Teensyduino 1.30 Beta #2 Available
Paul
Administrator
Staff member
Here is a second beta test for Teensyduino 1.30.
Arduino 1.6.10 has issues with some AVR-based boards (not Teensy). The Arduino devs are expected to release version 1.6.11 soon. I indent to hold off finalizing Teensyduino 1.30 until they've published 1.6.11 and we can test against 1.6.11 for at least a few days. Teensyduino 1.30 is likely to drop support for Arduino 1.6.10 after 1.6.11 is released.
Edit: old beta test linkes removed. Full non-beta release is here:
Changes since Teensyduino 1.30-beta1:
  • Fix for Teensy-LC (broken by recent K66 updates)
  • More K66 updates
  • Libraries updated: Audio, ADC, i2c_t3, IRremote
For the fun of it I tried installing Arduino 1.6.10 on an Odroid C2 which I installed a fresh copy of Ubuntu 16.04 (ARM 64 bit), to see if the 32 bit arm version would run on it, as I was earlier able to get the daily Arduino to run on the board, but I had played around a lot so was not sure what was needed...
The problem is their ARM version is setup to run 32 bit java and other stuff, so it needs the 32 bit versions of the libraries it uses...
I was able to get the basic Arduino to run by adding: sudo apt-get install libxtst6:armhf
Next up Teensyduino 1.30 beta 2... I downloaded it and it would not run. Was able to get it to run by
adding: sudo apt-get install libxft2:armhf
Started up Arduino, loaded blink, plugged T3.2 into C2 and clicked upload. The program compiled, but the Teensy loader failed to load. Tried in command line and the reboot also failed to load. Fixed by
adding: sudo apt-get install libusb-0.1-4:armh
Still failed until I added the udev rules. But now my Teensy is blinking :D
Note: it sometimes fails to program and I need to hit program button...
Audio.h still needs
#include "synth_simple_drum.h"
to make AudioSynthSimpleDrum work, and keywords.txt needs
AudioSynthSimpleDrum	KEYWORD2
(plus maybe some methods of AudioSynthSimpleDrum)
Won't let me install this.. here's what I get when I click the ? button:
Checking Arduino 1.6.10:
version: "Contents/Java/lib/version.txt" file missing
Does not match Arduino 1.6.10
Every copy of Arduino is supposed to have that version.txt file. Perhaps your copy got corrupted or damaged somehow? Maybe try downloading a fresh copy from Arduino.cc?
Also, please be aware Arduino 1.6.10 is going to be replaced with 1.6.11 sometime next week. Teensyduino will drop support for 1.6.10 when that happens. Unless you have an urgent need, might be simplest to just wait to upgrade.
I rewrite the RTC-Libray for the Arduino DUE and added it to the library and add it to the Library-Manager from the IDE, I modified your TimeArduinoDue.ino, Paul can you add it to your time library?
 * TimeArduinoDue.pde
 * example code illustrating Time library with Real Time Clock.
 * This example requires Markus Lange's Arduino Due RTC Library
 * https://github.com/MarkusLange/RTCDue
#include <TimeLib.h>
#include <RTCDue.h>
// Select the Slowclock source
//RTCDue rtc(RC);
RTCDue rtc(XTAL);
void setup()  {
  rtc.begin();
  if (rtc.isDateAlreadySet() == 0) {
    // Unfortunately, the Arduino Due hardware does not seem to
    // be designed to maintain the RTC clock state when the
    // board resets.  Markus described it thusly: "Uhh the Due
    // does reset with the NRSTB pin.  This resets the full chip
    // with all backup regions including RTC, RTT and SC.  Only
    // if the reset is done with the NRST pin will these regions
    // stay with their old values."
    rtc.setTime(__TIME__);
    rtc.setDate(__DATE__);
    // However, this might work on other unofficial SAM3X boards
    // with different reset circuitry than Arduino Due?
  setSyncProvider(getArduinoDueTime);
  if(timeStatus()!= timeSet)
     Serial.println("Unable to sync with the RTC");
     Serial.println("RTC has set the system time");
time_t getArduinoDueTime()
  return rtc.unixtime();
   digitalClockDisplay();
void digitalClockDisplay(){
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
void printDigits(int digits){
  // utility function for digital clock display: prints preceding colon and leading 0
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
Hope you like it.
  • TimeArd.ino
Ok so I bought a teensy, to use as midi control for an analog synth. Installed Teensyduino in my Arduino 1.6.10 IDE. Managed to upload one sketch using serial. But now, when put into program mode by pushing the button, I can't upload another sketch.
Using Arduino + Teensyduino on a mac I get the following error:
"Teensy did not respond to a USB-based request to automatically reboot.
Please press the PROGRAM MODE BUTTON on your Teensy to upload your sketch."
I already tried the following:
- Unplugging the teensy, rebooting, plugging in the teensy, press program mode button, start up IDE. -> No success.
- Repeating the same, but with a different USB port on the same system. -> No success.
- Tried it on a windows machine. Did not work. -> No success
- Tried it on another USB port, on the windows machine. -> no success.
I use the stable build of the arduino IDE. The latest Mac OS X (10.11.6), the latest Windows 10 updates.
I'm confused. Is this a mac or windows computer?
Do not use a virtual machine. The USB emulation in virtual machines is often problematic for Teensy's quick rebooting, where it disconnects and reconnects as another device.
Also, please understand Teensy Loader always uses HID protocol for uploading, not serial. More details here:
http://www.pjrc.com/teensy/troubleshoot.html
Turns out my issue was due to a charging only cable. N00b oversight. Now it works like a charm! my complements for integrating it into the arduino IDE :)
now I can get going with this again http://www.marc-nostromo.com/midi-control-for-the-monotron-using-a-teensy-3-0/#comment-109498
Possible issue with teensy_reboot:
Observation:
programs compiled for Serial-Midi break Arduino reprogram feature, requiring button press.
System PC win10, A1.6.9, TD 1.29
test procedure (using Arduino IDE):
download blink.hex compiled with Serial.
     download succeeds, will generate, say com19
download blink.hex compiled with Serial-MIDI
     download succeeds, will generate midi (new device for me) and, say com8 (as PID is different, windows will generate different com port)
download again blink.hex compiled with Serial
     download fails, requires button press, but com8 is clearly indicated.
     (to avoid button press, I opened com8 on terminal with baud 134, which put T3.2 into program mode)
     TD downloads blink.hex
     download succeeds, will generate, again com19
My hunch is, that teensy_reboot.exe, needs upgrade.
SSH requires much more. This could be used as one small piece, but among many other things needed are asymmetric cyphers for key exchange. This library is limited to only computing a few specific symmetric ciphers and one-way hashes. Even for those ciphers, it only does the basic computation. You'd still need to add at least block chaining since ECB mode is not secure.
Arduino 1.6.10 Keeps Recompiling Core
Update: Problem Solved by disabling Trend Micro Internet & Micro Security Version 10.0.1288 (see #38)
I am setting up a new Arduino installation on my Windows 10 PC to start testing my Teensy 3.6
I created a new directory and unzipped the latest Arduino 1.6.10 download into it.
I applied Teensyduino 1.30 Beta 2 without problems.
I have the new boards.txt file from post 910 of the K66 thread but the problem occurs both with the K66 boards.txt file and the Teensyduino 1.30B2 boards.txt file.
For now I'm just working with a Teensy 3.2.
It seems like Arduino is trying to recompile the entire core even when just trying to run the blink example.
This takes close to 20 minutes.
Here's an example verbose output from the Arduino console:
C:\Arduino1610Teensyduino130B2\arduino-builder -dump-prefs -logger=machine -hardware "C:\Arduino1610Teensyduino130B2\hardware" -hardware "C:\Users\Bob\AppData\Local\Arduino15\packages" -tools "C:\Arduino1610Teensyduino130B2\tools-builder" -tools "C:\Arduino1610Teensyduino130B2\hardware\tools\avr" -tools "C:\Users\Bob\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Arduino1610Teensyduino130B2\libraries" -libraries "C:\Users\Bob\Documents\Arduino\libraries" -fqbn=teensy:avr:teensy31:usb=serial,speed=96opt,keys=en-us -ide-version=10610 -build-path "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp" -warnings=default -verbose "C:\Arduino1610Teensyduino130B2\examples\Teensy\Tutorial1\Blink\Blink.pde"
Compiling libraries...
Compiling core...
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\memcpy-armv7m.S" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\memcpy-armv7m.S.o"
C:\Arduino1610Teensyduino130B2\arduino-builder -compile -logger=machine -hardware "C:\Arduino1610Teensyduino130B2\hardware" -hardware "C:\Users\Bob\AppData\Local\Arduino15\packages" -tools "C:\Arduino1610Teensyduino130B2\tools-builder" -tools "C:\Arduino1610Teensyduino130B2\hardware\tools\avr" -tools "C:\Users\Bob\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Arduino1610Teensyduino130B2\libraries" -libraries "C:\Users\Bob\Documents\Arduino\libraries" -fqbn=teensy:avr:teensy31:usb=serial,speed=96opt,keys=en-us -ide-version=10610 -build-path "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp" -warnings=default -verbose "C:\Arduino1610Teensyduino130B2\examples\Teensy\Tutorial1\Blink\Blink.pde"
Using board 'teensy31' from platform in folder: C:\Arduino1610Teensyduino130B2\hardware\teensy\avr
Using core 'teensy3' from platform in folder: C:\Arduino1610Teensyduino130B2\hardware\teensy\avr
Detecting libraries used...
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\sketch\Blink.pde.cpp" -o "nul"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\memset.S" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\memset.S.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w  -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\sketch\Blink.pde.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\analog.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\analog.c.o"
"C:\Arduino1610Teensyduino130B2\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\sketch\Blink.pde.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\sketch\Blink.pde.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\eeprom.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\eeprom.c.o"
Compiling core...
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\memcpy-armv7m.S" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\memcpy-armv7m.S.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\keylayouts.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\keylayouts.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -x assembler-with-cpp -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\memset.S" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\memset.S.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\math_helper.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\math_helper.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\analog.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\analog.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\mk20dx128.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\mk20dx128.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\eeprom.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\eeprom.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\nonstd.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\nonstd.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\keylayouts.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\keylayouts.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\pins_teensy.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\pins_teensy.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\math_helper.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\math_helper.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\ser_print.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\ser_print.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\mk20dx128.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\mk20dx128.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\serial1.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial1.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\nonstd.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\nonstd.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\serial2.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial2.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\pins_teensy.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\pins_teensy.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\serial3.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial3.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\ser_print.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\ser_print.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\serial4.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial4.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\serial1.c" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\serial1.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\serial5.c" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial5.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\HardwareSerial6.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\HardwareSerial6.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\Stream.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\Stream.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\IPAddress.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\IPAddress.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\Tone.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\Tone.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\IntervalTimer.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\IntervalTimer.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\WMath.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\WMath.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\Print.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\Print.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\WString.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\WString.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\Stream.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\Stream.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\avr_emulation.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\avr_emulation.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\Tone.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\Tone.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\main.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\main.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\WMath.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\WMath.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\new.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\new.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\WString.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\WString.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\usb_audio.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_audio.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\avr_emulation.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\avr_emulation.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\usb_flightsim.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_flightsim.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\main.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\main.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\usb_inst.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_inst.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\new.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\new.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\yield.cpp" -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\yield.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\usb_audio.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_audio.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\memcpy-armv7m.S.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\memset.S.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\analog.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\usb_flightsim.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_flightsim.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\eeprom.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\keylayouts.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\math_helper.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\usb_inst.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_inst.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\mk20dx128.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\nonstd.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\pins_teensy.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=130 -DARDUINO=10610 -DF_CPU=96000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3" "C:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3\yield.cpp" -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\yield.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\ser_print.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial1.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial2.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\memcpy-armv7m.S.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial3.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\memset.S.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial4.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\analog.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial5.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\eeprom.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial6.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\keylayouts.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\serial6_lpuart.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\math_helper.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\touch.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\mk20dx128.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_desc.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\nonstd.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_dev.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\pins_teensy.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_joystick.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\ser_print.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_keyboard.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\serial1.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_mem.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\serial2.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_midi.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\serial3.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_mouse.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\serial4.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_mtp.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\serial5.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_rawhid.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\serial6.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_seremu.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\serial6_lpuart.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_serial.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\touch.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_touch.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_desc.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\AudioStream.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_dev.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\DMAChannel.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_joystick.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\HardwareSerial1.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_keyboard.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\HardwareSerial2.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_mem.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\HardwareSerial3.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_midi.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\HardwareSerial4.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_mouse.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\HardwareSerial5.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_mtp.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\HardwareSerial6.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_rawhid.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\IPAddress.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_seremu.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\IntervalTimer.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_serial.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\Print.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_touch.c.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\Stream.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\AudioStream.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\Tone.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\DMAChannel.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\WMath.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\HardwareSerial1.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\WString.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\HardwareSerial2.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\avr_emulation.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\HardwareSerial3.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\main.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\HardwareSerial4.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\new.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\HardwareSerial5.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_audio.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\HardwareSerial6.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_flightsim.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\IPAddress.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\usb_inst.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\IntervalTimer.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\core\yield.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\Print.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1471185117 "-TC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3/mk20dx256.ld"  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -o "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/Blink.pde.elf" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp\sketch\Blink.pde.cpp.o" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/core\core.a" "-LC:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp" -larm_cortexM4l_math -lm
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\Stream.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\Tone.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\WMath.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/Blink.pde.elf" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/Blink.pde.eep"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\WString.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/Blink.pde.elf" "C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp/Blink.pde.hex"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\avr_emulation.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools//teensy_post_compile" "-file=Blink.pde" "-path=C:\Users\Bob\AppData\Local\Temp\buildb0adeeb323d517cca58e20d969e006a7.tmp" "-tools=C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/" "-board=TEENSY31"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\main.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\new.cpp.o"
Sketch uses 14,292 bytes (5%) of program storage space. Maximum is 262,144 bytes.
Global variables use 3,536 bytes (5%) of dynamic memory, leaving 62,000 bytes for local variables. Maximum is 65,536 bytes.
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_audio.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_flightsim.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\usb_inst.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-ar" rcs "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core/core.a" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\core\yield.cpp.o"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O -Wl,--gc-sections,--relax,--defsym=__rtc_localtime=1471185188 "-TC:\Arduino1610Teensyduino130B2\hardware\teensy\avr\cores\teensy3/mk20dx256.ld"  -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -o "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/Blink.pde.elf" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp\sketch\Blink.pde.cpp.o" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/core\core.a" "-LC:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp" -larm_cortexM4l_math -lm
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/Blink.pde.elf" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/Blink.pde.eep"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/Blink.pde.elf" "C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp/Blink.pde.hex"
"C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools//teensy_post_compile" "-file=Blink.pde" "-path=C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp" "-tools=C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/" "-board=TEENSY31"
Sketch uses 14,212 bytes (5%) of program storage space. Maximum is 262,144 bytes.
C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools/teensy_post_compile -test -file=Blink.pde -path=C:\Users\Bob\AppData\Local\Temp\build10d9ede01f91cc9811b250df4f403d55.tmp -tools=C:\Arduino1610Teensyduino130B2\hardware\teensy/../tools -board=TEENSY31 -reboot
Settings are;
Board: Teensy 3.1/3.2
USB: Serial
Keyboard layout: US English
CPU speed: 96 MHz optimize speed (overclock)
Port: COM5
Does anyone know what may be going on here?
Everything is still fine with my 1.6.9 setup.
Thanks
I'm still not having any luck.
It's taking over 20 minutes each time I try to build a sketch with Arduino 1.6.10
The same Blink sketch in Arduino 1.6.9 takes under 5 seconds to build.
I verified that the sketch folder is not read-only as discussed here https://forum.pjrc.com/threads/34233-Build-options-changed-rebuilding-all
I going to try and redownload and reinstall Arduino again this time using the installer.
Edit: Well that didn't work either.
Update: Problem Solved by disabling Trend Micro Internet & Micro Security Version 10.0.1288 (see #38)
Arduino 1.6.10 + Beta Teensyduino + WS8211 = SAD
FYI, I just spent today trying to figure out what I broke and/or where all the signal noise was coming from. Turn out that Ardunio 1.6.10 + the Teensyduino beta does not produce correct code to drive OctoWS2811. I tried plain FastLED, OctoWS2811 (dma), and a vast array of combinations of cables, Teensy's, level shifters, power supplies, etc :)
Downgrading to Arduino 1.6.9 and the non-beta Teensyduino fixed it.
Yikes, 20 minutes is horrible.
Does 1.6.10 do this for Arduino Uno or Arduino Due, or only when compiling for Teensy?
No need for a real Arduino. Just select it in the Tools > Boards menu and then click Verify. We're just looking for the compile time, right?
Yes, good point. Tonight, I'll reload a fresh Arduino 1.6.10, then try to "verify" before and after applying the Teensyduino 1.30B2 update.
