Designing a custom carrier PCB for a Teensy 4.1 + Ethernet project and want to sanity check a mechanical/electrical detail before I commit the layout.
My plan is:
Does this sound valid, or is there any reason the Ethernet pads on the Teensy 4.1 would not behave like normal plated through pads/vias?
I’m also trying to work out the mechanical side of this:
thepihut.com
My plan is:
- Teensy 4.1 mounted to the carrier PCB using female socket headers
- Ethernet PHY/RJ45 circuitry integrated directly onto the carrier PCB (so not using the standard Ethernet daughterboard PCB itself)
- Use the Teensy’s existing 6-pin Ethernet header pads to connect directly into a socket/header on the carrier PCB
- insert the male header pins from the underside of the Teensy
- solder them from the top side
- pins then protrude downward beneath the Teensy into a socket on the carrier board
- alignment of the Ethernet header relative to the two main Teensy header rows
- whether the header pins supplied with the Ethernet kit are actually long enough to reach a socket on the carrier PCB once the Teensy itself is socketed above the board
Ethernet Kit for Teensy 4.1
This kit has all the parts needed to connect to the Ethernet port on Teensy 4.1.
