Thundercat
Hi all, I'm trying to use the Teensy loader to upload a firmware image to a brand new Teensy 4.0 that has been security locked. I've done it a million times with these.
Today when I try to flash, nothing happens. The icon in the Teensy loader changes briefly to let me know the button has been pressed, then it turns back to gray and...nothing.
I tried a different cable, and also tried connecting directly to a computer vs using a hub. Both have worked fine in past.
I'm on macOS Tahoe 26.7.1, M3 laptop.
Here's the teensy loader log...
I also noticed that the Teensy has both the red and orange lights flashing about 2x/second, which I've never seen before.
This is also happening with another brand new Teensy 4.0 (security locked as well), so it can't just be a "bad" Teensy or something.
Does any one have any clues? This is a little scary because it's on a product I make, and as stated, I've done this tons of times before no issues.
Thanks,
Mike
12:53:29.187 (loader): Teensy Loader 1.59-beta3, begin program
12:53:29.268 (loader): Listening for remote control on port 3149
12:53:29.269 (loader): initialized, showing main window
12:53:32.996 (loader): Open File event
12:53:41.936 (loader): File "/Users/Mikey/Documents/0 MusioTech/Firmware Upgrades/Current/Fader_Pro_Premium_V6_31_SE.ino.TEENSY40.ehex", 1948672 bytes, and 5536 loader utility
12:53:41.939 (loader): ehex is valid, public key hash: 6031B41E 303B7C97 9E4D450D B0511B03 2DD5AB90 3A1263AF 8EA5DD73 860FAC41
12:53:41.940 (loader): File "Fader_Pro_Premium_V6_31_SE.ino.TEENSY40.ehex". 1948672 bytes
12:53:48.683 (loader): HID/macos: attach callback
12:53:48.768 (loader): HID/macos: number of devices found = 1
12:53:48.770 (loader): HID/macos: vid=1FC9, pid=0135, page=FF00, usage=0001, ver=1.01
12:53:48.776 (loader): Device came online, code_size = 100
12:53:48.778 (loader): Board is: NXP IMXRT1062 ROM
12:53:48.779 (loader): begin operation
12:53:48.896 (loader): File "/Users/Mikey/Documents/0 MusioTech/Firmware Upgrades/Current/Fader_Pro_Premium_V6_31_SE.ino.TEENSY40.ehex", 1948672 bytes, and 5536 loader utility
12:53:48.899 (loader): ehex is valid, public key hash: 6031B41E 303B7C97 9E4D450D B0511B03 2DD5AB90 3A1263AF 8EA5DD73 860FAC41
12:53:48.899 (loader): File "Fader_Pro_Premium_V6_31_SE.ino.TEENSY40.ehex". 1948672 bytes
12:53:48.921 (loader): set background IMG_ONLINE
12:53:48.927 (loader): HAB locked secure mode
12:53:48.929 (loader): sending ehex loader utility, 5536 bytes
12:53:48.935 (loader): run it..
12:53:49.008 (loader): HID/macos: detach callback: is currently open device
12:53:49.054 (loader): ehex loader utility sucessfully started
12:53:49.055 (loader): HID/macos: status: disconnected
12:53:49.055 (loader): end operation, total time = 0.275 seconds
12:53:49.056 (loader): redraw timer set, image 80 to show for 2000 ms
12:53:49.268 (loader): HID/macos: number of devices found = 0
12:53:49.270 (loader): HID/macos: no devices found (empty set)
12:53:51.057 (loader): redraw, image 9
12:53:54.354 (loader): Verbose Info event
12:54:13.751 (loader): HID/macos: attach callback
12:54:13.871 (loader): Device came online, code_size = 100
12:54:13.873 (loader): Board is: NXP IMXRT1062 ROM
12:54:13.874 (loader): begin operation
12:54:13.988 (loader): File "/Users/Mikey/Documents/0 MusioTech/Firmware Upgrades/Current/Fader_Pro_Premium_V6_31_SE.ino.TEENSY40.ehex", 1948672 bytes, and 5536 loader utility
12:54:13.992 (loader): ehex is valid, public key hash: 6031B41E 303B7C97 9E4D450D B0511B03 2DD5AB90 3A1263AF 8EA5DD73 860FAC41
12:54:13.993 (loader): File "Fader_Pro_Premium_V6_31_SE.ino.TEENSY40.ehex". 1948672 bytes
12:54:14.015 (loader): set background IMG_ONLINE
12:54:14.037 (loader): HAB locked secure mode
12:54:14.043 (loader): sending ehex loader utility, 5536 bytes
12:54:14.051 (loader): run it..
12:54:14.108 (loader): HID/macos: detach callback: is currently open device
12:54:14.187 (loader): ehex loader utility sucessfully started
12:54:14.191 (loader): HID/macos: status: disconnected
12:54:14.193 (loader): end operation, total time = 0.318 seconds
12:54:14.195 (loader): redraw timer set, image 80 to show for 2000 ms
12:54:14.267 (loader): HID/macos: number of devices found = 0
12:54:14.269 (loader): HID/macos: no devices found (empty set)
12:54:16.196 (loader): redraw, image 9
12:54:39.104 (loader): HID/macos: attach callback
12:54:39.268 (loader): Device came online, code_size = 100
12:54:39.273 (loader): Board is: NXP IMXRT1062 ROM
12:54:39.276 (loader): begin operation
12:54:39.394 (loader): File "/Users/Mikey/Documents/0 MusioTech/Firmware Upgrades/Current/Fader_Pro_Premium_V6_31_SE.ino.TEENSY40.ehex", 1948672 bytes, and 5536 loader utility
12:54:39.398 (loader): ehex is valid, public key hash: 6031B41E 303B7C97 9E4D450D B0511B03 2DD5AB90 3A1263AF 8EA5DD73 860FAC41
12:54:39.399 (loader): File "Fader_Pro_Premium_V6_31_SE.ino.TEENSY40.ehex". 1948672 bytes
12:54:39.421 (loader): set background IMG_ONLINE
12:54:39.430 (loader): HAB locked secure mode
12:54:39.436 (loader): sending ehex loader utility, 5536 bytes
12:54:39.443 (loader): run it..
12:54:39.524 (loader): HID/macos: detach callback: is currently open device
12:54:39.582 (loader): ehex loader utility sucessfully started
12:54:39.585 (loader): HID/macos: status: disconnected
12:54:39.587 (loader): end operation, total time = 0.308 seconds
12:54:39.589 (loader): redraw timer set, image 80 to show for 2000 ms
12:54:39.787 (loader): HID/macos: number of devices found = 0
12:54:39.789 (loader): HID/macos: no devices found (empty set)
12:54:41.590 (loader): redraw, image 9
Thanks,
Mike
