Teensy 4.1, FlexCAN_T4, Filtering
Harry888
Hello,
I my project I use FlexCAN_T4.
I would line FlexCAN_T4 to filter out all standard messages except 0x123 and 0x124.
But if I send another message, then 0x123 or 0x124 I receive them too.
How can I achieve that FlexCAN_T4 filter works.
Here is an example.
FlexCAN_T4 <CAN1, RX_SIZE_256, TX_SIZE_16> Can1 = FlexCAN_T4 <CAN1, RX_SIZE_256, TX_SIZE_16>();
CanMsg rxMsg;
void setup(void)
Can1.begin();
Can1.setBaudRate(250000);
Can1.setFIFOFilter(REJECT_ALL);
Can1.enableFIFO();
Can1.setFIFOFilterRange(0, 0x123, 0x124, STD);
if(Can1.read(rxMsg))
Serial.printf("Msg.ID 0x%06X\n", rxMsg.id);
Hello,
Here is an example.
CanMsg rxMsg;
void setup(void)
Can1.begin();
Can1.enableFIFO();
I've never played with filter ranges. Only message ID filters. But I want to help you so this is my guess of what would work.
Can't guarantee anything.
#include <FlexCAN_T4.h>
FlexCAN_T4<CAN1, RX_SIZE_256, TX_SIZE_16> Can1;
CAN_message_t rxMsg;
void setup(void)
  Can1.begin();
  // Reject all messages
  // Enable FIFO
  Can1.enableFIFO();
  // Allow only messages with IDs 0x123 and 0x124
  Can1.setFIFOFilter(0, 0x123, STD); // Filter for 0x123
  Can1.setFIFOFilter(1, 0x124, STD); // Filter for 0x124
  // Optionally: Set up interrupt or polling
  // Polling the CAN bus for messages
  if (Can1.read(rxMsg))
    Serial.printf("Msg.ID: 0x%03X\n", rxMsg.id);
Hallo,
thank you for a quick response.
I have pasted the code in a new project. With PCAN-View I can send every MsgID I wish.
here is the output of the program.
Here is the program output
09:48:12.157 -> Msg.ID: 0x100
09:48:13.227 -> Msg.ID: 0x101
09:48:15.976 -> Msg.ID: 0x104
09:48:17.303 -> Msg.ID: 0x113
09:48:19.409 -> Msg.ID: 0x123
09:48:21.772 -> Msg.ID: 0x124
09:48:23.721 -> Msg.ID: 0x125
09:48:24.981 -> Msg.ID: 0x131
09:48:26.534 -> Msg.ID: 0x132
It seems like the filter is not working, or I do something wrong
I solved it.
First enable FIFO then SetFilters....
Here is the solution
void setup(void)
Can1.begin();
// Enable FIFO
Can1.enableFIFO();
