General_Hex
I was using my Teensy 4.1 with my robot project today when all of a sudden in the middle of running the robot stopped and the teensy started flashing. I thought it strange but as the code was no longer running I turned off the power supply and tried to connected to my computer when I noticed it is no longer coming up in the ArduinoIDE which it was just fine before this.
What to note:
I have previously burned a teensy 4.1 however with that one the red LED no longer turned on, it was very hot to the touch, and the reason of the burning was clear (due to me accidentally short circuiting one of the pins with 5V) so i think there is hope that this one isn't burned. So it would be a great help if you could tell me:
Thank you in advance because I have an upcoming competition this week and this just happened. I have a spare teensy however now I am scared to use the spare because I don't know what caused it and i'm scared it can happen again because i've used this code and robot a lot before and such a thing has never happened.
What to note:
- The red LED is flashing red 9 times before stopping and starting again 9 times
- i've tried the reset with 15 seconds to no avail
- the teensy is heating up significantly
- no wires or anything were changed or moved prior to this
- the robot is made of 3D printed material and nothing was near it when this occurred so static shock is unlikely
- this happened in the middle of the robot's movement
- the robot has been tested previously with no such problems
- was running at 600Mhz CPU speed
- no visible burns or deformities on the teensy
- Do you believe my teensy is burned?
- if yes what do you believe the cause to be?
- if no then how can I fix this issue?
- is there any further information I can provide you which may help?
