Here is a third beta test for Teensyduino 1.58.
Arduino 2.0.x, all systems platforms:
use Boards Manager to install Teensy version 0.58.3
(to refresh versions, Shift-Ctrl-P and click "Arduino: Update Package Index")
Arduino 1.8.x, Linux 32 bit:
https://www.pjrc.com/teensy/td_158-beta3/TeensyduinoInstall.linux32
Arduino 1.8.x, Linux 64 bit:
https://www.pjrc.com/teensy/td_158-beta3/TeensyduinoInstall.linux64
Arduino 1.8.x, Linux ARM:
https://www.pjrc.com/teensy/td_158-beta3/TeensyduinoInstall.linuxarm
Arduino 1.8.x, Linux ARM64:
https://www.pjrc.com/teensy/td_158-beta3/TeensyduinoInstall.linuxaarch64
Arduino 1.8.x, MacOS (Catalina to Ventura)
https://www.pjrc.com/teensy/td_158-beta3/Teensyduino_MacOS_Catalina.zip
Arduino 1.8.x, Old MacOS (??? to Mojave)
https://www.pjrc.com/teensy/td_158-beta3/TeensyduinoInstall.dmg
Arduino 1.8.x, Windows:
https://www.pjrc.com/teensy/td_158-beta3/TeensyduinoInstall.exe
PlatformIO, DIY beta support:
https://forum.pjrc.com/threads/71730
Changes since Teensyduino 1.58-beta2:
New gcc 11.3.1 toolchain supported on all systems
Fix compiler warnings, many libraries
Fix missing serial receive with Arduino 2.0.x on Windows after Teensy reboots
Fix unable to start Teensy Loader on MacOS Ventura with Arduino 1.8.x
fix USB MIDI transmit on Teensy 4.x when running at only 12 Mbit/sec speed
Arduino 2.0.x "Invalid FQBN" workaround
Print warning message is "serial port" not "teensy port" selected
Fix Teensy Loader startup problem on Raspberry Pi 4 running Raspbian Buster
FlexIO / FlexSerial improvements (KurtE)
USBHost_t36 - update storage examples (KurtE)
ST7735_t3 - fix screen width check (KurtE)
C++11 move semantics on File (ScottDuckworth)
MTP.loop() would wait 1ms with no messages (KurtE)
Allow unconnected AudioConnection (Jonathan Oakley)
Fix Serial1.availableForWrite() on Teensy 2.0
AudioSynthWavetable fixes & docs (Jonathan Oakley)
USBHost_t36 Bluetooth improvements (KurtE and mjs513)
