danielroitman
i everyone,
I'm facing an issue integrating the Teensy 4.1 with an ESP32 (AirLift) for Wi-Fi communication, and I’d like to know if anyone has managed to achieve reasonable transfer speeds with this setup.
Thanks
Daniel
- Current setup:
- Teensy 4.1 connected to an ESP32 (AirLift) via SPI.
- Using the WiFiNINA library to handle communication.
- Ping works fine, with low latency.
- Goal:
- Transfer files from the Teensy’s SD card to another device over Wi-Fi.
- Results obtained:
- Using either HTTP or FTP servers over Wi-Fi, transfer speeds don’t exceed 100 KB/s.
- In many cases, the communication unexpectedly freezes.
Observations:
- Replacing the ESP32 with the Teensy 4.1’s native Ethernet (using the Ethernet_native library), I can achieve transfer speeds close to 10 MB/s.
- The issue seems to be with Wi-Fi communication, as the hardware works well with Ethernet.
- I’ve tried adjusting the buffer size (testing values like 64, 128, 256 bytes), but I noticed that buffers larger than 128 cause transfer failures, such as interruptions or freezes.
Question:
- Has anyone successfully used the Teensy 4.1 with a Wi-Fi interface (like the AirLift) and achieved satisfactory file transfer speeds?
- Are there any tips to optimize Wi-Fi communication in this setup?
- Could this be an inherent limitation of the ESP32 in AirLift mode, or might I be overlooking something?
Thanks
Daniel
