Teensy 4.1 hardware accelerated CRC32.
samm_flynn
Is there any library, with hardware acceleration? for teensy 4.1
I have been using FastCRC , from the src code I think it has hw acceleration for teensy 3.0 / 3.1 / 3.2 / 3.5 / 3.6.
Is there something similar for teensy 4.1?
I was hoping to get sub 2ms calculation, which would make other parts of my code much simpler.
C++:
#include <Arduino.h>
#include <FastCRC.h>
#include <inttypes.h>
#define N 16384
#define M 6
size_t ss = 5;
DMAMEM float arr[N][M];  // Large float array
bool hasRun = false;
  Serial.begin(115200);  // Initialize serial communication
  uint32_t t_start = micros();
  for (int i = 0; i < N; i++)
    for (int j = 0; j < M; j++)
      arr[i][j] = (i * M + j);  // Matches np.arange()
  Serial.printf("Time taken to loop through all the elements: %u microSeconds\n", micros() - t_start);
  if (Serial.dtr())
    if (!hasRun)
      FastCRC32 CRC32;
      uint32_t crcData = CRC32.crc32(reinterpret_cast<uint8_t*>(arr), sizeof(arr));
      hasRun = true;  // Set flag to prevent multiple runs during connection
      Serial.printf("Time taken to generate CRC32 : %u microSeconds\n", micros() - t_start);
      Serial.printf("CRC32 of float array: 0x%08X\n", crcData);
    hasRun = false;
T4 has a data co-processor (DCP) to support various encryption, etc. I don't know of any easy-to-use library, but the link below is to a sketch by user @manitou from the early days of T4 beta testing. It does CRC32 calculation and reports processing rate of close to 400 MB/sec. I tried 128 KB and it reports 383 us, well under your goal of 2 ms.
thanks @joepasquariello , for me it worked for 5x5 float arrays, didn't work for anything larger for some reason, the codes are shared below if anyone is interested.
Python code for checking ground truth -
Python:
import numpy as np
import crcmod
# Create CRC-32/MPEG-2 function using crcmod
compute_crc32_mpeg2 = crcmod.mkCrcFun(0x104C11DB7, initCrc=0xFFFFFFFF, rev=False, xorOut=0x00000000)
if __name__ == "__main__":
    N, M = 5, 5  # Same as C++
    float_arr = np.arange(N * M, dtype=np.float32).reshape(N, M)
    crc_float_array = compute_crc32_mpeg2(float_arr.tobytes())
    print(f"python : CRC32/MPEG-2 of float array: 0x{crc_float_array:08X}")
    message = b"123456781011"
    crc_value = compute_crc32_mpeg2(message)
    # print(f"CRC32 of {message} : 0x{crc_value:08X}")
teensy code -
C++:
#include "dcp_util.h"
#define N 5
#define M 5
DMAMEM float arr[N][M];  // Large float array in DMA memory
  while (!Serial)
      arr[i][j] = (float)(i * M + j);
  uint32_t t_start, crcData;
  t_start = micros();
  crcData = compute_crc32(reinterpret_cast<uint8_t*>(arr), sizeof(arr));
  Serial.printf("Time taken to generate CRC32 (float array): %u microSeconds\n", micros() - t_start);
dcp_util.h -
C++:
#ifndef DCP_UTIL_H
#define DCP_UTIL_H
// T4 DCP  AES SHA CRC32
//  tests on channel 0  non-blocking  no context switching
// https://forum.pjrc.com/threads/54711-Teensy-4-0-First-Beta-Test?p=197722&viewfull=1#post197722
// InputOutput  or just Input
#define __IO volatile
#define __I volatile
#define DCP_CH0SEMA_VALUE_MASK (0xFF0000U)
#define DCP_CH0STAT_ERROR_CODE_MASK (0xFF0000U)
#define DCP_HASH_BLOCK_SIZE 128
#define DCP_STAT_OTP_KEY_READY_MASK (0x10000000U)
#define DCP_KEY_INDEX_MASK (0x30U)
#define DCP_KEY_INDEX_SHIFT (4U)
#define DCP_KEY_INDEX(x) (((uint32_t)(((uint32_t)(x)) << DCP_KEY_INDEX_SHIFT)) & DCP_KEY_INDEX_MASK)
enum _generic_status
  kStatus_Success = 0,
  kStatus_Fail = 1,
  kStatus_ReadOnly = 2,
  kStatus_OutOfRange = 3,
  kStatus_InvalidArgument = 4,
  kStatus_Timeout = 5,
  kStatus_DCP_Again = 6,
typedef enum _dcp_ch_enable
  kDCP_chDisable = 0U,    /*!< DCP channel disable */
  kDCP_ch0Enable = 1U,    /*!< DCP channel 0 enable */
  kDCP_ch1Enable = 2U,    /*!< DCP channel 1 enable */
  kDCP_ch2Enable = 4U,    /*!< DCP channel 2 enable */
  kDCP_ch3Enable = 8U,    /*!< DCP channel 3 enable */
  kDCP_chEnableAll = 15U, /*!< DCP channel enable all */
} _dcp_ch_enable_t;
typedef enum _dcp_channel
  kDCP_Channel0 = (1u << 16), /*!< DCP channel 0. */
  kDCP_Channel1 = (1u << 17), /*!< DCP channel 1. */
  kDCP_Channel2 = (1u << 18), /*!< DCP channel 2. */
  kDCP_Channel3 = (1u << 19), /*!< DCP channel 3. */
} dcp_channel_t;
typedef enum _dcp_key_slot
  kDCP_KeySlot0 = 0U,     /*!< DCP key slot 0. */
  kDCP_KeySlot1 = 1U,     /*!< DCP key slot 1. */
  kDCP_KeySlot2 = 2U,     /*!< DCP key slot 2.*/
  kDCP_KeySlot3 = 3U,     /*!< DCP key slot 3. */
  kDCP_OtpKey = 4U,       /*!< DCP OTP key. */
  kDCP_OtpUniqueKey = 5U, /*!< DCP unique OTP key. */
  kDCP_PayloadKey = 6U,   /*!< DCP payload key. */
} dcp_key_slot_t;
typedef enum _dcp_swap
  kDCP_NoSwap = 0x0U,
  kDCP_KeyByteSwap = 0x40000U,
  kDCP_KeyWordSwap = 0x80000U,
  kDCP_InputByteSwap = 0x100000U,
  kDCP_InputWordSwap = 0x200000U,
  kDCP_OutputByteSwap = 0x400000U,
  kDCP_OutputWordSwap = 0x800000U,
} dcp_swap_t;
typedef enum _dcp_hash_algo_t
  kDCP_Sha1,   /*!< SHA_1 */
  kDCP_Sha256, /*!< SHA_256 */
  kDCP_Crc32,  /*!< CRC_32 */
} dcp_hash_algo_t;
enum _dcp_hash_digest_len
  kDCP_OutLenSha1 = 20u,
  kDCP_OutLenSha256 = 32u,
  kDCP_OutLenCrc32 = 4u,
enum _dcp_work_packet_bit_definitions
  kDCP_CONTROL0_DECR_SEMAPHOR = 1u << 1, /* DECR_SEMAPHOR */
  kDCP_CONTROL0_ENABLE_HASH = 1u << 6,   /* ENABLE_HASH */
  kDCP_CONTROL0_HASH_INIT = 1u << 12,    /* HASH_INIT */
  kDCP_CONTROL0_HASH_TERM = 1u << 13,    /* HASH_TERM */
  kDCP_CONTROL1_HASH_SELECT_SHA256 = 2u << 16,
  kDCP_CONTROL1_HASH_SELECT_SHA1 = 0u << 16,
  kDCP_CONTROL1_HASH_SELECT_CRC32 = 1u << 16,
typedef struct _dcp_hash_ctx_t
  uint32_t x[58];
} dcp_hash_ctx_t;
typedef union _dcp_hash_block
  uint32_t w[DCP_HASH_BLOCK_SIZE / 4]; /*!< array of 32-bit words */
  uint8_t b[DCP_HASH_BLOCK_SIZE];      /*!< byte array */
} dcp_hash_block_t;
typedef enum _dcp_hash_algo_state
  kDCP_StateHashInit = 1u, /*!< Init state. */
  kDCP_StateHashUpdate,    /*!< Update state. */
} dcp_hash_algo_state_t;
typedef struct _dcp_handle
  dcp_channel_t channel;  /*!< Specify DCP channel. */
  dcp_key_slot_t keySlot; /*!< For operations with key (such as AES encryption/decryption), specify DCP key slot. */
  uint32_t swapConfig;    /*!< For configuration of key, input, output byte/word swap options */
  uint32_t keyWord[4];
  uint32_t iv[4];
} dcp_handle_t;
typedef struct _dcp_hash_ctx_internal
  dcp_hash_block_t blk;        /*!< memory buffer. only full blocks are written to DCP during hash updates */
  size_t blksz;                /*!< number of valid bytes in memory buffer */
  dcp_hash_algo_t algo;        /*!< selected algorithm from the set of supported algorithms */
  dcp_hash_algo_state_t state; /*!< finite machine state of the hash software process */
  uint32_t fullMessageSize;    /*!< track message size */
  uint32_t ctrl0;              /*!< HASH_INIT and HASH_TERM flags */
  uint32_t runningHash[9];     /*!< running hash. up to SHA-256 plus size, that is 36 bytes. */
  dcp_handle_t *handle;
} dcp_hash_ctx_internal_t;
typedef struct _dcp_work_packet
  uint32_t nextCmdAddress;
  uint32_t control0;
  uint32_t control1;
  uint32_t sourceBufferAddress;
  uint32_t destinationBufferAddress;
  uint32_t bufferSize;
  uint32_t payloadPointer;
  uint32_t status;
} dcp_work_packet_t;
/** DCP - Register Layout Typedef */
typedef struct
  __IO uint32_t CTRL; /**< DCP control register 0, offset: 0x0 */
  uint8_t RESERVED_0[12];
  __IO uint32_t STAT; /**< DCP status register, offset: 0x10 */
  uint8_t RESERVED_1[12];
  __IO uint32_t CHANNELCTRL; /**< DCP channel control register, offset: 0x20 */
  uint8_t RESERVED_2[12];
  __IO uint32_t CAPABILITY0; /**< DCP capability 0 register, offset: 0x30 */
  uint8_t RESERVED_3[12];
  __I uint32_t CAPABILITY1; /**< DCP capability 1 register, offset: 0x40 */
  uint8_t RESERVED_4[12];
  __IO uint32_t CONTEXT; /**< DCP context buffer pointer, offset: 0x50 */
  uint8_t RESERVED_5[12];
  __IO uint32_t KEY; /**< DCP key index, offset: 0x60 */
  uint8_t RESERVED_6[12];
  __IO uint32_t KEYDATA; /**< DCP key data, offset: 0x70 */
  uint8_t RESERVED_7[12];
  __I uint32_t PACKET0; /**< DCP work packet 0 status register, offset: 0x80 */
  uint8_t RESERVED_8[12];
  __I uint32_t PACKET1; /**< DCP work packet 1 status register, offset: 0x90 */
  uint8_t RESERVED_9[12];
  __I uint32_t PACKET2; /**< DCP work packet 2 status register, offset: 0xA0 */
  uint8_t RESERVED_10[12];
  __I uint32_t PACKET3; /**< DCP work packet 3 status register, offset: 0xB0 */
  uint8_t RESERVED_11[12];
  __I uint32_t PACKET4; /**< DCP work packet 4 status register, offset: 0xC0 */
  uint8_t RESERVED_12[12];
  __I uint32_t PACKET5; /**< DCP work packet 5 status register, offset: 0xD0 */
  uint8_t RESERVED_13[12];
  __I uint32_t PACKET6; /**< DCP work packet 6 status register, offset: 0xE0 */
  uint8_t RESERVED_14[28];
  __IO uint32_t CH0CMDPTR; /**< DCP channel 0 command pointer address register, offset: 0x100 */
  uint8_t RESERVED_15[12];
  __IO uint32_t CH0SEMA; /**< DCP channel 0 semaphore register, offset: 0x110 */
  uint8_t RESERVED_16[12];
  __IO uint32_t CH0STAT; /**< DCP channel 0 status register, offset: 0x120 */
  uint8_t RESERVED_17[12];
  __IO uint32_t CH0OPTS; /**< DCP channel 0 options register, offset: 0x130 */
  uint8_t RESERVED_18[12];
  __IO uint32_t CH1CMDPTR; /**< DCP channel 1 command pointer address register, offset: 0x140 */
  uint8_t RESERVED_19[12];
  __IO uint32_t CH1SEMA; /**< DCP channel 1 semaphore register, offset: 0x150 */
  uint8_t RESERVED_20[12];
  __IO uint32_t CH1STAT; /**< DCP channel 1 status register, offset: 0x160 */
  uint8_t RESERVED_21[12];
  __IO uint32_t CH1OPTS; /**< DCP channel 1 options register, offset: 0x170 */
  uint8_t RESERVED_22[12];
  __IO uint32_t CH2CMDPTR; /**< DCP channel 2 command pointer address register, offset: 0x180 */
  uint8_t RESERVED_23[12];
  __IO uint32_t CH2SEMA; /**< DCP channel 2 semaphore register, offset: 0x190 */
  uint8_t RESERVED_24[12];
  __IO uint32_t CH2STAT; /**< DCP channel 2 status register, offset: 0x1A0 */
  uint8_t RESERVED_25[12];
  __IO uint32_t CH2OPTS; /**< DCP channel 2 options register, offset: 0x1B0 */
  uint8_t RESERVED_26[12];
  __IO uint32_t CH3CMDPTR; /**< DCP channel 3 command pointer address register, offset: 0x1C0 */
  uint8_t RESERVED_27[12];
  __IO uint32_t CH3SEMA; /**< DCP channel 3 semaphore register, offset: 0x1D0 */
  uint8_t RESERVED_28[12];
  __IO uint32_t CH3STAT; /**< DCP channel 3 status register, offset: 0x1E0 */
  uint8_t RESERVED_29[12];
  __IO uint32_t CH3OPTS; /**< DCP channel 3 options register, offset: 0x1F0 */
  uint8_t RESERVED_30[524];
  __IO uint32_t DBGSELECT; /**< DCP debug select register, offset: 0x400 */
  uint8_t RESERVED_31[12];
  __I uint32_t DBGDATA; /**< DCP debug data register, offset: 0x410 */
  uint8_t RESERVED_32[12];
  __IO uint32_t PAGETABLE; /**< DCP page table register, offset: 0x420 */
  uint8_t RESERVED_33[12];
  __I uint32_t VERSION; /**< DCP version register, offset: 0x430 */
} DCP_Type;
#define DCP ((DCP_Type *)0x402FC000)
static void dcp_reverse_and_copy(uint8_t *src, uint8_t *dest, size_t src_len)
  for (size_t i = 0; i < src_len; i++)
    dest[i] = src[src_len - 1 - i];
static uint32_t dcp_get_channel_status(dcp_channel_t channel)
  uint32_t statReg = 0;
  uint32_t semaReg = 0;
  uint32_t status = kStatus_Fail;
  switch (channel)
    case kDCP_Channel0:
      statReg = DCP->CH0STAT;
      semaReg = DCP->CH0SEMA;
    case kDCP_Channel1:
      statReg = DCP->CH1STAT;
      semaReg = DCP->CH1SEMA;
    case kDCP_Channel2:
      statReg = DCP->CH2STAT;
      semaReg = DCP->CH2SEMA;
    case kDCP_Channel3:
      statReg = DCP->CH3STAT;
      semaReg = DCP->CH3SEMA;
    default:
  if (!((semaReg & DCP_CH0SEMA_VALUE_MASK) || (statReg & DCP_CH0STAT_ERROR_CODE_MASK)))
    status = kStatus_Success;
  return status;
static void dcp_clear_status()
  volatile uint32_t *dcpStatClrPtr = &DCP->STAT + 2u;
  *dcpStatClrPtr = 0xFFu;
static void dcp_clear_channel_status(uint32_t mask)
  volatile uint32_t *chStatClrPtr;
  if (mask & kDCP_Channel0)
    chStatClrPtr = &DCP->CH0STAT + 2u;
    *chStatClrPtr = 0xFFu;
  if (mask & kDCP_Channel1)
    chStatClrPtr = &DCP->CH1STAT + 2u;
  if (mask & kDCP_Channel2)
    chStatClrPtr = &DCP->CH2STAT + 2u;
  if (mask & kDCP_Channel3)
    chStatClrPtr = &DCP->CH3STAT + 2u;
uint32_t DCP_WaitForChannelComplete(dcp_handle_t *handle)
  /* wait if our channel is still active */
  while ((DCP->STAT & (uint32_t)handle->channel) == handle->channel)
  if (dcp_get_channel_status(handle->channel) != kStatus_Success)
    dcp_clear_status();
    dcp_clear_channel_status(handle->channel);
    return kStatus_Fail;
  return kStatus_Success;
static uint32_t dcp_schedule_work(dcp_handle_t *handle, dcp_work_packet_t *dcpPacket)
  uint32_t status;
  /* check if our channel is active */
  if ((DCP->STAT & (uint32_t)handle->channel) != handle->channel)
    noInterrupts();
    /* re-check if our channel is still available */
    if ((DCP->STAT & (uint32_t)handle->channel) == 0)
      volatile uint32_t *cmdptr = NULL;
      volatile uint32_t *chsema = NULL;
      switch (handle->channel)
        case kDCP_Channel0:
          cmdptr = &DCP->CH0CMDPTR;
          chsema = &DCP->CH0SEMA;
        case kDCP_Channel1:
          cmdptr = &DCP->CH1CMDPTR;
          chsema = &DCP->CH1SEMA;
        case kDCP_Channel2:
          cmdptr = &DCP->CH2CMDPTR;
          chsema = &DCP->CH2SEMA;
        case kDCP_Channel3:
          cmdptr = &DCP->CH3CMDPTR;
          chsema = &DCP->CH3SEMA;
        default:
      if (cmdptr && chsema)
        /* set out packet to DCP CMDPTR */
        *cmdptr = (uint32_t)dcpPacket;
        /* set the channel semaphore */
        *chsema = 1u;
      status = kStatus_DCP_Again;
    interrupts();
    return kStatus_DCP_Again;
  return status;
static uint32_t dcp_hash_update_non_blocking(
  dcp_hash_ctx_internal_t *ctxInternal, dcp_work_packet_t *dcpPacket, const uint8_t *msg, size_t size)
  dcpPacket->control0 = ctxInternal->ctrl0 | (ctxInternal->handle->swapConfig & 0xFC0000u) | kDCP_CONTROL0_ENABLE_HASH | kDCP_CONTROL0_DECR_SEMAPHOR;
  if (ctxInternal->algo == kDCP_Sha256)
    dcpPacket->control1 = kDCP_CONTROL1_HASH_SELECT_SHA256;
  else if (ctxInternal->algo == kDCP_Sha1)
    dcpPacket->control1 = kDCP_CONTROL1_HASH_SELECT_SHA1;
  else if (ctxInternal->algo == kDCP_Crc32)
    dcpPacket->control1 = kDCP_CONTROL1_HASH_SELECT_CRC32;
    return 1;
  dcpPacket->sourceBufferAddress = (uint32_t)msg;
  dcpPacket->destinationBufferAddress = 0;
  dcpPacket->bufferSize = size;
  dcpPacket->payloadPointer = (uint32_t)ctxInternal->runningHash;
  return dcp_schedule_work(ctxInternal->handle, dcpPacket);
void dcp_hash_update(dcp_hash_ctx_internal_t *ctxInternal, const uint8_t *msg, size_t size)
  uint32_t completionStatus;
  dcp_work_packet_t dcpWork = { 0 };
  do
    completionStatus = dcp_hash_update_non_blocking(ctxInternal, &dcpWork, msg, size);
  } while (completionStatus == kStatus_DCP_Again);
  completionStatus = DCP_WaitForChannelComplete(ctxInternal->handle);
  ctxInternal->ctrl0 = 0; /* clear kDCP_CONTROL0_HASH_INIT and kDCP_CONTROL0_HASH_TERM flags */
  return;                 // (completionStatus);
void dcp_hash_process_message_data(
  const uint8_t *message,
  size_t messageSize)
  /* if there is partially filled internal buffer, fill it to full block */
  if (ctxInternal->blksz > 0)
    size_t toCopy = DCP_HASH_BLOCK_SIZE - ctxInternal->blksz;
    memcpy(&ctxInternal->blk.b[ctxInternal->blksz], message, toCopy);
    message += toCopy;
    messageSize -= toCopy;
    /* process full internal block */
    dcp_hash_update(ctxInternal, &ctxInternal->blk.b[0], DCP_HASH_BLOCK_SIZE);
  /* process all full blocks in message[] */
  uint32_t fullBlocksSize = ((messageSize >> 6) << 6); /* (X / 64) * 64 */
  if (fullBlocksSize > 0)
    dcp_hash_update(ctxInternal, message, fullBlocksSize);
    message += fullBlocksSize;
    messageSize -= fullBlocksSize;
  /* copy last incomplete message bytes into internal block */
  memcpy(&ctxInternal->blk.b[0], message, messageSize);
  ctxInternal->blksz = messageSize;
void DCP_HASH_Init(dcp_handle_t *handle, dcp_hash_ctx_t *ctx, dcp_hash_algo_t algo)
  dcp_hash_ctx_internal_t *ctxInternal;
  ctxInternal = (dcp_hash_ctx_internal_t *)ctx;
  ctxInternal->algo = algo;
  ctxInternal->blksz = 0u;
  for (size_t i = 0; i < sizeof(ctxInternal->blk.w) / sizeof(ctxInternal->blk.w[0]); i++)
    ctxInternal->blk.w[i] = 0u;  // bug was 0
  ctxInternal->state = kDCP_StateHashInit;
  ctxInternal->fullMessageSize = 0;
  ctxInternal->handle = handle;
void DCP_HASH_Update(dcp_hash_ctx_t *ctx, const uint8_t *input, size_t inputSize)
  bool isUpdateState;
  size_t blockSize = DCP_HASH_BLOCK_SIZE;
  ctxInternal->fullMessageSize += inputSize;
  /* if we are still less than DCP_HASH_BLOCK_SIZE bytes, keep only in context */
  if ((ctxInternal->blksz + inputSize) <= blockSize)
    memcpy((&ctxInternal->blk.b[0]) + ctxInternal->blksz, input, inputSize);
    ctxInternal->blksz += inputSize;
    return;
    isUpdateState = ctxInternal->state == kDCP_StateHashUpdate;
    if (!isUpdateState)
      /* start NEW hash */
      ctxInternal->ctrl0 = kDCP_CONTROL0_HASH_INIT;
      ctxInternal->state = kDCP_StateHashUpdate;
      //      dcp_hash_restore_running_hash(ctxInternal);  // context switch
  /* process input data */
  dcp_hash_process_message_data(ctxInternal, input, inputSize);
  //  dcp_hash_save_running_hash(ctxInternal);  // context
void DCP_HASH_Finish(dcp_hash_ctx_t *ctx, uint8_t *output)
  size_t algOutSize = 0;
  if (ctxInternal->state == kDCP_StateHashInit)
    ctxInternal->ctrl0 = kDCP_CONTROL0_HASH_INIT;  //dcp_hash_engine_init( ctxInternal);
  size_t outSize = 0u;
  /* compute algorithm output length */
  switch (ctxInternal->algo)
    case kDCP_Sha256:
      outSize = kDCP_OutLenSha256;
    case kDCP_Sha1:
      outSize = kDCP_OutLenSha1;
    case kDCP_Crc32:
      outSize = kDCP_OutLenCrc32;
    default:
  algOutSize = outSize;
  /* flush message last incomplete block, if there is any, and add padding bits */
  //dcp_hash_finalize( ctxInternal);
  ctxInternal->ctrl0 |= kDCP_CONTROL0_HASH_TERM;
  dcp_hash_update(ctxInternal, &ctxInternal->blk.b[0], ctxInternal->blksz);
  /* Reverse and copy result to output[] */
  dcp_reverse_and_copy((uint8_t *)ctxInternal->runningHash, &output[0], algOutSize);
  memset(ctx, 0, sizeof(dcp_hash_ctx_t));
void dcp_init()
  // volatile uint32_t *p;
  CCM_CCGR0 |= CCM_CCGR0_DCP(CCM_CCGR_ON);  // DCP on
  DCP->CTRL = 0xF0800000u; /* reset value */
  DCP->CTRL = 0x30800000u; /* default value */
  dcp_clear_status();
  // clear channel status
  dcp_clear_channel_status(kDCP_Channel0 | kDCP_Channel1 | kDCP_Channel2 | kDCP_Channel3);
  DCP->CTRL = 0x00C00000;  // enable caching  writes
  DCP->CHANNELCTRL = kDCP_ch0Enable;
void prhash(unsigned char *h, int n)
  int i;
  for (i = 0; i < n; i++)
    Serial.printf("%02x", h[i]);
    if (i % 4 == 3) Serial.printf(" ");
  Serial.printf("\n");
void do_crc32()
  dcp_handle_t m_handle;  //
  dcp_hash_ctx_t hashCtx;
  uint8_t msg[16 * 1024], hash[4];
  static const uint8_t message[] = "abcdbcdecdefdefgefghfghighijhijk";
  static const unsigned char crc32[] = { 0x7f, 0x04, 0x6a, 0xdd };  // crc
  m_handle.channel = kDCP_Channel0;
  m_handle.keySlot = kDCP_KeySlot0;
  m_handle.swapConfig = kDCP_NoSwap;
  DCP_HASH_Init(&m_handle, &hashCtx, kDCP_Crc32);
  DCP_HASH_Update(&hashCtx, message, sizeof(message) - 1);
  DCP_HASH_Finish(&hashCtx, hash);
  Serial.printf("memcmp %d\n", memcmp(hash, crc32, 4));
  prhash(hash, 4);
  uint32_t t = micros();
  DCP_HASH_Update(&hashCtx, msg, sizeof(msg));
  t = micros() - t;
  Serial.printf("CRC32 %d bytes %d us  %.3f MBs\n", sizeof(msg), t, (float)sizeof(msg) / t);
  prhash(hash, 4);
uint32_t compute_crc32(const uint8_t *data, size_t len)
  dcp_init();
  uint8_t hash[4];
  DCP_HASH_Update(&hashCtx, data, len);
  // Convert 4-byte hash result to uint32_t ( little-endian format)
  return (uint32_t)hash[3] | ((uint32_t)hash[2] << 8) | ((uint32_t)hash[1] << 16) | ((uint32_t)hash[0] << 24);
#endif  // DCP_UTIL_H
Try it without using DMAMEM for the array. It looks like that code isn't designed to manage cached memory at all.
Without DMA, It wroked upto 700x6 shaped float array, for me that's 0.7 seconds of axis control data.
I will try soon with different vars.
I will also take a closer look at how crc/mpeg2 works, maybe that will give me some insight, so far I just have been throwing things to see what sticks.
