Teensy 4.1 and webserver
pd0lew
Dear all,
My Teensy 4.1 has no memory enough for my Power meter firmware and webserver, webserver is working fine when no power meter code is included.
I soldered a extra flash chip underneath the board.
I have several webpages but the index page is the biggest, can someone help me out how to save this problem.
Thanks,
Johan
Dear all,
Thanks,
Johan
I noticed that is not coming from the index but from QNEthernet and
#include <AsyncWebServer_Teensy41.h> i think this is not solveable....
The code below is simply working but it's only a web page.
#include <LittleFS.h>
#include "index.h"  // Include the index content (content stored in external PSRAM)
// External PSRAM setup
extern "C" uint8_t external_psram_size;  // Access to external PSRAM size
bool memory_ok = false;
uint32_t *memory_begin, *memory_end;
  // Wait for serial to initialize
  while (!Serial);
  pinMode(13, OUTPUT);  // Initialize LED for status feedback
  uint8_t size = external_psram_size;  // Get the size of external PSRAM
  Serial.printf("EXTMEM Memory initialized, %d Mbyte\n", size);
  if (size == 0) {
    Serial.println("No external memory found.");
    return;  // Exit if no external PSRAM is available
  // Set up external PSRAM memory range
  memory_begin = (uint32_t *)(0x70000000);  // Base address of external PSRAM
  memory_end = (uint32_t *)(0x70000000 + size * 1048576);  // End address
  // Check if PSRAM is accessible
  if ((uintptr_t)memory_begin >= (uintptr_t)0x70000000 && (uintptr_t)memory_end <= (uintptr_t)(0x70000000 + (size * 1048576))) {
    Serial.println("External PSRAM initialized.");
    memory_ok = true;
    Serial.println("Invalid PSRAM range!");
    return;
  // Store the content of MAIN_page in external PSRAM
  storeIndexContent();
void storeIndexContent() {
  if (!memory_ok) {
    Serial.println("External memory not initialized.");
    return;
  // Ensure that MAIN_page from "index.h" is available
  if (!MAIN_page) {
    Serial.println("Error: MAIN_page is null!");
    return;
  // Allocate memory in PSRAM for storing the MAIN_page content
  char *psramIndexContent = (char*)malloc(strlen(MAIN_page) + 1);  // Allocate memory for the index content
  if (psramIndexContent == NULL) {
    Serial.println("PSRAM memory allocation failed.");
    return;
  // Copy the content of `MAIN_page` from `index.h` to PSRAM
  strcpy(psramIndexContent, MAIN_page);
  // Copy content into external PSRAM
  memcpy(memory_begin, psramIndexContent, strlen(psramIndexContent) + 1);
  Serial.println("index.h content stored in external PSRAM.");
  // Optionally free allocated memory
  free(psramIndexContent);
  // If external memory is initialized, print the index content stored in PSRAM
  if (memory_ok) {
    // Display content stored in external PSRAM
    Serial.println("Index content from PSRAM:");
    Serial.println((char*)memory_begin);  // Print content from PSRAM
    // Delay to avoid overwhelming the Serial Monitor
  digitalWrite(13, HIGH);  // Blink onboard LED
  digitalWrite(13, LOW);
