tomicdesu
I'm using Arduino 1.8.x on a laptop with A311D CPU, 8GM ram, Debian unstable, and Teensy 4.1. "Most of the time" the uploader works correctly -- erase, program, then returns to the "press Button on teensy..." ready state. But often enough it hangs part way through PROGRAMMING..., times out, say DOWNLOAD ERROR in red, then...
Recovery is sometimes simple -- press the button on Teensy, but other times Arduino IDE loses the port, then things get difficult, I haven't found a simple path back, I end up powering off teensy, quitting the IDE, etc.
Usually the uploader turns off Automatic mode (Operation --> Automatic mode).
Once it fails, it seems to then fail many times. Or I can go days without a failure.
I can't discern anything I'm doing differently. The CPU on this machine is very slow, I don't think this has ever happened on a fast i7 4GHz machine with 64 GB RAM.
Any suggestions on avoiding this error?
