(0x531e ,0x08);
				wrSensorReg16_8(0x531f ,0x08);
			case Manual_Sharpness3:
				wrSensorReg16_8(0x531e ,0x0c);
				wrSensorReg16_8(0x531f ,0x0c);
			case Manual_Sharpness4:
				wrSensorReg16_8(0x531e ,0x0f);
				wrSensorReg16_8(0x531f ,0x0f);
			case Manual_Sharpness5:
				wrSensorReg16_8(0x531e ,0x1f);
				wrSensorReg16_8(0x531f ,0x1f);
	void ArduCAM::OV5642_set_Mirror_Flip(uint8_t Mirror_Flip)
			 uint8_t reg_val;
	switch(Mirror_Flip)
			case MIRROR:
				rdSensorReg16_8(0x3818,&reg_val);
				reg_val = reg_val|0x00;
				reg_val = reg_val&0x9F;
			wrSensorReg16_8(0x3818 ,reg_val);
			rdSensorReg16_8(0x3621,&reg_val);
				reg_val = reg_val|0x20;
				wrSensorReg16_8(0x3621, reg_val );
			case FLIP:
				reg_val = reg_val&0xbF;
			case MIRROR_FLIP:
				reg_val = reg_val|0x60;
				reg_val = reg_val&0xFF;
				reg_val = reg_val&0xdf;
			case Normal:
				reg_val = reg_val|0x40;
				reg_val = reg_val&0xdF;
	void ArduCAM::OV5642_set_Compress_quality(uint8_t quality)
	switch(quality)
			case high_quality:
				wrSensorReg16_8(0x4407, 0x02);
			case default_quality:
			case low_quality:
				wrSensorReg16_8(0x4407, 0x08);
	void ArduCAM::OV5642_Test_Pattern(uint8_t Pattern)
	  switch(Pattern)
			case Color_bar:
				wrSensorReg16_8(0x503d , 0x80);
				wrSensorReg16_8(0x503e, 0x00);
			case Color_square:
				wrSensorReg16_8(0x503d , 0x85);
				wrSensorReg16_8(0x503e, 0x12);
			case BW_square:
				wrSensorReg16_8(0x503e, 0x1a);
			case DLI:
				wrSensorReg16_8(0x4741 , 0x4);
	void ArduCAM::OV5640_set_Night_Mode(uint8_t Night_mode)
			uint8_t reg_val;
			switch(Night_mode)
					case Night_Mode_On:
						rdSensorReg16_8(0x3a00,&reg_val);
				   reg_val = reg_val| 0x04;
						wrSensorReg16_8(0x3a00, reg_val);
					case Night_Mode_Off:
						reg_val = reg_val& 0xfb;
	void ArduCAM::OV5640_set_Banding_Filter(uint8_t Banding_Filter)
			uint8_t reg_val;
			switch(Banding_Filter)
					case Off:
						reg_val = reg_val & 0xdf; // turn off banding filter
					case Manual_50HZ:
						wrSensorReg16_8(0x3c00, 04); // set to 50Hz
						wrSensorReg16_8(0x3c01, 80); // manual banding filter
						reg_val = reg_val | 0x20; // turn on banding filter
				case Manual_60HZ:
						wrSensorReg16_8(0x3c00, 00); // set to 60Hz
						rdSensorReg16_8(0x3a00, &reg_val);
				case Auto_Detection:
						wrSensorReg16_8(0x3c01, 00); // auto banding filter
	 void ArduCAM::OV5640_set_EV(uint8_t EV)
			switch(EV)
				case EV3:
					wrSensorReg16_8(0x3a0f, 0x60);
					wrSensorReg16_8(0x3a10, 0x58);
					wrSensorReg16_8(0x3a11, 0xa0);
					wrSensorReg16_8(0x3a1b, 0x60);
					wrSensorReg16_8(0x3a1e, 0x58);
					wrSensorReg16_8(0x3a1f, 0x20);
				case EV2:
					wrSensorReg16_8(0x3a0f, 0x50);
					wrSensorReg16_8(0x3a10, 0x48);
					wrSensorReg16_8(0x3a11, 0x90);
					wrSensorReg16_8(0x3a1b, 0x50);
					wrSensorReg16_8(0x3a1e, 0x48);
				case EV1:
					wrSensorReg16_8(0x3a0f, 0x40);
					wrSensorReg16_8(0x3a10, 0x38);
					wrSensorReg16_8(0x3a11, 0x71);
					wrSensorReg16_8(0x3a1b, 0x40);
					wrSensorReg16_8(0x3a1e, 0x38);
					wrSensorReg16_8(0x3a1f, 0x10);
				case EV0:
					wrSensorReg16_8(0x3a0f, 0x38);
					wrSensorReg16_8(0x3a10, 0x30);
					wrSensorReg16_8(0x3a11, 0x61);
					wrSensorReg16_8(0x3a1b, 0x38);
					wrSensorReg16_8(0x3a1e, 0x30);
				case EV_1:
					wrSensorReg16_8(0x3a0f, 0x30);
					wrSensorReg16_8(0x3a10, 0x28);
					wrSensorReg16_8(0x3a1b, 0x30);
					wrSensorReg16_8(0x3a1e, 0x28);
				case EV_2:
					wrSensorReg16_8(0x3a0f, 0x20);
					wrSensorReg16_8(0x3a10, 0x18);
					wrSensorReg16_8(0x3a11, 0x41);
					wrSensorReg16_8(0x3a1b, 0x20);
					wrSensorReg16_8(0x3a1e, 0x18);
				case EV_3:
					wrSensorReg16_8(0x3a0f, 0x10);
					wrSensorReg16_8(0x3a10, 0x08);
					wrSensorReg16_8(0x3a1b, 0x10);
					wrSensorReg16_8(0x3a1e, 0x08);
					wrSensorReg16_8(0x3a11, 0x20);
	// Write 8 bit values to 8 bit register address
int ArduCAM::wrSensorRegs8_8(const struct sensor_reg reglist[])
		arducam_i2c_write_regs(reglist);
	#else
		int err = 0;
	  uint16_t reg_addr = 0;
	  uint16_t reg_val = 0;
	  const struct sensor_reg *next = reglist;
	  while ((reg_addr != 0xff) | (reg_val != 0xff))
	    reg_addr = pgm_read_word(&next->reg);
	    reg_val = pgm_read_word(&next->val);
	    err = wrSensorReg8_8(reg_addr, reg_val);
	    next++;
		    yield();
	return 1;
	// Write 16 bit values to 8 bit register address
int ArduCAM::wrSensorRegs8_16(const struct sensor_reg reglist[])
		arducam_i2c_write_regs16(reglist);
	#else
		int err = 0;
	  unsigned int reg_addr, reg_val;
	  while ((reg_addr != 0xff) | (reg_val != 0xffff))
		   reg_addr =next->reg;
       reg_val = next->val;
	   #else
	    err = wrSensorReg8_16(reg_addr, reg_val);
	    //  if (!err)
	    //return err;
	    next++;
			yield();
	return 1;
// Write 8 bit values to 16 bit register address
int ArduCAM::wrSensorRegs16_8(const struct sensor_reg reglist[])
		arducam_i2c_write_word_regs(reglist);
	#else
		int err = 0;
	  unsigned int reg_addr;
	  unsigned char reg_val;
	  while ((reg_addr != 0xffff) | (reg_val != 0xff))
	   #else
	    err = wrSensorReg16_8(reg_addr, reg_val);
	    //if (!err)
	    //return err;
	    next++;
			yield();
	return 1;
//I2C Array Write 16bit address, 16bit data
int ArduCAM::wrSensorRegs16_16(const struct sensor_reg reglist[])
	#else
	  int err = 0;
	  while ((reg_addr != 0xffff) | (reg_val != 0xffff))
	    err = wrSensorReg16_16(reg_addr, reg_val);
	    //if (!err)
	    //   return err;
	    next++;
			    yield();
  return 1;
// Read/write 8 bit value to/from 8 bit register address
byte ArduCAM::wrSensorReg8_8(int regID, int regDat)
	  arducam_i2c_write( regID , regDat );
	#else
	  i2c_->beginTransmission(sensor_addr >> 1);
	  i2c_->write(regID & 0x00FF);
	  i2c_->write(regDat & 0x00FF);
	  if (i2c_->endTransmission())
	    return 0;
	  delay(1);
	return 1;
byte ArduCAM::rdSensorReg8_8(uint8_t regID, uint8_t* regDat)
		arducam_i2c_read(regID,regDat);
	#else
	  i2c_->endTransmission();
	  i2c_->requestFrom((sensor_addr >> 1), 1);
	  if (i2c_->available())
	    *regDat = i2c_->read();
	  delay(1);
	return 1;
// Read/write 16 bit value to/from 8 bit register address
byte ArduCAM::wrSensorReg8_16(int regID, int regDat)
		arducam_i2c_write16(regID, regDat );
	#else
	  i2c_->write(regDat >> 8);            // sends data byte, MSB first
	    return 0;
	  delay(1);
	return 1;
byte ArduCAM::rdSensorReg8_16(uint8_t regID, uint16_t* regDat)
  	arducam_i2c_read16(regID, regDat);
  #else
  	uint8_t temp;
	  i2c_->write(regID);
	  i2c_->requestFrom((sensor_addr >> 1), 2);
	    temp = i2c_->read();
	    *regDat = (temp << 8) | i2c_->read();
	  delay(1);
  	return 1;
// Read/write 8 bit value to/from 16 bit register address
byte ArduCAM::wrSensorReg16_8(int regID, int regDat)
		arducam_i2c_word_write(regID, regDat);
		arducam_delay_ms(1);
	#else
	  i2c_->write(regID >> 8);            // sends instruction byte, MSB first
	    return 0;
	  delay(1);
	return 1;
byte ArduCAM::rdSensorReg16_8(uint16_t regID, uint8_t* regDat)
		arducam_i2c_word_read(regID, regDat );
	#else
	  delay(1);
	return 1;
//I2C Write 16bit address, 16bit data
byte ArduCAM::wrSensorReg16_16(int regID, int regDat)
	#else
	    return 0;
	  delay(1);
  return (1);
//I2C Read 16bit address, 16bit data
byte ArduCAM::rdSensorReg16_16(uint16_t regID, uint16_t* regDat)
	#else
	  uint16_t temp;
	  delay(1);
  return (1);
#if defined(ESP8266)
inline void ArduCAM::setDataBits(uint16_t bits) {
  const uint32_t mask = ~((SPIMMOSI << SPILMOSI) | (SPIMMISO << SPILMISO));
  bits--;
  SPI1U1 = ((SPI1U1 & mask) | ((bits << SPILMOSI) | (bits << SPILMISO)));
void ArduCAM::transferBytes_(uint8_t * out, uint8_t * in, uint8_t size) {
  while (SPI1CMD & SPIBUSY) {}
  // Set in/out Bits to transfer
  setDataBits(size * 8);
  volatile uint32_t * fifoPtr = &SPI1W0;
  uint8_t dataSize = ((size + 3) / 4);
  if (out) {
    uint32_t * dataPtr = (uint32_t*) out;
    while (dataSize--) {
      *fifoPtr = *dataPtr;
      dataPtr++;
      fifoPtr++;
    // no out data only read fill with dummy data!
      *fifoPtr = 0xFFFFFFFF;
      fifoPtr++;
  SPI1CMD |= SPIBUSY;
  if (in) {
    volatile uint8_t * fifoPtr8 = (volatile uint8_t *) &SPI1W0;
    dataSize = size;
      *in = *fifoPtr8;
      *in = (byte)(*in >> 1) | (*in << 7);
#else
      *in = *fifoPtr8;
      in++;
      fifoPtr8++;
void ArduCAM::transferBytes(uint8_t * out, uint8_t * in, uint32_t size) {
  while (size) {
    if (size > 64) {
      transferBytes_(out, in, 64);
      size -= 64;
      if (out) out += 64;
      if (in) in += 64;
      transferBytes_(out, in, size);
      size = 0;
This sounds like an issue that appeared with the recent toolchain update - Teensyduino 1.58 or so? Discussed in a few threads, for example this one. I can't see any indications of which Teensyduino you've all used, but 1.59 beta 3 has some fixes in place.
I can see calls to SPI::begin() and Wire::begin() in the Arducam constructor, which is typically the red flag for this issue. Further than that ... I don't have the hardware, sorry!
Actually you are probably correct. I am using 1.59-beta3 which corrects that issue.
