Platform Manager: Installing git+https://github.com/platformio/platform-teensy.git
git version 2.32.0.windows.2
Cloning into 'C:\Users\Frank\.platformio\.cache\tmp\pkg-installing-awxnapxb'...
remote: Enumerating objects: 77, done.
remote: Counting objects: 100% (77/77), done.
remote: Compressing objects: 100% (57/57), done.
Receiving objects: 100% (77/77)used 40 (delta 6), pack-reused 0R
Receiving objects: 100% (77/77), 284.66 KiB | 1.55 MiB/s, done.
Resolving deltas: 100% (27/27), done.
[B][COLOR=#008000]..so... it was downloaded.[/COLOR][/B]
0 [main] sh (13200) C:\Program Files\Git\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1387408/0x11D7408.
[COLOR=#ff0000]This problem is probably due to using incompatible versions of the cygwin DLL.[/COLOR]
[COLOR=#ff0000]Search for cygwin1.dll using the Windows Start->Find/Search facility
and delete all but the most recent version. The most recent version *should*
reside in x:\cygwin\bin, where 'x' is the drive on which you have
installed the cygwin distribution. Rebooting is also suggested if you
are unable to find another cygwin DLL.
[/COLOR][COLOR=#008000][B]There wasn't ANY cygwin1.dll on my computer. [COLOR=#008000] There was no directory c:\cygwin.[/COLOR][COLOR=#ff0000]
[/COLOR]Installing from original cygwin(to c:\cygwin64) it did not help[/B]. [/COLOR][COLOR=#008000]Copied the directory to c:\cygwin. Did not help.[/COLOR][COLOR=#ff0000]
[/COLOR][COLOR=#008000]...continue:[/COLOR][COLOR=#ff0000]
[/COLOR]
0 [main] sh 550 dofork: child -1 - forked process 13200 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
C:/Program Files/Git/mingw64/libexec/git-core\git-submodule: fork: retry: Resource temporarily unavailable
0 [main] sh (12688) C:\Program Files\Git\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1387408/0x1357408.
1098388 [main] sh 550 dofork: child -1 - forked process 12688 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
0 [main] sh (4980) C:\Program Files\Git\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1387408/0x13B7408.
3206793 [main] sh 550 dofork: child -1 - forked process 4980 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
0 [main] sh (12480) C:\Program Files\Git\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1387408/0x11D7408.
1 [main] sh 551 dofork: child -1 - forked process 12480 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
0 [main] sh (12356) C:\Program Files\Git\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1387408/0x11D7408.
1130320 [main] sh 551 dofork: child -1 - forked process 12356 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
0 [main] sh (13004) C:\Program Files\Git\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1387408/0x1297408.
3247602 [main] sh 551 dofork: child -1 - forked process 13004 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
0 [main] sh (8524) C:\Program Files\Git\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1387408/0x1357408.
7340165 [main] sh 551 dofork: child -1 - forked process 8524 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
1 [main] sh (1812) C:\Program Files\Git\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1387408/0x1347408.
15446823 [main] sh 551 dofork: child -1 - forked process 1812 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
0 [main] sh (3996) C:\Program Files\Git\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1387408/0x12C7408.
22898433 [main] sh 550 dofork: child -1 - forked process 3996 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
/mingw64/libexec/git-core/git-sh-setup: fork: retry: Resource temporarily unavailable
0 [main] sh (4268) C:\Program Files\Git\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1387408/0x11D7408.
23997767 [main] sh 550 dofork: child -1 - forked process 4268 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
0 [main] sh (12296) C:\Program Files\Git\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1387408/0x11D7408.
26106630 [main] sh 550 dofork: child -1 - forked process 12296 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
0 [main] sh (7540) C:\Program Files\Git\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1387408/0x1307408.
30212191 [main] sh 550 dofork: child -1 - forked process 7540 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
0 [main] sh (9300) C:\Program Files\Git\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x1387408/0x11D7408.
38325132 [main] sh 550 dofork: child -1 - forked process 9300 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
/mingw64/libexec/git-core/git-sh-setup: fork: Resource temporarily unavailable
Error: VCS: Could not process command ['git', 'clone', '--recursive', '--depth', '1', 'https://github.com/platformio/platform-teensy.git', 'C:\\Users\\Frank\\.platformio\\.cache\\tmp\\pkg-installing-awxnapxb']
Der Terminalprozess "C:\Users\Frank\.platformio\penv\Scripts\platformio.exe 'run'" wurde mit folgendem Exitcode beendet: 1.
Das Terminal wird von Aufgaben wiederverwendet, drücken Sie zum Schließen eine beliebige Taste.
> Executing task in folder 210705-225231-teensy41: C:\Users\Frank\.platformio\penv\Scripts\platformio.exe run <
Processing teensy41 (platform: https://github.com/platformio/platform-teensy.git; board: teensy41; framework: arduino)
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Platform Manager: Installing git+https://github.com/platformio/platform-teensy.git
Cloning into 'C:\Users\Frank\.platformio\.cache\tmp\pkg-installing-6d2khkbf'...
Receiving objects: 98% (76/77)used 40 (delta 6), pack-reused 0 eceiving objects: 97% (75/77)
Receiving objects: 100% (77/77), 284.66 KiB | 1.87 MiB/s, done.
1 [main] sh (9724) C:\Program Files\Git\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x12E7408/0x12A7408.
0 [main] sh 580 dofork: child -1 - forked process 9724 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
0 [main] sh (10716) C:\Program Files\Git\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x12E7408/0x1397408.
1096605 [main] sh 580 dofork: child -1 - forked process 10716 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
0 [main] sh (8564) C:\Program Files\Git\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x12E7408/0x1317408.
3194076 [main] sh 580 dofork: child -1 - forked process 8564 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
0 [main] sh (12032) C:\Program Files\Git\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x12E7408/0x1337408.
7303688 [main] sh 580 dofork: child -1 - forked process 12032 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
0 [main] sh (1376) C:\Program Files\Git\usr\bin\sh.exe: *** fatal error - cygheap base mismatch detected - 0x12E7408/0x1337408.
15437702 [main] sh 580 dofork: child -1 - forked process 1376 died unexpectedly, retry 0, exit code 0xC0000142, errno 11
C:/Program Files/Git/mingw64/libexec/git-core\git-submodule: fork: Resource temporarily unavailable
Error: VCS: Could not process command ['git', 'clone', '--recursive', '--depth', '1', 'https://github.com/platformio/platform-teensy.git', 'C:\\Users\\Frank\\.platformio\\.cache\\tmp\\pkg-installing-6d2khkbf']
