Teensy 4.1 Flash pinout discrepancy
MarkW307
I have just been bringing up my custom Teensy 4.1 board for the first time and the bootloader is indicating a problem with the Flash (3 flashes on the bootloader LED). I started to double check everything and I found that the Windbond datasheet pinout and the Teensy 4.1 pinout for the Flash do not match. Can someone chime in with an explanation? Perhaps I purchased the wrong Flash chips or looked at the wrong datasheet, but what I have looked at shows D0 on pin 2 and D1 on Pin 5 whereas the Teensy schematic shows those two swapped. I have attached the relevant portions of my schematic, a picture of the Flash chip and a snip from the datasheet. The part number on the bag from Digikey indicates the part number is W25Q64JVXGIM which is in the 4x4mm package. Any help is most appreciated.
  • FTR_CB_101_Sch_pg2.pdf
  • FTR_CB_101_Sch_pg5.pdf
Don't confuse DO with D0 and DI with D1.
IO0 = D0, IO1 = D1, IO2 = D2, IO3 = D3.
The FTR_CB_101_Sch_pg5 document has the pins on the flash chip labelled incorrectly.
Thanks, jmarsh. I about laughed out loud when I saw your response since that is exactly what I did. Fortunately, I can jumper the two lines pretty easily.
