teensydebug crashes on breakpoint other than ino file
I'm not sure if this is the right place to put this but I had to start somewhere.
I'm using VS 22, Visualgdb 5.6R9 , teensydebug 0.1 dated 2020-06-09 and teensy 3.6.
When debuging I can put breakpoints anywhere in the ino file without a problem and the break occurs. As soon as I put one in an external class GDB crashes with an internal error.
Has anyone had this problem ? The gdb version that came with teensydebug is dated 2015 so I'm wondering if a later version would work.
Any help would be gratefully accepted.
Crash dump from visualGDB/GDB
C:\Program Files (x86)\Arduino\hardware\tools\arm\bin\arm-none-eabi-gdb --interpreter mi C:/Users/simon/source/repos/RobIOT/Output/Teensy_3_6/Debug/RobIOT.ino.elf
-gdb-version
=thread-group-added,id="i1"
~"GNU gdb (GNU Tools for ARM Embedded Processors) 7.10.1.20160923-cvs\n"
~"Copyright (C) 2015 Free Software Foundation, Inc.\n"
~"License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>\nThis is free software: you are free to change and redistribute it.\nThere is NO WARRANTY, to the extent permitted by law. Type \"show copying\"\nand \"show warranty\" for details.\n"
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
~"This GDB was configured as \"--host=i686-w64-mingw32 --target=arm-none-eabi\".\nType \"show configuration\" for configuration details."
This GDB was configured as "--host=i686-w64-mingw32 --target=arm-none-eabi".
Type "show configuration" for configuration details.
~"\nFor bug reporting instructions, please see:\n"
~"<http://www.gnu.org/software/gdb/bugs/>.\n"
~"Find the GDB manual and other documentation resources online at:\n<http://www.gnu.org/software/gdb/documentation/>.\n"
~"For help, type \"help\".\n"
~"Type \"apropos word\" to search for commands related to \"word\"...\n"
~"Reading symbols from C:/Users/simon/source/repos/RobIOT/Output/Teensy_3_6/Debug/RobIOT.ino.elf..."
~"done.\n"
~"Type \"apropos word\" to search for commands related to \"word\".\n"
^done
-list-features
^done,features=["frozen-varobjs","pending-breakpoints","thread-info","data-read-memory-bytes","breakpoint-notifications","ada-task-info","language-option","info-gdb-mi-command","undefined-command-error-code","exec-run-start-option"]
-gdb-set verbose on
^done
-gdb-set disassembly-flavor intel
^error,msg="No symbol \"disassembly\" in current context."
-gdb-set print demangle off
^done
set serial baud 114200
&"set serial baud 114200\n"
=cmd-param-changed,param="serial baud",value="114200"
^done
target remote com3
&"target remote com3\n"
~"Remote debugging using com3\n"
=thread-group-started,id="i1",pid="42000"
=thread-created,id="1",group-id="i1"
&"warning: platform-specific solib_create_inferior_hook did not load initial shared libraries.\n"
~"Reading in symbols for C:\\Users\\simon\\OneDrive\\Documents\\Arduino\\Libraries\\blynk-library-master\\src\\utility\\BlynkTimer.cpp..."
~"done.\n"
~"0x00013486 in BlynkTimer::isValidTimer (id=7, this=0x1fff1ee4 <timer>) at C:\\Users\\simon\\OneDrive\\Documents\\Arduino\\Libraries\\blynk-library-master\\src/Blynk/BlynkTimer.h:193\n"
~"193\t return timer[id].callback || timer[id].callback_p;\n"
*stopped,frame={addr="0x00013486",func="BlynkTimer::isValidTimer",args=[{name="id",value="7"},{name="this",value="0x1fff1ee4 <timer>"}],file="C:\\Users\\simon\\OneDrive\\Documents\\Arduino\\Libraries\\blynk-library-master\\src/Blynk/BlynkTimer.h",fullname="C:\\Users\\simon\\OneDrive\\Documents\\Arduino\\Libraries\\blynk-library-master\\src\\Blynk\\BlynkTimer.h",line="193"},thread-id="1",stopped-threads="all"
^done
info shared
&"info shared\n"
~"No shared libraries loaded at this time.\n"
^done
info target
&"info target\n"
~"Symbols from \"C:\\Users\\simon\\source\\repos\\RobIOT\\Output\\Teensy_3_6\\Debug\\RobIOT.ino.elf\".\n"
~"Remote serial target in gdb-specific protocol:\n"
~"Debugging a target over a serial line.\n"
~"\tWhile running this, GDB does not access memory from...\n"
~"Local exec file:\n"
~"\t`C:\\Users\\simon\\source\\repos\\RobIOT\\Output\\Teensy_3_6\\Debug\\RobIOT.ino.elf', file type elf32-littlearm.\n"
~"\tEntry point: 0x0\n"
~"\t0x00000000 - 0x00030988 @ 0x00010000 is .text\n"
~"\t0x00030988 - 0x0003098c @ 0x00040988 is .fini\n"
~"\t0x0003098c - 0x000309a0 @ 0x0004098c is .ARM.extab.text._ZSt19__throw_logic_errorPKc\n"
~"\t0x000309a0 - 0x000309b4 @ 0x000409a0 is .ARM.extab.text._ZSt20__throw_length_errorPKc\n"
~"\t0x000309b4 - 0x000309c0 @ 0x000409b4 is .ARM.extab.text._ZSt25__throw_bad_function_callv\n"
~"\t0x000309c0 - 0x000309d4 @ 0x000409c0 is .ARM.extab.text._ZNSt11logic_errorC2EPKc\n"
~"\t0x000309d4 - 0x000309e0 @ 0x000409d4 is .ARM.extab.text._ZNSs12_S_constructIPKcEEPcT_S3_RKSaIcESt20forward_iterator_tag\n"
~"\t0x000309e0 - 0x000309f8 @ 0x000409e0 is .ARM.extab.text._ZNKSt3_V214error_category10_M_messageB5cxx11Ei\n"
~"\t0x000309f8 - 0x00030a18 @ 0x000409f8 is .ARM.extab.text.__cxa_begin_catch\n"
~"\t0x00030a18 - 0x00030a24 @ 0x00040a18 is .ARM.extab.text._ZL21base_of_encoded_valuehP15_Unwind_Context\n"
~"\t0x00030a24 - 0x00030a48 @ 0x00040a24 is .ARM.extab.text.__gxx_personality_v0\n"
~"\t0x00030a48 - 0x00030a74 @ 0x00040a48 is .ARM.extab.text._ZN10__cxxabiv111__terminateEPFvvE\n"
~"\t0x00030a74 - 0x00030a80 @ 0x00040a74 is .ARM.extab.text._ZN10__cxxabiv112__unexpectedEPFvvE\n"
~"\t0x00030a80 - 0x00030a8c @ 0x00040a80 is .ARM.extab.text._ZSt10unexpectedv\n"
~"\t0x00030a8c - 0x00030a98 @ 0x00040a8c is .ARM.extab.text._ZNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEE9_M_createERjj\n"
~"\t0x00030a98 - 0x00030ac0 @ 0x00040a98 is .ARM.extab.text.__cxa_call_unexpected\n"
~"\t0x00030ac0 - 0x00030af4 @ 0x00040ac0 is .ARM.extab.text._ZN9__gnu_cxx27__verbose_terminate_handlerEv\n"
~"\t0x00030af4 - 0x00030b0c @ 0x00040af4 is .ARM.extab\n"
~"\t0x00030b0c - 0x00030d54 @ 0x00040b0c is .ARM.exidx\n"
~"\t0x1fff0000 - 0x1fff00a0 @ 0x00060000 is .usbdescriptortable\n"
~"\t0x1fff0200 - 0x1fff03d0 @ 0x00060000 is .dmabuffers\n"
~"\t0x1fff03d0 - 0x1fff0730 @ 0x00060000 is .usbbuffers\n"
~"\t0x1fff0730 - 0x1fff1de8 @ 0x00050730 is .data\n"
~"\t0x1fff1de8 - 0x1fff38ac @ 0x00051de8 is .bss\n"
^done
-data-evaluate-expression "&_estack"
^done,value="0x20030000"
-data-evaluate-expression "sizeof(void *)"
^done,value="4"
-data-evaluate-expression "sizeof(int)"
^done,value="4"
-data-evaluate-expression "sizeof(short)"
^done,value="2"
-data-evaluate-expression "sizeof(long)"
^done,value="4"
-data-evaluate-expression "sizeof(long long)"
^done,value="8"
-data-evaluate-expression "sizeof(char)"
^done,value="1"
-data-evaluate-expression "sizeof(wchar_t)"
^done,value="4"
-data-evaluate-expression "sizeof(float)"
^done,value="4"
-data-evaluate-expression "sizeof(double)"
^done,value="8"
-data-evaluate-expression "sizeof(long double)"
^done,value="8"
-var-create - * "*((void **)0x2002fffc)"
^done,name="var1",numchild="0",value="0x540a1279",type="void *",has_more="0"
-var-assign "var1" 0x55d7694b
^done,value="0x55d7694b"
-data-evaluate-expression "\*\(\(void\ \*\*\)0x2002fffc\)"
-break-insert -f main
^done,bkpt={number="1",type="breakpoint",disp="keep",enabled="y",addr="0x00019f5e",func="main()",file="C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\main.cpp",fullname="C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\main.cpp",line="51",thread-groups=["i1"],times="0",original-location="main"}
-exec-run
^error,msg="The \"remote\" target does not support \"run\". Try \"help target\" or \"continue\"."
-stack-list-frames --thread 1
~"Reading in symbols for C:\\Users\\simon\\source\\repos\\RobIOT\\Output\\Teensy_3_6\\Debug\\sketch\\Internet.cpp..."
~"done.\n"
~"Reading in symbols for C:\\Users\\simon\\source\\repos\\RobIOT\\Output\\Teensy_3_6\\Debug\\sketch\\RobIOT.ino.cpp..."
~"done.\n"
^done,stack=[frame={level="0",addr="0x00013486",func="BlynkTimer::isValidTimer",file="C:\\Users\\simon\\OneDrive\\Documents\\Arduino\\Libraries\\blynk-library-master\\src/Blynk/BlynkTimer.h",fullname="C:\\Users\\simon\\OneDrive\\Documents\\Arduino\\Libraries\\blynk-library-master\\src\\Blynk\\BlynkTimer.h",line="193"},frame={level="1",addr="0x00013486",func="BlynkTimer::run",file="C:\\Users\\simon\\OneDrive\\Documents\\Arduino\\Libraries\\blynk-library-master\\src\\utility\\BlynkTimer.cpp",fullname="C:\\Users\\simon\\OneDrive\\Documents\\Arduino\\Libraries\\blynk-library-master\\src\\utility\\BlynkTimer.cpp",line="67"},frame={level="2",addr="0x000025f6",func="Internet::BlynkRun",file="C:\\Users\\simon\\source\\repos\\RobIOT\\sketches/Internet.cpp",fullname="C:\\Users\\simon\\source\\repos\\RobIOT\\sketches\\Internet.cpp",line="353"},frame={level="3",addr="0x00005ecc",func="loop",file="C:\\Users\\simon\\source\\repos\\RobIOT\\sketches/RobIOT.ino",fullname="C:\\Users\\simon\\source\\repos\\RobIOT\\sketches\\RobIOT.ino",line="161"},frame={level="4",addr="0x00019f66",func="main",file="C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\main.cpp",fullname="C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\main.cpp",line="53"}]
-stack-list-arguments --thread 1 0
^done,stack-args=[frame={level="0",args=[name="id",name="this"]},frame={level="1",args=[name="this"]},frame={level="2",args=[name="this"]},frame={level="3",args=[]},frame={level="4",args=[]}]
-thread-info
^done,threads=[{id="1",target-id="Thread <main>",frame={level="0",addr="0x00013486",func="BlynkTimer::isValidTimer",args=[{name="id",value="7"},{name="this",value="0x1fff1ee4 <timer>"}],file="C:\\Users\\simon\\OneDrive\\Documents\\Arduino\\Libraries\\blynk-library-master\\src/Blynk/BlynkTimer.h",fullname="C:\\Users\\simon\\OneDrive\\Documents\\Arduino\\Libraries\\blynk-library-master\\src\\Blynk\\BlynkTimer.h",line="193"},state="stopped"}],current-thread-id="1"
-data-list-register-names
^done,register-names=["r0","r1","r2","r3","r4","r5","r6","r7","r8","r9","r10","r11","r12","sp","lr","pc","","","","","","","","","","xpsr","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","","",""]
-var-create --frame 0 --thread 1 - * "unsigned"
&"Attempt to use a type name as an expression.\n"
^error,msg="-var-create: unable to create variable object"
-break-delete 1
^done
-exec-continue
^running
*running,thread-id="all"
~"Reading in symbols for C:\\Users\\simon\\source\\repos\\RobIOT\\Output\\Teensy_3_6\\Debug\\sketch\\Drive.cpp..."
~"done.\n"
~"\nProgram received signal "
~"SIGINT, Interrupt.\n"
~"0x000008d2 in elapsedMillis::eek:perator unsigned long (this=0x1fff2574 <UltrasoundTimer>) at C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3/elapsedMillis.h:42\n"
~"42\t\toperator unsigned long () const { return millis() - ms; }\n"
*stopped,reason="signal-received",signal-name="SIGINT",signal-meaning="Interrupt",frame={addr="0x000008d2",func="elapsedMillis::eek:perator unsigned long",args=[{name="this",value="0x1fff2574 <UltrasoundTimer>"}],file="C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3/elapsedMillis.h",fullname="C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3\\elapsedMillis.h",line="42"},thread-id="1",stopped-threads="all"
-break-insert -f C:/Users/simon/source/repos/RobIOT/Output/Teensy_3_6/Debug/sketch/Drive.cpp:152
~"/home/build/work/GCC-5-build/src/gdb/gdb/cp-namespace.c:343: internal-error: cp_search_static_and_baseclasses: Assertion `name[prefix_len + 1] == ':'' failed.\nA problem internal to GDB has been detected,\nfurther debugging may prove unreliable.\nQuit this debugging session? "
~"(y or n) [answered Y; input not from terminal]\n"
&"\nThis is a bug, please report it."
&" For instructions, see:\n<http://www.gnu.org/software/gdb/bugs/>."
&"\n\n"
~"/home/build/work/GCC-5-build/src/gdb/gdb/cp-namespace.c:343: internal-error: cp_search_static_and_baseclasses: Assertion `name[prefix_len + 1] == ':'' failed.\nA problem internal to GDB has been detected,\nfurther debugging may prove unreliable.\nCreate a core file of GDB? "
-data-read-memory-bytes 0x8d2 4
