Bakhanbeigi
I am trying to connect a MIDI keyboard using USB port on top of the Teensy 4.1 board. And here is the code I have.
I programmed the code using platformio to my teensy and here is the platformio.ini
I can successfully run and upload the code but it seems it does not recognize the usb midi keyboard. the light on midi keyboard is off and when I check the output it is waiting for keyboard.
Could you help me to know how should I fix it? I am also not sure if I need to include Arduino. Because in other project in same hardware I am not improting Arduino
C++:
#include <Arduino.h>
#include "USBHost_t36.h"
// -------- Audio shield (minimal bring-up) --------
// -------- USB host (MIDI) objects --------
USBHost myusb;
USBHub hub1(myusb); // optional hub support
USBHub hub2(myusb);
MIDIDevice_BigBuffer midi1(myusb);
// -------- MIDI callback prototypes --------
void handleNoteOn(byte channel, byte note, byte velocity);
void handleNoteOff(byte channel, byte note, byte velocity);
void handleControlChange(byte channel, byte control, byte value);
void handleProgramChange(byte channel, byte program);
void handlePitchBend(byte channel, int bend);
void handleAfterTouchPoly(byte channel, byte note, byte pressure);
void handleAfterTouchChannel(byte channel, byte pressure);
void handleSystemExclusive(const uint8_t *data, uint16_t length, bool lastChunk);
while (!Serial && millis() < 1500) {
; // wait for USB serial
// Bring up the audio shield (keeps I2S clocking happy when the board is attached)
AudioMemory(12);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5f);
pinMode(LED_BUILTIN, OUTPUT);
Serial.println(F("[USB-MIDI] Initializing USB host..."));
myusb.begin(); // powers the host port and starts enumeration
// Attach MIDI handlers
midi1.setHandleNoteOn(handleNoteOn);
midi1.setHandleNoteOff(handleNoteOff);
midi1.setHandleControlChange(handleControlChange);
midi1.setHandleProgramChange(handleProgramChange);
midi1.setHandlePitchChange(handlePitchBend);
midi1.setHandleAfterTouchPoly(handleAfterTouchPoly);
midi1.setHandleAfterTouchChannel(handleAfterTouchChannel);
midi1.setHandleSystemExclusive(handleSystemExclusive);
Serial.println(F("[USB-MIDI] Ready. Connect a USB-MIDI keyboard to the host port."));
myusb.Task(); // service the USB host controller
while (midi1.read()) { // dispatch all pending MIDI packets
// Callbacks execute during read()
// -------- MIDI callback implementations --------
void handleNoteOn(byte channel, byte note, byte velocity) {
if (velocity == 0) {
handleNoteOff(channel, note, 0);
return;
Serial.print(F("Note On ch="));
Serial.print(channel);
Serial.print(F(" note="));
Serial.print(note);
Serial.print(F(" vel="));
Serial.println(velocity);
void handleNoteOff(byte channel, byte note, byte velocity) {
Serial.print(F("Note Off ch="));
Serial.print(note);
void handleControlChange(byte channel, byte control, byte value) {
Serial.print(F("CC ch="));
Serial.print(F(" cc="));
Serial.print(control);
Serial.print(F(" val="));
Serial.println(value);
void handleProgramChange(byte channel, byte program) {
Serial.print(F("Program ch="));
Serial.print(F(" program="));
Serial.println(program);
void handlePitchBend(byte channel, int bend) {
Serial.print(F("Pitch ch="));
Serial.print(F(" value="));
Serial.println(bend);
void handleAfterTouchPoly(byte channel, byte note, byte pressure) {
Serial.print(F("PolyAT ch="));
Serial.print(note);
Serial.print(F(" pres="));
Serial.println(pressure);
void handleAfterTouchChannel(byte channel, byte pressure) {
Serial.print(F("ChanAT ch="));
void handleSystemExclusive(const uint8_t *data, uint16_t length, bool lastChunk) {
Serial.print(F("SysEx len="));
Serial.print(length);
Serial.print(lastChunk ? F(" (end) ") : F(" (cont) "));
for (uint16_t i = 0; i < length; ++i) {
if (data[i] < 16) Serial.print('0');
Serial.print(data[i], HEX);
if (i + 1 < length) Serial.print(' ');
; PlatformIO Project Configuration File
; Build options: build flags, source filter
; Upload options: custom upload port, speed and extra flags
; Library options: dependencies, extra library storages
; Advanced options: extra scripting
; Please visit documentation for the other options and examples
; https://docs.platformio.org/page/projectconf.html
[env:teensy41]
platform = teensy
board = teensy41
framework = arduino
upload_protocol = teensy-cli
lib_deps =
paulstoffregen/XPT2046_Touchscreen@0.0.0-alpha+sha.26b691b2c8
lvgl/lvgl@^9.0.0
bodmer/TFT_eSPI@^2.5.43
build_flags =
-Ilib
-D LV_CONF_INCLUDE_SIMPLE
-D LV_CONF_SKIP
-D LV_USE_TFT_ESPI
-D TFT_CS=3
-D USER_SETUP_LOADED
-D ILI9341_DRIVER
-D TFT_MISO=12
-D TFT_MOSI=11
-D TFT_SCLK=13
-D TFT_CS=3
-D TFT_DC=2
-D TFT_RST=-1
-D TOUCH_CS=5
-D USB_MIDI_SERIAL
