Teensy synth project - a few issues
MountSquishy
Hello! I have been working on a synthesizer with the Teensy Audio Library on a Teensy 4.1. It is working pretty well so far, but there are a few issues that I can't seem to resolve on my own.
Issues-
Potentiometer readings - So I have two pots that I am having a strange issue with. Basically, I have 2 different lfo waves that are sent to my waveform1, and my filter. The waveform1 input is meant to control the PhaseModulation (which I don't fully understand either). When I map the pot input to a value between 0 and 1, turning the pot doesnt give me a smooth amount of amplitude, it basically has a point where it is either on, or off. How would I fix this to cover the whole range between 0 and 1 of amplitude?
Cracking, tearing sound - this seems to be caused by the filter lfo. When I have the filter lfo at certain settings, specifcally 0 resonance, and maximum cutoff(open), I sometimes get a loud clicking or tearing sound that is brutal on the ears. I have fixed this through limiting my cutoff frequency range, and lfo speed, but I don't think this is right, if anything, I should be getting this problem with the resonance on full, instead of off.
Clicking when inputing notes - When I play notes in through midi, I sometimes get a faint click at the start of the note, not always, but about 50% of the time, and I can find no pattern. I have my midi circuit wired correctly, and connected to its own power and ground pin.
Can anyone help with this? Thank you so much! I am learning a ton doing this project. I am a musician first, and am learning as I go, so any help would be greatly appreciated!
#include <SerialFlash.h>
#include <MIDI.h>
#define POLY_COUNT 7
struct waveform_modulator {
  AudioSynthWaveformModulated waveform1;
  AudioEffectEnvelope envelope1;
  int note;
  boolean in_use;
  unsigned long note_start_time;
waveform_modulator poly_waveforms[POLY_COUNT];
AudioEffectFreeverb       freeverb1;
AudioEffectDelay          delay1;
AudioSynthWaveform        lfo;
AudioSynthWaveform        lfo2;
AudioSynthWaveform        lfo3;
AudioMixer4               mixer1;
AudioMixer4               mixer2;
AudioMixer4               mixer3;
AudioMixer4               mixer4;
AudioMixer4               mixer5;
AudioFilterStateVariable filter1;
AudioOutputI2S           i2s1;
AudioEffectEnvelope      envelope2;
AudioSynthWaveformModulated unison1;
AudioSynthWaveformModulated unison2;
AudioSynthWaveformModulated unison3;
AudioSynthWaveformModulated unison4;
AudioConnection patchCord20(lfo, 0, filter1, 1);
AudioConnection patchCord1(poly_waveforms[0].waveform1, 0, poly_waveforms[0].envelope1, 0);
AudioConnection patchCord2(poly_waveforms[1].waveform1, 0, poly_waveforms[1].envelope1, 0);
AudioConnection patchCord3(poly_waveforms[2].waveform1, 0, poly_waveforms[2].envelope1, 0);
AudioConnection patchCord4(poly_waveforms[3].waveform1, 0, poly_waveforms[3].envelope1, 0);
AudioConnection patchCord5(poly_waveforms[4].waveform1, 0, poly_waveforms[4].envelope1, 0);
AudioConnection patchCord6(poly_waveforms[5].waveform1, 0, poly_waveforms[5].envelope1, 0);
AudioConnection patchCord7(poly_waveforms[6].waveform1, 0, poly_waveforms[6].envelope1, 0);
AudioConnection patchCord8(poly_waveforms[0].envelope1, 0, mixer1, 0);
AudioConnection patchCord9(poly_waveforms[1].envelope1, 0, mixer1, 1);
AudioConnection patchCord10(poly_waveforms[2].envelope1, 0, mixer1, 2);
AudioConnection patchCord11(poly_waveforms[3].envelope1, 0, mixer1, 3);
AudioConnection patchCord12(poly_waveforms[4].envelope1, 0, mixer2, 0);
AudioConnection patchCord13(poly_waveforms[5].envelope1, 0, mixer2, 1);
AudioConnection patchCord14(poly_waveforms[6].envelope1, 0, mixer2, 2);
AudioConnection patchCord15(mixer5, 0, filter1, 0);
AudioConnection patchCord16(mixer3, 0, i2s1, 0);
AudioConnection patchCord17(mixer3, 0, i2s1, 1);
AudioConnection patchCord18(mixer1, 0, mixer5, 0);
AudioConnection patchCord19(mixer2, 0, mixer5, 1);
AudioConnection patchCord21(lfo2, 0, poly_waveforms[0].waveform1, 0);
AudioConnection patchCord22(lfo2, 0, poly_waveforms[1].waveform1, 0);
AudioConnection patchCord23(lfo2, 0, poly_waveforms[2].waveform1, 0);
AudioConnection patchCord24(lfo2, 0, poly_waveforms[3].waveform1, 0);
AudioConnection patchCord25(lfo2, 0, poly_waveforms[4].waveform1, 0);
AudioConnection patchCord26(lfo2, 0, poly_waveforms[5].waveform1, 0);
AudioConnection patchCord27(lfo2, 0, poly_waveforms[6].waveform1, 0);
AudioConnection patchCord28(filter1, 0, freeverb1, 0);
AudioConnection patchCord29(filter1, 0, mixer3, 1);
AudioConnection patchCord30(freeverb1, 0, mixer3, 0);
AudioConnection patchCord31(mixer4, 0, envelope2, 0);
AudioConnection patchCord31(envelope2, 0, filter1 0);
AudioConnection patchCord31(unison1, 0, mixer4, 0);
AudioConnection patchCord31(unison2, 0, mixer4, 1);
AudioConnection patchCord31(unison3, 0, mixer4, 2);
AudioConnection patchCord31(unison4, 0, mixer4, 3);
//PHASE MOD
int potPhaseAmplitude = A5;
int PotPhaseFreq = A3;
int potPhaseAmount = A0;
float modRatio = 1.0;
//LFO
int potAmplitudePin = A4;
int potFrequencyPin = A1;
//WAVEFORM BUTTON
const int waveformbutton = 5;
bool onAndOff = false;
int currentWaveformIndex = 0;
int buttonState = 0;
const int numWaveforms = 7;
const int availableWaveforms[numWaveforms] = {
  WAVEFORM_TRIANGLE,
  WAVEFORM_SAWTOOTH,
  WAVEFORM_SAWTOOTH_REVERSE,
  WAVEFORM_PULSE,
  WAVEFORM_SINE,
  WAVEFORM_SQUARE,
  WAVEFORM_TRIANGLE
//Envelope1
int potAttackPin = A2;
int potDecayPin = A13;
int potSustainPin = A12;
int potReleasePin = A10;
//FILTER1
int potCutoffPin = A11;
int potResonancePin = A14;
//REVERB
int reverbPin = A15;
MIDI_CREATE_DEFAULT_INSTANCE();
void OnNoteOn(byte channel, byte note, byte velocity);
void OnNoteOff(byte channel, byte note, byte velocity);
float midiNoteToFrequency(int note) {
  return 440.0 * pow(2.0, (note - 69.0) / 12.0);
  AudioMemory(100);
  sgtl5000_1.enable();
  sgtl5000_1.volume(0.5);
  MIDI.begin(MIDI_CHANNEL_OMNI);
  MIDI.setHandleNoteOn(OnNoteOn);
  MIDI.setHandleNoteOff(OnNoteOff);
//WAVEFORM SETUP
  pinMode(waveformbutton, INPUT_PULLUP);
  for (int i = 0; i < POLY_COUNT; i++) {
    poly_waveforms.waveform1.begin(availableWaveforms[currentWaveformIndex]);
    poly_waveforms.waveform1.amplitude(0.5);
    poly_waveforms.waveform1.phaseModulation(0);
    poly_waveforms.note = -1;
    poly_waveforms.in_use = false;
    poly_waveforms.envelope1.delay(0);
    poly_waveforms.envelope1.attack(15);
    poly_waveforms.envelope1.hold(2.5);
    poly_waveforms.envelope1.decay(127);
    poly_waveforms.envelope1.sustain(0.5);
    poly_waveforms.envelope1.release(63);
  //MOD
  pinMode(potPhaseAmplitude, INPUT);
 pinMode(potPhaseAmount, INPUT);
 pinMode(potPhaseFreq, INPUT);
  //LFO filter
  pinMode(potAmplitudePin, INPUT);
  pinMode(potFrequencyPin, INPUT);
  //envelope
  pinMode(potAttackPin, INPUT);
  pinMode(potDecayPin, INPUT);
  pinMode(potSustainPin, INPUT);
  pinMode(potReleasePin, INPUT);
  //FILTER
  pinMode(potCutoffPin, INPUT);
  pinMode(potResonancePin, INPUT);
//REVERB
pinMode(reverbPin, INPUT);
  //LFO TO FILTER
 // lfo.amplitude(.5);
  //lfo.frequency(10);
  lfo.begin(WAVEFORM_SINE);
  //LFO2 - PHASEMOD
  lfo2.amplitude(.95);
   lfo2.frequency(440);
 lfo2.begin(WAVEFORM_SINE);
  //FILTER SETUP
  filter1.frequency(800.0);
  filter1.resonance(0.7);
//REVERB SETUP
      freeverb1.roomsize(.7);
      freeverb1.damping(.1);
  //MIXER STUFF
  mixer1.gain(0, .2);
  mixer1.gain(1, .2);
  mixer1.gain(2, .2);
  mixer1.gain(3, .2);
  mixer2.gain(0, .2);
  mixer2.gain(1, .2);
  mixer2.gain(2, .2);
  mixer3.gain(0, 0.9);
  mixer3.gain(1, 0.1);
  mixer4.gain(0, 0);
  mixer4.gain(1, 0);
  mixer4.gain(2, 0);
  mixer4.gain(3, 0);
  mixer5.gain(0, .5);
  mixer5.gain(1, .5);
  MIDI.read();
//WAVEFORM BUTTON
  buttonState = digitalRead(waveformbutton);
  if (buttonState == HIGH) {
    if (!onAndOff) {
      onAndOff = true;
      // Move to the next waveform
      currentWaveformIndex = (currentWaveformIndex + 1) % numWaveforms;
      // Change the waveform based on the current index
    onAndOff = false;
    // check any slot that shows it is "in use"
    if (poly_waveforms.in_use == true) {
      // check to see if the envelope in any slot has completed - if so, then free up the slot
      if (poly_waveforms.envelope1.isActive() == false) {
        // clear out this slot & make it available for use once again
  // ENVELOPE1
  int attackValue = analogRead(potAttackPin);
   int decayValue = analogRead(potDecayPin);
  int sustainValue = analogRead(potSustainPin);
  int releaseValue = analogRead(potReleasePin);
  float attackMapped = map(attackValue, 0, 1023, 25, 500);
  float decayMapped = map(decayValue, 0, 1023, 25, 500);
  float sustainMapped = map(sustainValue, 0, 1023, 0, 50);
  float releaseMapped = map(releaseValue, 0, 1023, 20, 5000);
    // set the envelope "attack" parameter
    poly_waveforms.envelope1.attack(attackMapped);
    poly_waveforms.envelope1.decay(decayMapped);
    poly_waveforms.envelope1.sustain(sustainMapped);
    poly_waveforms.envelope1.release(releaseMapped);
  // FILTER
  int cutoffValue = analogRead(potCutoffPin);
  int resonanceValue = analogRead(potResonancePin);
  float cutoffMapped = map(cutoffValue, 0, 1023, 20, 8000);
  float resonanceMapped = map(resonanceValue, 0, 1023, 2, 6);
  filter1.frequency(cutoffMapped);
  filter1.resonance(resonanceMapped);
  // LFO
 int lfoSpeed = analogRead(potFrequencyPin);
int lfoAmount = analogRead(potAmplitudePin);
  float lfoSpeedMapped = map(lfoSpeed, 0, 1023, .4, 40);
  float lfoAmplitudeMapped = map(lfoAmount, 0, 1023, 0, 1);
Serial.println(lfoSpeed);
  lfo.amplitude(lfoAmplitudeMapped);
  lfo.frequency(lfoSpeedMapped);
  // MOD
  int FmAmount = analogRead(potPhaseAmplitude);
  //int FmFreq = analogRead(PotPhaseFreq);
  float FmAmountMapped = map(FmAmount, 0, 1023, 0, 1);
  //float FmFreqMapped = map(FmFreq, 0, 1023, 0, 1200);
lfo2.amplitude(FmAmountMapped);
//lfo2.frequency(FmFreqMapped);
int modRatioPotValue = analogRead(PotPhaseFreq);
if (modRatioPotValue < 150) {
  modRatio = 2.0;      // 0 - 341 corresponds to 1:1
} else if (modRatioPotValue < 300) {
  modRatio = 4.0;      // 342 - 682 corresponds to 1:2
} else if (modRatioPotValue < 450) {
  modRatio = 6.0;      // 683 - 1023 corresponds to 1:3
} else if (modRatioPotValue < 600) {
  modRatio = 8.0;      // 683 - 1023 corresponds to 1:3
 } else if (modRatioPotValue < 750) {
  modRatio = .25;      // 683 - 1023 corresponds to 1:3
 } else if (modRatioPotValue < 900) {
  modRatio = .5;      // 683 - 1023 corresponds to 1:3
  int phaseAmount = analogRead(potPhaseAmount);
  float phaseAmountMapped = map(phaseAmount, 0, 1023, 0, 800);
    poly_waveforms.waveform1.phaseModulation(phaseAmountMapped);
//REVERB
int reverbAmount = analogRead(reverbPin);
float reverbAmountMapped = map(reverbAmount, 0, 1023, 0, 1);
mixer3.gain(0, reverbAmountMapped);
mixer3.gain(1, 1.0 - reverbAmountMapped);
void OnNoteOn(byte channel, byte note, byte velocity) {
  int freq = (int)(440.0 * pow(2.0, ((float)note - 69.0) / 12.0));
  int poly_index = -1;
  unsigned long oldest_note_start_time = millis();
lfo2.frequency(freq * modRatio);
  // Find the oldest note
    if (!poly_waveforms.in_use) {
      // Found an empty slot, use it
      poly_index = i;
    } else if (poly_waveforms.note_start_time < oldest_note_start_time) {
      oldest_note_start_time = poly_waveforms.note_start_time;
      poly_index = i;
  if (poly_index != -1) {
    poly_waveforms[poly_index].envelope1.noteOff();
  // Set the slot for the new note
  poly_waveforms[poly_index].in_use = true;
  poly_waveforms[poly_index].note = note;
  poly_waveforms[poly_index].note_start_time = millis();
  poly_waveforms[poly_index].waveform1.frequency(freq);
  poly_waveforms[poly_index].waveform1.amplitude((float)velocity / 255.0);
  poly_waveforms[poly_index].envelope1.noteOn();
void OnNoteOff(byte channel, byte note, byte velocity) {
    if (poly_waveforms.note == note && poly_waveforms.in_use) {
      poly_index = i;
poly_waveforms[poly_index].in_use = false;
</code>
Oh and for reference, the unison 1-4 voices aren't connected and are for a future feature that I want to add. What I want, is to be able to push a button, and have it switch between poly mode (default), and a unison mode with detune.
The map function only uses integers and returns an integer so the only possible values that this can return are zero or one.
Similarly, in this one
the map function will see the .4 as zero.
All your uses of the map function store the result in a float. If you really need a floating point result, you will have to code the conversion yourself.
When you post code in a message, please use the </> icon to place code tags around the code.
Pete
Thank you for your reply! That is very helpful.
is this correct? or is there a better way to do it? it seems to work.
 float lfoAmplitudeMapped = map(lfoAmount, 0, 1023, 0, 100);
 lfo.amplitude(lfoAmplitudeMapped / 100);
The Arduino docs for the map function say it is implemented like this:
long map(long x, long in_min, long in_max, long out_min, long out_max) {
  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
You could define your own map_float function by replacing all occurrences of long with float:
float map_float(float x, float in_min, float in_max, float out_min, float out_max) {
Then add that function to your code, replace all the calls to "map" with "map_float" such as this:
  float lfoAmplitudeMapped = map_float(lfoAmount, 0, 1023, 0, 1);
and they should all work as you intended.
Pete
