Teensyduino 1.52 Beta #1
Again, thanks a lot. So that should work like expected. The frequency is precise to the theroretical 256*44100*2. Now I'm going to find the issue in the rest of the code. I'll open another thread once there is any progress and post the final code to be included in TD.
I just downloaded the 1.52 beta and tried to build a simple Audio example using Teensy LC. It gives an error in red within the IDE:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_adc.cpp: In static member function 'static void AudioInputAnalog::isr()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_adc.cpp:119:2: warning: 'daddr' is used uninitialized in this function [-Wuninitialized]
if (daddr < (uint32_t)analog_rx_buffer + sizeof(analog_rx_buffer) / 2) {
I can provide the full verbose output if needed. Here is the sketch I was trying to build:
#include <SerialFlash.h>
AudioSynthWaveform       waveform1;      //xy=456,2172
AudioOutputAnalog        dac1;           //xy=686,2188
AudioConnection          patchCord1(waveform1, dac1);
  AudioMemory(20);
  waveform1.begin(0.5, 200, WAVEFORM_SAWTOOTH);
I get the same result when building with any of the example sketches. If I try with a Teensy 4.0, it all works OK. Please let me know how I can help.
Thanks,
Steve
..and what is your reason to ask this here in this 1.52 beta thread? And, please use the code-tags next time! :)
The Audio Library is not officially supported by the Teensy LC.
Actually, there's a lot more red output, so here's the whole thing (sorry if it's too long):
Arduino: 1.8.12 (Windows 10), TD: 1.52-beta1, Board: "Teensy LC, Serial, 48 MHz, Smallest Code, US English"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\steve.corn\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\steve.corn\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\steve.corn\Documents\Arduino\libraries -fqbn=teensy:avr:teensyLC:usb=serial,speed=48,opt=osstd,keys=en-us -ide-version=10812 -build-path C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340 -warnings=none -build-cache C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_cache_54073 -verbose C:\SteveCorn\NuWave-GitLab\arduino\test-LC-audio\test-LC-audio.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\steve.corn\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\steve.corn\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\steve.corn\Documents\Arduino\libraries -fqbn=teensy:avr:teensyLC:usb=serial,speed=48,opt=osstd,keys=en-us -ide-version=10812 -build-path C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340 -warnings=none -build-cache C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_cache_54073 -verbose C:\SteveCorn\NuWave-GitLab\arduino\test-LC-audio\test-LC-audio.ino
Using board 'teensyLC' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Using core 'teensy3' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for Audio.h: [Audio@1.3]
ResolveLibrary(Audio.h)
  -> candidates: [Audio@1.3]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for SD.h: [SD@1.2.4 SD@1.2.2]
ResolveLibrary(SD.h)
  -> candidates: [SD@1.2.4 SD@1.2.2]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for SerialFlash.h: [SerialFlash@0.5]
ResolveLibrary(SerialFlash.h)
  -> candidates: [SerialFlash@0.5]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\sketch\\test-LC-audio.ino.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\analyze_fft1024.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\analyze_fft256.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\analyze_notefreq.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\analyze_peak.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\analyze_print.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\analyze_rms.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\analyze_tonedetect.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\control_ak4558.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\control_cs42448.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\control_cs4272.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\control_sgtl5000.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\control_tlv320aic3206.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\control_wm8731.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\data_spdif.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\data_ulaw.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\data_waveforms.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\data_windows.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\effect_bitcrusher.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\effect_chorus.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\effect_combine.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\effect_delay.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\effect_delay_ext.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\effect_envelope.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\effect_fade.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\effect_flange.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\effect_freeverb.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\effect_granular.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\effect_midside.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\effect_multiply.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\effect_reverb.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\effect_waveshaper.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\filter_biquad.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\filter_fir.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\filter_variable.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\input_adc.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\input_adcs.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\input_i2s.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\input_i2s2.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\input_i2s_hex.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\input_i2s_oct.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\input_i2s_quad.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\input_pdm.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\input_spdif3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\input_tdm.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\input_tdm2.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\memcpy_audio.S" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\mixer.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_adat.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_dac.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_dacs.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_i2s.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_i2s2.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_i2s_hex.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_i2s_oct.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_i2s_quad.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_mqs.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_pt8211.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_pt8211_2.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_pwm.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_spdif.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_spdif2.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_spdif3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_tdm.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_tdm2.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\play_memory.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\play_queue.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\play_sd_raw.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\play_sd_wav.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\play_serialflash_raw.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\record_queue.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\spi_interrupt.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\synth_dc.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\synth_karplusstrong.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\synth_pinknoise.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\synth_pwm.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\synth_simple_drum.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\synth_sine.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\synth_tonesweep.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\synth_waveform.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\synth_wavetable.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\synth_whitenoise.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility\\imxrt_hw.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility\\sqrt_integer.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI\\SPI.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\File.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\SD.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\cache_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\card_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\dir_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\fat_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\file_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\init_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility\\NXP_SDHC.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility\\Sd2Card.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility\\SdFile.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility\\SdVolume.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash\\SerialFlashChip.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash\\SerialFlashDirectory.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\Wire.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\WireIMXRT.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\WireKinetis.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility\\twi.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\sketch\\test-LC-audio.ino.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/precompile_helper" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340/pch/Arduino.h" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340/pch/Arduino.h.gch"
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\pch\Arduino.h.gch
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\sketch\\test-LC-audio.ino.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\sketch\\test-LC-audio.ino.cpp.o"
Compiling libraries...
Compiling library "Audio"
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\memcpy_audio.S.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\data_ulaw.c.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\data_windows.c.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\data_spdif.c.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\data_waveforms.c.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\analyze_print.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\analyze_peak.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\control_ak4558.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\analyze_fft1024.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\analyze_rms.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\analyze_notefreq.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\analyze_tonedetect.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\analyze_fft256.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\control_sgtl5000.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\control_cs42448.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\effect_combine.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\control_wm8731.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\control_cs4272.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\effect_delay.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\effect_delay_ext.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\effect_bitcrusher.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\effect_envelope.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\effect_fade.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\effect_granular.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\effect_freeverb.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\effect_chorus.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\effect_multiply.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\effect_flange.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\filter_biquad.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\effect_reverb.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\effect_midside.cpp.o
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\input_adc.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\libraries\\Audio\\input_adc.cpp.o"
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\effect_waveshaper.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\filter_fir.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\control_tlv320aic3206.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\input_adcs.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\input_i2s.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\filter_variable.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\input_i2s2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\input_i2s_hex.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\input_i2s_oct.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\input_tdm2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\input_spdif3.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\input_tdm.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\input_pdm.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\output_dacs.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\input_i2s_quad.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\output_i2s2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\mixer.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\output_i2s.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\output_dac.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\output_mqs.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\output_i2s_hex.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\output_adat.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\output_i2s_oct.cpp.o
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_pt8211.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\libraries\\Audio\\output_pt8211.cpp.o"
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\output_i2s_quad.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\output_pt8211_2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\output_pwm.cpp.o
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_spdif.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\libraries\\Audio\\output_spdif.cpp.o"
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\output_spdif3.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_598340\libraries\Audio\output_spdif2.cpp.o
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_tdm2.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\libraries\\Audio\\output_tdm2.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\output_tdm.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\libraries\\Audio\\output_tdm.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\play_memory.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\libraries\\Audio\\play_memory.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\play_queue.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\libraries\\Audio\\play_queue.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\play_sd_raw.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\libraries\\Audio\\play_sd_raw.cpp.o"
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_adc.cpp: In static member function 'static void AudioInputAnalog::isr()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_adc.cpp:119:2: warning: 'daddr' is used uninitialized in this function [-Wuninitialized]
  if (daddr < (uint32_t)analog_rx_buffer + sizeof(analog_rx_buffer) / 2) {
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif.cpp: In static member function 'static void AudioOutputSPDIF::isr()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif.cpp:141:25: error: 'class DMAChannel' has no member named 'TCD'
  saddr = (uint32_t)(dma.TCD->SADDR);
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif.cpp:176:26: error: 'PREAMBLE_B' was not declared in this scope
     *(dest+0) =  vucp | (PREAMBLE_B << 16 ) | aux; //special preamble for one of 192 frames
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif.cpp:179:25: error: 'PREAMBLE_M' was not declared in this scope
     *(dest+0) = vucp | (PREAMBLE_M << 16 ) | aux;
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif.cpp:225:26: error: 'PREAMBLE_W' was not declared in this scope
    *(dest+0)  =  vucp | (PREAMBLE_W << 16 ) | aux;
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif.cpp: In static member function 'static void AudioOutputSPDIF::mute_PCM(bool)':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif.cpp:256:14: error: 'VUCP_INVALID' was not declared in this scope
  vucp = mute?VUCP_INVALID:VUCP_VALID;
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif.cpp:256:27: error: 'VUCP_VALID' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif.cpp: At global scope:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif.cpp:449:6: error: redefinition of 'void AudioOutputSPDIF::update()'
 void AudioOutputSPDIF::update(void)
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif.cpp:259:6: note: 'virtual void AudioOutputSPDIF::update()' previously defined here
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_pt8211.cpp: In static member function 'static void AudioOutputPT8211::isr()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_pt8211.cpp:116:25: error: 'class DMAChannel' has no member named 'TCD'
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_tdm.cpp: In static member function 'static void AudioOutputTDM::isr()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_tdm.cpp:132:25: error: 'class DMAChannel' has no member named 'TCD'
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\play_sd_wav.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_598340\\libraries\\Audio\\play_sd_wav.cpp.o"
C:\Users\STEVE~1.COR\AppData\Local\Temp\ccLCsLIP.s: Assembler messages:
C:\Users\STEVE~1.COR\AppData\Local\Temp\ccLCsLIP.s:291: Error: selected processor does not support `smull r0,ip,r3,r5' in Thumb mode
C:\Users\STEVE~1.COR\AppData\Local\Temp\ccLCsLIP.s:292: Error: shifts in CMP/MOV instructions are only supported in unified syntax -- `mov ip,ip,asl r6'
C:\Users\STEVE~1.COR\AppData\Local\Temp\ccLCsLIP.s:293: Error: unshifted register required -- `orr r0,ip,r0,lsr r7'
Multiple libraries were found for "SD.h"
 Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
 Not used: C:\Program Files (x86)\Arduino\libraries\SD
Using library Audio at version 1.3 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI
Using library SD at version 1.2.2 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
Using library SerialFlash at version 0.5 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SerialFlash
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire
Error compiling for board Teensy LC.
I thought a new feature of 1.52 was that it adds support for Teensy LC and Audio/DAC output, according to the first post of the thread from Paul?
Then I am confused by the post from Paul that clearly states:
Changes since Teensyduino 1.51:
USB Audio support for Teensy 4.0
OctoWS2811 ported to Teensy 4.0
WS2812Serial support for RGBW SK6812 LEDs
FreqMeasureMulti ported to Teensy 4.0 (KurtE)
Dual & Triple USB Serial (Geert Uytterhoeven)
Audio support for 4,6,8 channel I2S on Teensy 4.0
Audio support for SPDIF input on Teensy 4.0 (FrankB)
Audio DAC support for Teensy LC (Ben Kurtz)
Audio PWM output for Teensy 4.0 (FrankB)
Fix Serial.print() conflict with USB Touchscreen
Fix contact count on USB Touchscreen (purple-ben)
Defined FLASHMEM on Teensy 3.x, for compatibility with Teensy 4 code (FrankB)
Fix cache handling in I2S audio input on Teensy 4.0 (Frank B)
Fix numerous iMXRT register field defines
MTP USB descriptors on Teensy 4.0 - actual MTP support still WIP
Libraries updated: FlexCAN_t4, ST7735_t3, RA8875
I have no Idea what is supported by the LC, and what not. I'd say 90% of the library will not work on LC.
The errorlog above mentions a ccLCsLIP.s - what is that?
The last one (ccLCsLIP.s) comes from dspinst.h
First would be to add the red lines to dspinst.h (in folder "utility")
[COLOR=#ff0000]#if defined (__ARM_ARCH_7EM__)[/COLOR]
// Multiply two S.31 fractional integers, and return the 32 most significant
// bits after a shift left by the constant z.
// This comes from rockbox.org
static inline int32_t FRACMUL_SHL(int32_t x, int32_t y, int z)
    int32_t t, t2;
    asm ("smull    %[t], %[t2], %[a], %[b]\n\t"
         "mov      %[t2], %[t2], asl %[c]\n\t"
         "orr      %[t], %[t2], %[t], lsr %[d]\n\t"
         : [t] "=&r" (t), [t2] "=&r" (t2)
         : [a] "r" (x), [b] "r" (y),
           [c] "Mr" ((z) + 1), [d] "Mr" (31 - (z)));
    return t;
[COLOR=#ff0000]#else
    return (int32_t) (((int64_t)x * y) >> (31 - z));
}[/COLOR]
[COLOR=#ff0000]#endif[/COLOR]
I'll do a pullrequest for this and the other errors tomorrow.
To be honest, I merged this pull request without any testing, other than making sure it didn't break anything on Teensy 3.x and 4.0. Since nothing has worked on LC, it didn't seem like much risk.
Actually trying this on LC, and a conversation on github about 22 vs 44 kHz sample rate are on a long list of things I need to review. But at the rate things are going (employees at home, PJRC down to just Robin & me) and working on a test fixture at this moment, it's unlikely I'll manage to look at this anytime soon. I wish I had a nicer answer for you, but I only have this honest one.
Does "on hold" or "paused" count as a schedule?
Realistically, that's the situation right now as Robin & I struggle to keep PJRC running without 2 employees.
Yes, just wondered if it was one of the things seen as a worthy distraction from what else you can do. Good luck with the rest of what is on your plates.
I appreciate it Paul. I had no expectation that LC would support Audio, but got excited when I saw the post. I have a T4 with Audio Shield which works great. I'll try to get to trying Frank's code change at some point, possibly this afternoon.
Speaking musically, IMO, if using the Audio library's "analog" synth oscillators, it should be OK to limit the sample rate to 22KHz, since you cannot hear anything above that freq anyway. In the project I am building, using MIDI notes 0 - 127, the full freq range is 8Hz - 16KHz, but the bulk of the notes are within the 4KHz or lower range. I cannot imagine getting an audible difference between 22KHz and 44KHz. That's my 2 cents...
Thanks!
22kHz sample rate means the maximum frequency that can be reconstructed is 11kHz. Google for Nyquist sampling theorem or Nyquist rate for more info.
On OSX Catalina (versions 10.15.2 - 10.15.4), Teensyduino (1.51 and 1.52 beta) will appear to work until you open a menu. It takes a few seconds and then the program disappears. Starting from command line provided the enclosed error log (ZIP format) and below is the OSX system log dump. I currently cannot use Teensyduino and other software prevent me from downgrading OSX to an older version than Catalina.
Is there anything I can do to help resolve this issue?
Process:               Arduino [4023]
Path:                  /Applications/Arduino.app/Contents/MacOS/Arduino
Identifier:            cc.arduino.Arduino
Version:               1.8.12 (1.8.12)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           Arduino [4023]
User ID:               502
Date/Time:             2020-03-27 21:52:37.305 +0100
OS Version:            Mac OS X 10.15.4 (19E266)
Report Version:        12
Bridge OS Version:     4.4 (17P4263)
Anonymous UUID:        DD6841D6-539B-086F-3BA7-D7778AB76291
Sleep/Wake UUID:       032FDDDA-308C-4D8A-9585-5077E01CA2BB
Time Awake Since Boot: 1400 seconds
Time Since Wake:       700 seconds
System Integrity Protection: enabled
Crashed Thread:        25  Java: Java2D Queue Flusher
Exception Type:        EXC_BAD_INSTRUCTION (SIGABRT)
Exception Codes:       0x0000000000000001, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Application Specific Information:
-[NSOpenGLContext setView:] must be called from the main thread.
Thread 0:: AppKit Thread  Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib        	0x00007fff73f06dfa mach_msg_trap + 10
1   libsystem_kernel.dylib        	0x00007fff73f07170 mach_msg + 60
2   com.apple.CoreFoundation      	0x00007fff39e7e0b5 __CFRunLoopServiceMachPort + 247
3   com.apple.CoreFoundation      	0x00007fff39e7cb82 __CFRunLoopRun + 1319
4   com.apple.CoreFoundation      	0x00007fff39e7bffe CFRunLoopRunSpecific + 462
5   com.apple.Foundation          	0x00007fff3c5102a8 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 212
6   libawt_lwawt.dylib            	0x00000001100c2a19 Java_sun_lwawt_macosx_LWCToolkit_doAWTRunLoopImpl + 314
7   ???                           	0x000000011398ffad 0 + 4623761325
8   ???                           	0x00000001139682bd 0 + 4623598269
9   ???                           	0x00000001139682bd 0 + 4623598269
10  ???                           	0x00000001139682bd 0 + 4623598269
11  ???                           	0x0000000113960671 0 + 4623566449
12  libjvm.dylib                  	0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
13  libjvm.dylib                  	0x0000000108d6e1ef jni_invoke_nonstatic(JNIEnv_*, JavaValue*, _jobject*, JNICallType, _jmethodID*, JNI_ArgumentPusher*, Thread*) + 1638
14  libjvm.dylib                  	0x0000000108d76055 jni_CallVoidMethodV + 542
15  JavaNativeFoundation          	0x00007fff3e78d9c2 JNFCallVoidMethod + 175
16  libosxui.dylib                	0x000000010e6bc4eb -[NativeToJavaDelegate menuWillOpen:] + 120
17  com.apple.AppKit              	0x00007fff3777ebce -[NSMenu _sendMenuOpeningNotification:] + 106
18  com.apple.AppKit              	0x00007fff374fda11 -[NSCarbonMenuImpl _carbonOpenEvent:handlerCallRef:] + 195
19  com.apple.AppKit              	0x00007fff3742ea19 NSSLMMenuEventHandler + 1197
20  com.apple.HIToolbox           	0x00007fff38a888ff DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1254
21  com.apple.HIToolbox           	0x00007fff38a87d8d SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 329
22  com.apple.HIToolbox           	0x00007fff38a87c3d SendEventToEventTargetWithOptions + 45
23  com.apple.HIToolbox           	0x00007fff38b0c5db SendMenuOpening(MenuSelectData*, MenuData*, double, unsigned int, unsigned int, __CFDictionary*, unsigned char, unsigned char*) + 482
24  com.apple.HIToolbox           	0x00007fff38b24ff6 DrawTheMenu(MenuSelectData*, __CFArray**, unsigned char, unsigned char*) + 286
25  com.apple.HIToolbox           	0x00007fff38b24dbe MenuChanged(MenuSelectData*, unsigned char, unsigned char) + 535
26  com.apple.HIToolbox           	0x00007fff38c319f4 TrackMenuCommon(MenuSelectData&, unsigned char*, SelectionData*, MenuResult*, MenuResult*) + 992
27  com.apple.HIToolbox           	0x00007fff38b247a0 MenuSelectCore(MenuData*, Point, double, unsigned int, OpaqueMenuRef**, unsigned short*) + 365
28  com.apple.HIToolbox           	0x00007fff38b24598 _HandleMenuSelection2 + 460
29  com.apple.AppKit              	0x00007fff372d186d _NSHandleCarbonMenuEvent + 215
30  com.apple.AppKit              	0x00007fff372d16da _DPSEventHandledByCarbon + 54
31  com.apple.AppKit              	0x00007fff370f9b2a -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2962
32  libosxapp.dylib               	0x000000010e8dfd2e -[NSApplicationAWT nextEventMatchingMask:untilDate:inMode:dequeue:] + 121
33  com.apple.AppKit              	0x00007fff370eb1ee -[NSApplication run] + 658
34  libosxapp.dylib               	0x000000010e8dfb73 +[NSApplicationAWT runAWTLoopWithApp:] + 219
35  libsplashscreen.dylib         	0x000000010e8acb16 __SplashInitPlatform_block_invoke + 70
36  JavaNativeFoundation          	0x00007fff3e790ff9 +[JNFRunLoop _performCopiedBlock:] + 15
37  com.apple.Foundation          	0x00007fff3c54b1bd __NSThreadPerformPerform + 204
38  com.apple.CoreFoundation      	0x00007fff39e7df12 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
39  com.apple.CoreFoundation      	0x00007fff39e7deb1 __CFRunLoopDoSource0 + 103
40  com.apple.CoreFoundation      	0x00007fff39e7dccb __CFRunLoopDoSources0 + 209
41  com.apple.CoreFoundation      	0x00007fff39e7c9fa __CFRunLoopRun + 927
42  com.apple.CoreFoundation      	0x00007fff39e7bffe CFRunLoopRunSpecific + 462
43  libjli.dylib                  	0x0000000106c78621 CreateExecutionEnvironment + 875
44  libjli.dylib                  	0x0000000106c74c1b JLI_Launch + 1878
45  cc.arduino.Arduino            	0x0000000106c4a166 launch + 8838
46  cc.arduino.Arduino            	0x0000000106c47d9f main + 143
47  cc.arduino.Arduino            	0x0000000106c47d04 start + 52
Thread 1:
0   libsystem_kernel.dylib        	0x00007fff73f0855e __ulock_wait + 10
1   libsystem_pthread.dylib       	0x00007fff73fcb5c2 _pthread_join + 347
2   libjli.dylib                  	0x0000000106c78d61 ContinueInNewThread0 + 129
3   libjli.dylib                  	0x0000000106c77453 ContinueInNewThread + 170
4   libjli.dylib                  	0x0000000106c75881 JLI_Launch + 5052
7   libjli.dylib                  	0x0000000106c793cc apple_main + 84
8   libsystem_pthread.dylib       	0x00007fff73fca109 _pthread_start + 148
9   libsystem_pthread.dylib       	0x00007fff73fc5b8b thread_start + 15
Thread 2:
0   libsystem_kernel.dylib        	0x00007fff73f09882 __psynch_cvwait + 10
1   libsystem_pthread.dylib       	0x00007fff73fca425 _pthread_cond_wait + 698
2   libjvm.dylib                  	0x0000000108fc8237 os::PlatformEvent::park() + 297
3   libjvm.dylib                  	0x0000000108f836a2 ParkCommon(ParkEvent*, long) + 59
4   libjvm.dylib                  	0x0000000108f83e43 Monitor::IWait(Thread*, long) + 219
5   libjvm.dylib                  	0x0000000108f84d2c Monitor::wait(bool, long, bool) + 586
6   libjvm.dylib                  	0x0000000109108b36 Threads::destroy_vm() + 140
7   libjvm.dylib                  	0x0000000108da1477 jni_DestroyJavaVM + 425
8   libjli.dylib                  	0x0000000106c762c4 JavaMain + 1746
9   libsystem_pthread.dylib       	0x00007fff73fca109 _pthread_start + 148
10  libsystem_pthread.dylib       	0x00007fff73fc5b8b thread_start + 15
Thread 3:
5   libjvm.dylib                  	0x0000000108f84cb5 Monitor::wait(bool, long, bool) + 467
6   libjvm.dylib                  	0x0000000108c7ccec GCTaskManager::get_task(unsigned int) + 252
7   libjvm.dylib                  	0x0000000108c7e45e GCTaskThread::run() + 462
8   libjvm.dylib                  	0x0000000108fc2ee7 java_start(Thread*) + 250
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:: Java: VM Thread
2   libjvm.dylib                  	0x0000000108fc56b9 os::PlatformEvent::park(long) + 529
3   libjvm.dylib                  	0x0000000108f83e43 Monitor::IWait(Thread*, long) + 219
4   libjvm.dylib                  	0x0000000108f84cb5 Monitor::wait(bool, long, bool) + 467
5   libjvm.dylib                  	0x0000000109188ec9 VMThread::loop() + 1169
6   libjvm.dylib                  	0x00000001091888f6 VMThread::run() + 202
7   libjvm.dylib                  	0x0000000108fc2ee7 java_start(Thread*) + 250
Thread 14:: Java: Reference Handler
3   libjvm.dylib                  	0x0000000108fb55e7 ObjectMonitor::wait(long, bool, Thread*) + 1013
4   libjvm.dylib                  	0x00000001090ccbc8 ObjectSynchronizer::wait(Handle, long, Thread*) + 562
5   libjvm.dylib                  	0x0000000108dce715 JVM_MonitorWait + 519
6   ???                           	0x000000011398ffad 0 + 4623761325
7   ???                           	0x0000000113d8e744 0 + 4627949380
8   ???                           	0x0000000113960671 0 + 4623566449
9   libjvm.dylib                  	0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
10  libjvm.dylib                  	0x0000000108d50966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
11  libjvm.dylib                  	0x0000000108d50bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
12  libjvm.dylib                  	0x0000000108dea739 thread_entry(JavaThread*, Thread*) + 177
13  libjvm.dylib                  	0x0000000109101963 JavaThread::thread_main_inner() + 373
14  libjvm.dylib                  	0x00000001091016ff JavaThread::run() + 847
15  libjvm.dylib                  	0x0000000108fc2ee7 java_start(Thread*) + 250
16  libsystem_pthread.dylib       	0x00007fff73fca109 _pthread_start + 148
17  libsystem_pthread.dylib       	0x00007fff73fc5b8b thread_start + 15
Thread 15:: Java: Finalizer
6   ???                           	0x0000000113f56ecf 0 + 4629819087
7   ???                           	0x0000000113d91ce4 0 + 4627963108
Thread 16:: Java: Signal Dispatcher
0   libsystem_kernel.dylib        	0x00007fff73f06e36 semaphore_wait_trap + 10
1   libjvm.dylib                  	0x0000000108fc458e check_pending_signals(bool) + 200
2   libjvm.dylib                  	0x0000000108fbe41b signal_thread_entry(JavaThread*, Thread*) + 52
Thread 17:: Java: C2 CompilerThread0
4   libjvm.dylib                  	0x0000000108f84dd0 Monitor::wait(bool, long, bool) + 750
5   libjvm.dylib                  	0x0000000108b631d1 CompileQueue::get() + 131
6   libjvm.dylib                  	0x0000000108b664cd CompileBroker::compiler_thread_loop() + 497
7   libjvm.dylib                  	0x0000000109101963 JavaThread::thread_main_inner() + 373
8   libjvm.dylib                  	0x00000001091016ff JavaThread::run() + 847
9   libjvm.dylib                  	0x0000000108fc2ee7 java_start(Thread*) + 250
10  libsystem_pthread.dylib       	0x00007fff73fca109 _pthread_start + 148
11  libsystem_pthread.dylib       	0x00007fff73fc5b8b thread_start + 15
Thread 18:: Java: C2 CompilerThread1
Thread 19:: Java: C2 CompilerThread2
Thread 20:: Java: C1 CompilerThread3
Thread 21:: Java: Service Thread
6   libjvm.dylib                  	0x0000000109061e1e ServiceThread::service_thread_entry(JavaThread*, Thread*) + 258
Thread 22:: Java: VM Periodic Task Thread
5   libjvm.dylib                  	0x000000010910033e WatcherThread::sleep() const + 110
6   libjvm.dylib                  	0x00000001091004e2 WatcherThread::run() + 296
Thread 23:: com.apple.NSEventThread
5   com.apple.AppKit              	0x00007fff3729c5b4 _NSEventThread + 132
Thread 24:: Java: process reaper
2   libjvm.dylib                  	0x0000000108fc882c Parker::park(bool, long) + 1186
3   libjvm.dylib                  	0x000000010913761b Unsafe_Park + 430
4   ???                           	0x00000001147b0c51 0 + 4638575697
5   ???                           	0x00000001139682bd 0 + 4623598269
6   ???                           	0x00000001139682bd 0 + 4623598269
7   ???                           	0x0000000113968040 0 + 4623597632
8   ???                           	0x0000000113968040 0 + 4623597632
9   ???                           	0x0000000113968114 0 + 4623597844
10  ???                           	0x0000000113968040 0 + 4623597632
11  ???                           	0x00000001139682bd 0 + 4623598269
12  ???                           	0x0000000113968302 0 + 4623598338
13  ???                           	0x0000000113960671 0 + 4623566449
14  libjvm.dylib                  	0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
15  libjvm.dylib                  	0x0000000108d50966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
16  libjvm.dylib                  	0x0000000108d50bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
17  libjvm.dylib                  	0x0000000108dea739 thread_entry(JavaThread*, Thread*) + 177
18  libjvm.dylib                  	0x0000000109101963 JavaThread::thread_main_inner() + 373
19  libjvm.dylib                  	0x00000001091016ff JavaThread::run() + 847
20  libjvm.dylib                  	0x0000000108fc2ee7 java_start(Thread*) + 250
21  libsystem_pthread.dylib       	0x00007fff73fca109 _pthread_start + 148
22  libsystem_pthread.dylib       	0x00007fff73fc5b8b thread_start + 15
Thread 25 Crashed:: Java: Java2D Queue Flusher
0   libsystem_kernel.dylib        	0x00007fff73f0d33a __pthread_kill + 10
1   libsystem_pthread.dylib       	0x00007fff73fc9e60 pthread_kill + 430
2   libsystem_c.dylib             	0x00007fff73e94808 abort + 120
3   libjvm.dylib                  	0x00000001091a68ca os::abort(bool) (.cold.1) + 125
4   libjvm.dylib                  	0x0000000108fc355b os::abort(bool) + 33
5   libjvm.dylib                  	0x000000010915c8a6 VMError::report_and_die() + 2298
6   libjvm.dylib                  	0x0000000108bb82d3 report_vm_error(char const*, int, char const*, char const*) + 93
7   libjvm.dylib                  	0x0000000108fc8fa8 os::get_sender_for_C_frame(frame*) + 76
8   libjvm.dylib                  	0x0000000108bb9524 print_native_stack(outputStream*, frame, Thread*, char*, int) + 336
9   libjvm.dylib                  	0x000000010915b703 VMError::report(outputStream*) + 2617
10  libjvm.dylib                  	0x000000010915c387 VMError::report_and_die() + 987
11  libjvm.dylib                  	0x0000000108fc93b7 JVM_handle_bsd_signal + 802
12  libjvm.dylib                  	0x0000000108fc5f0f signalHandler(int, __siginfo*, void*) + 88
13  libsystem_platform.dylib      	0x00007fff73fbe5fd _sigtramp + 29
14  libobjc.A.dylib               	0x00007fff72c12954 lookUpImpOrForward + 63
15  libawt_lwawt.dylib            	0x00000001100a8239 CGLSD_MakeCurrentToScratch + 93
16  libawt_lwawt.dylib            	0x00000001100a8390 OGLSD_MakeOGLContextCurrent + 166
17  libawt_lwawt.dylib            	0x00000001100c5e32 OGLContext_SetSurfaces + 188
18  libawt_lwawt.dylib            	0x00000001100ca69f Java_sun_java2d_opengl_OGLRenderQueue_flushBuffer + 1775
19  ???                           	0x00000001148190d1 0 + 4639002833
20  ???                           	0x000000011489bbe4 0 + 4639538148
21  ???                           	0x0000000113960671 0 + 4623566449
22  libjvm.dylib                  	0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
23  libjvm.dylib                  	0x0000000108d50966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
24  libjvm.dylib                  	0x0000000108d50bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
25  libjvm.dylib                  	0x0000000108dea739 thread_entry(JavaThread*, Thread*) + 177
26  libjvm.dylib                  	0x0000000109101963 JavaThread::thread_main_inner() + 373
27  libjvm.dylib                  	0x00000001091016ff JavaThread::run() + 847
28  libjvm.dylib                  	0x0000000108fc2ee7 java_start(Thread*) + 250
29  libsystem_pthread.dylib       	0x00007fff73fca109 _pthread_start + 148
30  libsystem_pthread.dylib       	0x00007fff73fc5b8b thread_start + 15
Thread 26:: Java: Java2D Disposer
8   ???                           	0x0000000113968302 0 + 4623598338
9   ???                           	0x0000000113960671 0 + 4623566449
10  libjvm.dylib                  	0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
11  libjvm.dylib                  	0x0000000108d50966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
12  libjvm.dylib                  	0x0000000108d50bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
13  libjvm.dylib                  	0x0000000108dea739 thread_entry(JavaThread*, Thread*) + 177
14  libjvm.dylib                  	0x0000000109101963 JavaThread::thread_main_inner() + 373
15  libjvm.dylib                  	0x00000001091016ff JavaThread::run() + 847
16  libjvm.dylib                  	0x0000000108fc2ee7 java_start(Thread*) + 250
17  libsystem_pthread.dylib       	0x00007fff73fca109 _pthread_start + 148
18  libsystem_pthread.dylib       	0x00007fff73fc5b8b thread_start + 15
Thread 27:: Java: cc.arduino.packages.discoverers.serial.SerialDiscovery
3   libjvm.dylib                  	0x0000000108fb5587 ObjectMonitor::wait(long, bool, Thread*) + 917
7   ???                           	0x00000001139682bd 0 + 4623598269
Thread 28:: Java: Multihomed mDNS.Timer
Thread 29:: Java: SocketListener(10-0-0-20.local.)
0   libsystem_kernel.dylib        	0x00007fff73f0a3a6 __recvfrom + 10
1   libnet.dylib                  	0x000000010e5d6167 NET_RecvFrom + 135
2   libnet.dylib                  	0x000000010e5d2457 Java_java_net_PlainDatagramSocketImpl_receive0 + 449
3   ???                           	0x0000000113991d3c 0 + 4623768892
4   ???                           	0x00000001139682bd 0 + 4623598269
7   ???                           	0x0000000113960671 0 + 4623566449
8   libjvm.dylib                  	0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
9   libjvm.dylib                  	0x0000000108d50966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
10  libjvm.dylib                  	0x0000000108d50bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
11  libjvm.dylib                  	0x0000000108dea739 thread_entry(JavaThread*, Thread*) + 177
12  libjvm.dylib                  	0x0000000109101963 JavaThread::thread_main_inner() + 373
13  libjvm.dylib                  	0x00000001091016ff JavaThread::run() + 847
14  libjvm.dylib                  	0x0000000108fc2ee7 java_start(Thread*) + 250
15  libsystem_pthread.dylib       	0x00007fff73fca109 _pthread_start + 148
16  libsystem_pthread.dylib       	0x00007fff73fc5b8b thread_start + 15
Thread 30:: Java: JmDNS(10-0-0-20.local.).Timer
Thread 31:: Java: JmDNS(10-0-0-20.local.).State.Timer
Thread 32:: Java: JmmDNS pool-3-thread-1
4   ???                           	0x000000011398ffad 0 + 4623761325
Thread 33:: Java: Batik CleanerThread
Thread 34:: Java: MarlinRenderer Disposer
Thread 35:: Java: AWT-Shutdown
7   ???                           	0x0000000113ef46d4 0 + 4629415636
Thread 36:: Java: AWT-EventQueue-0
7   ???                           	0x000000011489afa4 0 + 4639535012
8   ???                           	0x00000001146dfed4 0 + 4637720276
10  ???                           	0x0000000113967a90 0 + 4623596176
12  ???                           	0x00000001139682bd 0 + 4623598269
13  ???                           	0x00000001139682bd 0 + 4623598269
14  ???                           	0x0000000113968040 0 + 4623597632
15  ???                           	0x0000000113960671 0 + 4623566449
16  libjvm.dylib                  	0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
17  libjvm.dylib                  	0x0000000108dd71a4 JVM_DoPrivileged + 2657
18  ???                           	0x000000011453a0bc 0 + 4635992252
19  ???                           	0x0000000113cf48bc 0 + 4627318972
20  ???                           	0x00000001139682bd 0 + 4623598269
21  ???                           	0x00000001139682bd 0 + 4623598269
22  ???                           	0x00000001139682bd 0 + 4623598269
23  ???                           	0x00000001139682bd 0 + 4623598269
24  ???                           	0x00000001147af144 0 + 4638568772
25  libjvm.dylib                  	0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
26  libjvm.dylib                  	0x0000000108dd71a4 JVM_DoPrivileged + 2657
27  ???                           	0x000000011453a0bc 0 + 4635992252
28  ???                           	0x00000001145d64ac 0 + 4636632236
29  ???                           	0x00000001139682bd 0 + 4623598269
30  ???                           	0x00000001139682bd 0 + 4623598269
31  ???                           	0x00000001139682bd 0 + 4623598269
32  ???                           	0x00000001139682bd 0 + 4623598269
33  ???                           	0x0000000113960671 0 + 4623566449
34  libjvm.dylib                  	0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
35  libjvm.dylib                  	0x0000000108d50966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
36  libjvm.dylib                  	0x0000000108d50bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
37  libjvm.dylib                  	0x0000000108dea739 thread_entry(JavaThread*, Thread*) + 177
38  libjvm.dylib                  	0x0000000109101963 JavaThread::thread_main_inner() + 373
39  libjvm.dylib                  	0x00000001091016ff JavaThread::run() + 847
40  libjvm.dylib                  	0x0000000108fc2ee7 java_start(Thread*) + 250
41  libsystem_pthread.dylib       	0x00007fff73fca109 _pthread_start + 148
42  libsystem_pthread.dylib       	0x00007fff73fc5b8b thread_start + 15
Thread 37:: Java: TimerQueue
7   ???                           	0x0000000113967e15 0 + 4623597077
9   ???                           	0x0000000113968302 0 + 4623598338
10  ???                           	0x0000000113960671 0 + 4623566449
11  libjvm.dylib                  	0x0000000108d52127 JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*) + 2243
12  libjvm.dylib                  	0x0000000108d50966 JavaCalls::call_virtual(JavaValue*, KlassHandle, Symbol*, Symbol*, JavaCallArguments*, Thread*) + 626
13  libjvm.dylib                  	0x0000000108d50bb3 JavaCalls::call_virtual(JavaValue*, Handle, KlassHandle, Symbol*, Symbol*, Thread*) + 111
14  libjvm.dylib                  	0x0000000108dea739 thread_entry(JavaThread*, Thread*) + 177
15  libjvm.dylib                  	0x0000000109101963 JavaThread::thread_main_inner() + 373
16  libjvm.dylib                  	0x00000001091016ff JavaThread::run() + 847
17  libjvm.dylib                  	0x0000000108fc2ee7 java_start(Thread*) + 250
18  libsystem_pthread.dylib       	0x00007fff73fca109 _pthread_start + 148
19  libsystem_pthread.dylib       	0x00007fff73fc5b8b thread_start + 15
Thread 38:
0   libsystem_pthread.dylib       	0x00007fff73fc5b68 start_wqthread + 0
Thread 39:
Thread 40:
Thread 41:
Thread 42:: Java: Image Fetcher 0
Thread 25 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x0000700002fb3000  rcx: 0x0000700002fb1518  rdx: 0x0000000000000000
  rdi: 0x0000000000013d07  rsi: 0x0000000000000006  rbp: 0x0000700002fb1540  rsp: 0x0000700002fb1518
   r8: 0x0000000000000010   r9: 0x0000700002fb1550  r10: 0x0000700002fb3000  r11: 0x0000000000000246
  r12: 0x0000000000013d07  r13: 0x0000700002fb16c0  r14: 0x0000000000000006  r15: 0x0000000000000016
  rip: 0x00007fff73f0d33a  rfl: 0x0000000000000246  cr2: 0x00000001091a5644
Logical CPU:     0
Error Code:      0x02000148
Trap Number:     133
Binary Images:
       0x106c47000 -        0x106c4bfff +cc.arduino.Arduino (1.8.12 - 1.8.12) <2AE2040B-3408-3208-B101-5825B8F425F0> /Applications/Arduino.app/Contents/MacOS/Arduino
       0x106c73000 -        0x106c7cfff +libjli.dylib (0) <212562B4-111E-35D6-BB2B-A1BFD63A5B64> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/jli/libjli.dylib
       0x1088a6000 -        0x10933ffff +libjvm.dylib (0) <31202E71-A956-3765-B4D6-876A7D4FFBD9> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/server/libjvm.dylib
       0x109ccc000 -        0x109cd4fff +libverify.dylib (0) <B8F4EBC4-811F-33AD-BB9A-2C4B148C8C6D> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libverify.dylib
       0x109cdf000 -        0x109cfdfff +libjava.dylib (0) <32138414-C5B3-3330-8911-97D6CD983944> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libjava.dylib
       0x109d2d000 -        0x109d31fff +libzip.dylib (0) <346621C0-4ADF-3E59-A9AA-76CC581A12F0> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libzip.dylib
       0x10e5b4000 -        0x10e5bafff +libnio.dylib (0) <1FB68BF9-1173-3A83-A617-15DA017AD812> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libnio.dylib
       0x10e5cc000 -        0x10e5d9fff +libnet.dylib (0) <B9072F4C-3145-3661-9DBE-8AECB4DF85DB> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libnet.dylib
       0x10e6b9000 -        0x10e6bdfff +libosxui.dylib (0) <298413FC-09E2-3331-8821-E08823132ED9> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libosxui.dylib
       0x10e877000 -        0x10e8b3ff3 +libsplashscreen.dylib (0) <F8DFB9AF-1758-3CB3-8ECF-A40AF50AEFE2> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libsplashscreen.dylib
       0x10e8dd000 -        0x10e8e2fff +libosxapp.dylib (0) <44AA406A-BF46-3779-8247-5363068551AC> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libosxapp.dylib
       0x10fdb6000 -        0x10fe10ff3 +libawt.dylib (0) <F9DD7DEF-AB6A-3718-9314-73F7B227B709> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libawt.dylib
       0x10fea3000 -        0x10ff4dff7 +libmlib_image.dylib (0) <9474B2D4-5C83-3AED-A17D-155AC6A1292F> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libmlib_image.dylib
       0x11008e000 -        0x1100edff3 +libawt_lwawt.dylib (0) <4D83B9A4-989F-3D85-BA5E-F0208BEB2F86> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libawt_lwawt.dylib
       0x11016c000 -        0x11016f047  libobjc-trampolines.dylib (787.1) <CCA8AC98-12A2-3984-ACD6-1D77DAD6C0AD> /usr/lib/libobjc-trampolines.dylib
       0x1103c3000 -        0x1103d4ff7 +liblistSerialsj.dylib (0) <9652E9D9-1D2A-37ED-982B-F222108D70FF> /Applications/Arduino.app/Contents/Java/lib/liblistSerialsj.dylib
       0x1103dd000 -        0x110415ff3 +libfontmanager.dylib (0) <DF7F570B-A725-35D6-AD41-D00755395693> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libfontmanager.dylib
       0x11045e000 -        0x1104f7ff7 +libfreetype.dylib.6 (0) <D7022DC9-4783-3993-97D4-A548688EF098> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libfreetype.dylib.6
       0x11067e000 -        0x110684fff +libosx.dylib (0) <65FD3A00-CBF7-3B4C-95AA-041E9A8A0907> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libosx.dylib
       0x11086c000 -        0x110932ff7  com.apple.AMDRadeonX4000GLDriver (3.8.24 - 3.0.8) <C8948AD2-CFF9-31A6-95B9-F2E0A8068EF0> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
       0x11385b000 -        0x1138eceff  dyld (750.5) <1F893B81-89A5-3502-8510-95B97B9F730D> /usr/lib/dyld
       0x14f7ff000 -        0x14f819ff3 +libsunec.dylib (0) <43F0DC3E-70CC-3F3C-A260-25C03EAA8E36> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libsunec.dylib
       0x14fc31000 -        0x14fc34ffb +libmanagement.dylib (0) <8413F67C-85D3-3B3C-9FC2-75A0B470A96C> /Applications/Arduino.app/Contents/PlugIns/jre1.8.0_242.jre/Contents/Home/lib/libmanagement.dylib
       0x15289a000 -        0x1528d5fff +libastylej.dylib (0) <906AC4F1-6792-3FBA-A552-EF8D40DBEA1B> /Applications/Arduino.app/Contents/Java/lib/libastylej.dylib
       0x153c64000 -        0x153c72ff7 +libJTouchBar.dylib4957522234097849858 (0) <E9801EEC-0090-3848-8C4B-8335665DFE26> /var/folders/*/libJTouchBar.dylib4957522234097849858
    0x7fff2ce7a000 -     0x7fff2d0c7ff8  com.apple.RawCamera.bundle (9.01.0 - 1340.28) <3249E1E0-D226-3219-BFF2-22F85C39BB6D> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0x7fff2d0ca000 -     0x7fff2d1f7ff8  com.apple.AMDMTLBronzeDriver (3.8.24 - 3.0.8) <15983EE9-C22E-3979-BDB1-51682FFE9442> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
    0x7fff2d1f8000 -     0x7fff2d22efff  ATIRadeonX4000SCLib.dylib (3.8.24) <FC75895C-348F-3C26-B82F-6E17FFF0E63C> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
    0x7fff2e743000 -     0x7fff2f0fbff3  libSC.dylib (3.8.24) <3A787392-149B-3C17-8257-ECB04A04A1B7> /System/Library/Extensions/AMDShared.bundle/Contents/PlugIns/libSC.dylib
    0x7fff31800000 -     0x7fff32807fff  com.apple.driver.AppleIntelKBLGraphicsGLDriver (14.5.22 - 14.0.5) <4C6C15C9-6C8E-3E84-911D-D000FB94794D> /System/Library/Extensions/AppleIntelKBLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsGLDriver
    0x7fff32808000 -     0x7fff32c07ff1  com.apple.driver.AppleIntelKBLGraphicsMTLDriver (14.5.22 - 14.0.5) <0BB14CF6-CA95-34B0-B454-0AB95C5D4CF6> /System/Library/Extensions/AppleIntelKBLGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelKBLGraphicsMTLDriver
    0x7fff35a8e000 -     0x7fff35a8efff  com.apple.Accelerate (1.11 - Accelerate 1.11) <8BE0965F-6A6A-35B0-89D0-F0A75835C2CA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff35a8f000 -     0x7fff35aa5fff  libCGInterfaces.dylib (524.2) <9092665A-D5C7-3ED8-A7D5-9216B48F8E3E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fff35aa6000 -     0x7fff360fcfef  com.apple.vImage (8.1 - 524.2) <DAE0E5C5-BA70-325D-8B4C-6B821F009CBF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff360fd000 -     0x7fff36364ff7  libBLAS.dylib (1303.60.1) <4E980D6B-4B3A-33D6-B52C-AFC7D120D11A> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff36365000 -     0x7fff36838fef  libBNNS.dylib (144.100.2) <C05F9F9D-4498-37BD-9C1C-2F7B920B401D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fff36839000 -     0x7fff36bd4fff  libLAPACK.dylib (1303.60.1) <F8E9D081-7C60-32EC-A47D-2D30CAD73C5F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff36bd5000 -     0x7fff36beafec  libLinearAlgebra.dylib (1303.60.1) <79CB28C5-F811-3EAF-AD8E-7D7D879FE662> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff36beb000 -     0x7fff36bf0ff3  libQuadrature.dylib (7) <EB7C9E98-D1E7-314C-90B4-3EB04428CC7C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fff36bf1000 -     0x7fff36c61fff  libSparse.dylib (103) <8C55F5F2-6AE3-393C-B2FF-22B8CFCBD7FC> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
    0x7fff36c62000 -     0x7fff36c74fef  libSparseBLAS.dylib (1303.60.1) <08F6D629-5DAC-3A99-B261-2B6095DD38B4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fff36c75000 -     0x7fff36e4cfd7  libvDSP.dylib (735.100.4) <0744F29B-F822-3571-9B4A-B592146D4E03> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff36e4d000 -     0x7fff36f0ffef  libvMisc.dylib (735.100.4) <E6C94B52-931B-3858-AF4D-C2EA52ACB7F5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff36f10000 -     0x7fff36f10fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <66282197-81EE-316F-978E-EF1471551DEF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff36f11000 -     0x7fff36f70ff0  com.apple.Accounts (113 - 113) <4B85E422-169E-396D-898A-DD1A7715EC6D> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
    0x7fff370ba000 -     0x7fff37e79ff5  com.apple.AppKit (6.9 - 1894.40.150) <FDDF35FF-4007-3F0B-B59C-03CFF3A0A73B> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff37ec9000 -     0x7fff37ec9fff  com.apple.ApplicationServices (48 - 50) <CABCF23C-55E5-35E1-AAF0-EE5DDE3FDB03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff37eca000 -     0x7fff37f35fff  com.apple.ApplicationServices.ATS (377 - 493.0.4.1) <6AA4BBCC-43AF-3EBF-8EB5-7916A3B563AA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff37fce000 -     0x7fff3800cff0  libFontRegistry.dylib (274.0.4.2) <FBF6EC26-42C0-334E-B67C-871AD50DB0BC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff38067000 -     0x7fff38096fff  com.apple.ATSUI (1.0 - 1) <D8C604E9-D854-3A32-B37B-819197537A63> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI
    0x7fff38097000 -     0x7fff3809bffb  com.apple.ColorSyncLegacy (4.13.0 - 1) <2359E2CD-8FCE-32D7-AF76-F4D9A3D9D9F8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy
    0x7fff38135000 -     0x7fff3818cffa  com.apple.HIServices (1.22 - 675.1) <B2DEE96F-ED7A-3924-A2E2-44BB7A950BD8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff3818d000 -     0x7fff3819bfff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <1603F2CC-DC51-3E15-B6B5-0A9F9AB0C045> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff3819c000 -     0x7fff381e1ffa  com.apple.print.framework.PrintCore (15.4 - 516.2) <525E8A4B-297B-3CAC-8A4A-6C7E211D7A21> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff381e2000 -     0x7fff381ecff7  com.apple.QD (4.0 - 413) <1EAEF5BC-D649-3E42-87BC-43CCEE4D5274> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff381ed000 -     0x7fff381faffc  com.apple.speech.synthesis.framework (9.0.24 - 9.0.24) <C2E5BBFC-2EF0-3FFE-A1CF-960631DC249C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff381fb000 -     0x7fff382dcffa  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <4222CBDF-D637-30DB-BA45-C6E222BABB24> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff382de000 -     0x7fff382defff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <73D89D5E-05D5-3F64-BE02-2B2ED6AD6C03> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff38671000 -     0x7fff389ffffd  com.apple.CFNetwork (1125.2 - 1125.2) <1D4D81F7-FC48-3588-87FC-481E2586E345> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff38a7b000 -     0x7fff38a7bfff  com.apple.Carbon (160 - 162) <CAA294BD-BC93-384A-8415-B254C89098FC> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff38a7c000 -     0x7fff38a7fff3  com.apple.CommonPanels (1.2.6 - 101) <63261921-DD00-312E-AFD1-C099E1984725> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff38a80000 -     0x7fff38d74ff3  com.apple.HIToolbox (2.1.1 - 994.6) <C03A48FC-1A02-320D-9147-F4687A1BBC6F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff38d75000 -     0x7fff38d78ff3  com.apple.help (1.3.8 - 71) <F5E9EA64-5D5E-346F-98D0-D04A2F805D8D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff38d79000 -     0x7fff38d7eff7  com.apple.ImageCapture (9.0 - 1600.60.4.2) <63FE9A8C-A7C6-3ABD-AA1D-EA1BC6613C39> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff38d7f000 -     0x7fff38d7ffff  com.apple.ink.framework (10.15 - 227) <90518F56-AD8A-3627-905A-16E2B8640F87> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff38d80000 -     0x7fff38d9affa  com.apple.openscripting (1.7 - 185.1) <718C485A-4167-3A26-B2CD-6C42B5B36D01> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff38dbb000 -     0x7fff38dbbfff  com.apple.print.framework.Print (15 - 271) <29384C24-6667-3BAA-992A-DAD809D6387E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff38dbc000 -     0x7fff38dbeff7  com.apple.securityhi (9.0 - 55008) <478C57A9-D5A5-3951-B289-DA5323E9044A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff38dbf000 -     0x7fff38dc5fff  com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <E6BE4EC1-5C53-38BB-AAFD-E7BF7A8975BC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff38f5f000 -     0x7fff38f5ffff  com.apple.Cocoa (6.11 - 23) <37E98F4D-1D78-3F22-BDC0-59DC0B9B3A3E> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
    0x7fff38f6d000 -     0x7fff39063fff  com.apple.ColorSync (4.13.0 - 3394.7) <FC6CFACE-CDD8-3811-BAB6-C9F82AC0A594> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff3934e000 -     0x7fff39857ffb  com.apple.audio.CoreAudio (5.0 - 5.0) <CF50C6CC-6753-3D64-A76B-21CE211A98E8> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff398aa000 -     0x7fff398e2fff  com.apple.CoreBluetooth (1.0 - 1) <D2943204-C3A0-3C09-A7A9-BF75822678B4> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff398e3000 -     0x7fff39ccdfe8  com.apple.CoreData (120 - 977.3) <9A33F390-687F-3EE2-8293-4E564A164469> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff39cce000 -     0x7fff39df9ffe  com.apple.CoreDisplay (1.0 - 186.5.25) <53F750C6-947A-39AE-984E-41939B858A68> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fff39dfa000 -     0x7fff3a279ffb  com.apple.CoreFoundation (6.9 - 1675.129) <9E632A1E-9622-33D6-BCCE-23AC16DAA6B7> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff3a27b000 -     0x7fff3a8effe0  com.apple.CoreGraphics (2.0 - 1355.13) <54528FE3-21A7-3F64-B7AA-F6B95394488D> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff3a8fd000 -     0x7fff3ac58ff0  com.apple.CoreImage (15.0.0 - 940.9) <CA78A35D-E15E-3D98-BDEF-9F3D9039DB78> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff3b019000 -     0x7fff3b0f5ff4  com.apple.CoreMedia (1.0 - 2612.58.4.6) <301A075B-022D-3F28-AE2C-7F280CCF1F51> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
    0x7fff3b1e2000 -     0x7fff3b1e2fff  com.apple.CoreServices (1069.22 - 1069.22) <888FE7B9-CE6C-3C7C-BA33-63364462228A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff3b1e3000 -     0x7fff3b268fff  com.apple.AE (838.1 - 838.1) <2BAB1B88-C198-3D20-8DA3-056E66510E7A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff3b269000 -     0x7fff3b54aff7  com.apple.CoreServices.CarbonCore (1217 - 1217) <D0FECC17-7E16-308F-98EA-AF311CB77FE6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff3b54b000 -     0x7fff3b598ffd  com.apple.DictionaryServices (1.2 - 323.6) <11513ED9-8B4B-39BB-A6B2-AA6AA0A2DF72> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff3b599000 -     0x7fff3b5a1ff7  com.apple.CoreServices.FSEvents (1268.100.1 - 1268.100.1) <CE3D8B13-2583-3527-8532-D5DDAAD7D56B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff3b5a2000 -     0x7fff3b7dbffc  com.apple.LaunchServices (1069.22 - 1069.22) <E51EE658-608C-3034-9635-4FDF1E241E62> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff3b7dc000 -     0x7fff3b874ff1  com.apple.Metadata (10.7.0 - 2076.3) <EE42CCA1-FEC2-3F1C-9B62-2E73EFB05FCC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff3b875000 -     0x7fff3b8a2fff  com.apple.CoreServices.OSServices (1069.22 - 1069.22) <A0654B4E-3194-3066-911F-FF1FBEE1D2C2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff3b8a3000 -     0x7fff3b90afff  com.apple.SearchKit (1.4.1 - 1.4.1) <D4F82BC9-FD9B-3E04-B78E-D9E2A73B0BD7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff3b90b000 -     0x7fff3b92fff5  com.apple.coreservices.SharedFileList (131.4 - 131.4) <AEB4E42C-F5A2-3F63-80B0-4226483AD4F5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fff3bc54000 -     0x7fff3be0bffc  com.apple.CoreText (643.1.4.4 - 643.1.4.4) <5D4EA236-DC1B-3772-95C5-7F4B6CFEAF84> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff3be0c000 -     0x7fff3be50ffb  com.apple.CoreVideo (1.8 - 344.3) <8507ED54-43C3-3E5B-BC74-512FE510BF8D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff3be51000 -     0x7fff3bedeffc  com.apple.framework.CoreWLAN (13.0 - 1601.2) <C1C2BBD4-EA97-3CC1-845D-1F1578E68380> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff3c175000 -     0x7fff3c17bfff  com.apple.DiskArbitration (2.7 - 2.7) <D7617B57-B01C-3848-8818-593FB12039E9> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff3c34e000 -     0x7fff3c350ff2  com.apple.ExceptionHandling (1.5 - 13) <988B7AAE-677F-307B-BCF1-1BF2D11176E7> /System/Library/Frameworks/ExceptionHandling.framework/Versions/A/ExceptionHandling
    0x7fff3c36d000 -     0x7fff3c498ffa  com.apple.FileProvider (276 - 276) <B3EB6E66-807E-3F67-951F-88B8484FB8CD> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider
    0x7fff3c4b0000 -     0x7fff3c875ff8  com.apple.Foundation (6.9 - 1675.129) <9A74FA97-7F7B-3929-B381-D9514B1E4754> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff3c8e2000 -     0x7fff3c932ff7  com.apple.GSS (4.0 - 2.0) <16DE732E-4A48-3C8A-BD61-8AF810F3A48C> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff3ca6f000 -     0x7fff3cb83ff3  com.apple.Bluetooth (7.0.4 - 7.0.4f6) <9003721F-8543-3A21-BF11-2A981614F481> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff3cbe9000 -     0x7fff3cc8dff3  com.apple.framework.IOKit (2.0.2 - 1726.100.16) <3D8BA34A-AAF7-3AF2-9B5B-189AC4755404> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff3cc8f000 -     0x7fff3cca0ffb  com.apple.IOSurface (269.11 - 269.11) <887CD3FD-1BB8-3BB7-B7F8-6A0BA4B3AEAE> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff3cd1f000 -     0x7fff3ce7bfee  com.apple.ImageIO.framework (3.3.0 - 1976.3.4.4) <EDAA3E6B-6D65-3807-86C2-91736BC0AF88> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fff3ce7c000 -     0x7fff3ce7ffff  libGIF.dylib (1976.3.4.4) <A4627958-EB22-3ADA-92BE-16229F9E9767> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff3ce80000 -     0x7fff3cf39fff  libJP2.dylib (1976.3.4.4) <43672561-0E75-3A32-B428-697C6DA13BD8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff3cf3a000 -     0x7fff3cf5dfe3  libJPEG.dylib (1976.3.4.4) <52DC775B-CAB5-32B7-AC86-D9AAF7851BE9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff3d1d9000 -     0x7fff3d1f3fef  libPng.dylib (1976.3.4.4) <0B79BE68-50CD-3C99-9CF4-2396CD203EF8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff3d1f4000 -     0x7fff3d1f5fff  libRadiance.dylib (1976.3.4.4) <E506A652-A423-3170-8032-0B03FF367FE8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff3d1f6000 -     0x7fff3d23fffb  libTIFF.dylib (1976.3.4.4) <0419D70A-E156-3B5D-A8B0-33BA29B54A08> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff3e78a000 -     0x7fff3e792ffc  JavaNativeFoundation (75) <F45E2FA0-08FF-38FE-8EC2-771B5BFC8581> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.framework/Versions/A/JavaNativeFoundation
    0x7fff3e793000 -     0x7fff3e79bffb  com.apple.java.JavaRuntimeSupport (15.0.1 - 15.0.1) <163BD8C4-3AA6-3B46-B179-11BBA8556F44> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaRuntimeSupport.framework/Versions/A/JavaRuntimeSupport
    0x7fff3e79c000 -     0x7fff3e7a0ffd  com.apple.JavaVM (15.0.3 - 15.0.3) <E1B013EF-5C57-390C-A0AC-695FCE4A135D> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
    0x7fff3e7a1000 -     0x7fff3e7b3ff3  com.apple.Kerberos (3.0 - 1) <DC673FF3-4DC9-3C23-9718-343AB36B2984> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff3e7b4000 -     0x7fff3e7b4fff  libHeimdalProxy.dylib (77) <A970C7A8-7CCD-3701-A459-078BD5E8FE4E> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib
    0x7fff3eb46000 -     0x7fff3eb50ffb  com.apple.MediaAccessibility (1.0 - 125.1) <B2F72AF8-99DC-3613-B618-C588252EEAC2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
    0x7fff3ec1c000 -     0x7fff3f367ffd  com.apple.MediaToolbox (1.0 - 2612.58.4.6) <FEB63B0B-D774-3FEB-B89A-66C2179DAC85> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
    0x7fff3f369000 -     0x7fff3f433fff  com.apple.Metal (212.5.15 - 212.5.15) <2CBB178E-434E-31D3-BAE2-ED3EA801D4BC> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fff3f450000 -     0x7fff3f48dff7  com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <5DF84B7A-9DD0-36DB-8686-D669CDA93D59> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore
    0x7fff3f48e000 -     0x7fff3f518fe2  com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <CDC36001-66DA-3BBD-A9AA-2470B634B9C9> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage
    0x7fff3f519000 -     0x7fff3f53eff4  com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <1E4FE6EF-6D42-3439-835C-F4F20B05E0F5> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix
    0x7fff3f53f000 -     0x7fff3f554ffb  com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <8F8F0C2E-C4EC-3418-A06A-42B8280DDC9D> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray
    0x7fff3f555000 -     0x7fff3f6b3ffc  com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <6BEFB262-2538-3A12-9E9F-A7CF94D2B68A> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork
    0x7fff3f6b4000 -     0x7fff3f703ff4  com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <4D352B8E-97D8-34FA-B2AF-3AB4E3149E2E> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector
    0x7fff3f704000 -     0x7fff3f705ff5  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <07F3B58C-F362-35F2-9A79-F38015A78DDA> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fff4078c000 -     0x7fff40798ffe  com.apple.NetFS (6.0 - 4.0) <7A96A8FE-17F3-3850-8E81-9DDDC5A48DDB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fff40799000 -     0x7fff408f0ff3  com.apple.Network (1.0 - 1) <D1C8FDDE-C822-3C40-BB26-18F24CFC8AE2> /System/Library/Frameworks/Network.framework/Versions/A/Network
    0x7fff43318000 -     0x7fff43320ff7  libcldcpuengine.dylib (2.14) <BB23A727-5F40-3D27-AD3B-3197A7241F84> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fff43321000 -     0x7fff43379fff  com.apple.opencl (3.5 - 3.5) <3F0E363C-9380-3226-A4D1-67E740079AAD> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff4337a000 -     0x7fff43396fff  com.apple.CFOpenDirectory (10.15 - 220.40.1) <58835104-9E7A-32E8-862B-530CE899C9B4> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff43397000 -     0x7fff433a2ffd  com.apple.OpenDirectory (10.15 - 220.40.1) <D846BA35-59A1-3B78-B1C8-7E0EDE972AD2> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff43d08000 -     0x7fff43d0afff  libCVMSPluginSupport.dylib (17.10.22) <65052150-BEFD-38D8-A789-560C2FB1644A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff43d0b000 -     0x7fff43d10fff  libCoreFSCache.dylib (176.11) <AEAEE894-BA4B-334F-90E1-7374DFB41979> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fff43d11000 -     0x7fff43d15fff  libCoreVMClient.dylib (176.11) <29D2B5C2-CBFF-308A-ADD8-A559B760C494> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff43d16000 -     0x7fff43d1eff7  libGFXShared.dylib (17.10.22) <7FF5455A-3D5D-33D2-9C41-A51ABE53CE66> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff43d1f000 -     0x7fff43d29fff  libGL.dylib (17.10.22) <08450555-3BC8-3457-8F5E-E2BBE895C0C7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff43d2a000 -     0x7fff43d5eff7  libGLImage.dylib (17.10.22) <5182EE22-2914-30E0-A87D-C38F345F695B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff43d5f000 -     0x7fff43ef3ff7  libGLProgrammability.dylib (17.10.22) <942CCB23-9868-3D76-98CC-3430E45590D2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fff43ef4000 -     0x7fff43f30fff  libGLU.dylib (17.10.22) <2FE69FE7-B60D-3D05-824B-CD4958E2C7B8> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff4496c000 -     0x7fff4497bff7  com.apple.opengl (17.10.22 - 17.10.22) <4E9C4B23-6D44-3804-AFF8-84C3B060E8F5> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff4497c000 -     0x7fff44af5fff  GLEngine (17.10.22) <803CEBEC-8BA2-3B48-B6E7-23F080B7EE75> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
    0x7fff44af6000 -     0x7fff44b1efff  GLRendererFloat (17.10.22) <EE9FB4C6-8D39-39CC-9A91-7D3EFB16B2DB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    0x7fff45939000 -     0x7fff45bbbff2  com.apple.QuartzCore (1.11 - 840.18) <16502545-A0F3-3367-929B-DD80A6440226> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff4673c000 -     0x7fff46a85ff1  com.apple.security (7.0 - 59306.101.1) <430E04FE-F068-3476-9CA2-72CB5F040D1F> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff46a86000 -     0x7fff46b0effb  com.apple.securityfoundation (6.0 - 55236.60.1) <BC15B825-955D-33CF-B416-A64D69A1D008> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff46b3d000 -     0x7fff46b41ff8  com.apple.xpc.ServiceManagement (1.0 - 1) <C66FC9CF-224B-348C-94A5-ABAC579F5C0A> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff477ec000 -     0x7fff4785aff7  com.apple.SystemConfiguration (1.19 - 1.19) <71AC15DE-7018-3D2B-B599-F2972F0288AE> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff47ad9000 -     0x7fff47e5cff4  com.apple.VideoToolbox (1.0 - 2612.58.4.6) <C488A935-B94F-3F80-88E7-D2743FB1E460> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
    0x7fff4b7b7000 -     0x7fff4b87cff7  com.apple.APFS (1412.101.1 - 1412.101.1) <2F5A48FB-9788-3A24-87FE-C1B7DDBC8A07> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
    0x7fff4c98a000 -     0x7fff4c98bff1  com.apple.AggregateDictionary (1.0 - 1) <FE9B8728-9C37-367E-91A6-2D1321D485A0> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary
    0x7fff4cf25000 -     0x7fff4cf42ff4  com.apple.AppContainer (4.0 - 448.100.6) <FBA274DA-2172-31C8-9759-AFB227E0E7E7> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
    0x7fff4cf97000 -     0x7fff4cfa5ff7  com.apple.AppSandbox (4.0 - 448.100.6) <B38CE066-5303-3FBF-B0D3-A0D3889E2005> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
    0x7fff4d420000 -     0x7fff4d444ffb  com.apple.framework.Apple80211 (13.0 - 1602.3) <7D1A08A0-27B0-3F53-BFC4-A2A482B055A0> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff4d702000 -     0x7fff4d711fd7  com.apple.AppleFSCompression (119.100.1 - 1.0) <E1B024EB-DAB1-30A1-A43D-01D9E9357F2B> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fff4d810000 -     0x7fff4d81bff7  com.apple.AppleIDAuthSupport (1.0 - 1) <BE6A7C6D-060E-38E9-A010-61975ECE5E43> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
    0x7fff4d85d000 -     0x7fff4d8a5ff7  com.apple.AppleJPEG (1.0 - 1) <C163D80A-6818-3C36-B9A9-7CC8777FE593> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fff4dc93000 -     0x7fff4dcb5fff  com.apple.applesauce (1.0 - 16.25) <A6C6D37B-9AA5-3137-A02E-F61798A908B0> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce
    0x7fff4dd74000 -     0x7fff4dd77ffb  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <52444963-7A5E-36C8-BAAA-FFF8A0D14612> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
    0x7fff4dd78000 -     0x7fff4ddc8ff7  com.apple.AppleVAFramework (6.1.2 - 6.1.2) <A46D4D00-6251-302B-9A4A-3A930855BC1F> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x7fff4de11000 -     0x7fff4de20ff9  com.apple.AssertionServices (1.0 - 223.100.31) <2DA45CD2-C755-397C-977C-F4C6435A1272> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices
    0x7fff4e362000 -     0x7fff4e75dff8  com.apple.audio.AudioResourceArbitration (1.0 - 1) <B7E163FF-F028-32A5-9AD3-DB7022E99DE7> /System/Library/PrivateFrameworks/AudioResourceArbitration.framework/Versions/A/AudioResourceArbitration
    0x7fff4e9b3000 -     0x7fff4ebf3ff0  com.apple.audio.AudioToolboxCore (1.0 - 1104.80) <EE6A2BD9-843C-3CC3-AEFC-6D7855DBB331> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
    0x7fff4ebf7000 -     0x7fff4ed13ff3  com.apple.AuthKit (1.0 - 1) <0A3A05D4-0795-35B8-8729-4BF252D52E60> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
    0x7fff4eed0000 -     0x7fff4eed9ff7  com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <2088BC70-5329-3390-A851-C4ECF654047C> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement
    0x7fff4eeda000 -     0x7fff4ef7bff5  com.apple.backup.framework (1.11.4 - 1298.4.19) <1F848C06-11E3-3D85-8358-7E37AD2BE9D7> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fff4ef7c000 -     0x7fff4f008ff6  com.apple.BaseBoard (466.3 - 466.3) <1EFE4339-9393-3B15-8DC9-2BE9B03F3062> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
    0x7fff4f10a000 -     0x7fff4f146ff7  com.apple.bom (14.0 - 219.2) <4B7C18B2-1E51-376E-9D6A-CE3F58D2AE53> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
    0x7fff4fcc2000 -     0x7fff4fd11fff  com.apple.ChunkingLibrary (307 - 307) <4A5C3E8E-1E95-3363-8A78-CCD55770F064> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fff50b82000 -     0x7fff50b92ffb  com.apple.CommonAuth (4.0 - 2.0) <E09BBBBE-ECDD-3442-8D4E-27A12F5E2347> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff50ba6000 -     0x7fff50bbdfff  com.apple.commonutilities (8.0 - 900) <1E6CE910-4B06-3704-A47D-06337A6F0992> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
    0x7fff512c3000 -     0x7fff51698fc8  com.apple.CoreAUC (283.0.0 - 283.0.0) <5BF7FDC2-E106-3E73-B950-2A0DDE2CA11F> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
    0x7fff51699000 -     0x7fff516c6ff7  com.apple.CoreAVCHD (6.1.0 - 6100.4.1) <4BD22FB9-F5F7-35E5-AAD6-CF92706C9816> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
    0x7fff516e9000 -     0x7fff51708ffc  com.apple.analyticsd (1.0 - 1) <F33987F5-A14A-3A55-8D26-FDE9A57B9269> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
    0x7fff51c8f000 -     0x7fff51c9fff3  com.apple.CoreEmoji (1.0 - 107) <AC83B860-61BD-384E-81BF-CA3CBE655968> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fff522df000 -     0x7fff52349ff0  com.apple.CoreNLP (1.0 - 213) <687A4C31-A307-3255-83BE-9B123971FF62> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP
    0x7fff52777000 -     0x7fff5277fff8  com.apple.CorePhoneNumbers (1.0 - 1) <17E6A3B0-A181-3295-8B19-E139EDF12E4B> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers
    0x7fff5316c000 -     0x7fff5318ffff  com.apple.CoreSVG (1.0 - 129) <53213F48-F888-3EBE-AE30-E9303E9B712C> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
    0x7fff53190000 -     0x7fff531c3fff  com.apple.CoreServicesInternal (446.7 - 446.7) <4C4834E0-EA46-36DE-BA11-16B8826DD754> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff531c4000 -     0x7fff531f2ffd  com.apple.CSStore (1069.22 - 1069.22) <39E431F9-3584-34DF-A64D-C5895AA72068> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
    0x7fff53716000 -     0x7fff537acff7  com.apple.CoreSymbolication (11.4 - 64535.33.1) <DCA00787-D285-3944-AAFA-CAF78775B8D3> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff53844000 -     0x7fff53970ff6  com.apple.coreui (2.1 - 609.4) <55EACF17-86EA-3F6E-A2CF-AF2F08C5F295> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff53971000 -     0x7fff53b27ff5  com.apple.CoreUtils (6.2 - 620.34) <172FC306-619F-3451-9BCA-F0B0D0B58EFD> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fff53c61000 -     0x7fff53c74ff1  com.apple.CrashReporterSupport (10.13 - 15016) <8AB4A416-A174-386B-8A96-5F16EAA3FCDE> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fff53d2d000 -     0x7fff53d3fff8  com.apple.framework.DFRFoundation (1.0 - 252.40.1) <852E7EE8-EC39-3CFF-9605-9F971F7BCED5> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
    0x7fff53d40000 -     0x7fff53d45fff  com.apple.DSExternalDisplay (3.1 - 380) <61597AB3-7E66-339D-A709-50D4F9B3D8E9> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
    0x7fff53dcf000 -     0x7fff53e49ff0  com.apple.datadetectorscore (8.0 - 659) <F7BA8B28-FD51-34A7-A423-63878638D00E> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff53e95000 -     0x7fff53ed2ff8  com.apple.DebugSymbols (194 - 194) <0406F803-6865-370E-9D32-01EF177B5E7A> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff53ed3000 -     0x7fff5405aff2  com.apple.desktopservices (1.14.4 - 1281.4.19) <82777143-A900-33D0-BCFA-2511C89C9EAD> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff559f3000 -     0x7fff55e0eff1  com.apple.vision.FaceCore (4.3.0 - 4.3.0) <E081D201-B82C-3AE3-8B58-1E909CE053B3> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fff5649f000 -     0x7fff565d6ffc  libFontParser.dylib (277.2.4.2) <B59E080A-9FC3-3511-9024-E6D5461E60D1> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
    0x7fff565d7000 -     0x7fff5660bfff  libTrueTypeScaler.dylib (277.2.4.2) <3A485687-23E8-3C53-83B0-1AA9625DCD37> /System/Library/PrivateFrameworks/FontServices.framework/libTrueTypeScaler.dylib
    0x7fff56670000 -     0x7fff56680ff6  libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <5A0F87CA-81C0-3444-B958-AAC7BD4319BC> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib
    0x7fff59b61000 -     0x7fff59b62fff  libmetal_timestamp.dylib (902.14.9) <E675DA7E-A99D-3351-94D1-3485CD86808B> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib
    0x7fff5b206000 -     0x7fff5b211ff7  libGPUSupportMercury.dylib (17.10.22) <FE3E328E-F2AC-3FE3-BE4C-31592ABB168B> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7fff5b212000 -     0x7fff5b218fff  com.apple.GPUWrangler (5.1.16 - 5.1.16) <F91AD6D6-8242-348C-8296-AF1DD8DBA2EF> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler
    0x7fff5b537000 -     0x7fff5b55dff1  com.apple.GenerationalStorage (2.0 - 314) <54182052-9E17-3A2A-8943-8915E6D319CE> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fff5c68c000 -     0x7fff5c69affb  com.apple.GraphVisualizer (1.0 - 100.1) <7289AEE6-C577-3D89-A99E-98551218EB7D> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer
    0x7fff5c83a000 -     0x7fff5c8f8ff4  com.apple.Heimdal (4.0 - 2.0) <C4838DCE-48FB-3828-9FB2-097BA2848C99> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff5d2f5000 -     0x7fff5d324ff8  com.apple.HelpData (2.3 - 199) <2539BB59-73A2-33C1-9BA2-8DC4A1AF9155> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
    0x7fff5ea6f000 -     0x7fff5ea78ffe  com.apple.IOAccelMemoryInfo (1.0 - 1) <8626B839-52BD-3BE1-BD83-B5C72D7B586D> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
    0x7fff5ea79000 -     0x7fff5ea81ff5  com.apple.IOAccelerator (438.4.5 - 438.4.5) <4B2F1D11-C36B-3C48-9934-8A973348A966> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fff5ea8e000 -     0x7fff5eaa4fff  com.apple.IOPresentment (1.0 - 37) <2FE66352-4CF9-3F79-944D-053E2AD451D6> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fff5ee2c000 -     0x7fff5ee77ff1  com.apple.IconServices (438.3 - 438.3) <2431AD46-37B8-367F-A1DC-119C781B1453> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fff5f035000 -     0x7fff5f03cffa  com.apple.InternationalSupport (1.0 - 45.2) <296B6979-342E-35B8-A58B-B0797DFBA789> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport
    0x7fff5f0e0000 -     0x7fff5f0e4ff4  JavaLaunching (43) <0F441229-1FBB-3B50-B727-F4A219B2F4EA> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
    0x7fff5f2c9000 -     0x7fff5f2e8ffd  com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <D0F59C6D-F069-3F0D-81C2-CBFC2E6B7101> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
    0x7fff5f41d000 -     0x7fff5f4ebffd  com.apple.LanguageModeling (1.0 - 215.1) <3FAF1700-F7D4-3F92-88AA-A3920702B8BB> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fff5f4ec000 -     0x7fff5f534fff  com.apple.Lexicon-framework (1.0 - 72) <212D02CE-11BC-3C7F-BDFD-DF1A0C4017EE> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
    0x7fff5f53b000 -     0x7fff5f540ff3  com.apple.LinguisticData (1.0 - 353.18) <BA3869B7-9C39-32DA-A4BA-12F1BC4B04CF> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData
    0x7fff5fdd8000 -     0x7fff5fddbfff  com.apple.Mangrove (1.0 - 25) <9490A0D4-5EF9-3FDA-B048-A71BE3A17096> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
    0x7fff60044000 -     0x7fff600ceff8  com.apple.MediaExperience (1.0 - 1) <F86763CC-6791-390E-8BCF-512B04C931BA> /System/Library/PrivateFrameworks/MediaExperience.framework/Versions/A/MediaExperience
    0x7fff608a7000 -     0x7fff608f3fff  com.apple.spotlight.metadata.utilities (1.0 - 2076.3) <EF8AC054-B15F-375F-AACB-018DC73CD16E> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
    0x7fff608f4000 -     0x7fff609c5ffa  com.apple.gpusw.MetalTools (1.0 - 1) <BA343D96-58EA-374A-818C-E42968101EA8> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
    0x7fff60a22000 -     0x7fff60a3bff4  com.apple.MobileAssets (1.0 - 619.100.2) <4EAA222A-2128-3A7D-9270-C4878C8AD1AA> /System/Library/PrivateFrameworks/MobileAsset.framework/Versions/A/MobileAsset
    0x7fff60bf8000 -     0x7fff60c16fff  com.apple.MobileKeyBag (2.0 - 1.0) <0837C5C4-A860-387C-8F31-9A4627A3132F> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
    0x7fff60e79000 -     0x7fff60ea9ff7  com.apple.MultitouchSupport.framework (3440.1 - 3440.1) <0AA68A0D-23F6-3628-A93F-8F8018B84920> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff613a8000 -     0x7fff613b2fff  com.apple.NetAuth (6.2 - 6.2) <D324C7CC-E614-35F6-8619-DECBE90ECAEB> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff61dbd000 -     0x7fff61e08ffb  com.apple.OTSVG (1.0 - 643.1.4.4) <DCCAD72C-ED3E-3FB9-80C8-4DB36362C28A> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG
    0x7fff63010000 -     0x7fff6301bff2  com.apple.PerformanceAnalysis (1.243.2 - 243.2) <FFE831BE-C133-38BE-A6B4-BEEB9FD6BF37> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff6301c000 -     0x7fff63044ffb  com.apple.persistentconnection (1.0 - 1.0) <F16D4768-61F2-3298-8E37-0EAF612A55C0> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection
    0x7fff65a02000 -     0x7fff65a1bffb  com.apple.ProtocolBuffer (1 - 274.24.9.16.3) <05BE7640-A9FD-3963-8199-E60DE3C37A7E> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fff65e7a000 -     0x7fff65ea3ff1  com.apple.RemoteViewServices (2.0 - 148) <680F9F89-C44B-3AB3-B9EA-155B41B7295A> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff66008000 -     0x7fff66043ff0  com.apple.RunningBoardServices (1.0 - 223.100.31) <28C26D68-F1F5-3ADC-832B-AF63336F35FB> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
    0x7fff67920000 -     0x7fff67923ff5  com.apple.SecCodeWrapper (4.0 - 448.100.6) <87710569-BCB4-37C1-B56D-F0EB89863A78> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
    0x7fff67a96000 -     0x7fff67bbdff1  com.apple.Sharing (1526.14 - 1526.14) <8D0C1BC4-5133-399B-9EFC-74CAEF4FA389> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fff67c16000 -     0x7fff67c34ff2  com.apple.shortcut (2.16 - 106) <5C74A85D-4208-3AD8-958B-DBE676ECB209> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
    0x7fff68fd0000 -     0x7fff692c6fff  com.apple.SkyLight (1.600.0 - 450.9) <C6AF6A79-C673-3B9E-95E0-993F43AE7EED> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fff69b13000 -     0x7fff69b21ffb  com.apple.SpeechRecognitionCore (6.0.91 - 6.0.91) <4678A6DB-D56E-393F-90BD-5AF4F3664440> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fff6a1fb000 -     0x7fff6a23cff9  com.apple.StreamingZip (1.0 - 1) <67F0ED7B-0912-3151-BEB1-9D5FBAE0D46B> /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/StreamingZip
    0x7fff6a353000 -     0x7fff6a35cff7  com.apple.SymptomDiagnosticReporter (1.0 - 1238.100.26) <A2197A8A-796E-321C-8EBB-075AED9995B0> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter
    0x7fff6a612000 -     0x7fff6a622ff3  com.apple.TCC (1.0 - 1) <AEE98D6E-03FD-3C80-90AC-5B45B4AE7A2E> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fff6ab45000 -     0x7fff6ac0bff0  com.apple.TextureIO (3.10.9 - 3.10.9) <362C5815-6A2B-3CA8-B577-C5D4978EF981> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fff6adcc000 -     0x7fff6b024ff0  com.apple.UIFoundation (1.0 - 661.2) <27837A1C-A833-3F99-B8D8-84A583EEA523> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fff6bc97000 -     0x7fff6bcb7ffc  com.apple.UserManagement (1.0 - 1) <6F223C62-641C-3F7E-BE20-B0C9F19709C7> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
    0x7fff6ca63000 -     0x7fff6cb4dff8  com.apple.ViewBridge (464.1 - 464.1) <E1DB0984-8B31-36E4-9854-A3345F67BED3> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
    0x7fff6ccf3000 -     0x7fff6ccf4fff  com.apple.WatchdogClient.framework (1.0 - 67.101.1) <1D6C2858-0A09-380E-8718-14131D9A0FE1> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient
    0x7fff6d920000 -     0x7fff6d923ffa  com.apple.dt.XCTTargetBootstrap (1.0 - 16091) <B40E4B60-2DB5-30ED-A210-3ED708862162> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
    0x7fff6d99d000 -     0x7fff6d9abff5  com.apple.audio.caulk (1.0 - 32.3) <DFE1EBB6-9A42-3227-8601-5CFCB1F665CD> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
    0x7fff6dced000 -     0x7fff6dcefff3  com.apple.loginsupport (1.0 - 1) <B84ABC31-431B-3F99-BABE-44ED0A7DB3C0> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fff6dcf0000 -     0x7fff6dd03ffd  com.apple.login (3.0 - 3.0) <8FAC178E-0C61-3E48-844A-CB4446CC7BC6> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
    0x7fff707ce000 -     0x7fff70801ffa  libAudioToolboxUtility.dylib (1104.80) <C34C8FCE-54DE-3884-8074-057B06807D22> /usr/lib/libAudioToolboxUtility.dylib
    0x7fff70808000 -     0x7fff7083cfff  libCRFSuite.dylib (48) <E52BECF7-1819-3998-ACC4-8D1A332CE4EB> /usr/lib/libCRFSuite.dylib
    0x7fff7083f000 -     0x7fff70849fff  libChineseTokenizer.dylib (34) <EE842A48-3D30-34B0-B9D2-F045DE582650> /usr/lib/libChineseTokenizer.dylib
    0x7fff708d5000 -     0x7fff708d7ff7  libDiagnosticMessagesClient.dylib (112) <BE749883-9400-334A-8FBF-F3321CF205F5> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff7091d000 -     0x7fff70ad4ffb  libFosl_dynamic.dylib (100.4) <68038226-8CAA-36B5-B5D6-510F900B318D> /usr/lib/libFosl_dynamic.dylib
    0x7fff70afb000 -     0x7fff70b01ff3  libIOReport.dylib (54) <FA47D01E-E02C-3178-9C10-DF4E7F6351B0> /usr/lib/libIOReport.dylib
    0x7fff70be3000 -     0x7fff70beafff  libMatch.1.dylib (36) <815A4553-4763-369F-A77C-62663A586D60> /usr/lib/libMatch.1.dylib
    0x7fff70c19000 -     0x7fff70c39fff  libMobileGestalt.dylib (826.100.27) <4B771C86-0CB7-3B06-8F41-5A40DDF66D72> /usr/lib/libMobileGestalt.dylib
    0x7fff70dab000 -     0x7fff70dacfff  libSystem.B.dylib (1281.100.1) <DB8310F1-272D-3533-A840-3B390AF55C26> /usr/lib/libSystem.B.dylib
    0x7fff70e39000 -     0x7fff70e3afff  libThaiTokenizer.dylib (3) <DC582222-7C1F-3C27-8C3A-BAF696A2197D> /usr/lib/libThaiTokenizer.dylib
    0x7fff70e52000 -     0x7fff70e68fff  libapple_nghttp2.dylib (1.39.2) <268F4E3E-95DC-35FB-82DC-5B0D1855A676> /usr/lib/libapple_nghttp2.dylib
    0x7fff70e9d000 -     0x7fff70f0fff7  libarchive.2.dylib (72.100.1) <65E0870E-02AB-365D-84F9-5800B5BB69FC> /usr/lib/libarchive.2.dylib
    0x7fff70f10000 -     0x7fff70fa9fe5  libate.dylib (3.0.1) <4477640F-CC1B-3825-B877-69508F367E3D> /usr/lib/libate.dylib
    0x7fff70fad000 -     0x7fff70fadff3  libauto.dylib (187) <FD0E5750-7004-36A7-B9C2-D6B6B4EF559B> /usr/lib/libauto.dylib
    0x7fff71073000 -     0x7fff71083ffb  libbsm.0.dylib (60.100.1) <B0373A39-DBC6-3A84-879B-BA46E30D04BF> /usr/lib/libbsm.0.dylib
    0x7fff71084000 -     0x7fff71090fff  libbz2.1.0.dylib (44) <FFCD4427-AF87-36D2-8097-8870FDC75A1B> /usr/lib/libbz2.1.0.dylib
    0x7fff71091000 -     0x7fff710e3fff  libc++.1.dylib (902.1) <08199809-33CA-321E-9B9D-FD5B2BC64580> /usr/lib/libc++.1.dylib
    0x7fff710e4000 -     0x7fff710f9ffb  libc++abi.dylib (902) <1C880020-396D-3F91-BE27-5A09A9239F68> /usr/lib/libc++abi.dylib
    0x7fff710fa000 -     0x7fff710fafff  libcharset.1.dylib (59) <4E63BA25-04A3-329A-923D-251155C03F30> /usr/lib/libcharset.1.dylib
    0x7fff710fb000 -     0x7fff7110cfff  libcmph.dylib (8) <D4C5E0A8-92D9-33D5-9F83-6F4742FFBE29> /usr/lib/libcmph.dylib
    0x7fff7110d000 -     0x7fff71124fd7  libcompression.dylib (87) <7F258A06-E01D-32D2-9CD2-6B2931DA5DA7> /usr/lib/libcompression.dylib
    0x7fff713fe000 -     0x7fff71414ff7  libcoretls.dylib (167) <EFC237BB-78F7-33C6-BFF9-53860062DD99> /usr/lib/libcoretls.dylib
    0x7fff71415000 -     0x7fff71416fff  libcoretls_cfhelpers.dylib (167) <2E542A2B-7730-33EE-9B3B-154B08608AA6> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fff719d3000 -     0x7fff71a32ff7  libcups.2.dylib (483.6) <F446DEF0-66C0-31AD-88E1-919B05F06C90> /usr/lib/libcups.2.dylib
    0x7fff71b3e000 -     0x7fff71b3efff  libenergytrace.dylib (21) <FFB9FB70-8DBD-3025-BC92-51F02481A489> /usr/lib/libenergytrace.dylib
    0x7fff71b3f000 -     0x7fff71b57fff  libexpat.1.dylib (19.60.2) <1ED53818-578C-3D17-8761-68792CCAD685> /usr/lib/libexpat.1.dylib
    0x7fff71b65000 -     0x7fff71b67fff  libfakelink.dylib (149.1) <B04F9A05-7E52-3382-9186-F603BE4BFBB2> /usr/lib/libfakelink.dylib
    0x7fff71b76000 -     0x7fff71b7bfff  libgermantok.dylib (24) <8091F952-B592-38E3-982B-7DEA0A44E211> /usr/lib/libgermantok.dylib
    0x7fff71b7c000 -     0x7fff71b85ff7  libheimdal-asn1.dylib (564.100.1) <2D639331-43CF-331F-98F4-CDF41990A468> /usr/lib/libheimdal-asn1.dylib
    0x7fff71b86000 -     0x7fff71c76fff  libiconv.2.dylib (59) <9458704B-A702-37CB-9707-66ABBB5DB71E> /usr/lib/libiconv.2.dylib
    0x7fff71c77000 -     0x7fff71ecefff  libicucore.A.dylib (64260.0.1) <DCC4A4EE-32FD-350F-84D8-E857F2F29855> /usr/lib/libicucore.A.dylib
    0x7fff71ee8000 -     0x7fff71ee9fff  liblangid.dylib (133) <E9595222-602B-38F0-8572-0F1872A00527> /usr/lib/liblangid.dylib
    0x7fff71eea000 -     0x7fff71f02ff3  liblzma.5.dylib (16) <0AA1EB11-A433-327E-B8DB-7395CFF06554> /usr/lib/liblzma.5.dylib
    0x7fff71f1a000 -     0x7fff71fc1ff7  libmecab.dylib (883.10) <13136C11-8763-37BA-AEB2-676092798DAA> /usr/lib/libmecab.dylib
    0x7fff71fc2000 -     0x7fff72224fe1  libmecabra.dylib (883.10) <6AC22857-F528-35CE-94A9-D70F6F766C15> /usr/lib/libmecabra.dylib
    0x7fff72591000 -     0x7fff725c0fff  libncurses.5.4.dylib (57) <6BD6F430-C8B3-39D8-87B5-2C16E6578FD5> /usr/lib/libncurses.5.4.dylib
    0x7fff726f0000 -     0x7fff72b6bff5  libnetwork.dylib (1880.100.30) <9519B6F8-44E2-3F53-B995-1527C5333240> /usr/lib/libnetwork.dylib
    0x7fff72c0b000 -     0x7fff72c3efde  libobjc.A.dylib (787.1) <20AC082F-2DB7-3974-A2D4-8C5E01787584> /usr/lib/libobjc.A.dylib
    0x7fff72c51000 -     0x7fff72c55fff  libpam.2.dylib (25.100.1) <D5CEC1AD-A2EC-362C-B71A-22FD521917F1> /usr/lib/libpam.2.dylib
    0x7fff72c58000 -     0x7fff72c8eff7  libpcap.A.dylib (89.100.1) <171BAAB0-A5C8-32C5-878E-83D46073BF8C> /usr/lib/libpcap.A.dylib
    0x7fff72d12000 -     0x7fff72d2afff  libresolv.9.dylib (67.40.1) <92A522F9-95E2-35EE-A8AD-FC8DEE6B2C1F> /usr/lib/libresolv.9.dylib
    0x7fff72d2c000 -     0x7fff72d70ff7  libsandbox.1.dylib (1217.101.2) <5E362637-203E-3170-B988-1C470A6B0642> /usr/lib/libsandbox.1.dylib
    0x7fff72d84000 -     0x7fff72d85ff7  libspindump.dylib (281.3) <16F53AD2-1839-37BF-A2F5-92253FE4AF1A> /usr/lib/libspindump.dylib
    0x7fff72d86000 -     0x7fff72f70ff7  libsqlite3.dylib (308.4) <BBC375B7-AF20-3D2C-8826-78D3BDC8A004> /usr/lib/libsqlite3.dylib
    0x7fff731c1000 -     0x7fff731c4ffb  libutil.dylib (57) <07ED7CF0-1744-3386-B8B2-0DDBD446999E> /usr/lib/libutil.dylib
    0x7fff731c5000 -     0x7fff731d2ff7  libxar.1.dylib (425.2) <625F24E1-1A0F-3301-9F99-F0F3DADE0287> /usr/lib/libxar.1.dylib
    0x7fff731d8000 -     0x7fff732baff7  libxml2.2.dylib (33.3) <24147A90-E3EB-3926-BFB0-5F0FC9F706E2> /usr/lib/libxml2.2.dylib
    0x7fff732be000 -     0x7fff732e6fff  libxslt.1.dylib (16.9) <8C8648B1-F2CA-38EA-A409-D6F19715C6E6> /usr/lib/libxslt.1.dylib
    0x7fff732e7000 -     0x7fff732f9ff3  libz.1.dylib (76) <6A449C6A-DF88-36C1-8F2D-DB9A808263B5> /usr/lib/libz.1.dylib
    0x7fff73ba7000 -     0x7fff73bacff3  libcache.dylib (83) <5F90FFCE-403B-3724-991D-BA32401D99C5> /usr/lib/system/libcache.dylib
    0x7fff73bad000 -     0x7fff73bb8fff  libcommonCrypto.dylib (60165) <C7A5E3F7-1E5A-3785-875A-B6647082B614> /usr/lib/system/libcommonCrypto.dylib
    0x7fff73bb9000 -     0x7fff73bc0fff  libcompiler_rt.dylib (101.2) <A517E149-2D25-3C04-BCEF-F69149C85B18> /usr/lib/system/libcompiler_rt.dylib
    0x7fff73bc1000 -     0x7fff73bcaff7  libcopyfile.dylib (166.40.1) <1A5270B5-0D97-35DA-9296-4F4A428BC6A2> /usr/lib/system/libcopyfile.dylib
    0x7fff73bcb000 -     0x7fff73c5dfe3  libcorecrypto.dylib (866.100.30) <FCDEC0D1-8C30-3989-BDD1-996BBC715C29> /usr/lib/system/libcorecrypto.dylib
    0x7fff73d6a000 -     0x7fff73daaff0  libdispatch.dylib (1173.100.2) <EB592997-B11C-3AB3-85B1-F725F3D0B412> /usr/lib/system/libdispatch.dylib
    0x7fff73dab000 -     0x7fff73de1fff  libdyld.dylib (750.5) <D2A07EF5-A64B-3692-BE13-89DAA2EC5E80> /usr/lib/system/libdyld.dylib
    0x7fff73de2000 -     0x7fff73de2ffb  libkeymgr.dylib (30) <CC5A2B43-770B-3C6C-BA10-AA3A6B4A142D> /usr/lib/system/libkeymgr.dylib
    0x7fff73de3000 -     0x7fff73defff3  libkxld.dylib (6153.101.6) <77282DCB-83D6-3199-874E-9A4A0FD7D4F3> /usr/lib/system/libkxld.dylib
    0x7fff73df0000 -     0x7fff73df0ff7  liblaunch.dylib (1738.100.39) <A7FF7357-600F-3014-8C28-A4F367717E8D> /usr/lib/system/liblaunch.dylib
    0x7fff73df1000 -     0x7fff73df6ff7  libmacho.dylib (959.0.1) <D8FED478-25A2-3844-AE4B-A5C9F9827615> /usr/lib/system/libmacho.dylib
    0x7fff73df7000 -     0x7fff73df9ff3  libquarantine.dylib (110.40.3) <51E0304F-AB11-3BF7-99DC-BB916CC9088B> /usr/lib/system/libquarantine.dylib
    0x7fff73dfa000 -     0x7fff73dfbff7  libremovefile.dylib (48) <078F29AB-26BA-3493-BCAA-E1E75A187521> /usr/lib/system/libremovefile.dylib
    0x7fff73dfc000 -     0x7fff73e13ff3  libsystem_asl.dylib (377.60.2) <0F1BAC19-2AE0-3F8E-9B90-AACF819B2BF7> /usr/lib/system/libsystem_asl.dylib
    0x7fff73e14000 -     0x7fff73e14ff7  libsystem_blocks.dylib (74) <32224AFF-C06F-3279-B753-097194EDEF49> /usr/lib/system/libsystem_blocks.dylib
    0x7fff73e15000 -     0x7fff73e9cfff  libsystem_c.dylib (1353.100.2) <4F5EED22-4D46-3F04-8C64-C492CDAD70EB> /usr/lib/system/libsystem_c.dylib
    0x7fff73e9d000 -     0x7fff73ea0ffb  libsystem_configuration.dylib (1061.101.1) <2A2C778D-07EB-35C7-A954-8BF8FD74BD75> /usr/lib/system/libsystem_configuration.dylib
    0x7fff73ea1000 -     0x7fff73ea4fff  libsystem_coreservices.dylib (114) <FDA41CC4-170A-3D93-85BD-838A563B03C4> /usr/lib/system/libsystem_coreservices.dylib
    0x7fff73ea5000 -     0x7fff73eadfff  libsystem_darwin.dylib (1353.100.2) <B567B86D-8818-38A4-A861-03EB83B55867> /usr/lib/system/libsystem_darwin.dylib
    0x7fff73eae000 -     0x7fff73eb5fff  libsystem_dnssd.dylib (1096.100.3) <7C690DF5-E119-33FB-85CD-9EFC67A36E40> /usr/lib/system/libsystem_dnssd.dylib
    0x7fff73eb6000 -     0x7fff73eb7ffb  libsystem_featureflags.dylib (17) <415D83EF-084C-3485-B757-53001870EA94> /usr/lib/system/libsystem_featureflags.dylib
    0x7fff73eb8000 -     0x7fff73f05ff7  libsystem_info.dylib (538) <17049D3F-C798-3651-B391-1551FC699D3E> /usr/lib/system/libsystem_info.dylib
    0x7fff73f06000 -     0x7fff73f32ff7  libsystem_kernel.dylib (6153.101.6) <E76440E1-D1E8-3D9A-8B47-D01F554FF1C4> /usr/lib/system/libsystem_kernel.dylib
    0x7fff73f33000 -     0x7fff73f7afff  libsystem_m.dylib (3178) <74741FA8-5C29-3241-9046-4FC91C6A6D4A> /usr/lib/system/libsystem_m.dylib
    0x7fff73f7b000 -     0x7fff73fa2fff  libsystem_malloc.dylib (283.100.5) <97833239-2F83-3AEB-A426-0593997C8A54> /usr/lib/system/libsystem_malloc.dylib
    0x7fff73fa3000 -     0x7fff73fb0ffb  libsystem_networkextension.dylib (1095.100.29) <C9E988B2-6A18-35C0-9577-63201E9D6018> /usr/lib/system/libsystem_networkextension.dylib
    0x7fff73fb1000 -     0x7fff73fbaff7  libsystem_notify.dylib (241.100.2) <E405F84B-BD4F-3874-9755-CB3EC86E18D5> /usr/lib/system/libsystem_notify.dylib
    0x7fff73fbb000 -     0x7fff73fc3fef  libsystem_platform.dylib (220.100.1) <6EF12F34-C33F-36BF-9A9A-2A35EA19EFE0> /usr/lib/system/libsystem_platform.dylib
    0x7fff73fc4000 -     0x7fff73fcefff  libsystem_pthread.dylib (416.100.3) <A8514582-E000-3854-911A-0A73D2C79600> /usr/lib/system/libsystem_pthread.dylib
    0x7fff73fcf000 -     0x7fff73fd3ff3  libsystem_sandbox.dylib (1217.101.2) <E9D78CDE-FB67-32E7-BABC-9EFC23AA0DC6> /usr/lib/system/libsystem_sandbox.dylib
    0x7fff73fd4000 -     0x7fff73fd6fff  libsystem_secinit.dylib (62.100.2) <AAC639E5-7103-3366-A602-8FC6944E2C13> /usr/lib/system/libsystem_secinit.dylib
    0x7fff73fd7000 -     0x7fff73fdeffb  libsystem_symptoms.dylib (1238.100.26) <487B92DE-45F9-39F9-A478-89BBD478157D> /usr/lib/system/libsystem_symptoms.dylib
    0x7fff73fdf000 -     0x7fff73ff5ff2  libsystem_trace.dylib (1147.100.8) <BB90B1FD-8C09-3DF4-BD8B-9E4AEADFEA2B> /usr/lib/system/libsystem_trace.dylib
    0x7fff73ff7000 -     0x7fff73ffcff7  libunwind.dylib (35.4) <CC87C836-BE9D-334E-A0E6-0297D52E9D73> /usr/lib/system/libunwind.dylib
    0x7fff73ffd000 -     0x7fff74032ffe  libxpc.dylib (1738.100.39) <32B0E31E-9DA3-328B-A962-BC9591B93537> /usr/lib/system/libxpc.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 1018
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=631.0M resident=0K(0%) swapped_out_or_unallocated=631.0M(100%)
Writable regions: Total=1.2G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.2G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               768K        6
Activity Tracing                   256K        1
CG backing stores                 6340K       11
CG image                          4772K       16
CoreAnimation                     5792K       34
CoreGraphics                         8K        1
CoreImage                           56K        7
CoreUI image data                 1160K       17
Foundation                           4K        1
Image IO                           224K       14
Kernel Alloc Once                    8K        1
MALLOC                           522.4M     1249
MALLOC guard page                   32K        8
MALLOC_LARGE (reserved)            256K        1         reserved VM address space (unallocated)
MALLOC_NANO (reserved)           256.0M        1         reserved VM address space (unallocated)
Memory Tag 242                      12K        1
STACK GUARD                        372K       43
Stack                             46.2M       44
Stack Guard                       56.1M       25
VM_ALLOCATE                        1.8G      485
__DATA                            45.0M      326
__DATA_CONST                       104K        4
__FONT_DATA                          4K        1
__GLSLBUILTINS                    5176K        1
__LINKEDIT                       398.6M       27
__OBJC_RO                         32.2M        1
__OBJC_RW                         1892K        2
__TEXT                           232.4M      321
__UNICODE                          564K        1
mapped file                      822.6M      448
shared memory                      692K       24
TOTAL                              4.2G     3122
TOTAL, minus reserved VM space     3.9G     3122
  • hs_err_pid4608.log.zip
So, any news?
Sorry, I couldn't test yesterday. But I just tried it now, get a new error:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_simple_drum.cpp: In member function 'virtual void AudioSynthSimpleDrum::update()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_simple_drum.cpp:143:74: error: 'multiply_16tx16t' was not declared in this scope
env_sqr_current = multiply_16tx16t(env_lin_current, env_lin_current) ;
Here is the full dump (again sorry for the length):
Arduino: 1.8.12 (Windows 10), TD: 1.52-beta1, Board: "Teensy LC, Serial, 48 MHz, Smallest Code, US English"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\steve.corn\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\steve.corn\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\steve.corn\Documents\Arduino\libraries -fqbn=teensy:avr:teensyLC:usb=serial,speed=48,opt=osstd,keys=en-us -ide-version=10812 -build-path C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800 -warnings=none -build-cache C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_cache_15264 -verbose C:\SteveCorn\NuWave-GitLab\arduino\test-LC-audio\test-LC-audio.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\steve.corn\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\steve.corn\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\steve.corn\Documents\Arduino\libraries -fqbn=teensy:avr:teensyLC:usb=serial,speed=48,opt=osstd,keys=en-us -ide-version=10812 -build-path C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800 -warnings=none -build-cache C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_cache_15264 -verbose C:\SteveCorn\NuWave-GitLab\arduino\test-LC-audio\test-LC-audio.ino
Using board 'teensyLC' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Using core 'teensy3' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_146800\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for Audio.h: [Audio@1.3 Audio.sav@1.3]
ResolveLibrary(Audio.h)
  -> candidates: [Audio@1.3 Audio.sav@1.3]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_146800\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_146800\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for SD.h: [SD@1.2.4 SD@1.2.2]
ResolveLibrary(SD.h)
  -> candidates: [SD@1.2.4 SD@1.2.2]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_146800\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for SerialFlash.h: [SerialFlash@0.5]
ResolveLibrary(SerialFlash.h)
  -> candidates: [SerialFlash@0.5]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_146800\\sketch\\test-LC-audio.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_146800\\sketch\\test-LC-audio.ino.cpp" -o nul
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\analyze_fft1024.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\analyze_fft256.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\analyze_notefreq.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\analyze_peak.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\analyze_print.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\analyze_rms.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\analyze_tonedetect.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\control_ak4558.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\control_cs42448.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\control_cs4272.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\control_sgtl5000.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\control_tlv320aic3206.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\control_wm8731.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\data_spdif.c
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\data_ulaw.c
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\data_waveforms.c
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\data_windows.c
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_bitcrusher.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_chorus.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_combine.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_delay.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_delay_ext.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_envelope.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_fade.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_flange.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_freeverb.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_granular.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_midside.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_multiply.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_reverb.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\effect_waveshaper.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\filter_biquad.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\filter_fir.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\filter_variable.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_adc.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_adcs.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s2.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s_hex.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s_oct.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_i2s_quad.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_pdm.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_spdif3.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_tdm.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\input_tdm2.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\memcpy_audio.S
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\mixer.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_adat.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_dac.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_dacs.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s2.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s_hex.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s_oct.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_i2s_quad.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_mqs.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_pt8211.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_pt8211_2.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_pwm.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif2.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_spdif3.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_tdm.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\output_tdm2.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\play_memory.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\play_queue.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\play_sd_raw.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\play_sd_wav.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\play_serialflash_raw.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\record_queue.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\spi_interrupt.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_dc.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_karplusstrong.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_pinknoise.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_pwm.cpp
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\synth_simple_drum.cpp" -o nul
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_sine.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_tonesweep.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_waveform.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_wavetable.cpp
Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_whitenoise.cpp
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility\\imxrt_hw.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility\\sqrt_integer.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI\\SPI.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\File.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\SD.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\cache_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\card_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\dir_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\fat_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\file_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\init_t3.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility\\NXP_SDHC.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility\\Sd2Card.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility\\SdFile.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD\\utility\\SdVolume.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash\\SerialFlashChip.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash\\SerialFlashDirectory.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\Wire.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\WireIMXRT.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\WireKinetis.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire\\utility\\twi.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_146800\\sketch\\test-LC-audio.ino.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_146800\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_146800\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/precompile_helper" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_146800" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -x c++-header -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr/cores/teensy3" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_146800/pch/Arduino.h" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_146800/pch/Arduino.h.gch"
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\pch\Arduino.h.gch
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_146800/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_146800\\sketch\\test-LC-audio.ino.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_146800\\sketch\\test-LC-audio.ino.cpp.o"
Compiling libraries...
Compiling library "Audio"
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\memcpy_audio.S.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\data_spdif.c.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\data_ulaw.c.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\data_windows.c.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\data_waveforms.c.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\analyze_peak.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\control_ak4558.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\analyze_print.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\analyze_fft256.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\analyze_notefreq.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\analyze_tonedetect.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\analyze_fft1024.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\analyze_rms.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\control_cs42448.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\effect_bitcrusher.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\control_wm8731.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\control_cs4272.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\control_sgtl5000.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\effect_chorus.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\effect_delay.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\effect_combine.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\effect_delay_ext.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\effect_envelope.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\effect_fade.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\effect_flange.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\effect_freeverb.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\control_tlv320aic3206.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\effect_granular.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\effect_reverb.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\effect_multiply.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\effect_midside.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\effect_waveshaper.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\filter_biquad.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\filter_fir.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\input_adc.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\filter_variable.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\input_i2s2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\input_adcs.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\input_i2s.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\input_spdif3.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\input_i2s_oct.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\input_i2s_quad.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\input_tdm2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\input_pdm.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\input_tdm.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\mixer.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\input_i2s_hex.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\output_adat.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\output_dacs.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\output_i2s2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\output_dac.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\output_mqs.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\output_i2s_hex.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\output_pt8211.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\output_i2s_oct.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\output_pt8211_2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\output_spdif2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\output_i2s.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\output_spdif3.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\output_i2s_quad.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\output_spdif.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\output_pwm.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\output_tdm.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\output_tdm2.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\play_memory.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\play_queue.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\record_queue.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\play_sd_raw.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\synth_pinknoise.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\synth_karplusstrong.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\spi_interrupt.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\synth_dc.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\play_serialflash_raw.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\synth_pwm.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\synth_wavetable.cpp.o
"C:\\Program Files (x86)\\Arduino\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -Os --specs=nano.specs -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -fno-exceptions -fpermissive -felide-constructors -std=gnu++14 -Wno-error=narrowing -fno-rtti -mthumb -mcpu=cortex-m0plus -fsingle-precision-constant -D__MKL26Z64__ -DTEENSYDUINO=152 -DARDUINO=10812 -DARDUINO_TEENSYLC -DF_CPU=48000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_146800/pch" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\cores\\teensy3" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SPI" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SD" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\SerialFlash" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Wire" "-IC:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\utility" "C:\\Program Files (x86)\\Arduino\\hardware\\teensy\\avr\\libraries\\Audio\\synth_simple_drum.cpp" -o "C:\\Users\\STEVE~1.COR\\AppData\\Local\\Temp\\arduino_build_146800\\libraries\\Audio\\synth_simple_drum.cpp.o"
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\synth_sine.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\synth_waveform.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\synth_tonesweep.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\synth_whitenoise.cpp.o
Using previously compiled file: C:\Users\STEVE~1.COR\AppData\Local\Temp\arduino_build_146800\libraries\Audio\play_sd_wav.cpp.o
Multiple libraries were found for "Audio.h"
 Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio
 Not used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio.sav
Multiple libraries were found for "SD.h"
 Used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
 Not used: C:\Program Files (x86)\Arduino\libraries\SD
Using library Audio at version 1.3 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI
Using library SD at version 1.2.2 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
Using library SerialFlash at version 0.5 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SerialFlash
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire
Error compiling for board Teensy LC.
22kHz sample rate means the maximum frequency that can be reconstructed is 11kHz. Google for Nyquist sampling theorem or Nyquist rate for more info.
True, I am familiar with Nyquist, but in the context of Teensy LC...it doesn't have the power to run the full Audio library, but [as we are trying to test] if we can enable basic functionality, like generate a simple Square wave and output via the DAC pin, I don't see 22KHz sample rate as a hindrance all things considering, and still considering "audible" frequencies.
AudioOutputUSB works fine on both Mac OS 10.12.6 and iOS 12, but I'm running into issues with the AudioInputUSB, getting periodic clicks and pops on the audio stream.
I also tried to adapt the USB code to work at 48kHz as described in various threads around here and it appears to work fine, the clicks are getting less frequent but they are still present. At 48kHz they happen at approx. 13 second intervals, at 44.1kHz they are more frequent. Apart from that, the audio quality is perfect as far as I can tell.
I added a bit of code to toggle a LED at usb_audio.cpp line 195 and it will flicker with each 'click' on the output, so I assume it must be buffer overruns.
I don't know if this is the appropriate time and place to ask for troubleshooting advice, but I wanted to report the bug anyway.
