Teensy 4.1 SPI Slave - here it is
tjaekel
When you are looking (like me) for a SPI Slave implementation on Teensy 4.1...
(all the code provided by PJRC, Arduino, looking in Internet says: "just SPI master is supported")
Based on tonton81's approach: https://github.com/tonton81/SPISlave_T4 - I could bring up
this SPI Slave to work (but it needs some modifications, see attached ZIP with my code and sketch).
How does it work?
It configures some MCU registers directly (the mode for SPI), so it goes to the MCU Config registers for SPI, directly!
It sets an ISR handler for the SPI: so, the SPI slave runs in INT-mode (not DMA).
The format for SPI (e.g. SPI mode, LSB vs. MSB first) is fix and hard-coded (but could be changed, if you use the RT1062 reference manual, knowing which register to write with what).
Strange is just: the H-file includes the "SPISlave_T4.tpp" file (the CPP source code, but not as *.CPP file). Changing to use as CPP instead fails with compile error.
(maybe somebody could fix to have real *.H and *.CPP files).
So, the entire code comes via this "SPISlave_T4.h" included, including also this "SPISlave_T4.tpp" (watch the file extension not as *.CPP).
My example code works this way:
The ISR places all the received SPI Slave bytes into a shared buffer.
The buffer index keeps incrementing (so, the buffer is filled with the received bytes on SPI Slave input, every ISR called for a complete Rx bytes fills the buffer in ISR).
When the PCS comes, the SPI Slave Select signal (CS, SS) comes (this is enabled now as ISR trigger!) - it sets a flag so that main thread (loop) can realize the SPI Rx has completed (the deactivation of SPI CS was there).
Print all the received bytes, reset the notification flag and also the buffer index (a handshake between main() and ISR(), write from start again on next SPI Rx transaction).
The original implementation has some flaws, e.g.:
- the handling of the PCS signal (SPI Chip Select, CS) plus/as "Frame Complete Flag" (PCS goes high) was not enabled, not working (the order of bytes received were wrong, the logic was wrong).
- the ISR keeps looping inside the ISR ("not nice") and uses also Serial.print() calls inside ISR (it slows down the performance, dramatically)
- so, the maximum speed was limited to the USB VCP speed, so, just 1 MHz SPI was working (doing printfs or Serial in an ISR is not a "smart idea", esp. if USB VCP tickles out with 1 KHz clock)
- the order and number of received bytes was wrong (the logic inside ISR was wrong, because it has not really acted on "Frame Complete" (PCR))
I could improve and fix some issues:
- it runs now up to 22 MHz generated by a SPI master (faster fails with wrong number of bytes received or the order is wrong)
Important:
the original code and even my one use still the "swapped pin mapping":
So, the input as MOSI is located on the MISO Teensy 4.1 pin (as MISO, pin number 12)!
(a bit strange, because MOSI remains MOSI, per definition, never mind if slave or master)
So, if you are looking for a SPI Slave for Teensy 4.1... - give it a try.
  • SPISlave_T4.zip
@tonton81 did that code years back {2018} when a T_3.6 or T_3.5 was newer and overloaded with IMU sensor data - SPI _Transfer was created to offload the data to a second Teensy for Serial.print()'ing that to external GUI at 24 MHz. It was done to work on LC to 3.6 of the day IIRC and only Master was needed and it was a tremendous high speed boost allowing RAW struct data export for remote printf() formatting of float data. The T_4.x's came later ...
How does it work?
Important:
I have a couple of suggestions:-
Having two Libraries with the same name, especially with the similarities that exist, could (will) be extreemly confusing so
1) could you change the library name to remove the confusion i.e. Improved_SPISlave_T4 or T4_SPISlave, or
2) could you colaborate with TonTon to come up with a difinitive library.
Any way well done in getting it going so well.
Oh, as an aside, could you include some revision information in the code so we know if it has been updated.
EDIT: For my own use I have renamed it as T4_SPISlave.
Indeed good work - maybe PR to update the @tonton81 2 yr old Slave code?
@tjaekel: Great work, thanks a lot! I haven't been able to get your script to work using SPI1 on Teensy 4.1. Just switched out
C++:
SPISlave_T4<&SPI, SPI_8_BITS> mySPI;
with
C++:
SPISlave_T4<&SPI1, SPI_8_BITS> mySPI;
and rewired accordingly. spiRxComplete is never true. I assume it has to do something with the definitions in
C++:
SPISlave_T4_FUNC SPISlave_T4_OPT::SPISlave_T4() {
  if ( port == &SPI ) {
    _LPSPI4 = this;
    _portnum = 3;
    CCM_CCGR1 |= (3UL << 6);
    nvic_irq = 32 + _portnum;
    _VectorsRam[16 + nvic_irq] = lpspi4_slave_isr;
    /* Alternate pins not broken out on Teensy 4.0/4.1 for LPSPI4 */
    SLAVE_PINS_ADDR;
    spiAddr[0] = 0; /* PCS0_SELECT_INPUT */
    spiAddr[1] = 0; /* SCK_SELECT_INPUT */
    spiAddr[2] = 0; /* SDI_SELECT_INPUT */
    spiAddr[3] = 0; /* SDO_SELECT_INPUT */
    IOMUXC_SW_MUX_CTL_PAD_GPIO_B0_03 = 0x3; /* LPSPI4 SCK (CLK) */
    IOMUXC_SW_MUX_CTL_PAD_GPIO_B0_01 = 0x3; /* LPSPI4 SDI (MISO) */
    IOMUXC_SW_MUX_CTL_PAD_GPIO_B0_02 = 0x3; /* LPSPI4 SDO (MOSI) */
    IOMUXC_SW_MUX_CTL_PAD_GPIO_B0_00 = 0x3; /* LPSPI4 PCS0 (CS) */
but I'm not adept enough to know what to change. Could you help me out here? Thanks!
How does it work?
Important:
Thanks for the sample code.
I like to know if you encounter issue of delayed Slave reply of Master commands processing?
I made some changes to process Master commands and reply with the Slave.
for the first Master CMD1 Salve reply 0x00 (preloaded at begin stage) .
At this point i assume Slave read the master CMD1 and process it
Next master sends 0x00 for the Slave reply 0xFF (since RF FIFO empty)
On the next Master CMD2 Slave reply with the data that is result of Master CMD1 processing.
Please advice
Thanks!
It is not possible to use a SPI Slave in Full-Duplex mode: if the Master sends a command to Slave, but the Slave has to wait for FIFO, read from FIFO, decode the command, generate the response and write to the Slave Tx FIFO - it will take much longer as ONE SPI CLK cycle (it must be shorter, assume just Half a clock cycle left).
On the SPI Slave, the entire Slave Tx FIFO must be pre-loaded with the entire response to Master.
Otherwise: implement a "protocol": split it into two separate SPI transactions, with a delay (gap, pause) between the SPI transactions, in order to give the SPI Slave time to prepare the response.
(for Bluem ax: see the private conversation)
I use SPI Slave just as a uni-directional receiver (Rx only): I use one Master as Tx, another SPI as Slave for Rx: it allows me to feedback the SPI CLK signal, for runtime (delay) compensation (e.g. due to the length of cable, using level shifters).
A SPI Slave as a full-duplex device, where the "tail" of a SPI transaction depends on what was received at the start of SPI transaction (e.g. command) - works only when all is implemented in real HW (a chip, a FPGA). In MCU FW - not possible - FW is too slow to modify during an ongoing SPI transaction what has to be "clocked out" by the Master. The Master keeps going and FW has no time to fill the Slave Tx FIFO.
Hello tjaekel, I like what you did with this library. It works for my project, except, that I actually need another cs on the slave side. Is this possible? I have developed a pcb with three teensy's 4.1, of which two should work as master-slave, but I forgot to keep the cs pin 10 free. That's why I'm looking for a possibility to use another pin as cs. On the master side it's no problem.
On a Master you could use any GPIO pin as a CSn, running it in SW mode. But on a Slave, if you want to use CSn (to enable a slave from a master, e.g. selecting 1 of N slaves) - it has to be a dedicated CSn pin for this SPI slave.
You can look into the ALT function table and check, if you find another pin for this SPI acting as a CSn signal. If not: not possible to use any other pin. as CSn IN for a slave.
You could run the Slave without CSn, enable it via SW. But you would not be able to select 1 of N slaves by a master.
Maybe, based on your schematics, you could use an external logic, e.g. a multiplexer or a combinatorical logic: e.g. a regular GPIO pin as input to it would multiplex a CSn signal coming out. So, assume the dedicated nCS signal is used for something else: you route this signal to the slave, but the external logic between master and slave will be controlled by a regular GPIO, to select where this signal should go.
It means: the CSn signal is used for something else. But you need it also as the correct CSn on the slave. You "gate" this signal, so that you "disconnect" it from the other external device and instead it is "connected" now at the slave. A regular GPIO pin controls where this CSn coming out of MCU should go to. Just to make sure that the "disconnected" CSn on the other device is inactive when disconnected (e.g. a Tri-State buffer with pull-up or a signal de-multiplexer: one signal in to two different out).
Thanks for your response. I will study how and what I can do best. My thoughts go to SPI without cs, because I only have one slave. I think it would also be possible without MISO, because the data always goes in one direction. I have to look how I can do this with the SPISlave_T4 library. I am not yet an expert in the field of SPI communication, but I will do my best to change that.
If you have just one SPI slave, maybe you can enable the slave by driving its nCS with a constant.
BUT:
not all SPI slave devices work this way: some chips require to toggle nCS so that the chip can "see" a completed SPI transaction.
Not really clear if this SPI Slave is on the Teensy MCU. If so, enabling it via SW instead of using an external nCS input pin, could work.
Just to make sure you do not toggle the SPI SCLK signal, even not by "mistake", e.g. generating a SCLK pulse edge which the always enabled SPI slave could see as a 1st clock edge. So, your SCLK must be "glitch-free".
If it is an external SPI slave device (chip) - it depends on its datasheet, if a permanent slave enable would work.
Thank you for you're effort, but it was not the best solution for me. Then we came to the idea to connect the ethernet from one teensy 4.1 to the second teensy 4.1 and communicate with a max speed of 100mbit/s. I made a pcb for this and it works right now at about 95 mbit/s.
Not sure why you need magnetics for a simple Teensy-to-teensy link - or are they a long way apart and need galvanic isolation?
BTW m is milli, M is mega. 95mbits/s isn't so impressive :)
I wasn't sure if galvanic isolation was necessary. My thought was, those blocks cost nothing, so why not just put them in between. It won't slow down the communication. But since both teensy's have the same ground it probably won't be necessary. And of course it's Mbit, thanks.
I want to thank tonton81 and tjaekel for the work they did on the SPISlave_T4 library
The pinswap and sniffer is not in my version anymore, cause I did not need it and it works for SPI2 (sd-card slot) only.
I changed the spiRx array into uint8_t spiRx[256], so I can transmit 256 bytes at once per transfer.
Connection is now
Master - Slave
MISO(42) - MOSI(43)
MOSI(43) - MISO(42)
CLK(45) - CLK(45)
CS(44) - CS(44)
I did a test with 22MHz SPI speed. This works fine with a transmit of one package every ms from the master to the slave.
I don't know everything there is to know about SPI and Teensy 4.1 and maybe it good be done better, but it works for me now.
  • teensy4.1_spi2_master_slave-main.zip
How does it work?
Important:
Hi Tjaekel! 😄
Did the code you wrote ever end up in a PR/repo anywhere?
