Teensy 4 Audio - i2s alternate pins
Dogbone06
I've found some info on how to change the i2s pins for Teensy 3, but no real forward way for Teensy 4.
I think I know the place where it needs to be done, but there's probably more to it.
In file libraries\Audio\output_i2s.cpp
CCM_CCGR5 |= CCM_CCGR5_SAI1(CCM_CCGR_ON);
  // if either transmitter or receiver is enabled, do nothing
  if (I2S1_TCSR & I2S_TCSR_TE) return;
  if (I2S1_RCSR & I2S_RCSR_RE) return;
  // not using MCLK in slave mode - hope that's ok?
  //CORE_PIN23_CONFIG = 3;  // AD_B1_09  ALT3=SAI1_MCLK
  CORE_PIN21_CONFIG = 3;  // AD_B1_11  ALT3=SAI1_RX_BCLK
  CORE_PIN20_CONFIG = 3;  // AD_B1_10  ALT3=SAI1_RX_SYNC
  IOMUXC_SAI1_RX_BCLK_SELECT_INPUT = 1; // 1=GPIO_AD_B1_11_ALT3, page 868
  IOMUXC_SAI1_RX_SYNC_SELECT_INPUT = 1; // 1=GPIO_AD_B1_10_ALT3, page 872
  // configure transmitter
  I2S1_TMR = 0;
  I2S1_TCR1 = I2S_TCR1_RFW(1);  // watermark at half fifo size
  I2S1_TCR2 = I2S_TCR2_SYNC(1) | I2S_TCR2_BCP;
  I2S1_TCR3 = I2S_TCR3_TCE;
  I2S1_TCR4 = I2S_TCR4_FRSZ(1) | I2S_TCR4_SYWD(31) | I2S_TCR4_MF
    | I2S_TCR4_FSE | I2S_TCR4_FSP | I2S_RCR4_FSD;
  I2S1_TCR5 = I2S_TCR5_WNW(31) | I2S_TCR5_W0W(31) | I2S_TCR5_FBT(31);
  // configure receiver
  I2S1_RMR = 0;
  I2S1_RCR1 = I2S_RCR1_RFW(1);
  I2S1_RCR2 = I2S_RCR2_SYNC(0) | I2S_TCR2_BCP;
  I2S1_RCR3 = I2S_RCR3_RCE;
  I2S1_RCR4 = I2S_RCR4_FRSZ(1) | I2S_RCR4_SYWD(31) | I2S_RCR4_MF
    | I2S_RCR4_FSE | I2S_RCR4_FSP;
  I2S1_RCR5 = I2S_RCR5_WNW(31) | I2S_RCR5_W0W(31) | I2S_RCR5_FBT(31);
I am using these pins:
Is there a proper way to set alternate i2s?
