Teensy 4.1 SPI SLAVE late data processing problem
Bluemax
I am testing SPI slave mode (sensor emulation) with Teensy 4.1 base on SPISlave_T4*
The SPI master sends CMDx and 0x00 (generate CLK for the SPI Slave reply)
The master transmit sequence is:
CMD1
0x0 //generate CLK for slave reply1
CMD2
0x0 //generate CLK for slave reply2
CMD3
0x0 //generate CLK for slave reply3
At slave code:
SLAVE_TDR = 0x0;
It is done at begin function prior to master command processing.
It is dummy data, that populate initial TX slot.
The result of the Slave processing :
Master Slave
Master_CMD1 0x0 <---- since the begin operastion loaded the TX slot
0x0 0xFF <---- since the code did not process Master_CMD1 YET!!!! no TX from slave
Master_CMD2 Slave_Reply_for_CMD1 <----- after Master_CMD1 was processed!!!
0x0 0x0 <--- each slave TX is followed by TX of 0x0
Can anyone provide some idea why the late delay of Master incoming data processing?
Teensy is at 600Mhz and SPI is at 8Mhz
Please note :
if i prepare 2 values for the first command prior to getting CMD it work fine
Master Slave
Master_CMD1 Slave_Reply1_default
0x0 Slave_Reply2_dafault
its looks like the SPI Slave processing of the Master Commands is done in 16 CLK shift.
Thanks for the help
