Hello,
I'm also am newbie at Teensy SDR project. I downloaded all the files from
https://github.com/DD4WH/Teensy-ConvolutionSDR.
I have been able to stop the compilation errors by adding all of the necessary libraries but, it still gives a lot of warnings.
Can I ignore these warnings? See below.
Regards.
Teensy_Convolution_SDR_aw:406: warning: large integer implicitly truncated to unsigned type
uint16_t termColor = 0x10000;
Teensy_Convolution_SDR_aw:678: warning: ISO C++ forbids converting a string constant to 'char*'
Teensy_Convolution_SDR_aw:689: warning: ISO C++ forbids converting a string constant to 'char*'
Teensy_Convolution_SDR_aw: In function 'void setup()':
/Users/aw/Documents/Arduino/Teensy_Convolution_SDR_aw/Teensy_Convolution_SDR_aw.ino:3546:116: warning: invalid conversion from 'const float32_t* {aka const float*}' to 'float32_t* {aka float*}' [-fpermissive]
arm_fir_init_f32 (&FIR_WFM_I, FIR_WFM_num_taps, FIR_WFM_Coef, FIR_WFM_I_state, (uint32_t)WFM_BLOCKS * BUFFER_SIZE);
In file included from /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/analyze_fft256.h:32:0,
from /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/Audio/Audio.h:61,
from /Users/aw/Documents/Arduino/Teensy_Convolution_SDR_aw/Teensy_Convolution_SDR_aw.ino:269:
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4/arm_math.h:1234:8: note: initializing argument 3 of 'void arm_fir_init_f32(arm_fir_instance_f32*, uint16_t, float32_t*, float32_t*, uint32_t)'
/Users/aw/Documents/Arduino/Teensy_Convolution_SDR_aw/Teensy_Convolution_SDR_aw.ino:3547:116: warning: invalid conversion from 'const float32_t* {aka const float*}' to 'float32_t* {aka float*}' [-fpermissive]
arm_fir_init_f32 (&FIR_WFM_Q, FIR_WFM_num_taps, FIR_WFM_Coef, FIR_WFM_Q_state, (uint32_t)WFM_BLOCKS * BUFFER_SIZE);
Teensy_Convolution_SDR_aw: In function 'void loop()':
Teensy_Convolution_SDR_aw:3786: warning: comparison between signed and unsigned integer expressions
if (Q_in_L.available() > (WFM_BLOCKS) && Q_in_R.available() > (WFM_BLOCKS) && Menu_pointer != MENU_PLAYER)
Teensy_Convolution_SDR_aw:4049: warning: comparison between signed and unsigned integer expressions
for (int i = 1; i < BUFFER_SIZE * WFM_BLOCKS; i++)
Teensy_Convolution_SDR_aw:4402: warning: comparison between signed and unsigned integer expressions
for (int i = 0; i < WFM_BLOCKS; i++)
Teensy_Convolution_SDR_aw:4502: warning: comparison between signed and unsigned integer expressions
if (Q_in_L.available() > N_BLOCKS + 0 && Q_in_R.available() > N_BLOCKS + 0 && Menu_pointer != MENU_PLAYER)
Teensy_Convolution_SDR_aw: In function 'void Zoom_FFT_exe(uint32_t)':
Teensy_Convolution_SDR_aw:7761: warning: statement has no effect
high_Zoom_buffer_x[i + high_Zoom_buffer_ptr];
Teensy_Convolution_SDR_aw:7767: warning: comparison between signed and unsigned integer expressions
if(flag_2nd_decimation >= high_Zoom_2nd_dec_rounds)
Teensy_Convolution_SDR_aw: In function 'void FrequencyBarText()':
Teensy_Convolution_SDR_aw:9140: warning: variable 'c' set but not used
char txt[16], *c;
Teensy_Convolution_SDR_aw: In function 'void buttons()':
Teensy_Convolution_SDR_aw:9951: warning: variable 'PWR_Change' set but not used
static uint8_t PWR_Change;
Teensy_Convolution_SDR_aw: In function 'void show_menu()':
Teensy_Convolution_SDR_aw:11287: warning: enumeration value 'RTTY_SHIFT_NUM' not handled in switch
switch (rtty_ctrl_config.shift_idx)
Teensy_Convolution_SDR_aw:11315: warning: enumeration value 'RTTY_SPEED_NUM' not handled in switch
switch (rtty_ctrl_config.speed_idx)
Teensy_Convolution_SDR_aw:11331: warning: enumeration value 'RTTY_STOP_NUM' not handled in switch
switch (rtty_ctrl_config.stopbits_idx)
Teensy_Convolution_SDR_aw: In function 'void alt_noise_blanking(float*, int, float*)':
Teensy_Convolution_SDR_aw:14142: warning: comparison between signed and unsigned integer expressions
} while ((search_pos < NB_FFT_SIZE - boundary_blank) && (impulse_count < 20)); // avoid upper boundary
Teensy_Convolution_SDR_aw: In function 'uint8_t CwGen_CharacterIdFunc(uint32_t)':
Teensy_Convolution_SDR_aw:16165: warning: comparison between signed and unsigned integer expressions
for (int i = 0; i<CW_CHAR_CODES; i++)
Teensy_Convolution_SDR_aw:16175: warning: comparison between signed and unsigned integer expressions
for (int i = 0; i<CW_SIGN_CODES; i++)
Teensy_Convolution_SDR_aw: In function 'void showDayOfWeek(uint8_t)':
Teensy_Convolution_SDR_aw:16980: warning: ISO C++ forbids converting a string constant to 'char*'
if ( weekday==1) { Serial.printf("MONDAY ") ; termPutStr("MONDAY ") ;}
Teensy_Convolution_SDR_aw:16981: warning: ISO C++ forbids converting a string constant to 'char*'
if ( weekday==2) { Serial.printf("TUESDAY ") ; termPutStr("TUESDAY ") ;}
Teensy_Convolution_SDR_aw:16982: warning: ISO C++ forbids converting a string constant to 'char*'
if ( weekday==3) { Serial.printf("WEDNESDAY") ; termPutStr("WEDNESDAY") ;}
Teensy_Convolution_SDR_aw:16983: warning: ISO C++ forbids converting a string constant to 'char*'
if ( weekday==4) { Serial.printf("THURSDAY ") ; termPutStr("THURSDAY ") ;}
Teensy_Convolution_SDR_aw:16984: warning: ISO C++ forbids converting a string constant to 'char*'
if ( weekday==5) { Serial.printf("FRIDAY ") ; termPutStr("FRIDAY ") ; }
Teensy_Convolution_SDR_aw:16985: warning: ISO C++ forbids converting a string constant to 'char*'
if ( weekday==6) { Serial.printf("SATURDAY ") ; termPutStr("SATURDAY ") ; }
Teensy_Convolution_SDR_aw:16986: warning: ISO C++ forbids converting a string constant to 'char*'
if ( weekday==7) { Serial.printf("SUNDAY ") ; termPutStr("SUNDAY ") ;}
Teensy_Convolution_SDR_aw: In function 'void dcfDisplayTime()':
Teensy_Convolution_SDR_aw:17402: warning: ISO C++ forbids converting a string constant to 'char*'
if ( weekday==1) { termPutStr("MONDAY ") ; }
Teensy_Convolution_SDR_aw:17403: warning: ISO C++ forbids converting a string constant to 'char*'
if ( weekday==2) { termPutStr("TUESDAY ") ; }
Teensy_Convolution_SDR_aw:17404: warning: ISO C++ forbids converting a string constant to 'char*'
if ( weekday==3) { termPutStr("WEDNESDAY") ; }
Teensy_Convolution_SDR_aw:17405: warning: ISO C++ forbids converting a string constant to 'char*'
if ( weekday==4) { termPutStr("THURSDAY ") ; }
Teensy_Convolution_SDR_aw:17406: warning: ISO C++ forbids converting a string constant to 'char*'
if ( weekday==5) { termPutStr("FRIDAY ") ; }
Teensy_Convolution_SDR_aw:17407: warning: ISO C++ forbids converting a string constant to 'char*'
if ( weekday==6) { termPutStr("SATURDAY ") ; }
Teensy_Convolution_SDR_aw:17408: warning: ISO C++ forbids converting a string constant to 'char*'
if ( weekday==7) { termPutStr("SUNDAY ") ; }
Teensy_Convolution_SDR_aw: In function 'void AudioEqualizer_display_response(uint16_t, float32_t*)':
Teensy_Convolution_SDR_aw:18562: warning: variable 'centerIdx' set but not used
int centerIdx;
Teensy_Convolution_SDR_aw: In function 'void SSB_AUTOTUNE_est(int, float*, float*, float, float*, float*, float*)':
Teensy_Convolution_SDR_aw:14442: warning: 'angl' may be used uninitialized in this function
*pshift = *ppitch * angl / (2.*pi);
Memory Usage on Teensy 4.0:
FLASH: code:258364, data:158404, headers:9208 free for files:1605640
RAM1: variables:201472, code:253960, padding:8184 free for local variables:60672
RAM2: variables:329440 free for malloc/new:194848
/Applications/Teensyduino.app/Contents/Java/hardware/tools/arm/arm-none-eabi/include/stdio.h
