Teensy 4.1 Winbond Compatibility
mfrac
More of a curious question than anything critical. Normally I use the W25Q64JVZEIM with no issue, but problem is I'm running low and they're out of stock everywhere. I've only been able to find the W25Q64JVSSIM and W25Q64JVSSIM TR chips as two in stock viable options and so I was wondering if the "TR" mattered much when choosing these for a custom Teensy 4.1 PCB? Frankly I have no idea what it even means.
W25Q64JVSSIM:
https://www.mouser.com/ProductDetail/Winbond/W25Q64JVSSIM?qs=qSfuJ%2Bfl/d7U0hcTKxbcpQ==
W25Q64JVSSIM TR:
https://www.mouser.com/ProductDetail/Winbond/W25Q64JVSSIM-TR?qs=qSfuJ%2Bfl/d4D4t%2BHFzDXrw==
TR means Cut Tape / Reel.
Without TR normally means shipped in a tube or tray.
Both same device.
One note: I believe when you order TR, there is an additional charge:
The additional charge only applies if you select MouseReel. Cut Tape is no extra charge.
You can only see this after you enter the quantity.
