teensy 4.1 mouse+mouse injected movments
raw packets to teensy plus raw mouse movments are unified I think.
Any pro advice on if I have it correct
#include <Arduino.h>
#include <USBHost_t36.h>
#if !defined(RAWHID_INTERFACE)
#error "Select a Teensy USB Type that includes RawHID."
#if !defined(MOUSE_INTERFACE)
#error "Select a Teensy USB Type that includes Mouse."
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
USBHIDParser hid1(myusb);
USBHIDParser hid2(myusb);
USBHIDParser hid3(myusb);
USBHIDParser hid4(myusb);
MouseController mouse1(myusb);
static constexpr uint16_t HOST_MAGIC = 0x3448;
static constexpr uint16_t DEVICE_MAGIC = 0x4834;
static constexpr uint8_t PROTOCOL_VERSION = 1;
static constexpr const char PROTOCOL_SOURCE[] = "Teensy41RawHid";
enum : uint8_t {
COMMAND_MOVE = 1,
COMMAND_BUTTONS = 2,
EVENT_BUTTON = 1,
EVENT_STATUS = 2,
PC_BUTTON_LEFT = 0x01,
PC_BUTTON_RIGHT = 0x02,
PC_BUTTON_MIDDLE = 0x04,
PC_BUTTON_BACK = 0x08,
PC_BUTTON_FORWARD = 0x10,
struct __attribute__((packed)) RawHidHostPacket {
uint16_t magic;
uint8_t version;
uint8_t command;
uint8_t buttonMask;
int16_t dx;
int16_t dy;
int16_t wheel;
int16_t wheelH;
uint32_t sequence;
uint8_t reserved[47];
struct __attribute__((packed)) RawHidDeviceEventPacket {
uint16_t magic;
uint8_t version;
uint8_t event;
uint8_t buttonId;
uint8_t pressed;
uint8_t hostButtonMask;
uint32_t sequenceAck;
uint8_t reserved[53];
static_assert(sizeof(RawHidHostPacket) == 64, "RawHID host packet must be 64 bytes");
static_assert(sizeof(RawHidDeviceEventPacket) == 64, "RawHID device packet must be 64 bytes");
uint8_t hostButtons = 0;
uint8_t pcButtons = 0;
uint32_t lastSequence = 0;
int8_t clampMouseStep(int value) {
if (value > 127) return 127;
if (value < -127) return -127;
return (int8_t)value;
void moveMouseInSteps(int dx, int dy, int wheel = 0, int wheelH = 0) {
while (dx != 0 || dy != 0 || wheel != 0 || wheelH != 0) {
int8_t stepX = clampMouseStep(dx);
int8_t stepY = clampMouseStep(dy);
int8_t stepWheel = clampMouseStep(wheel);
int8_t stepWheelH = clampMouseStep(wheelH);
Mouse.move(stepX, stepY, stepWheel, stepWheelH);
dx -= stepX;
dy -= stepY;
wheel -= stepWheel;
wheelH -= stepWheelH;
void setMouseButtons(uint8_t buttons) {
Mouse.set_buttons(
buttons & MOUSE_LEFT,
buttons & MOUSE_MIDDLE,
buttons & MOUSE_RIGHT,
buttons & MOUSE_BACK,
buttons & MOUSE_FORWARD
void applyButtons() {
Mouse.set_buttons(
(hostButtons & MOUSE_LEFT) || (pcButtons & PC_BUTTON_LEFT),
(hostButtons & MOUSE_MIDDLE) || (pcButtons & PC_BUTTON_MIDDLE),
(hostButtons & MOUSE_RIGHT) || (pcButtons & PC_BUTTON_RIGHT),
(hostButtons & MOUSE_BACK) || (pcButtons & PC_BUTTON_BACK),
(hostButtons & MOUSE_FORWARD) || (pcButtons & PC_BUTTON_FORWARD)
uint8_t buttonIdForMask(uint8_t mask) {
if (mask == MOUSE_LEFT) return 1;
if (mask == MOUSE_RIGHT) return 2;
if (mask == MOUSE_MIDDLE) return 3;
if (mask == MOUSE_BACK) return 4;
if (mask == MOUSE_FORWARD) return 5;
return 0;
void emitButtonTransition(uint8_t previousButtons, uint8_t currentButtons, uint8_t mask) {
bool wasDown = (previousButtons & mask) != 0;
bool isDown = (currentButtons & mask) != 0;
if (wasDown == isDown) return;
RawHidDeviceEventPacket packet = {};
packet.magic = DEVICE_MAGIC;
packet.version = PROTOCOL_VERSION;
packet.event = EVENT_BUTTON;
packet.buttonId = buttonIdForMask(mask);
packet.pressed = isDown ? 1 : 0;
packet.hostButtonMask = currentButtons;
packet.sequenceAck = lastSequence;
if (packet.buttonId != 0) {
RawHID.send(&packet, 0);
void emitButtonTransitions(uint8_t previousButtons, uint8_t currentButtons) {
emitButtonTransition(previousButtons, currentButtons, MOUSE_LEFT);
emitButtonTransition(previousButtons, currentButtons, MOUSE_RIGHT);
emitButtonTransition(previousButtons, currentButtons, MOUSE_MIDDLE);
emitButtonTransition(previousButtons, currentButtons, MOUSE_BACK);
emitButtonTransition(previousButtons, currentButtons, MOUSE_FORWARD);
bool validHostPacket(const RawHidHostPacket &packet) {
return packet.magic == HOST_MAGIC && packet.version == PROTOCOL_VERSION;
void handleRawHidHostPacket() {
RawHidHostPacket packet = {};
int received = RawHID.recv(&packet, 0);
if (received != 64 || !validHostPacket(packet)) return;
lastSequence = packet.sequence;
if (packet.command == COMMAND_MOVE) {
moveMouseInSteps(packet.dx, packet.dy, packet.wheel, packet.wheelH);
pcButtons = packet.buttonMask;
applyButtons();
void forwardHostMouse() {
if (!mouse1.available()) return;
int dx = mouse1.getMouseX();
int dy = mouse1.getMouseY();
int wheel = mouse1.getWheel();
int wheelH = mouse1.getWheelH();
uint8_t buttons = mouse1.getButtons();
moveMouseInSteps(dx, dy, wheel, wheelH);
if (buttons != hostButtons) {
emitButtonTransitions(hostButtons, buttons);
hostButtons = buttons;
applyButtons();
mouse1.mouseDataClear();
(void)PROTOCOL_SOURCE;
pinMode(LED_BUILTIN, OUTPUT);
myusb.begin();
Mouse.begin();
applyButtons();
myusb.Task();
handleRawHidHostPacket();
forwardHostMouse();
When posting code, can you do it between code tags using the </> button.
It makes your code so much more readable and therefore more likely to get a responce.
I have posted your code below so you can see the improvement.
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
enum : uint8_t {
    COMMAND_MOVE = 1,
    EVENT_BUTTON = 1,
    EVENT_STATUS = 2,
    uint16_t magic;
    uint8_t version;
    uint8_t command;
    uint8_t buttonMask;
    int16_t dx;
    int16_t dy;
    int16_t wheel;
    int16_t wheelH;
    uint32_t sequence;
    uint16_t magic;
    uint8_t version;
    uint8_t event;
    uint8_t buttonId;
    uint8_t pressed;
        dx -= stepX;
        dy -= stepY;
        wheel -= stepWheel;
    Mouse.set_buttons(
    Mouse.set_buttons(
    return 0;
bool validHostPacket(const RawHidHostPacket& packet) {
    applyButtons();
        applyButtons();
    myusb.begin();
    Mouse.begin();
    applyButtons();
    myusb.Task();
    forwardHostMouse();
Many years ago I tried to use some prior generation of teensy to automate things using mouse movements. I found the way that operating systems interpret rapid movement as going farther than slow mouse movement to make for a very difficult interfacing problem. I think they called it 'acceleration'. Learning about the issue did help me use a trackpad or mouse more effectively, though.
