Teensy 4.1 Resetting when running FreeRtos/Linux issue?
Bodger62
Hello All,
My problem is that the attached code, compiled on my Linux computer, used to work but now causes the Teensy 4.1 to constantly reset.
Teansy 4.1 core = 411FC271
Power-up Sequence
CPU Lockup or Software Reset
I am relatively certain that the problem is with my laptop, as the code works on another colleague's computer without resetting, but I’ve no idea how to fix it.
I have attached the code, but not the FreeRros as it was too big, and the Arduino start-up statements.
Any help would be greatly received.
regards,
Ray
I couldn't attach the FreeRtos.zip as it was too large. The properties of the version I'm using are as shown below
name=FreeRTOS
version=10.4.3-8
author=Richard Barry <info@freertos.org>
maintainer=Phillip Stevens <phillip.stevens@gmail.com>
sentence=<h3>FreeRTOS Real Time Operating System implemented for AVR (Uno, Nano, Leonardo, Mega).</h3>
paragraph=The primary design goals are: Easy to use, Small footprint, Robust. Uses Watchdog Timer for 15ms resolution. Slow blink = stack overflow. Fast blink = heap malloc() failure.
category=Timing
url=https://github.com/feilipu/Arduino_FreeRTOS_Library
architectures=*
license=MIT
includes=Arduino_FreeRTOS.h
======================= It didn't like the .odt file either =======================
aygray@MORCHEBA:~$ uname --kernel-name --kernel-release --machine
Linux 5.4.0-195-generic x86_64
raygray@MORCHEBA:~$ cat /etc/os-release
NAME="Ubuntu"
VERSION="20.04.6 LTS (Focal Fossa)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 20.04.6 LTS"
VERSION_ID="20.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
  • test.txt
  • Pretend_GPU.ino
After a bit more research I have found the following
CrashReport:
A problem occurred at (system time) 14:43:47
Code was executing from address 0xEB000426
CFSR: 92
(DACCVIOL) Data Access Violation
(MMARVALID) Accessed Address: 0x3530
HTSR: 40000000
(FORCED) Forced Hard Fault
Temperature inside the chip was 41.15 °C
Startup CPU clock speed is 600MHz
Reboot was caused by auto reboot after fault or bad interrupt detected
Booting FreeRTOS kernel V10.3.1. Built by gcc 11.3.1 20220712 (newlib @NEWLIB_VERSION@) on Sep 18 2024. ***
raygray@MORCHEBA:~/.arduino15/packages/teensy/tools/teensy-compile/11.3.1/arm/bin$ ./arm-none-eabi-addr2line -e Pretend_GPU.ino.elf 0x3530
/home/raygray/.arduino15/packages/teensy/hardware/avr/1.59.0/cores/teensy4/pwm.c:336
However, pwm.c isn't used in this project.
oid quadtimer_init(IMXRT_TMR_t *p)
int i;
for (i=0; i < 4; i++) {
p->CH.CTRL = 0; // stop timer
p->CH.CNTR = 0;
p->CH.SCTRL = TMR_SCTRL_OEN | TMR_SCTRL_OPS | TMR_SCTRL_VAL | TMR_SCTRL_FORCE;
p->CH.CSCTRL = TMR_CSCTRL_CL1(1) | TMR_CSCTRL_ALT_LOAD;
// COMP must be less than LOAD - otherwise output is always low
L336 p->CH.LOAD = 24000; // low time (65537 - x) -
p->CH.COMP1 = 0; // high time (0 = always low, max = LOAD-1)
p->CH.CMPLD1 = 0;
p->CH.CTRL = TMR_CTRL_CM(1) | TMR_CTRL_PCS(8) |
TMR_CTRL_LENGTH | TMR_CTRL_OUTMODE(6);
0xEB000426 is not a valid address for code. It looks more like an opcode than a memory address.
