teensycoder
I've been coding using the Teensy 3.6 using Adafruit Winc 1500 and the wifi101 library with Blynk and had no problems. I've recently switched to using the Teensy 4.1 and the same hardware. I can connect to the Wifi without a problem and also the initial Blynk.connect works. However when using Blynk.run in the Loop it hangs. I did read somwhere ther is a known problem with this setup but cannot find any details. Any help would be apreciated.
