C:\arduino_16_11\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:25:57: error: 'void (* SdFile::dateTime_)(uint16_t*, uint16_t*)' is not a static member of 'class SdFile'
C:\arduino_16_11\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:33:28: error: no 'uint8_t SdFile::addCluster()' member function declared in class 'SdFile'
C:\arduino_16_11\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:46:35: error: no 'uint8_t SdFile::addDirCluster()' member function declared in class 'SdFile'
C:\arduino_16_11\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:61:44: error: no 'dir_t* SdFile::cacheDirEntry(uint8_t)' member function declared in class 'SdFile'
C:\arduino_16_11\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:74:27: error: no 'uint8_t SdFile::close()' member function declared in class 'SdFile'
C:\arduino_16_11\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:91:71: error: no 'uint8_t SdFile::contiguousRange(uint32_t*, uint32_t*)' member function declared in class 'SdFile'
C:\arduino_16_11\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:130:44: error: no 'uint8_t SdFile::createContiguous(SdFile*, const char*, uint32_t)' member function declared in class 'SdFile'
C:\arduino_16_11\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:158:36: error: no 'uint8_t SdFile::dirEntry(dir_t*)' member function declared in class 'SdFile'
C:\arduino_16_11\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:178:50: error: no 'void SdFile::dirName(const dir_t&, char*)' member function declared in class 'SdFile'
C:\arduino_16_11\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:201:46: error: no 'void SdFile::ls(uint8_t, uint8_t)' member function declared in class 'SdFile'
C:\arduino_16_11\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:245:58: error: no 'uint8_t SdFile::make83Name(const char*, uint8_t*)' member function declared in class 'SdFile'
C:\arduino_16_11\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:284:57: error: no 'uint8_t SdFile::makeDir(SdFile*, const char*)' member function declared in class 'SdFile'
C:\arduino_16_11\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:384:74: error: no 'uint8_t SdFile::open(SdFile*, const char*, uint8_t)' member function declared in class 'SdFile'
C:\arduino_16_11\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:476:68: error: no 'uint8_t SdFile::open(SdFile*, uint16_t, uint8_t)' member function declared in class 'SdFile'
C:\arduino_16_11\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:502:64: error: no 'uint8_t SdFile::openCachedEntry(uint8_t, uint8_t)' member function declared in class 'SdFile'
C:\arduino_16_11\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:550:26: error: 'uint8_t SdFile::openRoot' is not a static member of 'class SdFile'
C:\arduino_16_11\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:550:26: error: 'SdVolume' was not declared in this scope
C:\arduino_16_11\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:550:36: error: 'vol' was not declared in this scope
C:\arduino_16_11\hardware\teensy\avr\libraries\SD\utility\SdFile.cpp:550:41: error: expected ',' or ';' before '{' token
Multiple libraries were found for "SD.h"
Used: C:\arduino_16_11\hardware\teensy\avr\libraries\SD
Not used: C:\arduino_16_11\libraries\SD
Using library Audio at version 1.3 in folder: C:\arduino_16_11\hardware\teensy\avr\libraries\Audio
Using library SPI at version 1.0 in folder: C:\arduino_16_11\hardware\teensy\avr\libraries\SPI
Using library SD at version 1.0.8 in folder: C:\arduino_16_11\hardware\teensy\avr\libraries\SD
Using library SerialFlash at version 0.4 in folder: C:\arduino_16_11\hardware\teensy\avr\libraries\SerialFlash
Using library Wire at version 1.0 in folder: C:\arduino_16_11\hardware\teensy\avr\libraries\Wire
[U][B]Using library SdFat at version 2016.7.24 in folder: i:\tcode\libraries\SdFat [/B][/U]
Error compiling for board Teensy 3.6.
