Teensy 4.1 Ethernet Error: client.availableForWrite
jimmie
Hello:
The attached code runs without problems on my Teensy 4.0. I switched to a Teensy 4.1 primarily because of its superior Ethernet. But the same EXACT code now is not running.
As you can see in my code, I changed the library to "NativeEthernet". The code compiles and the 4.1 does get an IP correctly.
But the code than ran before is now giving the following error:
Client not availableForWrite from
if (!client.availableForWrite())
When I comment out that code, I get the error "Error with writeBuffer available" from
if (!writeBuffer.available())
I would appreciate the community's help because I prefer to use the Teensy 4.1 from now on for its Ethernet.
  • RG15T41.ino
