From my limited research, and the datasheet, the bit-banding in M3 and M4 is not implemented in the M7 in Teensy 4.1?
A knowledgeable response, even if boolean, would be appreciated.
Thanks for the tip.
I don't have a mission-critical need for bit-band, but I combed through the INXRT 1060 datasheet, and while it has the bit alias addresses marked reserved, I was still unsure.
I will study the port registers you mentioned. While I am just a hobbyist, I have been bit-banging since the 80C51 days.
Those GPIO bit set, clear, toggle registers are used in the most efficient way if you use digitalWriteFast() or digitalToggleFast() in your code, and the pin number is a compile-time constant. No need to mess with the registers directly, unless you really prefer that over easily readable code.
