Hello, fine folks.
I've been messing around with a Teensy-LC with an Audio Shield, and it's pretty neat. I've got a simple piezo triggered kick drum project going, and I found it convenient to have a sample playback class that could generate stereo, with optional phase inversion. This lets me get push-pull output from the DAC for differential output.
While doing this I found the AudioAmplifier object was broken for KINETISL processors, so I fixed the part I was using.
I put pull requests in to Paul's github repo, and the code can be tried out from my fork at https://github.com/timnbraun/Audio
The mixer.cpp file gets three lines changed :
/* Audio Library for Teensy 3.X
* Copyright (c) 2014, Paul Stoffregen, paul@pjrc.com
* Development of this audio library was funded by PJRC.COM, LLC by sales of
* Teensy and Audio Adaptor boards. Please support PJRC's efforts to develop
* open source software by purchasing Teensy or other PJRC products.
* THE SOFTWARE.
#include <Arduino.h>
#include "mixer.h"
#include "utility/dspinst.h"
#if defined(__ARM_ARCH_7EM__)
#define MULTI_UNITYGAIN 65536
static void applyGain(int16_t *data, int32_t mult)
uint32_t *p = (uint32_t *)data;
const uint32_t *end = (uint32_t *)(data + AUDIO_BLOCK_SAMPLES);
do {
uint32_t tmp32 = *p; // read 2 samples from *data
int32_t val1 = signed_multiply_32x16b(mult, tmp32);
int32_t val2 = signed_multiply_32x16t(mult, tmp32);
val1 = signed_saturate_rshift(val1, 16, 0);
val2 = signed_saturate_rshift(val2, 16, 0);
*p++ = pack_16b_16b(val2, val1);
} while (p < end);
static void applyGainThenAdd(int16_t *data, const int16_t *in, int32_t mult)
uint32_t *dst = (uint32_t *)data;
const uint32_t *src = (uint32_t *)in;
if (mult == MULTI_UNITYGAIN) {
do {
uint32_t tmp32 = *dst;
*dst++ = signed_add_16_and_16(tmp32, *src++);
tmp32 = *dst;
} while (dst < end);
do {
uint32_t tmp32 = *src++; // read 2 samples from *data
tmp32 = pack_16b_16b(val2, val1);
uint32_t tmp32b = *dst;
*dst++ = signed_add_16_and_16(tmp32, tmp32b);
#elif defined(KINETISL)
const int16_t *end = data + AUDIO_BLOCK_SAMPLES;
do {
int32_t val = *data * mult;
*data++ = signed_saturate_rshift(val, 16, 16);
} while (data < end);
static void applyGainThenAdd(int16_t *dst, const int16_t *src, int32_t mult)
const int16_t *end = dst + AUDIO_BLOCK_SAMPLES;
do {
int32_t val = *dst + *src++;
*dst++ = signed_saturate_rshift(val, 16, 0);
do {
int32_t val = *dst + signed_saturate_rshift(*src++ * mult, 16, 16); // overflow possible??
void AudioMixer4::update(void)
audio_block_t *in, *out=NULL;
unsigned int channel;
for (channel=0; channel < 4; channel++) {
if (!out) {
out = receiveWritable(channel);
if (out) {
int32_t mult = multiplier[channel];
if (mult != MULTI_UNITYGAIN) applyGain(out->data, mult);
in = receiveReadOnly(channel);
if (in) {
applyGainThenAdd(out->data, in->data, multiplier[channel]);
release(in);
if (out) {
transmit(out);
release(out);
void AudioAmplifier::update(void)
audio_block_t *block;
int32_t mult = multiplier;
if (mult == 0) {
// zero gain, discard any input and transmit nothing
block = receiveReadOnly(0);
if (block) release(block);
} else if (mult == MULTI_UNITYGAIN) {
// unity gain, pass input to output without any change
if (block) {
transmit(block);
release(block);
// apply gain to signal
block = receiveWritable(0);
if (block) {
applyGain(block->data, mult);
transmit(block);
release(block);
