teensy mtp - windows explorer shows teensy - how can i change the name?
Fluxanode
I think my question has already been answered but I can't find it, how can i change the name MTP shows from teensy?
If memory serves me correctly "Teensy" is hardcoded into the library. If you look in MTP_Teensy.h (assuming you are using @KurtE's github version) you will see:
#include "MTP_Storage.h"
// modify strings if needed (see MTP.cpp how they are used)
#define MTP_MANUF "PJRC"
#define MTP_MODEL "Teensy"
#define MTP_VERS "1.0"
#define MTP_SERNR "1234"
#define MTP_NAME "Teensy"
You would have to change MTP_NAME to want you want - no programmatical way to change it.
Paul's version will take over. https://github.com/PaulStoffregen/MTP_Teensy
However I am not sure what his current plans are. That is at one point he was going to integrate MTP probably
directly into the core project, like all of the other USB types. At that point hopefully there will be settings in the header files
to make it easier to customize.
Although not sure if it is any easier/harder to change places like usbdesc.h or MTP_Teensy.h...
I was messing around with MTP and made the above changes to MTP_Teensy.h with one of the example programs and now the teensy 4.1 won't show up as a usb device in Arduino. The comm port (com4) shows but not the HID. I can't program it any longer. Did i break something?
Error is
Teensy should be selected from "teensy ports" rather
than "Serial ports" in Arduino's Tools > Port menu
No Teensy boards were found on any USB ports of your computer.
program:
 SD datalogger
  This example shows how to log data from three analog sensors
  to a storage device such as a microSD card.
#include <MTP_Teensy.h>
File dataFile; // Specifies that dataFile is of File type
int record_count = 0;
bool write_data = false;
/////////////////////////////////////////////Setup/////////////////////////
  while (!Serial) {
    // wait for serial port to connect.
  Serial.print("Initializing SD card ...");
  if (!SD.begin(BUILTIN_SDCARD)) {
    Serial.println("Error mounting SD card!");
    while (1) {
      // Error, so don't do anything more - stay stuck here
  MTP.begin();
  MTP.addFilesystem(SD, "SD");
  Serial.println("SD card initialized.");
  menu();
/////////////////////////////////////////////main loop//////////////////////
  MTP.loop();
  if (write_data) {
    logData();
  if (Serial.available()) {
    char rr = Serial.read();
    switch (rr) {
      case 'l':
        listFiles();
      case 'e':
        eraseFiles();
      case 's':
        Serial.println("\nLogging Data!!!");
        write_data = true; // continue writing data until stopped
        dataFile = SD.open("datalog.txt", FILE_WRITE);
        logData();
      case 'x':
        stopLogging();
      case 'd':
        dumpLog();
      case '\r':
      case '\n':
      case 'h':
        menu();
    while (Serial.read() != -1);
///////////////////////////////////////////////////////////////////////END OF main
void logData() {
  // assemble the data to log:
  String dataString;
  // read three sensors and append to the string:
  for (int analogPin = 0; analogPin < 3; analogPin++) {
    int sensor = analogRead(analogPin);
    dataString += String(sensor);
    if (analogPin < 2) dataString += ",";
  if (dataFile) {
    dataFile.println(dataString);
    Serial.println(dataString);
    record_count++;
    Serial.println("error opening datalog.txt");
void stopLogging() {
  Serial.println("\nStopped Logging Data!!!");
  write_data = false;
  dataFile.close();
  Serial.printf("Records written = %d\n", record_count);
  MTP.reset();
void dumpLog() {
  Serial.println("\nDumping Log!!!");
  dataFile = SD.open("datalog.txt");
  if (dataFile) {
    while (dataFile.available()) {
      Serial.write(dataFile.read());
    dataFile.close();
void menu() {
  Serial.println("Menu Options:");
  Serial.println("\tl - List files on disk");
  Serial.println("\te - Erase log file");
  Serial.println("\ts - Start Logging data");
  Serial.println("\tx - Stop Logging data");
  Serial.println("\td - Dump Log");
  Serial.println("\th - Menu");
void listFiles() {
  Serial.println("\nDirectory\n---------");
  printDirectory(SD.open("/"), 0);
void eraseFiles() {
  if (SD.exists("datalog.txt")) {
    SD.remove("datalog.txt");
  Serial.println("\nLog erased!");
  MTP.reset();
void printDirectory(File dir, int numSpaces) {
  while (true) {
    File entry = dir.openNextFile();
    if (!entry) break;
    for (int i = 0; i < numSpaces; i++) Serial.print(" ");
    Serial.print(entry.name());
    if (entry.isDirectory()) {
      Serial.println("/");
      printDirectory(entry, numSpaces + 2);
      for (int i = 0; i < (36 - numSpaces - strlen(entry.name())); i++) Serial.print(" ");
      Serial.print("  ");
      Serial.println(entry.size(), DEC);
    entry.close();
I tested with a new teensy by plugging it into the usb and it behaves as it should but i have not attempted to program it as i don't need it broken too
ok got it back after several resets...
Can someone look over my example program and see if there is anything that could have screwed it up?
topic was started with "change Name of MTP device apearing in window explorer" . i also tried as mentioned in post#2
C++:
in " MTP_Teensy.h" but no changes. is this issue been solved
please reply if any get completed
Sorry what version of Teensyduino are you running? Where is MTP coming from. Over that last several iterations Paul took it over.
Before that my directory was probably the most recent. For what Teensy? As far as I can tell, Paul has only merged it into his current
sources for the Teensy 4.x boards. But I think this is only currently in the current Beta release.
If you are using the current beta it is in the file cores\teensy4\MTP_Teensy.h
If you are using different version, it should be in the library sources that you are using. Either mine or Paul's, where the Paul's is the
version that is being merged into the core and I have not touched it in a long time.
Thank you Kurte ,,,
you are right. i was wrong . i was editing in
C:\Users\acer\Documents\Arduino\libraries\MTP_Teensy-pauls_branch\src\MTP_Teensy.h
now it is working....
Thank you..
C:\Program Files\Arduino\hardware\teensy\avr\cores\teensy4\MTP_Teensy.h
in this file , Name modification working..
I have edited MTP_Teensy.h and still cannot get the drive name to change? I am using the latest Arduino 2 with VS Visual Micro. I even asked CHATgpt and it came to the conclusion that it can't be done?
Sorry I don't use VS Micro... but:
I edited the file <Arduino15>\packages\teensy\hardware\avr\1.60.0\cores\teensy4\MPT_Teensy.h
I changed the section like:
#define MTP_MODEL "Kurts_Teensy"
#define MTP_NAME "Kurts_Teensy"
I rebuilt my picture viewer sketch and now I have:
So it appears to work for me, I was also able to copy in a new image, which displayed
Thanks guys - i found it in C:\Users\User\AppData\Local\Arduino15\packages\teensy\hardware\avr\1.60.0\cores\teensy4. i had changed the one in libraries in the Sketch folder but that only changed part of the label not the drive name in explorer but the name under it did change. Why would MTP only get part of the setting from one location and not both from the local libraries location?
Anyway it's fixed now thanks.
Because one is the device name, the other is the volume name. A device can host multiple volumes.
