yellownotblack
Hello
Im want to record some audio with the teensy 4.1. But I am unable. I only get noise, regardless of what I am trying. But playback is no problem. But I have to use ti SD Card on the teensy otherwise there is extreme noise.
I have just adjusted the example code to use the other SD Card.
I have tried using “Lin In” and “Mic In” in the software aswell as different gains. I plug in the microphone via the 3,5mm audio jack. I have tried normal headphones with a mic (Bose SoundSport Wired) aswell as a lavalier mic.
This is my code (recoder axample with some adjustments (pins)):
Has anyone an idea?
Thanks
// Record sound as raw data to a SD card, and play it back.
// Requires the audio shield:
// http://www.pjrc.com/store/teensy3_audio.html
// Three pushbuttons need to be connected:
// Record Button: pin 33 to GND
// Stop Button: pin 34 to GND
// Play Button: pin 35 to GND
// This example code is in the public domain.
#include <Bounce.h>
#include <SerialFlash.h>
AudioInputI2S i2s2; //xy=105,63
AudioAnalyzePeak peak1; //xy=278,108
AudioRecordQueue queue1; //xy=281,63
AudioPlaySdRaw playRaw1; //xy=302,157
AudioOutputI2S i2s1; //xy=470,120
AudioConnection patchCord1(i2s2, 0, queue1, 0);
AudioConnection patchCord2(i2s2, 0, peak1, 0);
AudioConnection patchCord3(playRaw1, 0, i2s1, 0);
AudioConnection patchCord4(playRaw1, 0, i2s1, 1);
AudioControlSGTL5000 sgtl5000_1; //xy=265,212
// For a stereo recording version, see this forum thread:
// https://forum.pjrc.com/threads/46150?p=158388&viewfull=1#post158388
// A much more advanced sound recording and data logging project:
// https://github.com/WMXZ-EU/microSoundRecorder
// https://github.com/WMXZ-EU/microSoundRecorder/wiki/Hardware-setup
// https://forum.pjrc.com/threads/52175?p=185386&viewfull=1#post185386
// Bounce objects to easily and reliably read the buttons
Bounce buttonRecord = Bounce(33, 8);
Bounce buttonStop = Bounce(34, 8); // 8 = 8 ms debounce time
Bounce buttonPlay = Bounce(35, 8);
// which input on the audio shield will be used?
// Use these with the Teensy Audio Shield
//#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 11 // Teensy 4 ignores this, uses pin 11
#define SDCARD_SCK_PIN 13 // Teensy 4 ignores this, uses pin 13
// Use these with the Teensy 3.5 & 3.6 & 4.1 SD card
#define SDCARD_CS_PIN BUILTIN_SDCARD
//#define SDCARD_MOSI_PIN 11 // not actually used
//#define SDCARD_SCK_PIN 13 // not actually used
// Use these for the SD+Wiz820 or other adaptors
//#define SDCARD_CS_PIN 4
// Remember which mode we're doing
int mode = 0; // 0=stopped, 1=recording, 2=playing
// The file where data is recorded
File frec;
// Configure the pushbutton pins
pinMode(33, INPUT_PULLUP);
pinMode(34, INPUT_PULLUP);
pinMode(35, INPUT_PULLUP);
AudioMemory(60);
sgtl5000_1.enable();
sgtl5000_1.volume(0.8);
sgtl5000_1.micGain(60);
// Initialize the SD card
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
while (1) {
// First, read the buttons
buttonRecord.update();
buttonStop.update();
buttonPlay.update();
// Respond to button presses
if (buttonRecord.fallingEdge()) {
Serial.println("Record Button Press");
if (mode == 2) stopPlaying();
if (mode == 0) startRecording();
if (buttonStop.fallingEdge()) {
Serial.println("Stop Button Press");
if (mode == 1) stopRecording();
if (buttonPlay.fallingEdge()) {
Serial.println("Play Button Press");
if (mode == 0) startPlaying();
// If we're playing or recording, carry on...
if (mode == 1) {
continueRecording();
if (mode == 2) {
continuePlaying();
// when using a microphone, continuously adjust gain
if (myInput == AUDIO_INPUT_MIC) adjustMicLevel();
void startRecording() {
Serial.println("startRecording");
if (SD.exists("RECORD.RAW")) {
// The SD library writes new data to the end of the
// file, so to start a new recording, the old file
// must be deleted before new data is written.
SD.remove("RECORD.RAW");
frec = SD.open("RECORD.RAW", FILE_WRITE);
if (frec) {
queue1.begin();
mode = 1;
void continueRecording() {
if (queue1.available() >= 2) {
byte buffer[512];
// into a 512 byte buffer. The Arduino SD library
// writes are used.
memcpy(buffer, queue1.readBuffer(), 256);
queue1.freeBuffer();
memcpy(buffer+256, queue1.readBuffer(), 256);
// write all 512 bytes to the SD card
//elapsedMicros usec = 0;
frec.write(buffer, 512);
// Uncomment these lines to see how long SD writes
// are taking. A pair of audio blocks arrives every
// 5802 microseconds, so hopefully most of the writes
// take well under 5802 us. Some will take more, as
// the SD library also must write to the FAT tables
// and the SD card controller manages media erase and
// wear leveling. The queue1 object can buffer
// approximately 301700 us of audio, to allow time
// for occasional high SD card latency, as long as
// the average write time is under 5802 us.
//Serial.print("SD write, us=");
//Serial.println(usec);
void stopRecording() {
Serial.println("stopRecording");
queue1.end();
if (mode == 1) {
frec.write((byte*)queue1.readBuffer(), 256);
frec.close();
mode = 0;
void startPlaying() {
Serial.println("startPlaying");
playRaw1.play("RECORD.RAW");
mode = 2;
void continuePlaying() {
if (!playRaw1.isPlaying()) {
playRaw1.stop();
mode = 0;
void stopPlaying() {
Serial.println("stopPlaying");
if (mode == 2) playRaw1.stop();
mode = 0;
void adjustMicLevel() {
// TODO: read the peak1 object and adjust sgtl5000_1.micGain()
// if anyone gets this working, please submit a github pull request :-)
Has anyone an idea?
Thanks
