Teensy 4.1 freezing closing files on sd card with sdfat
Hello, I have a bug with the teensy 4.1 I'm using. It always freezes when it has to close a file.
C++:
void ChangeSettings(int newSpeed, int newPower) {
  dbSerialPrintln(newSpeed);
  dbSerialPrintln(newPower);
  // Initialize the SD card
  if (!sd.begin(SD_CONFIG)) {
    dbSerialPrintln("Sd couldnt be initialized");
    return;
  for(int i=0;i<100;i++)
    char settingsFileName[10];
    sprintf(settingsFileName, "%d.nc", i);  // Create the filename as "0.nc", "1.nc", "2.nc", etc.
    dbSerialPrintln(settingsFileName);
    ChangeSettingsFile(settingsFileName, newSpeed, newPower);
  char defaultFileName[] = "sd_default.nc";
  ChangeSettingsFile(defaultFileName, newSpeed, newPower);
  progressBar.setValue(100);
  dbSerialPrintln("G-code modification complete.");
void ChangeSettingsFile(char settingsFileName[], int newSpeed, int newPower){
  settingsFile = sd.open(settingsFileName, FILE_READ);
  if (!settingsFile) {
    dbSerialPrintln("Error opening the G-code file.");
    return;
  int lineCount = 0;
  String fileContent = "";
  while (settingsFile.available()) {
    String line = settingsFile.readStringUntil('\n');
    if (line.indexOf("F") >= 0 && lineCount != 0) {
      line = modifySpeed(line, newSpeed);
      dbSerialPrintln("Modifying speed with line : ");
      dbSerialPrintln(line);
    if (line.indexOf("S") >= 0 && lineCount != 0) {
      line = modifyPower(line, newPower);
      dbSerialPrintln("Modifying power with line : ");
    fileContent += line + "\n";
    lineCount++;
  dbSerialPrintln("closing the file");
  settingsFile.close();
  delay(50);
  //sd.remove(settingsFileName);
  // if (!sd.exists(settingsFileName)) {
  //   dbSerialPrintln("File does not exist, attempting to create it.");
  dbSerialPrintln("test");
  settingsFile = sd.open(settingsFileName, O_WRITE | O_CREAT | O_TRUNC);
  dbSerialPrintln("passed");
    dbSerialPrintln("Error opening the file for writing.");
    return;
  settingsFile.print(fileContent);
  uint32_t progressBarValue = 0;
  progressBar.getValue(&progressBarValue);
  int progressBarValueInt = (int)progressBarValue;
  progressBar.setValue(min(progressBarValueInt+1,100));
// Function to modify the laser speed (F value)
String modifySpeed(String line, int newSpeed) {
  String newLine = line;
  int index = line.indexOf("F");
  if (index >= 0) {
    newLine = line.substring(0, index + 1) + String(newSpeed);  // Replace the speed value
  return newLine;
// Function to modify the laser power (S value)
String modifyPower(String line, int newPower) {
  int index = line.indexOf("S");
  if (index >= 0) {
    newLine = line.substring(0, index + 1) + String(newPower);  // Replace the power value
  return newLine;
Here is the code that I use, it's only a part of it, it worked well and I don't know why but it just stopped working. I changed sd card and the sd is not the problem. I freezes when it has to close the file. Does anyone have any idea on what could be happening? Thank very much in advance. what is very very strange is that it perfectly works whenever I totally isolate the code from the main one. Even with all the main libraries imported. I'm also using teensythreads. Is it possible that it causes some issues?
Ok i found the problem, for the people wondering, SdFat is absolutely not thread safe and I used threads so be careful not having a thread running at the same time as your sd code
