Rolfdegen
Hello. I use modified (exponential) envelopes from the Teensy audio lib by P.Steffregen in my synthesizer project. When I use effect_envelope.delay the envelope freezes after a while. Paul's original effect_envelope.delay function works without problems.
Thanks for help
modified envelope
Thanks for help
modified envelope
C++:
/* Audio Library for Teensy 3.X
* Portions Copyright (c) 2017, Paul Stoffregen, paul@pjrc.com
* Portions Copyright (c) 2021 Vince R. Pearson
* Development of this audio library was funded by PJRC.COM, LLC by sales of
* Teensy and Audio Adaptor boards. Please support PJRC's efforts to develop
* open source software by purchasing Teensy or other PJRC products.
* THE SOFTWARE.
#ifndef effect_envelope_h_
#define effect_envelope_h_
#include "Arduino.h"
#include "AudioStream.h"
#include "utility/dspinst.h"
#define SAMPLES_PER_MSEC (AUDIO_SAMPLE_RATE_EXACT / 1000.0)
#define EXP_ENV_ONE ((int32_t)0x40000000)
// Envelope type. EXP_Nx are attacks with different amounts of negative curvature. EXP_Px have positive curvature.
// EXP_0 has a linear attack.
#define NUM_ENV_TYPES 18 // Linear, Exp -8 through Exp +8
// Fast Sustain Time Constant for Exp Envelope
// Normally changes in sustain level while in sustain are subject to the decay delay setting.
// Here we sense a change in sustain level and kick the state machine into a state with a faster time constant.
// This filter time constant is precalculated during compile.
// Time constant = exp(-Ts/To).
#define FAST_SUSTAIN_KF 0.999773268 // 100 ms
// #define FAST_SUSTAIN_KF 0.999886627 // 200 ms
// #define FAST_SUSTAIN_KF 0.999943312 // 400 ms
// #define FAST_SUSTAIN_KF 0.999971655 // 800 ms
#define FAST_SUSTAIN_K1 (uint32_t)(FAST_SUSTAIN_KF * EXP_ENV_ONE)
// The exponential difference equations are based on the impulse invariant method.
// The equation used for attack is k1 = exp(curveFactor*Ts/To) and k2=(k1-1)/((e^curveFactor)-1)
// This allows different eponential curvatures (positive and negative) with the endpoints constrained
// to start at 0 and end at 1 (normalized) in the specified time interval.
// and ynew = k1*yold+k2 (normalized).
// The funtion for the k2 term is a continous funtion of curveFactor through zero, but it is an indeterminate form at zero that
// This causes problems with finite precision math when approaching zero from either side (like the sinc funtion sin(x)/x but worse).
// It can be expressed as a continous function using a ratio of power series but it is simpler to restrict the values to integers
// between -8 and 8 treating zero as a special case (linear ramp).
// The other stages use y(n+1)=k*(y(n)-target)+target where k=exp(-Ts/To)(normalized).
class AudioEffectEnvelopeTS : public AudioStream
public:
AudioEffectEnvelopeTS() : AudioStream(1, inputQueueArray)
state = 0;
env_type = -128; // Added for addition of exponential envelope. Default is linear. -8 through 8 are different amounts of positive and negative curvature.
delay(6.0f); // default values...
attack(10.5f);
hold(2.5f);
decay(35.0f);
sustain(0.5f);
release(300.0f);
releaseNoteOn(0.0f);
void noteOn();
void noteOff();
FLASHMEM void delay(float milliseconds)
delay_count = milliseconds2count(milliseconds); // Number of samples is 8 times this number for linear mode.
__disable_irq();
if (state == STATE_IDLE_NEXT)
state = STATE_IDLE; // Force counter reload if in STATE_IDLE_NEXT.
__enable_irq();
// Attack curve negative numbers generate negative curvature (like typical exp attack curves).
// Positive numbers generate positive curvature (accelerating upward).
// Zero produces linear attack curve.
// This is used to change the time constant and target value to enforce zero to full scale in
// the requested attack time.
// The equation used for the input, (1-e^(curve_factor*Ts/To))(e^curve_factor-1) is singular at curve_factor=0.
// The precision required starts to blow up as abs(curve_factor) approaches zero at which there is a singularity.
// The function is however continuous through zero and can be expressed as a ratio of power series but it is easier to restrict the
// curve factors to be integers and to treat zero as a special case which is a linear ramp.
// The numbers are additionally restricted to -8 to +8 as numbers outside this range asymptotically approach a step function.
FLASHMEM void setEnvType(int8_t type)
env_type = type;
updateExpAttack(); // Exponential attack parameters need updating.
FLASHMEM int8_t getEnvType() { return env_type; };
FLASHMEM void attack(float milliseconds)
attack_count = milliseconds2count(milliseconds);
if (attack_count == 0)
attack_count = 1; //************* added check for div/0
updateExpAttack();
FLASHMEM void hold(float milliseconds)
hold_count = milliseconds2count(milliseconds);
FLASHMEM void decay(float milliseconds)
decay_count = milliseconds2count(milliseconds);
if (decay_count == 0)
decay_count = 1;
updateExpDecay();
FLASHMEM void sustain(float level)
if (level < 0.0)
level = 0;
else if (level > 1.0)
level = 1.0;
// Exponential generator uses same sustain variable.
sustain_mult = level * 1073741824.0;
__disable_irq();
if (state == STATE_DECAY || state == STATE_SUSTAIN)
state = STATE_SUSTAIN_FAST_CHANGE;
__enable_irq();
FLASHMEM void release(float milliseconds)
release_count = milliseconds2count(milliseconds);
if (release_count == 0)
release_count = 1;
updateExpRelease();
FLASHMEM void releaseNoteOn(float milliseconds)
release_forced_count = milliseconds2count(milliseconds);
updateExpReleaseNoteOn();
// ElectroTechnique 2020 - close the envelope to silence it
FLASHMEM void close()
__disable_irq();
mult_hires = 0; // Zero gain
inc_hires = 0; // Same as STATE_DELAY
state=STATE_IDLE; // Added, VRP. Shouldn't this be in the idle state when closed?
ysum = 0;
__enable_irq();
bool isActive();
bool isSustain();
using AudioStream::release;
virtual void update(void);
private:
uint16_t milliseconds2count(float milliseconds)
if (milliseconds < 0.0)
milliseconds = 0.0;
uint32_t c = ((uint32_t)(milliseconds * SAMPLES_PER_MSEC) + 7) >> 3;
if (c > 65535)
c = 65535; // allow up to 11.88 seconds
return c;
FLASHMEM void updateExpDecay() // needed in case sustain changes.
double k;
k = exp(-1.0L / (decay_count * 4.0L));
decay_k = (uint32_t)(EXP_ENV_ONE * k);
// decay_target=(1.0L-k)*sustain_target;
void updateExpAttack() // This is needed in case env type changes.
double k1, k2;
if (env_type > 8 || env_type < -8)
return; // Anything outside this range is a linear envelope.
if (env_type == 0) // Linear attack. Everything else is exponential.
attack_k = EXP_ENV_ONE;
attack_target = (uint32_t)(EXP_ENV_ONE / (attack_count * 8.0L));
k1 = exp((double)env_type / (attack_count * 8.0L));
k2 = (k1 - 1.0L) / (exp((double)env_type) - 1.0L);
attack_k = (uint32_t)(EXP_ENV_ONE * k1);
attack_target = (uint32_t)(EXP_ENV_ONE * k2);
FLASHMEM void updateExpRelease()
double k;
k = exp(-1.0L / (release_count * 4.0L));
release_k = (uint32_t)(EXP_ENV_ONE * k);
FLASHMEM void updateExpReleaseNoteOn()
double k;
// Increased forced release rate x4 so it will end before the next note off call.
// Unlike linear mode this time is dependant on sustain level and release rate. It may be better to implement this state as a linear ramp with a fixed time
// for consistent behaviour.
k = exp(-4.0L / (release_forced_count * 8.0L));
release_forced_k = (uint32_t)(EXP_ENV_ONE * k);
audio_block_t *inputQueueArray[1];
static const uint8_t env_type_values[NUM_ENV_TYPES];
// state
uint8_t state; // idle, delay, attack, hold, decay, sustain, release, forced (now idle_next)
uint16_t count; // how much time remains in this state, in 8 sample units
int32_t mult_hires; // attenuation, 0=off, 0x40000000=unity gain
int32_t inc_hires; // amount to change mult_hires every 8 samples
// settings
uint16_t delay_count;
uint16_t attack_count;
uint16_t hold_count;
uint16_t decay_count;
int32_t sustain_mult; // Shared with exponential envelope generator.
uint16_t release_count;
uint16_t release_forced_count;
enum
{ // Make this a private class enum set instead of using defines.
STATE_IDLE,
STATE_DELAY,
STATE_ATTACK,
STATE_HOLD,
STATE_DECAY,
STATE_SUSTAIN,
STATE_SUSTAIN_FAST_CHANGE,
STATE_RELEASE,
STATE_FORCED,
STATE_IDLE_NEXT, // Not used for original linear envelope.
// Exponential ADSR variables
int8_t env_type; // Attack curve type. Limit to -8 to 8 integers for exp curve, -128 for original linear.
uint32_t exp_count; // same function as count in linear generator but for single samples, not groups of 8.
int32_t ysum;
int32_t attack_k;
int32_t attack_target;
int32_t decay_k;
int32_t release_k;
int32_t release_forced_k;
#undef SAMPLES_PER_MSEC
* THE SOFTWARE.
#include <Arduino.h>
#include "effect_envelope.h"
#define RELEASE_BIAS 256 // based on a 1.31 fixed point integer. This is the level below zero that is the release target and causes the output to go to zero earlier. Otherwise it can take a relatively long time.
// Difference equation for exponential envelope.
#define FORCED_RELEASE_BIAS 0x1000000 // empirically determined with forced release time constant to attain ~5ms between forced release and next attack.
// Form 1 for attack stage: y(n+1) = k1*y(n)+kx using unsigned S1.30 fixed point format
#define EXP_ENV_FILT1(k,y,x) ((uint32_t)(((uint64_t)(y)*(k))>>30)+(uint32_t)(x))
// Form 2 for remaining stages: y(n+1) = k1*(y(n)-x(n))+x(n) using unsigned S1.30 fixed point format
#define EXP_ENV_FILT2(k,y,x) ((((int64_t)(k)*(int64_t)(y-x))>>30)+(x))
#define YSUM2MULT(x) ((x)>>14)
void AudioEffectEnvelopeTS::noteOn(void)
//__disable_irq();
if(release_forced_count==0)
state=STATE_IDLE;
switch(state)
case STATE_IDLE:
case STATE_IDLE_NEXT:
count=delay_count;
if(count>0)
state=STATE_DELAY;
inc_hires=0;
state=STATE_ATTACK;
count=attack_count;
inc_hires = 0x40000000 / (int32_t)count;
case STATE_DELAY:
case STATE_HOLD:
case STATE_ATTACK:
case STATE_DECAY:
case STATE_SUSTAIN:
case STATE_SUSTAIN_FAST_CHANGE:
case STATE_RELEASE:
state=STATE_FORCED;
count=release_forced_count;
inc_hires=(-mult_hires)/(int32_t)count;
case STATE_FORCED:
default:
state=STATE_RELEASE;
//__enable_irq();
void AudioEffectEnvelopeTS::noteOff(void)
//__disable_irq();
switch(state)
case STATE_IDLE:
case STATE_DELAY:
state=STATE_IDLE;
default:
state = STATE_RELEASE;
count = release_count;
inc_hires = (-mult_hires) / (int32_t)count;
// __enable_irq();
void AudioEffectEnvelopeTS::update(void)
audio_block_t *block;
uint32_t *p, *end;
uint32_t sample12, sample34, sample56, sample78, tmp1, tmp2;
uint32_t exp_mult[8];
block = receiveWritable();
if (!block) return;
if (state == STATE_IDLE) {
release(block);
return;
p = (uint32_t *)(block->data);
end = p + AUDIO_BLOCK_SAMPLES/2;
if(env_type==-128)
{ // Original AudioEffectEnvelope class linear envelope.
while (p < end) {
// we only care about the state when completing a region
if (count == 0) {
if (state == STATE_ATTACK) {
count = hold_count;
if (count > 0) {
state = STATE_HOLD;
mult_hires = 0x40000000;
inc_hires = 0;
state = STATE_DECAY;
count = decay_count;
inc_hires = (sustain_mult - 0x40000000) / (int32_t)count;
continue;
} else if (state == STATE_HOLD) {
continue;
} else if (state == STATE_DECAY) {
state = STATE_SUSTAIN;
count = 0xFFFF;
mult_hires = sustain_mult;
inc_hires = 0;
} else if (state == STATE_SUSTAIN) {
count = 0xFFFF;
} else if (state == STATE_RELEASE) {
state = STATE_IDLE;
while (p < end) {
*p++ = 0;
*p++ = 0;
*p++ = 0;
*p++ = 0;
} else if (state == STATE_FORCED) {
mult_hires = 0;
count = delay_count;
if (count > 0) {
state = STATE_DELAY;
inc_hires = 0;
state = STATE_ATTACK;
count = attack_count;
} else if (state == STATE_DELAY) {
inc_hires = 0x40000000 / count;
continue;
state=STATE_IDLE; // If in some unused state switching back into linear mode, set to known state that linear mode uses.
count=delay_count;
int32_t mult = mult_hires >> 14;
int32_t inc = inc_hires >> 17;
// process 8 samples, using only mult and inc (16 bit resolution)
sample12 = *p++;
sample34 = *p++;
sample56 = *p++;
sample78 = *p++;
p -= 4;
mult += inc;
tmp1 = signed_multiply_32x16b(mult, sample12);
mult += inc;
tmp2 = signed_multiply_32x16t(mult, sample12);
sample12 = pack_16b_16b(tmp2, tmp1);
mult += inc;
tmp1 = signed_multiply_32x16b(mult, sample34);
mult += inc;
tmp2 = signed_multiply_32x16t(mult, sample34);
sample34 = pack_16b_16b(tmp2, tmp1);
mult += inc;
tmp1 = signed_multiply_32x16b(mult, sample56);
mult += inc;
tmp2 = signed_multiply_32x16t(mult, sample56);
sample56 = pack_16b_16b(tmp2, tmp1);
mult += inc;
tmp1 = signed_multiply_32x16b(mult, sample78);
mult += inc;
tmp2 = signed_multiply_32x16t(mult, sample78);
sample78 = pack_16b_16b(tmp2, tmp1);
*p++ = sample12;
*p++ = sample34;
*p++ = sample56;
*p++ = sample78;
// adjust the long-term gain using 30 bit resolution (fix #102)
// https://github.com/PaulStoffregen/Audio/issues/102
mult_hires += inc_hires;
count--;
else //Exponential ADSR Vince R. Pearson
while (p < end)
for (uint8_t i = 0; i < 8; i++)
switch(state)
case STATE_IDLE:
// Since delay counts may not necessarily start at aligned boundaries of 8 samples,
// the loop count has to be multiplied by 8
// and counted down in the for loop, not in the while loop.
exp_count=((uint32_t)(delay_count))*8;
ysum=0;
state=STATE_IDLE_NEXT; // Do this so reinitialization is only done once at every idle state.
// Falls through to STATE_IDLE_NEXT
break; //ysum is zero here
case STATE_DELAY:
if(exp_count--) break; // ysum is zero here
state=STATE_ATTACK;
case STATE_ATTACK:
ysum=EXP_ENV_FILT1(attack_k,ysum,attack_target);
if(ysum>=EXP_ENV_ONE)
{ // The maximum 32 bit value of the envelope has been reached.
ysum=EXP_ENV_ONE;
if(hold_count)
exp_count=((uint32_t)hold_count)*8;
state=STATE_HOLD;
state=STATE_DECAY;
exp_count=((uint32_t)delay_count)*8; // Only used to arbitrarioly define where sustain begins.
case STATE_HOLD:
if((exp_count--)==0)
state=STATE_DECAY; // ysum is maximum here (ENV_MAX_32).
case STATE_DECAY:
if((exp_count--)==0) state=STATE_SUSTAIN;
// Sustain is only needed to support isRelease(). This happens after delay_count is decremented to zero.
// The point at which sustain begins after the start of decay is arbitrary on an exponential curve
// Here it occurs after one time constant (delay_count*8) which is 63.2% down the decay curve.
ysum=EXP_ENV_FILT2(decay_k,ysum,sustain_mult);
case STATE_SUSTAIN: // Gets here from decay when delay count is zero. Used to flag when sustain begins.
case STATE_SUSTAIN_FAST_CHANGE: // Only gets here when sustain is changed while in decay or any sustain states.
ysum=EXP_ENV_FILT2(FAST_SUSTAIN_K1,ysum,sustain_mult);
case STATE_RELEASE:
ysum=EXP_ENV_FILT2(release_k,ysum,-RELEASE_BIAS);
if(ysum<0) ysum=0;
// Bias added to end release a bit sooner. Value must be checked for underflow since unsigned integers are used.
// This has affects the longest release settings the most since it is not scaled with the release time constant.
if(YSUM2MULT(ysum)==0) // All of the useful bits are zero so no reason to stay in this state.
state=STATE_IDLE;
case STATE_FORCED:
ysum=EXP_ENV_FILT2(release_forced_k,ysum,-FORCED_RELEASE_BIAS);
if(YSUM2MULT(ysum)<=0)
state=STATE_ATTACK;// revert to IDLE state when useful bits are zero.
ysum=0;
default:
exp_mult[i]=YSUM2MULT(ysum);
// multiply audio samples with 8 envelope samples
sample12 = *p++;
sample34 = *p++;
sample56 = *p++;
sample78 = *p++;
p -= 4;
tmp1 = signed_multiply_32x16b(exp_mult[0], sample12);
tmp2 = signed_multiply_32x16t(exp_mult[1], sample12);
tmp1 = signed_multiply_32x16b(exp_mult[2], sample34);
tmp2 = signed_multiply_32x16t(exp_mult[3], sample34);
tmp1 = signed_multiply_32x16b(exp_mult[4], sample56);
tmp2 = signed_multiply_32x16t(exp_mult[5], sample56);
tmp1 = signed_multiply_32x16b(exp_mult[6], sample78);
tmp2 = signed_multiply_32x16t(exp_mult[7], sample78);
*p++ = sample12;
*p++ = sample34;
*p++ = sample56;
*p++ = sample78;
transmit(block);
release(block);
bool AudioEffectEnvelopeTS::isActive()
uint8_t current_state = *(volatile uint8_t *)&state;
if ((current_state == STATE_IDLE)|| (current_state==STATE_IDLE_NEXT)) return false; // Added STATE_IDLE_NEXT. VRP
return true;
bool AudioEffectEnvelopeTS::isSustain()
if (current_state == STATE_SUSTAIN || current_state==STATE_SUSTAIN_FAST_CHANGE) return true;
return false;
