PaulStoffregen
I tested on a Mac with El Capitan and I was able to reproduce the problem.
It's due to a bug in handling endpoint halting, deep in the Teensyduino USB stack. Until El Capitan, none of the operating systems have used this, so the bug went unnoticed all this time.
Well, actually, I noticed it a couple weeks ago by random chance while working on the MTP stuff. I fixed the bug as part of this initial MTP work. Here's the specific fix:
https://github.com/PaulStoffregen/c...117#diff-7b3a44510f0e4eee93c6b42a56b5b3b5L279
I just tested this with El Capitan. It does solve the problem.
If you'd like to try this now, right click (or control click) on Arduino and choose "Show Package Contents". Then navigate to Contents/Java/hardware/teensy/avr/cores/teensy3. You'll need to replace everything in that folder with the contents of this github repository. Use "Download ZIP" on the right hand side to download the whole thing.
https://github.com/PaulStoffregen/cores
Within the next couple weeks I'm going to put together a first beta for 1.26, which will have this fix.
I'm also going to try to find way to create a Yosemite and El Capitan compatible signatures without losing Snow Leopard and Lion compatibility. Unforunately, that's a *lot* harder than fixing USB bugs! Apple really makes it tough to build compatibly for their older systems, so I'm going to try to set up a build process using two macs....
