Here is a second beta test for Teensyduino 1.38.
Changes since Teensyduino 1.38-beta1:
Fix C++14 delete and link with -lstdc++
Add pure code choices in Tools > Optimization
Fix Wire lib with fastest optimize and >120 MHz CPU speed
Wire emulate AVR twi_writeTo - for Adafruit compatibility
Wire1 support for pins on SD socket (if not using SD card)
Fix install problem on Arduino 1.0.6
Fix analogReadAveraging with ADC1
Allow more memory for audio library on Teensy 3.5 & 3.6
Fix audio library delay effect on Teensy 3.5 & 3.6
Audio I2S uses 64 bit frame, improve compatibility with I2S mics
Fix OctoWS2811 seldom-used color conversion options
USBHost_t36 improved handling of error & pipe stall
