This test uses the optional quad spi flash on Teensy 4.1
https://github.com/pellepl/spiffs/wiki/Using-spiffs
https://github.com/pellepl/spiffs/wiki/FAQ
ATTENTION: Flash needs to be empty before first use of SPIFFS
Frank B, 2020
#include <spiffs.h>
static spiffs fs; //filesystem
char buf[512] = "Hello World! What a wonderful World :) Hello World! What a wonderful World :) Hello World! What a wonderful World :) Hello World! What a wonderful World :) Hello World! What a wonderful World :) Hello World! What a wonderful World :) Hello World! What a wonderful World :) Hello World! What a wonderful World :) Hello World! What a wonderful World :) Hello World! What a wonderful World :) Hello World! What a wonderful World :)";
int szLen = strlen( buf );
void test_spiffs_write() {
// Surely, I've mounted spiffs before entering here
spiffs_file fd = SPIFFS_open(&fs, "my_file", SPIFFS_CREAT | SPIFFS_TRUNC | SPIFFS_RDWR, 0);
if (SPIFFS_write(&fs, fd, (u8_t *)buf, szLen) < 0) Serial.printf("errno %i\n", SPIFFS_errno(&fs));
SPIFFS_close(&fs, fd);
SPIFFS_fflush(&fs, fd);
static void test_spiffs_read() {
spiffs_file fd = SPIFFS_open(&fs, "my_file", SPIFFS_RDWR, 0);
if (SPIFFS_read(&fs, fd, (u8_t *)buf, szLen) < 0) Serial.printf("errno %i\n", SPIFFS_errno(&fs));
static void test_spiffs_listDir() {
spiffs_DIR d;
struct spiffs_dirent e;
struct spiffs_dirent *pe = &e;
SPIFFS_opendir(&fs, "/", &d);
while ((pe = SPIFFS_readdir(&d, pe))) {
Serial.printf("%s [%04x] size:%i\n", pe->name, pe->obj_id, pe->size);
SPIFFS_closedir(&d);
while (!Serial);
#if 1
Serial.println("\n Enter 'y' in 6 seconds to format FlashChip - other to skip");
uint32_t pauseS = millis();
char chIn = 9;
while ( pauseS + 6000 > millis() && 9 == chIn ) {
if ( Serial.available() ) {
do {
if ( chIn != 'y' )
chIn = Serial.read();
Serial.read();
while ( Serial.available() );
if ( chIn == 'y' ) {
eraseFlashChip();
Serial.println("Mount SPIFFS:");
int res = my_spiffs_mount();
Serial.printf("mount res: %i\n", res);
#if 1
Serial.println("Write file:");
Serial.println(buf);
test_spiffs_write();
Serial.println("Directoy contents:");
test_spiffs_listDir();
memset(buf, 0, sizeof(buf)); //emtpy buffer
Serial.println("Read file:");
test_spiffs_read();
QSPI Flash Interface
#define LUT0(opcode, pads, operand) (FLEXSPI_LUT_INSTRUCTION((opcode), (pads), (operand)))
#define LUT1(opcode, pads, operand) (FLEXSPI_LUT_INSTRUCTION((opcode), (pads), (operand)) << 16)
#define CMD_SDR FLEXSPI_LUT_OPCODE_CMD_SDR
#define ADDR_SDR FLEXSPI_LUT_OPCODE_RADDR_SDR
#define READ_SDR FLEXSPI_LUT_OPCODE_READ_SDR
#define WRITE_SDR FLEXSPI_LUT_OPCODE_WRITE_SDR
#define DUMMY_SDR FLEXSPI_LUT_OPCODE_DUMMY_SDR
#define PINS1 FLEXSPI_LUT_NUM_PADS_1
#define PINS4 FLEXSPI_LUT_NUM_PADS_4
#define FLASH_MEMMAP 1 //Use memory-mapped access
static const void* extBase = (void*)0x70000000u;
static const uint32_t flashBaseAddr = 0x01000000u;
static uint32_t flashCapacity = 16u * 1024u * 1024u;
static char flashID[8];
void setupFlexSPI2() {
memset(flashID, 0, sizeof(flashID));
// cmd index 7 = read ID bytes SPI
FLEXSPI2_LUT28 = LUT0(CMD_SDR, PINS1, 0x9F) | LUT1(READ_SDR, PINS1, 1); //RAM, FLASH
// ----------------- FLASH only ----------------------------------------------
// cmd index 8 = read Status register #1 SPI
FLEXSPI2_LUT32 = LUT0(CMD_SDR, PINS1, 0x05) | LUT1(READ_SDR, PINS1, 1);
// cmd index 9 = read Status register #2 SPI
FLEXSPI2_LUT36 = LUT0(CMD_SDR, PINS1, 0x35) | LUT1(READ_SDR, PINS1, 1);
//cmd index 10 = exit QPI mode
FLEXSPI2_LUT40 = LUT0(CMD_SDR, PINS4, 0xFF);
//cmd index 11 = write enable QPI
FLEXSPI2_LUT44 = LUT0(CMD_SDR, PINS4, 0x06);
//cmd index 12 = sector erase
FLEXSPI2_LUT48 = LUT0(CMD_SDR, PINS4, 0x20) | LUT1(ADDR_SDR, PINS4, 24);
//cmd index 13 = page program
FLEXSPI2_LUT52 = LUT0(CMD_SDR, PINS4, 0x02) | LUT1(ADDR_SDR, PINS4, 24);
FLEXSPI2_LUT53 = LUT0(WRITE_SDR, PINS4, 1);
//cmd index 14 = set read parameters
FLEXSPI2_LUT56 = LUT0(CMD_SDR, PINS4, 0xc0) | LUT1(CMD_SDR, PINS4, 0x20);
//cmd index 15 = enter QPI mode
FLEXSPI2_LUT60 = LUT0(CMD_SDR, PINS1, 0x38);
void printStatusRegs() {
#if 0
uint8_t val;
flexspi_ip_read(8, flashBaseAddr, &val, 1 );
Serial.print("Status 1:");
Serial.printf(" %02X", val);
Serial.printf("\n");
flexspi_ip_read(9, flashBaseAddr, &val, 1 );
Serial.print("Status 2:");
Waits for busy bit = 0 (statusregister #1 )
Timeout is optional
bool waitFlash(uint32_t timeout = 0) {
uint8_t val;
uint32_t t = millis();
FLEXSPI_IPRXFCR = FLEXSPI_IPRXFCR_CLRIPRXF; // clear rx fifo
do {
if (timeout && (millis() - t > timeout)) return 1;
} while ((val & 0x01) == 1);
return 0;
void setupFlexSPI2Flash() {
// reset the chip
flexspi_ip_command(10, flashBaseAddr); //exit QPI
flexspi_ip_command(1, flashBaseAddr); //reset enable
flexspi_ip_command(2, flashBaseAddr); //reset
delayMicroseconds(50);
flexspi_ip_read(7, flashBaseAddr, flashID, sizeof(flashID) );
#if 1
Serial.print("ID:");
for (unsigned i = 0; i < sizeof(flashID); i++) Serial.printf(" %02X", flashID[i]);
printStatusRegs();
//TODO!!!!! set QPI enable bit in status reg #2 if not factory set!!!!!
// Serial.println("ENTER QPI MODE");
flexspi_ip_command(15, flashBaseAddr);
//patch LUT for QPI:
FLEXSPI2_LUT32 = LUT0(CMD_SDR, PINS4, 0x05) | LUT1(READ_SDR, PINS4, 1);
FLEXSPI2_LUT36 = LUT0(CMD_SDR, PINS4, 0x35) | LUT1(READ_SDR, PINS4, 1);
flexspi_ip_command(14, flashBaseAddr);
printStatusRegs();
void flexspi_ip_command(uint32_t index, uint32_t addr)
uint32_t n;
FLEXSPI2_IPCR0 = addr;
FLEXSPI2_IPCR1 = FLEXSPI_IPCR1_ISEQID(index);
FLEXSPI2_IPCMD = FLEXSPI_IPCMD_TRG;
while (!((n = FLEXSPI2_INTR) & FLEXSPI_INTR_IPCMDDONE)); // wait
if (n & FLEXSPI_INTR_IPCMDERR) {
Serial.printf("Error: FLEXSPI2_IPRXFSTS=%08lX\n", FLEXSPI2_IPRXFSTS);
FLEXSPI2_INTR = FLEXSPI_INTR_IPCMDDONE;
void flexspi_ip_read(uint32_t index, uint32_t addr, void *data, uint32_t length)
uint32_t n;
uint8_t *p = (uint8_t *)data;
const uint8_t *src;
FLEXSPI2_IPCR1 = FLEXSPI_IPCR1_ISEQID(index) | FLEXSPI_IPCR1_IDATSZ(length);
while (!((n = FLEXSPI2_INTR) & FLEXSPI_INTR_IPCMDDONE)) {
if (n & FLEXSPI_INTR_IPRXWA) {
//Serial.print("*");
if (length >= 8) {
length -= 8;
*(uint32_t *)(p + 0) = FLEXSPI2_RFDR0;
*(uint32_t *)(p + 4) = FLEXSPI2_RFDR1;
p += 8;
src = (const uint8_t *)&FLEXSPI2_RFDR0;
while (length > 0) {
length--;
*p++ = *src++;
FLEXSPI2_INTR = FLEXSPI_INTR_IPRXWA;
Serial.printf("Error: FLEXSPI2_IPRXFSTS=%08lX\r\n", FLEXSPI2_IPRXFSTS);
//printf(" FLEXSPI2_RFDR0=%08lX\r\n", FLEXSPI2_RFDR0);
//if (length > 4) Serial.printf(" FLEXSPI2_RFDR1=%08lX\n", FLEXSPI2_RFDR1);
//if (length > 8) Serial.printf(" FLEXSPI2_RFDR1=%08lX\n", FLEXSPI2_RFDR2);
//if (length > 16) Serial.printf(" FLEXSPI2_RFDR1=%08lX\n", FLEXSPI2_RFDR3);
*p++ = *src++;
length--;
if (FLEXSPI2_INTR & FLEXSPI_INTR_IPRXWA) FLEXSPI2_INTR = FLEXSPI_INTR_IPRXWA;
static void flexspi_ip_write(uint32_t index, uint32_t addr, const void *data, uint32_t length)
const uint8_t *src;
uint32_t n, wrlen;
src = (const uint8_t *)data;
if (n & FLEXSPI_INTR_IPTXWE) {
wrlen = length;
if (wrlen > 8) wrlen = 8;
if (wrlen > 0) {
//memcpy((void *)&FLEXSPI2_TFDR0, src, wrlen); !crashes sometimes!
//src += wrlen;
uint8_t *p = (uint8_t *) &FLEXSPI2_TFDR0;
for (unsigned i = 0; i < wrlen; i++) *p++ = *src++;
length -= wrlen;
FLEXSPI2_INTR = FLEXSPI_INTR_IPTXWE;
void eraseFlashChip() {
setupFlexSPI2();
setupFlexSPI2Flash();
waitFlash();
flexspi_ip_command(11, flashBaseAddr);
Serial.println("Erasing... (may take some time)");
FLEXSPI2_LUT60 = LUT0(CMD_SDR, PINS4, 0x60); //Chip erase
#ifdef FLASH_MEMMAP
arm_dcache_delete((void*)((uint32_t)extBase + flashBaseAddr), flashCapacity);
while (waitFlash(500)) {
Serial.print(".");
t = millis() - t;
Serial.printf("\nChip erased in %d seconds.\n", t / 1000);
SPIFFS interface
#define LOG_PAGE_SIZE 256
static u8_t spiffs_work_buf[LOG_PAGE_SIZE * 2];
static u8_t spiffs_fds[32 * 4];
static u8_t spiffs_cache_buf[(LOG_PAGE_SIZE + 32) * 4];
static const u32_t blocksize = 4096; //or 32k or 64k (set correct flash commands above)
static s32_t my_spiffs_read(u32_t addr, u32_t size, u8_t *dst) {
#ifdef FLASH_MEMMAP
memcpy(dst, (uint8_t *)extBase + addr, size);
#else
flexspi_ip_read(5, addr, dst, size);
return SPIFFS_OK;
static s32_t my_spiffs_write(u32_t addr, u32_t size, u8_t *src) {
flexspi_ip_command(11, flashBaseAddr); // write enable
flexspi_ip_write(13, addr, src, size); // write
#ifdef FLASH_MEMMAP
arm_dcache_delete((void*)((uint32_t)extBase + addr), size);
waitFlash();
return SPIFFS_OK;
static s32_t my_spiffs_erase(u32_t addr, u32_t size) {
int s = size;
while (s > 0) { //TODO: Is this loop needed, or is size max 4096?
flexspi_ip_command(11, flashBaseAddr); //write enable
flexspi_ip_command(12, addr);
#ifdef FLASH_MEMMAP
arm_dcache_delete((void*)((uint32_t)extBase + addr), blocksize);
addr += blocksize;
s -= blocksize;
waitFlash();
return SPIFFS_OK;
int my_spiffs_mount() {
setupFlexSPI2();
spiffs_config cfg;
cfg.phys_size = flashCapacity; // use 16 MB flash TODO use ID to get capacity
cfg.phys_addr = /* 0x70000000 + */flashBaseAddr; // start spiffs here (physical adress)
cfg.phys_erase_block = blocksize; //4K sectors
cfg.log_block_size = cfg.phys_erase_block; // let us not complicate things
cfg.log_page_size = LOG_PAGE_SIZE; // as we said
cfg.hal_read_f = my_spiffs_read;
cfg.hal_write_f = my_spiffs_write;
cfg.hal_erase_f = my_spiffs_erase;
int res = SPIFFS_mount(&fs,
&cfg,
spiffs_work_buf,
spiffs_fds,
sizeof(spiffs_fds),
spiffs_cache_buf,
sizeof(spiffs_cache_buf),
0);
return res;
