Teensyduino 1.20 Released
The uploader works as it should now on Linux too. I think Paul nailed the problem finally.
Fastrun
I need help with the new "FASTRUN" Feature, how can i use it ?
Could you please provide an example ?
Here's an example. A rather silly one, since you'd want to use FASTRUN on functions that matter for performance.
FASTRUN void loop() {
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);               // wait for a second
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
Sometimes FASTRUN can help a lot, especially when running at faster clock speeds (eg, overclocking stuff that's disabled by default in boards.txt), but more often than not it gives little to no benefit, for a lot of extra RAM usage, when used on functions that don't matter for performance.
Thank you!
Different topic: While experementing with GCC 4.8.3, i got this warning:
C:\Arduino\libraries\Audio\effect_fade.cpp:31:22: warning: type of 'fader_table' does not match original declaration [enabled by default]
 extern const int16_t fader_table[256];
C:\Arduino\libraries\Audio\data_waveforms.c:81:15: note: previously declared here
 const int16_t fader_table[257] = {
Thanks for the example. How does it make things faster, inlining to avoid call and return overhead?
No, the FASTRUN macro uses an __attribute__ to put the code for the function into the .fastrun data section, instead of the the .text section. The linker script puts the .fastrun section into the read/write SRAM instead of the read-only FLASH memory that normally the code goes into. I would imagine the trade off is SRAM is much faster to reference, but by using it, you have less data for your data. Because it is in read/write memory, you also run the risk of something that writes outside of its bounds changing the code.
In the new SPI library in 1.20, is it possible to change
#elif defined(__arm__) && defined(TEENSYDUINO)
to this?
#elif defined(__arm__) && defined(CORE_TEENSY)
I'm running sublime text 3 with the Stino plugin, and for some reason, TEENSYDUINO is not defined, but CORE_TEENSY is.
In the previous version of the SPI libraries, CORE_TEENSY is used instead of TEENSYDUINO.
Otherwise, upon compiling, the whole section for the Teensy 3.x is not used and I get all these errors with SPIClass is not defined etc.
I have manually changed this, but it'd be great if it could be added to the next release.
Thanks.
Hey Paul, Any chance of bundling the teensy_loader_cli under hardware/tools/ ?? This would be very handy.
I don't know what the compiler would do, but inlining a "FASTRUN"-Function (which means that it should run in the RAM) to code which is in the FLASH would be pretty obscure...
This is the definition:
 #define FASTRUN __attribute__ ((section(".fastrun"), noinline, noclone ))
You'll notice the "noinline" :)
