Teensy 4.1 H.O.T.A.S Joystick and Throttle
airely
I am a complete newbie that decided to be ambitious and take on this new project.
I would like to use a HOTAS joystick and throttle to control an RC plane. I have seen people do it on YouTube but I don’t know the exact logic behind it. I was able to get my Logitech X56 to communicate to my teensy 4.1 through a usb hub; however it will not talk to the both the throttle and the joystick at the same time. My assumption is that the joystick example code in the Arduino IDE is finding the first device (joystick or throttle) and reading the inputs from that.
Any help with understanding how to get it to read inputs from both devices as well as how to convert those readings to send to my transmitter?
I have a: logitech Saitek G Pro Flight X56 Rhino HOTAS (Renewed) which I tested on a T3.6 a very long time ago. Should be able to work on a T4.1 no problem. Don't see a sketch that you are testing with so hard to know what the issue is.
Look at the joystick example you will see you will need a instance of a USB hub 2 joystick instacnes for the throttle and the joystick. The beginning has the following, suggest you give the example a try.
C++:
#include "USBHost_t36.h"
USBHost myusb;
USBHub hub1(myusb);
USBHIDParser hid1(myusb);
#define COUNT_JOYSTICKS 4
JoystickController joysticks[COUNT_JOYSTICKS] = {
  JoystickController(myusb), JoystickController(myusb),
int user_axis[64];
uint32_t buttons_prev = 0;
USBDriver *drivers[] = {&hub1, &joysticks[0], &joysticks[1], &joysticks[2], &joysticks[3], &hid1};
#define CNT_DEVICES (sizeof(drivers)/sizeof(drivers[0]))
const char * driver_names[CNT_DEVICES] = {"Hub1", "joystick[0D]", "joystick[1D]", "joystick[2D]", "joystick[3D]",  "HID1"};
bool driver_active[CNT_DEVICES] = {false, false, false, false};
// Lets also look at HID Input devices
USBHIDInput *hiddrivers[] = {&joysticks[0], &joysticks[1], &joysticks[2], &joysticks[3]};
#define CNT_HIDDEVICES (sizeof(hiddrivers)/sizeof(hiddrivers[0]))
const char * hid_driver_names[CNT_DEVICES] = {"joystick[0H]", "joystick[1H]", "joystick[2H]", "joystick[3H]"};
bool hid_driver_active[CNT_DEVICES] = {false};
bool show_changed_only = false;
uint8_t joystick_left_trigger_value[COUNT_JOYSTICKS] = {0};
uint8_t joystick_right_trigger_value[COUNT_JOYSTICKS] = {0};
uint64_t joystick_full_notify_mask = (uint64_t) - 1;
int psAxis[64];
I see the same code in the joystick example under USBHost t36. Im not sure what you mean by 2 instances? The issue I am having is that when I connect my joystick and throttle to the USB hub it is only detecting the device that is closest to the first port. For example if I connect the joystick to port 2 and the throttle to port 3, only the joystick will be detected and have its values read. As another example: if I connect the throttle to port 3 and the joystick to port 4, only the throttle will be detected. I have tried 2 different powered USB hubs (3.0 and 2.0) and both have the same result. My assumption is: the program or the board is only searching for the first device and once it finds that device it begins reading values versus searching for all devices and reading them both.
See the example code below.
// Simple test of USB Host Joystick
// This example is in the public domain
USBHost myusb;
USBHub hub1(myusb);
int user_axis[64];
int psAxis[64];
// Setup
  Serial1.begin(2000000);
  while (!Serial) ; // wait for Arduino Serial Monitor
  Serial.println("\n\nUSB Host Joystick Testing");
  myusb.begin();
// loop
  myusb.Task();
  PrintDeviceListChanges();
  if (Serial.available()) {
    int ch = Serial.read(); // get the first char.
    while (Serial.read() != -1) ;
    if ((ch == 'b') || (ch == 'B')) {
      Serial.println("Only notify on Basic Axis changes");
      for (int joystick_index = 0; joystick_index < COUNT_JOYSTICKS; joystick_index++)
        joysticks[joystick_index].axisChangeNotifyMask(0x3ff);
    } else if ((ch == 'f') || (ch == 'F')) {
      Serial.println("Only notify on Full Axis changes");
        joysticks[joystick_index].axisChangeNotifyMask(joystick_full_notify_mask);
      if (show_changed_only) {
        Serial.println("\n*** Show All fields mode ***");
        show_changed_only = true;
        Serial.println("\n*** Show only changed fields mode ***");
  for (int joystick_index = 0; joystick_index < COUNT_JOYSTICKS; joystick_index++) {
    if (joysticks[joystick_index].available()) {
      uint64_t axis_mask = joysticks[joystick_index].axisMask();
      uint64_t axis_changed_mask = joysticks[joystick_index].axisChangedMask();
      uint32_t buttons = joysticks[joystick_index].getButtons();
      Serial.printf("Joystick(%d): buttons = %x", joystick_index, buttons);
      //Serial.printf(" AMasks: %x %x:%x", axis_mask, (uint32_t)(user_axis_mask >> 32), (uint32_t)(user_axis_mask & 0xffffffff));
      //Serial.printf(" M: %lx %lx", axis_mask, joysticks[joystick_index].axisChangedMask());
        for (uint8_t i = 0; axis_changed_mask != 0; i++, axis_changed_mask >>= 1) {
          if (axis_changed_mask & 1) {
            Serial.printf(" %d:%d", i, joysticks[joystick_index].getAxis(i));
        for (uint8_t i = 0; axis_mask != 0; i++, axis_mask >>= 1) {
          if (axis_mask & 1) {
      uint8_t ltv;
      uint8_t rtv;
      for (uint8_t i = 0; i<64; i++) {
          psAxis[i] = joysticks[joystick_index].getAxis(i);
      switch (joysticks[joystick_index].joystickType()) {
        default:
        case JoystickController::PS4:
          printAngles();
          ltv = joysticks[joystick_index].getAxis(3);
          rtv = joysticks[joystick_index].getAxis(4);
          if ((ltv != joystick_left_trigger_value[joystick_index]) || (rtv != joystick_right_trigger_value[joystick_index])) {
            joystick_left_trigger_value[joystick_index] = ltv;
            joystick_right_trigger_value[joystick_index] = rtv;
            joysticks[joystick_index].setRumble(ltv, rtv);
        case JoystickController::PS3:
          ltv = joysticks[joystick_index].getAxis(18);
          rtv = joysticks[joystick_index].getAxis(19);
            joysticks[joystick_index].setRumble(ltv, rtv,50);
        case JoystickController::XBOXONE:
        case JoystickController::XBOX360:
            Serial.printf(" Set Rumble %d %d", ltv, rtv);
      if (buttons != buttons_prev) {
        if (joysticks[joystick_index].joystickType() == JoystickController::PS3) {
          //joysticks[joystick_index].setLEDs((buttons >> 12) & 0xf); //  try to get to TRI/CIR/X/SQuare
          uint8_t leds = 0;
          if (buttons & 0x8000) leds = 1;   //Srq
          if (buttons & 0x2000) leds = 2;   //Cir
          if (buttons & 0x1000) leds = 4;   //Tri
          if (buttons & 0x4000) leds = 8;   //X  //Tri
          joysticks[joystick_index].setLEDs(leds);
          uint8_t lr = (buttons & 1) ? 0xff : 0;
          uint8_t lg = (buttons & 2) ? 0xff : 0;
          uint8_t lb = (buttons & 4) ? 0xff : 0;
          joysticks[joystick_index].setLEDs(lr, lg, lb);
          buttons_prev = buttons;
      joysticks[joystick_index].joystickDataClear();
// Show when devices are added or removed
void PrintDeviceListChanges() {
  for (uint8_t i = 0; i < CNT_DEVICES; i++) {
    if (*drivers[i] != driver_active[i]) {
      if (driver_active[i]) {
        Serial.printf("*** Device %s - disconnected ***\n", driver_names[i]);
        driver_active[i] = false;
        Serial.printf("*** Device %s %x:%x - connected ***\n", driver_names[i], drivers[i]->idVendor(), drivers[i]->idProduct());
        driver_active[i] = true;
        const uint8_t *psz = drivers[i]->manufacturer();
        if (psz && *psz) Serial.printf("  manufacturer: %s\n", psz);
        psz = drivers[i]->product();
        if (psz && *psz) Serial.printf("  product: %s\n", psz);
        psz = drivers[i]->serialNumber();
        if (psz && *psz) Serial.printf("  Serial: %s\n", psz);
  for (uint8_t i = 0; i < CNT_HIDDEVICES; i++) {
    if (*hiddrivers[i] != hid_driver_active[i]) {
      if (hid_driver_active[i]) {
        Serial.printf("*** HID Device %s - disconnected ***\n", hid_driver_names[i]);
        hid_driver_active[i] = false;
        Serial.printf("*** HID Device %s %x:%x - connected ***\n", hid_driver_names[i], hiddrivers[i]->idVendor(), hiddrivers[i]->idProduct());
        hid_driver_active[i] = true;
        const uint8_t *psz = hiddrivers[i]->manufacturer();
        psz = hiddrivers[i]->product();
        psz = hiddrivers[i]->serialNumber();
@airely
Unfortunately my main computer is down and all my Teensies are packed away - probably be another day or two before I can give this a try.
I am still not clear what sketch you are using. But to explain a bit - its been a while since I played with USBhost, If we look at the joystick sketch:
USBHost myusb;
USBHub hub1(myusb);
This is setting up a "instance" of a attached USB Hub letting the lib know that you have a hub attached. Since you also need to let it know to parse HID messages:
Setting `#define COUNT_JOYSTICKS 4` is letting the sketch know that you can have 4 joysticks attached which in the following line setups the 4 controlloers
The next lines configure the drivers:
1 instance of a USB Hub, 4 instances of Joystick controllers and 1 for a hid device.
So I am not sure why both are not being picked up. I have had multiple joysticks attached without issue. As I said I wont be able to check it out until next week. But it should work.
