Am I correct in assuming the onboard SD card slot on a Teensy 4.1 is on pin 4?
If yes... damn. Had a PCB made that uses pin 4 for something else, and now it's come to light I need to use the SD card slot.
All the SPI pins are available, I just have pin 4 allocated as an I/O that I now can't change.
Didn't realise I might need the SD card.
No options I assume...
