Hi Everyone,
i currently have a project using the sgtl5000 codec in combination with teensy 4.1's to send audio over UDP. As the codec is the same as on the teensy audio board, i've been using it to prototype and also used part of it's schematic. My board however, has a bit of a noise problem, which is caused by the decoupling capacitor i used on the VAG pin. Replacing it with the one used on the teensy audio board solves the issue.
It would be amazing, if someone could give me a part number for that cap (the 0.15uF one connected to the VAG pin), as i'm not sure what to look for / what property of the capacitor is actually causing the noise.
Thanks in Advance
Thanks in Advance
