I've made a custom board to generate an RTP stream using a 4.1 and the audio adapter.
The microphone seems to work well and I can here the audio over the network.
I have the line-out jack wired to a 12v speaker that has it's own mini-amp.
When I connect the speaker everything seems to stop working.
The microphone is now just noise and the speaker sounds about the same.
This same setup works fine if I only connect the output to headphones?? I'm a bit lost as this is my first audio project.
Digitally everything associated with the RTP is working...so this feels like some sort of grounding issue or other analog item that I don't understand.
I'm using this speaker:
Everything is powered from the same 12v battery.....I have a 5v converter for the teensy.
I also just noticed that when everything is connected i can hear the microphone slightly playing over the speaker....they should be independent in this setup.
