Presumably, one could adapt the SDIO driver from SDFAT:
https://github.com/greiman/SdFat/blob/master/src/SdCard/TeensySdio/TeensySdio.cpp
Edit: You could take a look at
https://github.com/espressif/idf-extra-components/blob/master/esp_serial_slave_link/essl_sdio.c , too - that code it not for Teensy but shows the logic behind it.
Edit2: If you use SdFat as a starting point, I recommend removing the workarounds for the Teensy's missing pull-up resistors and adding the required resistors to the board instead. I don't remember the exact details, though.
So the first step would be to build some hardware and get simple communication between T4 and C6 up and running. Once that’s done, the biggest milestone is already behind you—you can also borrow a lot from the ESP code.
Edit 3: Kicad adapter files as starting point:
https://github.com/newdigate/teensy-eurorack/tree/master/hardware/board
