I'm working on using a 4.1 to drive RC servo using PWM. For simplicity I would like to use GPT2, with COMPARE_1 resetting the count, and COMPARE_2 and COMPARE_3 giving me 2 channels of PWM. I have used manitou48's "gptisr3" as a starting point. I want to set OP2 and OP3 on the start of a cycle and clear them on the compare event.
I have managed to get the general approach working, with the outputs toggling on the compares using GPT_CR_OMx(1). However, when I replace the (1) with (2) to clear the output on a match, it stays low (and if I use (3) to set it, it stays high). I cannot find anywhere in the GPT part of the manual that indicates how I can reset these pins. I can get the required result by using GPIO pins as in the code, but would like to be totally self-contained in my application.
Any pointers would be appreciated.
const uint32_t maxPos = 0x000493e0;
const uint32_t minPos = 0x000249f0;
uint32_t pos1;
uint32_t pos2;
void gpt2_isr()
uint32_t srtmp = GPT2_SR;
// GPT2_SR &= 0x3F; // clear all set bits
if (srtmp & GPT_SR_OF1)
digitalWriteFast(3, 1 - digitalReadFast(3));
digitalWriteFast(4, HIGH);
digitalWriteFast(5, HIGH);
GPT2_SR &= GPT_SR_OF1; // clear all set bits
if (srtmp & GPT_SR_OF2)
digitalWriteFast(4, LOW);
GPT2_SR &= GPT_SR_OF2;
if (srtmp & GPT_SR_OF3)
digitalWriteFast(5,LOW);
GPT2_SR &= GPT_SR_OF3;
asm volatile("dsb");
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(13, OUTPUT);
CCM_CSCMR1 &= ~CCM_CSCMR1_PERCLK_CLK_SEL; // turn off 24MHz mode
CCM_CCGR0 |= CCM_CCGR0_GPT2_BUS(CCM_CCGR_ON) ; // enable GPT2 module
//configure GPT2 for test
GPT2_CR = 0; //clear the control register, FRR = 0 means restart after Compare
GPT2_SR = 0x3F; //clear all prior status
GPT2_PR = 0; //prescale register set divide by 1
GPT2_CR |= GPT_CR_CLKSRC(1); //clock selection #1 (peripheral clock = 150 MHz)
GPT2_CR |= GPT_CR_ENMOD; //reset count to zero before enabling
GPT2_CR |= GPT_CR_OM3(0b010); // mode 2 - clear output on match
GPT2_CR |= GPT_CR_OM2(0b011); // mode 3 - set output on match
GPT2_OCR1 = 0x002dc6c0; //Compare1 value = 20 mS at 150 MHz
GPT2_OCR2 = 0x000249f0; //Compare2 value = 1 mS at150 MHz
GPT2_OCR3 = 0x000493e0; //Compare3 value = 2 mS at 150 MHz
GPT2_IR = GPT_IR_OF1IE; //enable interrupt on full count flag
GPT2_CR |= GPT_CR_EN; //enable GPT2
//configure Teensy pin 16, 17 as GPT2 outputs
IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_07 = 8; // GPT2 Compare3 is now output on pin 16
IOMUXC_SW_MUX_CTL_PAD_GPIO_AD_B1_06 = 8; // GPT2 Compare2 is now output on pin 17
attachInterruptVector(IRQ_GPT2, gpt2_isr);
NVIC_ENABLE_IRQ(IRQ_GPT2);
digitalWrite(13, !digitalRead(13));
delay(200);
