Hello,
I have to port some teensy 3.x code to teensy 4.x.
With Teensy 3.x I used to use EEPROMEX library (https://github.com/thijse/Arduino-EEPROMEx) which allow me to store many datas in EEPROM.
Teensy 4.x seem to don't behave the same as Teensy 3.x regarding EEPROM.
Is there a similar library that can operate with Teensy 4.x ?
Here are some code I use to use :
Thank you,
Manu
void initEEprom()
EEPROM.updateByte(1, 1); // Durée tempo rotation écran en minutes
#if defined(FENIXECU)
EEPROM.updateByte(2, 0); // Type de calculateur (par défaut Megasquirt)
EEPROM.updateLong(4, 500000); // Bus CAN 500kbps
EEPROM.updateBit(24, 0, 0); // Français + Pas de rotation
#if defined(MOD7R)
EEPROM.updateByte(2, 3); // Type de calculateur (par défaut Sybele)
EEPROM.updateLong(4, 1000000); // Bus CAN 1Mbps
EEPROM.updateBit(24, 0, 1); // Anglais
#if defined(PPRACING)
EEPROM.updateByte(2, 5); // Type de calculateur (par défaut Nicolas Serre)
EEPROM.updateByte(3, 1); // ZT Active
EEPROM.updateByte(8, 0); // Vue 0 (Roulage)
EEPROM.updateByte(9, 7);
EEPROM.updateByte(10, 9);
EEPROM.updateByte(11, 10);
EEPROM.updateByte(12, 6); // Vue 1 (Réglage)
EEPROM.updateByte(13, 4);
EEPROM.updateByte(14, 3);
EEPROM.updateByte(15, 9);
EEPROM.updateByte(16, 0); // Vue 3 (Températures)
EEPROM.updateByte(17, 1);
EEPROM.updateByte(18, 2);
EEPROM.updateByte(19, 3);
EEPROM.updateByte(20, 6); // Vue 4 (Pressions)
EEPROM.updateByte(21, 7);
EEPROM.updateByte(22, 8);
EEPROM.updateByte(23, 11);
MiniMAxi_razEEPROM();
EEPROM.updateByte(0, 170); // EEprom configurée
return;
void MiniMAxi_razEEPROM()
for (int i = FIRST_MINI_VALUE_ADRESS; i < (FIRST_MINI_VALUE_ADRESS + EEPROM_MIN_MAX_LENGTH); i = i + 4)
EEPROM.updateFloat(i, 0.);
EEPROM.updateFloat(25, 60.); // Mini tMot
EEPROM.updateFloat(33, 60.); // Mini tAir
EEPROM.updateFloat(41, 90.); // Mini tOil
EEPROM.updateFloat(49, 300.); // Mini tEch
EEPROM.updateFloat(57, 50.); // Mini alphaPap
EEPROM.updateFloat(81, 6.); // Mini pOil
EEPROM.updateFloat(89, 6.); // Mini pEss
EEPROM.updateFloat(97, 16.7); // Mini AFR
EEPROM.updateFloat(105, 20.); // Mini Niveau Carburant
EEPROM.updateFloat(113, 14.5); // Mini vBat
EEPROM.updateByte(1023, 0); // Rotation EEPROM = 0 (20 rotations maxi)
EEPROM_Mini_StartAdress = FIRST_MINI_VALUE_ADRESS;
EEPROM_Maxi_StartAdress = FIRST_MINI_VALUE_ADRESS + 4;
rotationEEPROM = 0;
return;
Thank you,
Manu
