Hi everyone,
I'm running into an issue with a software reset on my Teensy 4.1 after updating the bootloader.
However, since switching to Bootloader v1.0a, executing this command causes the board to fail to restart properly. Instead, I get blink code 9 (the red LED blinks 9 times periodically). The board only recovers and boots normally after a full power cycle.
Has anyone experienced similar behavior after updating to bootloader v1.0a, or is there a new recommended way to trigger a software reset on this bootloader version?
Thanks for any insights!
The Problem
Previously, a software reset using the Application Interrupt and Reset Control Register always worked reliably:
C++:
SCB_AIRCR = 0x05FA0004;
