The library functions for Teensy 4.1 GPIOs, e.g. in "digital.c" do NOT support a glitch free configuration.
Use Case
I want to generate an nRES signal (low active, inactive is high) for an external board.
If I reset the MCU, e.g. via software, as a command, BTW: I do via:
the nRES signal (GPIO output) generates a low pulse glitch (and resets also the external board).
Reason
When you reset MCU - all signals, GPIOs, become floating, until they are configured again, here as Output.
But it is NOT POSSIBLE to set the GPIO output register BEFORE you configure GPIO as output.
Due to fact that output register is reset (has value 0), a GPIO config for output generates a tiny low pulse before GPIO is set to high (as inactive), a glitch.
The function
which sets the GPIO output value (low or high), can ONLY be called AFTER GPIO is set to output:
This generates a transition from (MCU reset) value low to high (set as default inactive in a subsequent function call).
This happens on every MCU reset and resets also my external board - even you have a pull-up there in order to deal with the floating signal during reset.
If you do this - which FAILS completely:
it does not set the GPIO output register - instead: it uses the value as pull-up or pull-down config value for an input (pin is still an input when this call is done).
You do not have any support to preset the output register for GPIO before you bring it into output mode.
Solution
Create a new function which has this code:
Now you SHOULD do:
With an external pull-up (internal does not help, it does not work), this signal is now glitch free.
Why the LIB functions are not coded in a way that you can set GPIO output before you enable as output?
(this would be professional and the right way to do, common "standard" for me)
Use Case
////NVIC_SystemReset(); //CMSIS files do not work!
SCB_AIRCR = 0x05FA0004;
Reason
The function
void digitalWrite(uint8_t pin, uint8_t val)
digitalWrite(2, arduino::HIGH);
pinMode(2, arduino::OUTPUT);
Solution
void GPIO_setOutValue(uint8_t pin, uint8_t val)
const struct digital_pin_bitband_and_config_table_struct *p;
uint32_t mask;
if (pin >= CORE_NUM_DIGITAL) return;
p = digital_pin_to_info_PGM + pin;
mask = p->mask;
// pin is configured for output mode
if (val) {
*(p->reg + 0x21) = mask; // set register
*(p->reg + 0x22) = mask; // clear register
Now you SHOULD do:
//configure nRES output signal
GPIO_setOutValue(2, arduino::HIGH);
//drive high as default
////digitalWrite(2, arduino::HIGH);
