Teensy 4.1 GPIO protection
bdoan
I am using a 4.1 as the controller in a test fixture.
I want to protect the GPIO pins against worst case faults (short to ground or short to 5V)
If I simply build out the output pins with 1.5K to limit the current, is that sufficient?
Absolute maximum rated voltage for T4.1 pins is 3.6V. if you expect the possibility of 5V, you will need something more to limit the voltage closer to 3.3V, like a zener or schottky clamp diode.
Something like this:-
But with Schottky diodes, not standard ones. You might also need to protect the 3.3V rail from rising above 4V with a zener clamp as well.
