Fiskusmati
Hello.
I'm running below test code. It does produce unexpected result on my setup.
It should print out only zeros on html page. But instead it looks like that:
It seems like it is printing some random garbage in the middle, if payload length is higher or equal 11585 bytes.
Looks like this payload is split into 3 TCP packets, but on the third packet, there are unexpected bytes at the beginning of the payload:
Can anyone replicate that, or knows how to solve this issue? Thanks.
C:
#if !(defined(CORE_TEENSY) && defined(__IMXRT1062__) && defined(ARDUINO_TEENSY41))
#error Only Teensy 4.1 supported
#define BUFFER_SIZE 32000
#include "QNEthernet.h" // https://github.com/ssilverman/QNEthernet
using namespace qindesign::network;
#include <AsyncWebServer_Teensy41.h>
AsyncWebServer server(80);
void handleRoot(AsyncWebServerRequest *request) {
char temp[BUFFER_SIZE];
memset(temp, 0, sizeof(temp));
strcat(temp, "<html><body>");
for (int i = 0; i < 11559; i++) {
strcat(temp, "0");
strcat(temp, "</body></html>");
request->send(200, "text/html", temp);
Serial.println(strlen(temp));
Ethernet.begin();
if (!Ethernet.waitForLocalIP(5000)) {
Serial.println(F("Failed to configure Ethernet"));
if (!Ethernet.linkStatus()) {
Serial.println(F("Ethernet cable is not connected."));
// Stay here forever
while (true) {
delay(1);
Serial.print(F("Connected! IP address:"));
Serial.println(Ethernet.localIP());
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request) {
handleRoot(request);
server.begin();
Serial.print(F("HTTP EthernetWebServer is @ IP : "));
